[U-Boot] [PATCH] sunxi: Support SID e-fuses on A83T and H3
On the A83T and H3, the SID block is at a different address. Furthurmore, the e-fuses are at an offset of 0x200 within the hardware's address space.
Signed-off-by: Chen-Yu Tsai wens@csie.org --- arch/arm/include/asm/arch-sunxi/cpu_sun4i.h | 7 +++++++ 1 file changed, 7 insertions(+)
diff --git a/arch/arm/include/asm/arch-sunxi/cpu_sun4i.h b/arch/arm/include/asm/arch-sunxi/cpu_sun4i.h index 0cdefdc..f797649 100644 --- a/arch/arm/include/asm/arch-sunxi/cpu_sun4i.h +++ b/arch/arm/include/asm/arch-sunxi/cpu_sun4i.h @@ -74,7 +74,14 @@ #define SUNXI_AD_DA_BASE 0x01c22c00 #define SUNXI_KEYPAD_BASE 0x01c23000 #define SUNXI_TZPC_BASE 0x01c23400 + +#if defined(CONFIG_MACH_SUN8I_A83T) || defined(CONFIG_MACH_SUN8I_H3) +/* SID address space starts at 0x01c1400, but e-fuse is at offset 0x200 */ +#define SUNXI_SID_BASE 0x01c14200 +#else #define SUNXI_SID_BASE 0x01c23800 +#endif + #define SUNXI_SJTAG_BASE 0x01c23c00
#define SUNXI_TP_BASE 0x01c25000
Cubietruck Plus is a A83T/H8 based development board. The board has standard DDR3 SDRAM, AXP818 PMIC/codec, SD/MMC, eMMC, USB 2.0 host via HSIC USB Hub, USB OTG, SATA via USB bridge, gigabit ethernet, WiFi, headphone out / mic in, and various GPIO headers.
The board also has an EEPROM on i2c0 which holds the MAC address.
DLDO3 and DLDO4 provide power to the EMAC pins and PHY. Pin PA20 is connected to the reset control of the PHY. EMAC is not actually supported yet.
The DTS is the same as the one already in the kernel.
Signed-off-by: Chen-Yu Tsai wens@csie.org --- arch/arm/dts/Makefile | 1 + arch/arm/dts/sun8i-a83t-cubietruck-plus.dts | 65 +++++++++++++++++++++++++++++ configs/Cubietruck_plus_defconfig | 18 ++++++++ 3 files changed, 84 insertions(+) create mode 100644 arch/arm/dts/sun8i-a83t-cubietruck-plus.dts create mode 100644 configs/Cubietruck_plus_defconfig
diff --git a/arch/arm/dts/Makefile b/arch/arm/dts/Makefile index 1c7d359..e338db5 100644 --- a/arch/arm/dts/Makefile +++ b/arch/arm/dts/Makefile @@ -184,6 +184,7 @@ dtb-$(CONFIG_MACH_SUN8I_A33) += \ sun8i-a33-sinlinx-sina33.dtb dtb-$(CONFIG_MACH_SUN8I_A83T) += \ sun8i-a83t-allwinner-h8homlet-v2.dtb \ + sun8i-a83t-cubietruck-plus.dtb \ sun8i-a83t-sinovoip-bpi-m3.dtb dtb-$(CONFIG_MACH_SUN8I_H3) += \ sun8i-h3-orangepi-pc.dtb \ diff --git a/arch/arm/dts/sun8i-a83t-cubietruck-plus.dts b/arch/arm/dts/sun8i-a83t-cubietruck-plus.dts new file mode 100644 index 0000000..88b1e09 --- /dev/null +++ b/arch/arm/dts/sun8i-a83t-cubietruck-plus.dts @@ -0,0 +1,65 @@ +/* + * Copyright 2015 Chen-Yu Tsai + * + * Chen-Yu Tsai wens@csie.org + * + * This file is dual-licensed: you can use it either under the terms + * of the GPL or the X11 license, at your option. Note that this dual + * licensing only applies to this file, and not this project as a + * whole. + * + * a) This file is free software; you can redistribute it and/or + * modify it under the terms of the GNU General Public License as + * published by the Free Software Foundation; either version 2 of the + * License, or (at your option) any later version. + * + * This file is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * Or, alternatively, + * + * b) Permission is hereby granted, free of charge, to any person + * obtaining a copy of this software and associated documentation + * files (the "Software"), to deal in the Software without + * restriction, including without limitation the rights to use, + * copy, modify, merge, publish, distribute, sublicense, and/or + * sell copies of the Software, and to permit persons to whom the + * Software is furnished to do so, subject to the following + * conditions: + * + * The above copyright notice and this permission notice shall be + * included in all copies or substantial portions of the Software. + * + * THE SOFTWARE IS PROVIDED "AS IS", WITHOUT WARRANTY OF ANY KIND, + * EXPRESS OR IMPLIED, INCLUDING BUT NOT LIMITED TO THE WARRANTIES + * OF MERCHANTABILITY, FITNESS FOR A PARTICULAR PURPOSE AND + * NONINFRINGEMENT. IN NO EVENT SHALL THE AUTHORS OR COPYRIGHT + * HOLDERS BE LIABLE FOR ANY CLAIM, DAMAGES OR OTHER LIABILITY, + * WHETHER IN AN ACTION OF CONTRACT, TORT OR OTHERWISE, ARISING + * FROM, OUT OF OR IN CONNECTION WITH THE SOFTWARE OR THE USE OR + * OTHER DEALINGS IN THE SOFTWARE. + */ + +/dts-v1/; +#include "sun8i-a83t.dtsi" + +/ { + model = "Cubietech Cubietruck Plus"; + compatible = "cubietech,cubietruck-plus", "allwinner,sun8i-a83t"; + + aliases { + serial0 = &uart0; + }; + + chosen { + stdout-path = "serial0:115200n8"; + }; +}; + +&uart0 { + pinctrl-names = "default"; + pinctrl-0 = <&uart0_pins_b>; + status = "okay"; +}; diff --git a/configs/Cubietruck_plus_defconfig b/configs/Cubietruck_plus_defconfig new file mode 100644 index 0000000..bb0b336 --- /dev/null +++ b/configs/Cubietruck_plus_defconfig @@ -0,0 +1,18 @@ +CONFIG_ARM=y +CONFIG_ARCH_SUNXI=y +CONFIG_MACH_SUN8I_A83T=y +CONFIG_DRAM_CLK=672 +CONFIG_DRAM_ZQ=15355 +CONFIG_DRAM_ODT_EN=y +CONFIG_MMC0_CD_PIN="PF6" +CONFIG_I2C0_ENABLE=y +CONFIG_AXP_GPIO=y +CONFIG_DEFAULT_DEVICE_TREE="sun8i-a83t-cubietruck-plus" +# CONFIG_SYS_MALLOC_CLEAR_ON_INIT is not set +CONFIG_SPL=y +CONFIG_SYS_EXTRA_OPTIONS="RGMII,MACPWR=SUNXI_GPD(20)" +# CONFIG_CMD_IMLS is not set +# CONFIG_CMD_FLASH is not set +# CONFIG_CMD_FPGA is not set +CONFIG_AXP_DLDO3_VOLT=2500 +CONFIG_AXP_DLDO4_VOLT=3300
Hans,
What is the status of this patch?
