[U-Boot] [UBOOT PATCH v2 1/2] zynqmp: nand: Add Nand driver support for zynqmp
Add nand driver support for zynqmp. The Nand controller used in ZynqMP is Arasan Nand Flash controller.
Signed-off-by: Siva Durga Prasad Paladugu sivadur@xilinx.com --- Changes from v1: - Newly added in series --- arch/arm/cpu/armv8/zynqmp/Kconfig | 3 +++ arch/arm/include/asm/arch-zynqmp/hardware.h | 2 ++ configs/xilinx_zynqmp_ep_defconfig | 1 + include/configs/xilinx_zynqmp.h | 9 +++++++++ 4 files changed, 15 insertions(+)
diff --git a/arch/arm/cpu/armv8/zynqmp/Kconfig b/arch/arm/cpu/armv8/zynqmp/Kconfig index e5a4fdd..161954f 100644 --- a/arch/arm/cpu/armv8/zynqmp/Kconfig +++ b/arch/arm/cpu/armv8/zynqmp/Kconfig @@ -27,4 +27,7 @@ config SECURE_IOU config ZYNQMP_USB bool "Configure ZynqMP USB"
+config NAND_ARASAN + bool "Configure Arasan Nand" + endif diff --git a/arch/arm/include/asm/arch-zynqmp/hardware.h b/arch/arm/include/asm/arch-zynqmp/hardware.h index 0f03c24..3c9f08c 100644 --- a/arch/arm/include/asm/arch-zynqmp/hardware.h +++ b/arch/arm/include/asm/arch-zynqmp/hardware.h @@ -25,6 +25,8 @@ #define ZYNQ_SDHCI_BASEADDR0 0xFF160000 #define ZYNQ_SDHCI_BASEADDR1 0xFF170000
+#define ARASAN_NAND_BASEADDR 0xFF100000 + #define ZYNQMP_SATA_BASEADDR 0xFD0C0000
#define ZYNQMP_USB0_XHCI_BASEADDR 0xFE200000 diff --git a/configs/xilinx_zynqmp_ep_defconfig b/configs/xilinx_zynqmp_ep_defconfig index 79304c1..43a24a7 100644 --- a/configs/xilinx_zynqmp_ep_defconfig +++ b/configs/xilinx_zynqmp_ep_defconfig @@ -1,6 +1,7 @@ CONFIG_ARM=y CONFIG_ARCH_ZYNQMP=y CONFIG_ZYNQMP_USB=y +CONFIG_NAND_ARASAN=y CONFIG_SYS_TEXT_BASE=0x8000000 CONFIG_DEFAULT_DEVICE_TREE="zynqmp-ep108" CONFIG_SYS_PROMPT="ZynqMP> " diff --git a/include/configs/xilinx_zynqmp.h b/include/configs/xilinx_zynqmp.h index 36c1100..1f17adb 100644 --- a/include/configs/xilinx_zynqmp.h +++ b/include/configs/xilinx_zynqmp.h @@ -101,6 +101,15 @@ # define CONFIG_CMD_EXT4_WRITE #endif
+#ifdef CONFIG_NAND_ARASAN +# define CONFIG_CMD_NAND +# define CONFIG_CMD_NAND_LOCK_UNLOCK +# define CONFIG_SYS_MAX_NAND_DEVICE 1 +# define CONFIG_SYS_NAND_SELF_INIT +# define CONFIG_SYS_NAND_ONFI_DETECTION +# define CONFIG_MTD_DEVICE +#endif + /* Miscellaneous configurable options */ #define CONFIG_SYS_LOAD_ADDR 0x8000000
Added initial nand driver support for arasan nand flash controller.This supports nand erase,nand read, nand write This uses the hardware ECC for read and write operations ZynqMP uses this driver.
