[U-Boot-Users] [PATCH v2 4/7] add SMSC LAN9x1x Network driver
This patch adds a driver for the following smsc network controllers: LAN9115 LAN9116 LAN9117 LAN9215 LAN9216 LAN9217
Signed-off-by: Sascha Hauer s.hauer@pengutronix.de Signed-off-by: Guennadi Liakhovetski lg@denx.de
Changes since v1: Removed C++ style comments
drivers/net/Makefile | 1 + drivers/net/smc911x.c | 668 +++++++++++++++++++++++++++++++++++++++++++++++++ 2 files changed, 669 insertions(+), 0 deletions(-) create mode 100644 drivers/net/smc911x.c
diff --git a/drivers/net/Makefile b/drivers/net/Makefile index 320dc3e..9482398 100644 --- a/drivers/net/Makefile +++ b/drivers/net/Makefile @@ -54,6 +54,7 @@ COBJS-y += rtl8139.o COBJS-y += rtl8169.o COBJS-y += s3c4510b_eth.o COBJS-y += smc91111.o +COBJS-y += smc911x.o COBJS-y += tigon3.o COBJS-y += tsec.o COBJS-y += tsi108_eth.o diff --git a/drivers/net/smc911x.c b/drivers/net/smc911x.c new file mode 100644 index 0000000..5830368 --- /dev/null +++ b/drivers/net/smc911x.c @@ -0,0 +1,667 @@ +/* + * SMSC LAN9[12]1[567] Network driver + * + * (c) 2007 Pengutronix, Sascha Hauer s.hauer@pengutronix.de + * + * See file CREDITS for list of people who contributed to this + * project. + * + * This program is free software; you can redistribute it and/or + * modify it under the terms of the GNU General Public License as + * published by the Free Software Foundation; either version 2 of + * the License, or (at your option) any later version. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * You should have received a copy of the GNU General Public License + * along with this program; if not, write to the Free Software + * Foundation, Inc., 59 Temple Place, Suite 330, Boston, + * MA 02111-1307 USA + */ + +#include <common.h> + +#ifdef CONFIG_DRIVER_SMC911X + +#include <command.h> +#include <net.h> +#include <miiphy.h> + +#define mdelay(n) udelay((n)*1000) + +#define __REG(x) (*((volatile u32 *)(x))) + +/* Below are the register offsets and bit definitions + * of the Lan911x memory space + */ +#define RX_DATA_FIFO __REG(CONFIG_DRIVER_SMC911X_BASE + 0x00) + +#define TX_DATA_FIFO __REG(CONFIG_DRIVER_SMC911X_BASE + 0x20) +#define TX_CMD_A_INT_ON_COMP (0x80000000) +#define TX_CMD_A_INT_BUF_END_ALGN (0x03000000) +#define TX_CMD_A_INT_4_BYTE_ALGN (0x00000000) +#define TX_CMD_A_INT_16_BYTE_ALGN (0x01000000) +#define TX_CMD_A_INT_32_BYTE_ALGN (0x02000000) +#define TX_CMD_A_INT_DATA_OFFSET (0x001F0000) +#define TX_CMD_A_INT_FIRST_SEG (0x00002000) +#define TX_CMD_A_INT_LAST_SEG (0x00001000) +#define TX_CMD_A_BUF_SIZE (0x000007FF) +#define TX_CMD_B_PKT_TAG (0xFFFF0000) +#define TX_CMD_B_ADD_CRC_DISABLE (0x00002000) +#define TX_CMD_B_DISABLE_PADDING (0x00001000) +#define TX_CMD_B_PKT_BYTE_LENGTH (0x000007FF) + +#define RX_STATUS_FIFO __REG(CONFIG_DRIVER_SMC911X_BASE + 0x40) +#define RX_STS_PKT_LEN (0x3FFF0000) +#define RX_STS_ES (0x00008000) +#define RX_STS_BCST (0x00002000) +#define RX_STS_LEN_ERR (0x00001000) +#define RX_STS_RUNT_ERR (0x00000800) +#define RX_STS_MCAST (0x00000400) +#define RX_STS_TOO_LONG (0x00000080) +#define RX_STS_COLL (0x00000040) +#define RX_STS_ETH_TYPE (0x00000020) +#define RX_STS_WDOG_TMT (0x00000010) +#define RX_STS_MII_ERR (0x00000008) +#define RX_STS_DRIBBLING (0x00000004) +#define RX_STS_CRC_ERR (0x00000002) +#define RX_STATUS_FIFO_PEEK __REG(CONFIG_DRIVER_SMC911X_BASE + 0x44) +#define TX_STATUS_FIFO __REG(CONFIG_DRIVER_SMC911X_BASE + 0x48) +#define TX_STS_TAG (0xFFFF0000) +#define TX_STS_ES (0x00008000) +#define TX_STS_LOC (0x00000800) +#define TX_STS_NO_CARR (0x00000400) +#define TX_STS_LATE_COLL (0x00000200) +#define TX_STS_MANY_COLL (0x00000100) +#define TX_STS_COLL_CNT (0x00000078) +#define TX_STS_MANY_DEFER (0x00000004) +#define TX_STS_UNDERRUN (0x00000002) +#define TX_STS_DEFERRED (0x00000001) +#define TX_STATUS_FIFO_PEEK __REG(CONFIG_DRIVER_SMC911X_BASE + 0x4C) +#define ID_REV __REG(CONFIG_DRIVER_SMC911X_BASE + 0x50) +#define ID_REV_CHIP_ID (0xFFFF0000) /* RO */ +#define ID_REV_REV_ID (0x0000FFFF) /* RO */ + +#define INT_CFG __REG(CONFIG_DRIVER_SMC911X_BASE + 0x54) +#define INT_CFG_INT_DEAS (0xFF000000) /* R/W */ +#define INT_CFG_INT_DEAS_CLR (0x00004000) +#define INT_CFG_INT_DEAS_STS (0x00002000) +#define INT_CFG_IRQ_INT (0x00001000) /* RO */ +#define INT_CFG_IRQ_EN (0x00000100) /* R/W */ +#define INT_CFG_IRQ_POL (0x00000010) /* R/W Not Affected by SW Reset */ +#define INT_CFG_IRQ_TYPE (0x00000001) /* R/W Not Affected by SW Reset */ + +#define INT_STS __REG(CONFIG_DRIVER_SMC911X_BASE + 0x58) +#define INT_STS_SW_INT (0x80000000) /* R/WC */ +#define INT_STS_TXSTOP_INT (0x02000000) /* R/WC */ +#define INT_STS_RXSTOP_INT (0x01000000) /* R/WC */ +#define INT_STS_RXDFH_INT (0x00800000) /* R/WC */ +#define INT_STS_RXDF_INT (0x00400000) /* R/WC */ +#define INT_STS_TX_IOC (0x00200000) /* R/WC */ +#define INT_STS_RXD_INT (0x00100000) /* R/WC */ +#define INT_STS_GPT_INT (0x00080000) /* R/WC */ +#define INT_STS_PHY_INT (0x00040000) /* RO */ +#define INT_STS_PME_INT (0x00020000) /* R/WC */ +#define INT_STS_TXSO (0x00010000) /* R/WC */ +#define INT_STS_RWT (0x00008000) /* R/WC */ +#define INT_STS_RXE (0x00004000) /* R/WC */ +#define INT_STS_TXE (0x00002000) /* R/WC */ +/*#define INT_STS_ERX (0x00001000)*/ /* R/WC */ +#define INT_STS_TDFU (0x00000800) /* R/WC */ +#define INT_STS_TDFO (0x00000400) /* R/WC */ +#define INT_STS_TDFA (0x00000200) /* R/WC */ +#define INT_STS_TSFF (0x00000100) /* R/WC */ +#define INT_STS_TSFL (0x00000080) /* R/WC */ +/*#define INT_STS_RXDF (0x00000040)*/ /* R/WC */ +#define INT_STS_RDFO (0x00000040) /* R/WC */ +#define INT_STS_RDFL (0x00000020) /* R/WC */ +#define INT_STS_RSFF (0x00000010) /* R/WC */ +#define INT_STS_RSFL (0x00000008) /* R/WC */ +#define INT_STS_GPIO2_INT (0x00000004) /* R/WC */ +#define INT_STS_GPIO1_INT (0x00000002) /* R/WC */ +#define INT_STS_GPIO0_INT (0x00000001) /* R/WC */ +#define INT_EN __REG(CONFIG_DRIVER_SMC911X_BASE + 0x5C) +#define INT_EN_SW_INT_EN (0x80000000) /* R/W */ +#define INT_EN_TXSTOP_INT_EN (0x02000000) /* R/W */ +#define INT_EN_RXSTOP_INT_EN (0x01000000) /* R/W */ +#define INT_EN_RXDFH_INT_EN (0x00800000) /* R/W */ +/*#define INT_EN_RXDF_INT_EN (0x00400000)*/ /* R/W */ +#define INT_EN_TIOC_INT_EN (0x00200000) /* R/W */ +#define INT_EN_RXD_INT_EN (0x00100000) /* R/W */ +#define INT_EN_GPT_INT_EN (0x00080000) /* R/W */ +#define INT_EN_PHY_INT_EN (0x00040000) /* R/W */ +#define INT_EN_PME_INT_EN (0x00020000) /* R/W */ +#define INT_EN_TXSO_EN (0x00010000) /* R/W */ +#define INT_EN_RWT_EN (0x00008000) /* R/W */ +#define INT_EN_RXE_EN (0x00004000) /* R/W */ +#define INT_EN_TXE_EN (0x00002000) /* R/W */ +/*#define INT_EN_ERX_EN (0x00001000)*/ /* R/W */ +#define INT_EN_TDFU_EN (0x00000800) /* R/W */ +#define INT_EN_TDFO_EN (0x00000400) /* R/W */ +#define INT_EN_TDFA_EN (0x00000200) /* R/W */ +#define INT_EN_TSFF_EN (0x00000100) /* R/W */ +#define INT_EN_TSFL_EN (0x00000080) /* R/W */ +/*#define INT_EN_RXDF_EN (0x00000040)*/ /* R/W */ +#define INT_EN_RDFO_EN (0x00000040) /* R/W */ +#define INT_EN_RDFL_EN (0x00000020) /* R/W */ +#define INT_EN_RSFF_EN (0x00000010) /* R/W */ +#define INT_EN_RSFL_EN (0x00000008) /* R/W */ +#define INT_EN_GPIO2_INT (0x00000004) /* R/W */ +#define INT_EN_GPIO1_INT (0x00000002) /* R/W */ +#define INT_EN_GPIO0_INT (0x00000001) /* R/W */ + +#define BYTE_TEST __REG(CONFIG_DRIVER_SMC911X_BASE + 0x64) +#define FIFO_INT __REG(CONFIG_DRIVER_SMC911X_BASE + 0x68) +#define FIFO_INT_TX_AVAIL_LEVEL (0xFF000000) /* R/W */ +#define FIFO_INT_TX_STS_LEVEL (0x00FF0000) /* R/W */ +#define FIFO_INT_RX_AVAIL_LEVEL (0x0000FF00) /* R/W */ +#define FIFO_INT_RX_STS_LEVEL (0x000000FF) /* R/W */ + +#define RX_CFG __REG(CONFIG_DRIVER_SMC911X_BASE + 0x6C) +#define RX_CFG_RX_END_ALGN (0xC0000000) /* R/W */ +#define RX_CFG_RX_END_ALGN4 (0x00000000) /* R/W */ +#define RX_CFG_RX_END_ALGN16 (0x40000000) /* R/W */ +#define RX_CFG_RX_END_ALGN32 (0x80000000) /* R/W */ +#define RX_CFG_RX_DMA_CNT (0x0FFF0000) /* R/W */ +#define RX_CFG_RX_DUMP (0x00008000) /* R/W */ +#define RX_CFG_RXDOFF (0x00001F00) /* R/W */ +/*#define RX_CFG_RXBAD (0x00000001)*/ /* R/W */ + +#define TX_CFG __REG(CONFIG_DRIVER_SMC911X_BASE + 0x70) +/*#define TX_CFG_TX_DMA_LVL (0xE0000000)*/ /* R/W */ +/*#define TX_CFG_TX_DMA_CNT (0x0FFF0000)*/ /* R/W Self Clearing */ +#define TX_CFG_TXS_DUMP (0x00008000) /* Self Clearing */ +#define TX_CFG_TXD_DUMP (0x00004000) /* Self Clearing */ +#define TX_CFG_TXSAO (0x00000004) /* R/W */ +#define TX_CFG_TX_ON (0x00000002) /* R/W */ +#define TX_CFG_STOP_TX (0x00000001) /* Self Clearing */ + +#define HW_CFG __REG(CONFIG_DRIVER_SMC911X_BASE + 0x74) +#define HW_CFG_TTM (0x00200000) /* R/W */ +#define HW_CFG_SF (0x00100000) /* R/W */ +#define HW_CFG_TX_FIF_SZ (0x000F0000) /* R/W */ +#define HW_CFG_TR (0x00003000) /* R/W */ +#define HW_CFG_PHY_CLK_SEL (0x00000060) /* R/W */ +#define HW_CFG_PHY_CLK_SEL_INT_PHY (0x00000000) /* R/W */ +#define HW_CFG_PHY_CLK_SEL_EXT_PHY (0x00000020) /* R/W */ +#define HW_CFG_PHY_CLK_SEL_CLK_DIS (0x00000040) /* R/W */ +#define HW_CFG_SMI_SEL (0x00000010) /* R/W */ +#define HW_CFG_EXT_PHY_DET (0x00000008) /* RO */ +#define HW_CFG_EXT_PHY_EN (0x00000004) /* R/W */ +#define HW_CFG_32_16_BIT_MODE (0x00000004) /* RO */ +#define HW_CFG_SRST_TO (0x00000002) /* RO */ +#define HW_CFG_SRST (0x00000001) /* Self Clearing */ + +#define RX_DP_CTRL __REG(CONFIG_DRIVER_SMC911X_BASE + 0x78) +#define RX_DP_CTRL_RX_FFWD (0x80000000) /* R/W */ +#define RX_DP_CTRL_FFWD_BUSY (0x80000000) /* RO */ + +#define RX_FIFO_INF __REG(CONFIG_DRIVER_SMC911X_BASE + 0x7C) +#define RX_FIFO_INF_RXSUSED (0x00FF0000) /* RO */ +#define RX_FIFO_INF_RXDUSED (0x0000FFFF) /* RO */ + +#define TX_FIFO_INF __REG(CONFIG_DRIVER_SMC911X_BASE + 0x80) +#define TX_FIFO_INF_TSUSED (0x00FF0000) /* RO */ +#define TX_FIFO_INF_TDFREE (0x0000FFFF) /* RO */ + +#define PMT_CTRL __REG(CONFIG_DRIVER_SMC911X_BASE + 0x84) +#define PMT_CTRL_PM_MODE (0x00003000) /* Self Clearing */ +#define PMT_CTRL_PHY_RST (0x00000400) /* Self Clearing */ +#define PMT_CTRL_WOL_EN (0x00000200) /* R/W */ +#define PMT_CTRL_ED_EN (0x00000100) /* R/W */ +#define PMT_CTRL_PME_TYPE (0x00000040) /* R/W Not Affected by SW Reset */ +#define PMT_CTRL_WUPS (0x00000030) /* R/WC */ +#define