Dennis
- sun8i-a83t-cubietruck-plus.dtb \ sun8i-a83t-sinovoip-bpi-m3.dtb
- Copyright 2015 Chen-Yu Tsai
- Chen-Yu Tsai wens@csie.org
- This file is dual-licensed: you can use it either under the terms
- of the GPL or the X11 license, at your option. Note that this dual
- licensing only applies to this file, and not this project as a
- whole.
- a) This file is free software; you can redistribute it and/or
- Or, alternatively,
- b) Permission is hereby granted, free of charge, to any person
conditions:
- model = "Cubietech Cubietruck Plus";
- compatible = "cubietech,cubietruck-plus", "allwinner,sun8i-a83t";
- aliases {
serial0 = &uart0;
- chosen {
+&uart0 {
- pinctrl-names = "default";
- pinctrl-0 = <&uart0_pins_b>;
- status = "okay";
On Saturday, March 19, 2016 5:43:52 PM CDT Dennis Gilmore wrote:
Hans,
Dennis
With the patch applied building for Cubietruck_plus fails with
ld.bfd -pie --gc-sections -Bstatic -Ttext 0x4a000000 -o u-boot -T u- boot.lds arch/arm/cpu/armv7/start.o --start-group arch/arm/cpu/built-in.o arch/arm/cpu/armv7/built-in.o arch/arm/lib/built-in.o board/sunxi/built-in.o cmd/built-in.o common/built-in.o disk/built-in.o drivers/built-in.o drivers/dma/built-in.o drivers/gpio/built-in.o drivers/i2c/built-in.o drivers/mmc/built-in.o drivers/mtd/built-in.o drivers/mtd/onenand/built-in.o drivers/mtd/spi/built-in.o drivers/net/built-in.o drivers/net/phy/built-in.o drivers/pci/built-in.o drivers/power/built-in.o drivers/power/battery/built- in.o drivers/power/fuel_gauge/built-in.o drivers/power/mfd/built-in.o drivers/power/pmic/built-in.o drivers/power/regulator/built-in.o drivers/ serial/built-in.o drivers/spi/built-in.o drivers/usb/dwc3/built-in.o drivers/usb/emul/built-in.o drivers/usb/eth/built-in.o drivers/usb/gadget/ built-in.o drivers/usb/gadget/udc/built-in.o drivers/usb/host/built-in.o drivers/usb/musb-new/built-in.o drivers/usb/musb/built-in.o drivers/usb/phy/ built-in.o drivers/usb/ulpi/built-in.o fs/built-in.o lib/built-in.o net/ built-in.o test/built-in.o test/dm/built-in.o --end-group arch/arm/lib/ eabi_compat.o -L /usr/lib/gcc/armv7hl-redhat-linux-gnueabi/6.0.0 -lgcc -Map u-boot.map board/sunxi/built-in.o: In function `i2c_init_board': /builddir/build/BUILD/u-boot-2016.03/board/sunxi/board.c:363: undefined reference to `clock_twi_onoff' ld.bfd: BFD version 2.26.20160125 assertion fail elf32-arm.c:8434 ld.bfd: error: required section '.rel.plt' not found in the linker script ld.bfd: final link failed: Invalid operation
- whole.
conditions:
- aliases {
serial0 = &uart0;
- chosen {
+&uart0 {
- status = "okay";
hI,
On 19-03-16 23:43, Dennis Gilmore wrote:
Hans,
I added this to my sunxi-wip tree (including a fix for the build error) a couple of days ago. I will send a pull-req for various u-boot sunxi patch soonish and then it will hit mainline.
Regards,
Hans
Dennis
- sun8i-a83t-cubietruck-plus.dtb \ sun8i-a83t-sinovoip-bpi-m3.dtb dtb-$(CONFIG_MACH_SUN8I_H3) += \ sun8i-h3-orangepi-pc.dtb \
- whole.
conditions:
- aliases {
serial0 = &uart0;
- chosen {
+&uart0 {
- status = "okay";
Thanks, applied to my tree and this will go out with the next pull-req.
Regards,
Hans
Chen-Yu Tsai
Dennis Gilmore
Hans de Goede
