[U-Boot] [PATCH] mx6qsabresd: Add Ethernet support
mx6qsabresd has a AR8031 Gigabit PHY.
Add support for it.
Also increase CONFIG_SYS_MALLOC_LEN so that FEC buffer allocation does not fail.
Tested on 1Gbp and 100Mbps networks.
Suggested-by: Kim Phillips kim.phillips@freescale.com Signed-off-by: Fabio Estevam fabio.estevam@freescale.com --- board/freescale/mx6qsabresd/mx6qsabresd.c | 76 +++++++++++++++++++++++++++++ include/configs/mx6qsabresd.h | 17 ++++++- 2 files changed, 91 insertions(+), 2 deletions(-)
diff --git a/board/freescale/mx6qsabresd/mx6qsabresd.c b/board/freescale/mx6qsabresd/mx6qsabresd.c index c86b51b..c0ea956 100644 --- a/board/freescale/mx6qsabresd/mx6qsabresd.c +++ b/board/freescale/mx6qsabresd/mx6qsabresd.c @@ -56,6 +56,36 @@ iomux_v3_cfg_t uart1_pads[] = { MX6Q_PAD_CSI0_DAT11__UART1_RXD | MUX_PAD_CTRL(UART_PAD_CTRL), };
+iomux_v3_cfg_t enet_pads[] = { + MX6Q_PAD_ENET_MDIO__ENET_MDIO | MUX_PAD_CTRL(ENET_PAD_CTRL), + MX6Q_PAD_ENET_MDC__ENET_MDC | MUX_PAD_CTRL(ENET_PAD_CTRL), + MX6Q_PAD_RGMII_TXC__ENET_RGMII_TXC | MUX_PAD_CTRL(ENET_PAD_CTRL), + MX6Q_PAD_RGMII_TD0__ENET_RGMII_TD0 | MUX_PAD_CTRL(ENET_PAD_CTRL), + MX6Q_PAD_RGMII_TD1__ENET_RGMII_TD1 | MUX_PAD_CTRL(ENET_PAD_CTRL), + MX6Q_PAD_RGMII_TD2__ENET_RGMII_TD2 | MUX_PAD_CTRL(ENET_PAD_CTRL), + MX6Q_PAD_RGMII_TD3__ENET_RGMII_TD3 | MUX_PAD_CTRL(ENET_PAD_CTRL), + MX6Q_PAD_RGMII_TX_CTL__RGMII_TX_CTL | MUX_PAD_CTRL(ENET_PAD_CTRL), + MX6Q_PAD_ENET_REF_CLK__ENET_TX_CLK | MUX_PAD_CTRL(ENET_PAD_CTRL), + MX6Q_PAD_RGMII_RXC__ENET_RGMII_RXC | MUX_PAD_CTRL(ENET_PAD_CTRL), + MX6Q_PAD_RGMII_RD0__ENET_RGMII_RD0 | MUX_PAD_CTRL(ENET_PAD_CTRL), + MX6Q_PAD_RGMII_RD1__ENET_RGMII_RD1 | MUX_PAD_CTRL(ENET_PAD_CTRL), + MX6Q_PAD_RGMII_RD2__ENET_RGMII_RD2 | MUX_PAD_CTRL(ENET_PAD_CTRL), + MX6Q_PAD_RGMII_RD3__ENET_RGMII_RD3 | MUX_PAD_CTRL(ENET_PAD_CTRL), + MX6Q_PAD_RGMII_RX_CTL__RGMII_RX_CTL | MUX_PAD_CTRL(ENET_PAD_CTRL), + /* AR8031 PHY Reset */ + MX6Q_PAD_ENET_CRS_DV__GPIO_1_25 | MUX_PAD_CTRL(NO_PAD_CTRL), +}; + +static void setup_iomux_enet(void) +{ + imx_iomux_v3_setup_multiple_pads(enet_pads, ARRAY_SIZE(enet_pads)); + + /* Reset AR8031 PHY */ + gpio_direction_output(IMX_GPIO_NR(1, 25) , 0); + udelay(500); + gpio_set_value(IMX_GPIO_NR(1, 25), 1); +} + iomux_v3_cfg_t usdhc3_pads[] = { MX6Q_PAD_SD3_CLK__USDHC3_CLK | MUX_PAD_CTRL(USDHC_PAD_CTRL), MX6Q_PAD_SD3_CMD__USDHC3_CMD | MUX_PAD_CTRL(USDHC_PAD_CTRL), @@ -90,6 +120,52 @@ int board_mmc_init(bd_t *bis) } #endif