PMT_CTRL_WUPS_NOWAKE (0x00000000) /* R/WC */ +#define PMT_CTRL_WUPS_ED (0x00000010) /* R/WC */ +#define PMT_CTRL_WUPS_WOL (0x00000020) /* R/WC */ +#define PMT_CTRL_WUPS_MULTI (0x00000030) /* R/WC */ +#define PMT_CTRL_PME_IND (0x00000008) /* R/W */ +#define PMT_CTRL_PME_POL (0x00000004) /* R/W */ +#define PMT_CTRL_PME_EN (0x00000002) /* R/W Not Affected by SW Reset */ +#define PMT_CTRL_READY (0x00000001) /* RO */ + +#define GPIO_CFG __REG(CONFIG_DRIVER_SMC911X_BASE + 0x88) +#define GPIO_CFG_LED3_EN (0x40000000) /* R/W */ +#define GPIO_CFG_LED2_EN (0x20000000) /* R/W */ +#define GPIO_CFG_LED1_EN (0x10000000) /* R/W */ +#define GPIO_CFG_GPIO2_INT_POL (0x04000000) /* R/W */ +#define GPIO_CFG_GPIO1_INT_POL (0x02000000) /* R/W */ +#define GPIO_CFG_GPIO0_INT_POL (0x01000000) /* R/W */ +#define GPIO_CFG_EEPR_EN (0x00700000) /* R/W */ +#define GPIO_CFG_GPIOBUF2 (0x00040000) /* R/W */ +#define GPIO_CFG_GPIOBUF1 (0x00020000) /* R/W */ +#define GPIO_CFG_GPIOBUF0 (0x00010000) /* R/W */ +#define GPIO_CFG_GPIODIR2 (0x00000400) /* R/W */ +#define GPIO_CFG_GPIODIR1 (0x00000200) /* R/W */ +#define GPIO_CFG_GPIODIR0 (0x00000100) /* R/W */ +#define GPIO_CFG_GPIOD4 (0x00000010) /* R/W */ +#define GPIO_CFG_GPIOD3 (0x00000008) /* R/W */ +#define GPIO_CFG_GPIOD2 (0x00000004) /* R/W */ +#define GPIO_CFG_GPIOD1 (0x00000002) /* R/W */ +#define GPIO_CFG_GPIOD0 (0x00000001) /* R/W */ + +#define GPT_CFG __REG(CONFIG_DRIVER_SMC911X_BASE + 0x8C) +#define GPT_CFG_TIMER_EN (0x20000000) /* R/W */ +#define GPT_CFG_GPT_LOAD (0x0000FFFF) /* R/W */ + +#define GPT_CNT __REG(CONFIG_DRIVER_SMC911X_BASE + 0x90) +#define GPT_CNT_GPT_CNT (0x0000FFFF) /* RO */ + +#define ENDIAN __REG(CONFIG_DRIVER_SMC911X_BASE + 0x98) +#define FREE_RUN __REG(CONFIG_DRIVER_SMC911X_BASE + 0x9C) +#define RX_DROP __REG(CONFIG_DRIVER_SMC911X_BASE + 0xA0) +#define MAC_CSR_CMD __REG(CONFIG_DRIVER_SMC911X_BASE + 0xA4) +#define MAC_CSR_CMD_CSR_BUSY (0x80000000) /* Self Clearing */ +#define MAC_CSR_CMD_R_NOT_W (0x40000000) /* R/W */ +#define MAC_CSR_CMD_CSR_ADDR (0x000000FF) /* R/W */ + +#define MAC_CSR_DATA __REG(CONFIG_DRIVER_SMC911X_BASE + 0xA8) +#define AFC_CFG __REG(CONFIG_DRIVER_SMC911X_BASE + 0xAC) +#define AFC_CFG_AFC_HI (0x00FF0000) /* R/W */ +#define AFC_CFG_AFC_LO (0x0000FF00) /* R/W */ +#define AFC_CFG_BACK_DUR (0x000000F0) /* R/W */ +#define AFC_CFG_FCMULT (0x00000008) /* R/W */ +#define AFC_CFG_FCBRD (0x00000004) /* R/W */ +#define AFC_CFG_FCADD (0x00000002) /* R/W */ +#define AFC_CFG_FCANY (0x00000001) /* R/W */ + +#define E2P_CMD __REG(CONFIG_DRIVER_SMC911X_BASE + 0xB0) +#define E2P_CMD_EPC_BUSY (0x80000000) /* Self Clearing */ +#define E2P_CMD_EPC_CMD (0x70000000) /* R/W */ +#define E2P_CMD_EPC_CMD_READ (0x00000000) /* R/W */ +#define E2P_CMD_EPC_CMD_EWDS (0x10000000) /* R/W */ +#define E2P_CMD_EPC_CMD_EWEN (0x20000000) /* R/W */ +#define E2P_CMD_EPC_CMD_WRITE (0x30000000) /* R/W */ +#define E2P_CMD_EPC_CMD_WRAL (0x40000000) /* R/W */ +#define E2P_CMD_EPC_CMD_ERASE (0x50000000) /* R/W */ +#define E2P_CMD_EPC_CMD_ERAL (0x60000000) /* R/W */ +#define E2P_CMD_EPC_CMD_RELOAD (0x70000000) /* R/W */ +#define E2P_CMD_EPC_TIMEOUT (0x00000200) /* RO */ +#define E2P_CMD_MAC_ADDR_LOADED (0x00000100) /* RO */ +#define E2P_CMD_EPC_ADDR (0x000000FF) /* R/W */ + +#define E2P_DATA __REG(CONFIG_DRIVER_SMC911X_BASE + 0xB4) +#define E2P_DATA_EEPROM_DATA (0x000000FF) /* R/W */ +/* end of LAN register offsets and bit