+int mx6_rgmii_rework(struct phy_device *phydev) +{ + unsigned short val; + + /* To enable AR8031 ouput a 125MHz clk from CLK_25M */ + phy_write(phydev, MDIO_DEVAD_NONE, 0xd, 0x7); + phy_write(phydev, MDIO_DEVAD_NONE, 0xe, 0x8016); + phy_write(phydev, MDIO_DEVAD_NONE, 0xd, 0x4007); + + val = phy_read(phydev, MDIO_DEVAD_NONE, 0xe); + val &= 0xffe3; + val |= 0x18; + phy_write(phydev, MDIO_DEVAD_NONE, 0xe, val); + + /* introduce tx clock delay */ + phy_write(phydev, MDIO_DEVAD_NONE, 0x1d, 0x5); + val = phy_read(phydev, MDIO_DEVAD_NONE, 0x1e); + val |= 0x0100; + phy_write(phydev, MDIO_DEVAD_NONE, 0x1e, val); + + return 0; +} + +int board_phy_config(struct phy_device *phydev) +{ + mx6_rgmii_rework(phydev); + + if (phydev->drv->config) + phydev->drv->config(phydev); + + return 0; +} + +int board_eth_init(bd_t *bis) +{ + int ret; + + setup_iomux_enet(); + + ret = cpu_eth_init(bis); + if (ret) + printf("FEC MXC: %s:failed\n", __func__); + + return 0; +} + u32 get_board_rev(void) { return 0x63000; diff --git a/include/configs/mx6qsabresd.h b/include/configs/mx6qsabresd.h index 448ce28..a2d2c65 100644 --- a/include/configs/mx6qsabresd.h +++ b/include/configs/mx6qsabresd.h @@ -33,9 +33,8 @@ #define CONFIG_REVISION_TAG
/* Size of malloc() pool */ -#define CONFIG_SYS_MALLOC_LEN CONFIG_ENV_SIZE +#define CONFIG_SYS_MALLOC_LEN (CONFIG_ENV_SIZE + 2 * 1024 * 1024)
-#define CONFIG_ARCH_CPU_INIT #define CONFIG_BOARD_EARLY_INIT_F #define CONFIG_MXC_GPIO
@@ -55,6 +54,20 @@ #define CONFIG_CMD_FAT #define CONFIG_DOS_PARTITION
+#define CONFIG_CMD_PING +#define CONFIG_CMD_DHCP +#define CONFIG_CMD_MII +#define CONFIG_CMD_NET +#define CONFIG_FEC_MXC +#define CONFIG_MII +#define IMX_FEC_BASE ENET_BASE_ADDR +#define CONFIG_FEC_XCV_TYPE RGMII +#define CONFIG_ETHPRIME "FEC" +#define CONFIG_FEC_MXC_PHYADDR 1 + +#define CONFIG_PHYLIB +#define CONFIG_PHY_ATHEROS + /* allow to overwrite serial and ethaddr */ #define CONFIG_ENV_OVERWRITE #define CONFIG_CONS_INDEX 1
Add support for it.
Acked-by: Kim Phillips kim.phillips@freescale.com
Kim
Add support for it.
Applied to u-boot-imx, next branch.
Best regards, Stefano Babic
Fabio Estevam
Kim Phillips
Stefano Babic