definitions */ + +/* MAC Control and Status registers */ +#define MAC_CR (0x01) /* R/W */ + +/* MAC_CR - MAC Control Register */ +#define MAC_CR_RXALL (0x80000000) +/* TODO: delete this bit? It is not described in the data sheet. */ +#define MAC_CR_HBDIS (0x10000000) +#define MAC_CR_RCVOWN (0x00800000) +#define MAC_CR_LOOPBK (0x00200000) +#define MAC_CR_FDPX (0x00100000) +#define MAC_CR_MCPAS (0x00080000) +#define MAC_CR_PRMS (0x00040000) +#define MAC_CR_INVFILT (0x00020000) +#define MAC_CR_PASSBAD (0x00010000) +#define MAC_CR_HFILT (0x00008000) +#define MAC_CR_HPFILT (0x00002000) +#define MAC_CR_LCOLL (0x00001000) +#define MAC_CR_BCAST (0x00000800) +#define MAC_CR_DISRTY (0x00000400) +#define MAC_CR_PADSTR (0x00000100) +#define MAC_CR_BOLMT_MASK (0x000000C0) +#define MAC_CR_DFCHK (0x00000020) +#define MAC_CR_TXEN (0x00000008) +#define MAC_CR_RXEN (0x00000004) + +#define ADDRH (0x02) /* R/W mask 0x0000FFFFUL */ +#define ADDRL (0x03) /* R/W mask 0xFFFFFFFFUL */ +#define HASHH (0x04) /* R/W */ +#define HASHL (0x05) /* R/W */ + +#define MII_ACC (0x06) /* R/W */ +#define MII_ACC_PHY_ADDR (0x0000F800) +#define MII_ACC_MIIRINDA (0x000007C0) +#define MII_ACC_MII_WRITE (0x00000002) +#define MII_ACC_MII_BUSY (0x00000001) + +#define MII_DATA (0x07) /* R/W mask 0x0000FFFFUL */ + +#define FLOW (0x08) /* R/W */ +#define FLOW_FCPT (0xFFFF0000) +#define FLOW_FCPASS (0x00000004) +#define FLOW_FCEN (0x00000002) +#define FLOW_FCBSY (0x00000001) + +#define VLAN1 (0x09) /* R/W mask 0x0000FFFFUL */ +#define VLAN1_VTI1 (0x0000ffff) + +#define VLAN2 (0x0A) /* R/W mask 0x0000FFFFUL */ +#define VLAN2_VTI2 (0x0000ffff) + +#define WUFF (0x0B) /* WO */ + +#define WUCSR (0x0C) /* R/W */ +#define WUCSR_GUE (0x00000200) +#define WUCSR_WUFR (0x00000040) +#define WUCSR_MPR (0x00000020) +#define WUCSR_WAKE_EN (0x00000004) +#define WUCSR_MPEN (0x00000002) + +/* Chip ID values */ +#define CHIP_9115 0x115 +#define CHIP_9116 0x116 +#define CHIP_9117 0x117 +#define CHIP_9118 0x118 +#define CHIP_9215 0x115a +#define CHIP_9216 0x116a +#define CHIP_9217 0x117a +#define CHIP_9218 0x118a + +struct chip_id { + u16 id; + char *name; +}; + +static const struct chip_id chip_ids[] = { + { CHIP_9115, "LAN9115" }, + { CHIP_9116, "LAN9116" }, + { CHIP_9117, "LAN9117" }, + { CHIP_9118, "LAN9118" }, + { CHIP_9215, "LAN9215" }, + { CHIP_9216, "LAN9216" }, + { CHIP_9217, "LAN9217" }, + { CHIP_9218, "LAN9218" }, + { 0, NULL }, +}; + +#define DRIVERNAME "smc911x" + +u32 smc911x_get_mac_csr(u8 reg) +{ + while (MAC_CSR_CMD & MAC_CSR_CMD_CSR_BUSY); + MAC_CSR_CMD = MAC_CSR_CMD_CSR_BUSY | MAC_CSR_CMD_R_NOT_W | reg; + while (MAC_CSR_CMD & MAC_CSR_CMD_CSR_BUSY); + + return MAC_CSR_DATA; +} + +void smc911x_set_mac_csr(u8 reg, u32 data) +{ + while (MAC_CSR_CMD & MAC_CSR_CMD_CSR_BUSY); + MAC_CSR_DATA = data; + MAC_CSR_CMD = MAC_CSR_CMD_CSR_BUSY | reg; + while (MAC_CSR_CMD & MAC_CSR_CMD_CSR_BUSY); +} + +static int smx911x_handle_mac_address(bd_t *bd) +{ + unsigned long addrh, addrl; + unsigned char *m = bd->bi_enetaddr; + + /* if the environment has a valid mac address then use it */ + if ((m[0] | m[1] | m[2] | m[3] | m[4] | m[5])) { + addrl = m[0] | m[1] << 8 | m[2] << 16 | m[3] << 24; + addrh = m[4] | m[5] << 8; + smc911x_set_mac_csr(ADDRH, addrh); + smc911x_set_mac_csr(ADDRL, addrl); + } else { + /* if not, try to get one from the eeprom */ + addrh = smc911x_get_mac_csr(ADDRH); + addrl = smc911x_get_mac_csr(ADDRL); + + m[0] = (addrl ) & 0xff; + m[1] = (addrl >> 8 ) & 0xff; + m[2] = (addrl >> 16 ) & 0xff; + m[3] = (addrl >> 24 ) & 0xff; + m[4] = (addrh ) & 0xff; + m[5] = (addrh >> 8 ) & 0xff; + + /* we get 0xff when there is no eeprom connected */ + if ((m[0] & m[1] & m[2] & m[3] & m[4] & m[5]) == 0xff) { + printf(DRIVERNAME ": no valid mac address in environment " + "and no eeprom found\n"); + return -1; + } + } + + printf(DRIVERNAME ": MAC %02x:%02x:%02x:%02x:%02x:%02x\n", + m[0], m[1], m[2], m[3], m[4], m[5]); + + return 0; +} + +static int smc911x_miiphy_read(u8 phy, u8 reg, u16 *val) +{ + while (smc911x_get_mac_csr(MII_ACC) & MII_ACC_MII_BUSY); + + smc911x_set_mac_csr( MII_ACC, phy << 11 | reg << 6 | MII_ACC_MII_BUSY); + + while (smc911x_get_mac_csr(MII_ACC) & MII_ACC_MII_BUSY); + + *val = smc911x_get_mac_csr(MII_DATA); + + return 0; +} + +static int smc911x_miiphy_write(u8 phy, u8 reg, u16 val) +{ + while (smc911x_get_mac_csr(MII_ACC) & MII_ACC_MII_BUSY); + + smc911x_set_mac_csr(MII_DATA, val); + smc911x_set_mac_csr(MII_ACC, + phy << 11 | reg << 6 | MII_ACC_MII_BUSY | MII_ACC_MII_WRITE); + + while (smc911x_get_mac_csr(MII_ACC) & MII_ACC_MII_BUSY); + return 0; +} + +static int smc911x_phy_reset(void) +{ + u32 reg; + + reg = PMT_CTRL; + reg &= ~0xfffff030; + reg |= PMT_CTRL_PHY_RST; + PMT_CTRL = reg; + + mdelay(100); + + return 0; +} + +static void smc911x_phy_configure(void) +{ + int timeout; + u16 status; + + smc911x_phy_reset(); + + smc911x_miiphy_write(1, PHY_BMCR, PHY_BMCR_RESET); + mdelay(1); + smc911x_miiphy_write(1, PHY_ANAR, 0x01e1); + smc911x_miiphy_write(1, PHY_BMCR, PHY_BMCR_AUTON | PHY_BMCR_RST_NEG); + + timeout = 5000; + do { + mdelay(1); + if ((timeout--) == 0) + goto err_out; + + if (smc911x_miiphy_read(1, PHY_BMSR, &status) != 0) + goto err_out; + } while (!(status & PHY_BMSR_LS)); + + printf(DRIVERNAME ": phy initialized\n"); + + return; + +err_out: + printf(DRIVERNAME ": autonegotiation timed out\n"); +} + +static void smc911x_reset(void) +{ + int timeout; + + /* Take out of PM setting first */ + if (PMT_CTRL & PMT_CTRL_READY) { + /* Write to the bytetest will take out of powerdown */ + BYTE_TEST = 0x0; + + timeout = 10; + + while ( timeout-- && !(PMT_CTRL & PMT_CTRL_READY)) + udelay(10); + if (!timeout) { + printf(DRIVERNAME + ": timeout waiting for PM restore\n"); + return; + } + } + + /* Disable interrupts */ + INT_EN = 0; + + HW_CFG = HW_CFG_SRST; + + timeout = 1000; + while (timeout-- && E2P_CMD & E2P_CMD_EPC_BUSY) + udelay(10); + + if(!timeout) { + printf(DRIVERNAME ": reset timeout\n"); + return; + } + + /* Reset the FIFO level and flow control settings */ + smc911x_set_mac_csr(FLOW, FLOW_FCPT | FLOW_FCEN); + AFC_CFG = 0x0050287F; + + /* Set to LED outputs */ + GPIO_CFG = 0x70070000; +} + +static void smc911x_enable(void) +{ + /* Enable TX */ + HW_CFG = 8 << 16 | HW_CFG_SF; + + GPT_CFG = GPT_CFG_TIMER_EN | 10000; + + TX_CFG = TX_CFG_TX_ON; + + /* no padding to start of packets */ + RX_CFG = 0; + + smc911x_set_mac_csr(MAC_CR, MAC_CR_TXEN | MAC_CR_RXEN | MAC_CR_HBDIS); + +} + +int eth_init(bd_t *bd) +{ + unsigned long val, i; + + printf(DRIVERNAME ": initializing\n"); + + val = BYTE_TEST; + if(val != 0x87654321) { + printf(DRIVERNAME ": Invalid chip endian 0x08%x\n", val); + goto err_out; + } + + val = ID_REV >> 16; + for(i = 0; chip_ids[i].id != 0; i++) { + if (chip_ids[i].id == val) break; + } + if (!chip_ids[i].id) { + printf(DRIVERNAME ": Unknown chip ID %04x\n", val); + goto err_out; + } + + printf(DRIVERNAME ": detected %s controller\n", chip_ids[i].name); + + smc911x_reset(); + + /* Configure the PHY, initialize the link state */ + smc911x_phy_configure(); + + if (smx911x_handle_mac_address(bd)) + goto err_out; + + /* Turn on Tx + Rx */ + smc911x_enable(); + + return 0; + +err_out: + return -1; +} + +int eth_send(volatile void *packet, int length) +{ + u32 *data = (u32*)packet; + u32 tmplen; + u32 status; + + TX_DATA_FIFO = TX_CMD_A_INT_FIRST_SEG | TX_CMD_A_INT_LAST_SEG | length; + TX_DATA_FIFO = length; + + tmplen = (length + 3) / 4; + + while(tmplen--) + TX_DATA_FIFO = *data++; + + /* wait for transmission */ + while (!((TX_FIFO_INF & TX_FIFO_INF_TSUSED) >> 16)); + + /* get status. Ignore 'no carrier' error, it has no meaning for + * full duplex operation + */ + status = TX_STATUS_FIFO & (TX_STS_LOC | TX_STS_LATE_COLL | + TX_STS_MANY_COLL | TX_STS_MANY_DEFER | TX_STS_UNDERRUN); + + if(!status) + return 0; + + printf(DRIVERNAME ": failed to send packet: %s%s%s%s%s\n", + status & TX_STS_LOC ? "TX_STS_LOC " : "", + status & TX_STS_LATE_COLL ? "TX_STS_LATE_COLL " : "", + status & TX_STS_MANY_COLL ? "TX_STS_MANY_COLL " : "", + status & TX_STS_MANY_DEFER ? "TX_STS_MANY_DEFER " : "", + status & TX_STS_UNDERRUN ? "TX_STS_UNDERRUN" : ""); + + return -1; +} + +void eth_halt(void) +{ + smc911x_reset(); +} + +int eth_rx(void) +{ + u32 *data = (u32 *)NetRxPackets[0]; + u32 pktlen, tmplen; + u32 status; + + if((RX_FIFO_INF & RX_FIFO_INF_RXSUSED) >> 16) { + status = RX_STATUS_FIFO; + pktlen = (status & RX_STS_PKT_LEN) >> 16; + + RX_CFG = 0; + + tmplen = (pktlen + 2+ 3) / 4; + while(tmplen--) + *data++ = RX_DATA_FIFO; + + if(status & RX_STS_ES) + printf(DRIVERNAME + ": dropped bad packet. Status: 0x%08x\n", + status); + else + NetReceive(NetRxPackets[0], pktlen); + } + + return 0; +} + +#endif /* CONFIG_DRIVER_SMC911X */
Hi Guennadi,
How many of these have been tested, and on what platforms. I'm asking because the code seems to assume a 32-bit interface and these aren't all 32-bit chips.
- SMSC LAN9[12]1[567] Network driver
- (c) 2007 Pengutronix, Sascha Hauer s.hauer@pengutronix.de
- project.
- MA 02111-1307 USA
This should be moved to the Makefile. Looks like I beat J-C to this one...
See, you're assuming 32-bit accesses. That should be configurable, I think
- of the Lan911x memory space
Register and bitfield definitions should be in a header file. More generally, only register addresses and bitfields should be defined. Using macros to encapsulate both address and function is bad form, IMHO. More on that later. <snip>
- while (MAC_CSR_CMD & MAC_CSR_CMD_CSR_BUSY);
Using macros like this is both unreadable and hard to debug. Instead, consider something like:
while (reg_read(MAC_CSR) & MAC_CSR_BUSY));
IMHO, one-liner while loops are bad too, but that's debatable.
I haven't even gotten into the functionality, because I think there's a lot of work to be done just in coding style before we look at substance.
regards, Ben
Hi Ben,
On Wed, 26 Mar 2008, Ben Warren wrote:
Hi Guennadi,
I'll let the author reply to all your question / take care of all your suggestions, apart, maybe from just one:
I disagree with this. If only one .c file uses registers and bitfields and whatever other macros, I think, they better be defined in the .c file directly.
Thanks Guennadi --- Guennadi Liakhovetski, Ph.D.
DENX Software Engineering GmbH, MD: Wolfgang Denk & Detlev Zundel HRB 165235 Munich, Office: Kirchenstr.5, D-82194 Groebenzell, Germany Phone: +49-8142-66989-0 Fax: +49-8142-66989-80 Email: office@denx.de
-----Original Message----- From: Ben Warren [mailto:biggerbadderben@gmail.com] Sent: 26 March 2008 20:08 To: Guennadi Liakhovetski Cc: u-boot-users@lists.sourceforge.net; Wolfgang Denk; Peter Pearse Subject: Re: [U-Boot-Users] [PATCH v2 4/7] add SMSC LAN9x1x Network driver
Hi Guennadi,
Comments please Sascha.
---snip---
---snip---
Agreed
---snip---
Not these file specific ones. Ben - where else would they be applicable?
Agreed
Ben - perhaps you could help by pointing out some more examples
Regards
Peter
Hi Peter,
Hi Guennadi,
---snip---
---snip---
Agreed
---snip---
Well, I can't come up with a better answer than 'precedent', so I guess it's OK to keep the #defines in the C code.
Agreed
By coding style I mean the nasty macros, not stuff like brackets and whitespace. If the code was more readable and addressed the bus width differences between chips, this would probably go in quickly. I'll have another look to see if I can be more helpful rather than curmudgeonly.
regards, Ben
-----Original Message----- From: Ben Warren [mailto:biggerbadderben@gmail.com] Sent: 27 March 2008 13:57 To: Peter Pearse Cc: s.hauer@pengutronix.de; lg@denx.de; u-boot-users@lists.sourceforge.net Subject: Re: [U-Boot-Users] [PATCH v2 4/7] add SMSC LAN9x1x Network driver
Hi Peter,
LAN9x1x Network
driver
Thanks Ben
Hopefully we can make this window....
Regards
Peter
regards, Ben
Hi Guennadi,
It's tested on the LAN9217 but I remember using it on one of the 16bit controllers as well, maybe with some register access adjustments. Maybe it's best to abstract the register accesses because I already had a board which had the address lines shifted (somehow SMSC seems to provoke this)
Sascha
Thanks Sascha,
Hi Guennadi,
Sascha
I have no issue with bringing this in as a 32-bit only driver, leaving 16-bit implementation as a future exercise. We really should do this right, and the amount of code in the driver is small, so hopefully it can be fixed up for this merge window. If either you or Guennadi can do the following, I'll try my best to keep up:
1. Change all register definitions as following: #define RX_DATA_FIFO __REG(CONFIG_DRIVER_SMC911X_BASE + 0x00) to #define RX_DATA_FIFO CONFIG_DRIVER_SMC911X_BASE + 0x00
2. Implement read/write methods #ifdef CONFIG_DRIVER_SMC911X_32_BIT static inline u32 reg_read(u32 addr) ... static inline void reg_write(u32 addr, u32 val) ... #else #error "SMC911X: Only 32-bit bus is supported" #endif
or use macros if you insist. I won't get religious on this, just make it readable and debuggable.
thanks, Ben
Hi Everyone,
Would this driver work with the LAN9218 chip as well?
Nick
Ben Warren wrote:
Thanks Sascha,
Hi Guennadi,
Sascha
thanks, Ben
Check out the new SourceForge.net Marketplace. It's the best place to buy or sell services for just about anything Open Source. http://ad.doubleclick.net/clk;164216239;13503038;w?http://sf.net/marketplace _______________________________________________ U-Boot-Users mailing list U-Boot-Users@lists.sourceforge.net https://lists.sourceforge.net/lists/listinfo/u-boot-users
On Thu, Mar 27, 2008 at 02:23:44PM -0400, Nick Droogh wrote:
Hi Everyone,
The chips in this family differ in that some of them have an integrated phy and others not. Some have a 16bit bus interface and others have a 32bit bus interface. So yes, the driver should work with the 9218.
Sascha
Nick
Ben Warren wrote:
Thanks Sascha,
Hi Guennadi,
Sascha
thanks, Ben
sh: vcard-filter: command not found
Hi Everyone,
Ben, it seems discussion stopped here without a decision or so. What's the state of this driver, then?
Hi Everyone,
I'm so sorry for non-responsiveness on this. I hate to make excuses but I'm in the midst of moving my family across the country and um, some things have slipped through the cracks.
I've pulled Guennadi's latest submission for this driver into my local copy, but haven't pushed it to the net repo yet. I have a few hours available tomorrow where I'll finish this up and also look more closely into JCPV's regression fix for the ne2000-related build failure.
regards, Ben
Hi Everyone,
i'm guessing the eeprom programmer i posted wont be part of this. should i just wait for everything to hit mainline and then post a patch to add it then ? -mike
Hi Everyone,
Right - this particular one has been given the OK as a bug fix for 1.3.3. The EEPROM programmer will make it into the next release.
regards, Ben
participants (7)
Ben Warren
Mike Frysinger
Nick Droogh
Peter Pearse
Sascha Hauer