Signed-off-by: Siva Durga Prasad Paladugu sivadur@xilinx.com --- Changes from v1: - Made some variables global to filescope wherever applicable - Used real units of time for timeouts - Handled proper return values - Removed arasan_read_byte and merged its functionality to arasan_nand_read_byte - Fixed coding style changes - Removed On Die ECC support code for now - Removed code ReadId from init. --- drivers/mtd/nand/Makefile | 1 + drivers/mtd/nand/arasan_nfc.c | 1173 +++++++++++++++++++++++++++++++++++++++++ 2 files changed, 1174 insertions(+) create mode 100644 drivers/mtd/nand/arasan_nfc.c
diff --git a/drivers/mtd/nand/Makefile b/drivers/mtd/nand/Makefile index b4e5376..6fb3718 100644 --- a/drivers/mtd/nand/Makefile +++ b/drivers/mtd/nand/Makefile @@ -42,6 +42,7 @@ ifdef NORMAL_DRIVERS obj-$(CONFIG_NAND_ECC_BCH) += nand_bch.o
obj-$(CONFIG_NAND_ATMEL) += atmel_nand.o +obj-$(CONFIG_NAND_ARASAN) += arasan_nfc.o obj-$(CONFIG_DRIVER_NAND_BFIN) += bfin_nand.o obj-$(CONFIG_NAND_DAVINCI) += davinci_nand.o obj-$(CONFIG_NAND_DENALI) += denali.o diff --git a/drivers/mtd/nand/arasan_nfc.c b/drivers/mtd/nand/arasan_nfc.c new file mode 100644 index 0000000..a697cce --- /dev/null +++ b/drivers/mtd/nand/arasan_nfc.c @@ -0,0 +1,1173 @@ +/* + * Arasan NAND Flash Controller Driver + * + * Copyright (C) 2014 - 2015 Xilinx, Inc. + * + * SPDX-License-Identifier: GPL-2.0 + */ + +#include <common.h> +#include <malloc.h> +#include <asm/io.h> +#include <asm/errno.h> +#include <linux/mtd/mtd.h> +#include <linux/mtd/nand.h> +#include <linux/mtd/partitions.h> +#include <linux/mtd/nand_ecc.h> +#include <asm/arch/hardware.h> +#include <asm/arch/sys_proto.h> +#include <nand.h> + +struct arasan_nand_info { + void __iomem *nand_base; + u32 page; +}; + +struct nand_regs { + u32 pkt_reg; + u32 memadr_reg1; + u32 memadr_reg2; + u32 cmd_reg; + u32 pgm_reg; + u32 intsts_enr; + u32 intsig_enr; + u32 intsts_reg; + u32 rdy_busy; + u32 cms_sysadr_reg; + u32 flash_sts_reg; + u32 tmg_reg; + u32 buf_dataport; + u32 ecc_reg; + u32 ecc_errcnt_reg; + u32 ecc_sprcmd_reg; + u32 errcnt_1bitreg; + u32 errcnt_2bitreg; + u32 errcnt_3bitreg; + u32 errcnt_4bitreg; + u32 dma_sysadr0_reg; + u32 dma_bufbdry_reg; + u32 cpu_rls_reg; + u32 errcnt_5bitreg; + u32 errcnt_6bitreg; + u32 errcnt_7bitreg; + u32 errcnt_8bitreg; + u32 data_if_reg; +}; + +#define arasan_nand_base ((struct nand_regs __iomem*)ARASAN_NAND_BASEADDR) + +struct arasan_nand_command_format { + u8 cmd1; + u8 cmd2; + u8 addr_cycles; + u32 pgm; +}; + +#define ONDIE_ECC_FEATURE_ADDR 0x90 + +#define ARASAN_PROG_RD_MASK 0x00000001 +#define ARASAN_PROG_BLK_ERS_MASK 0x00000004 +#define ARASAN_PROG_RD_ID_MASK 0x00000040 +#define ARASAN_PROG_RD_STS_MASK 0x00000008 +#define ARASAN_PROG_PG_PROG_MASK 0x00000010 +#define ARASAN_PROG_RD_PARAM_PG_MASK 0x00000080 +#define ARASAN_PROG_RST_MASK 0x00000100 +#define ARASAN_PROG_GET_FTRS_MASK 0x00000200 +#define ARASAN_PROG_SET_FTRS_MASK 0x00000400 +#define ARASAN_PROG_CHNG_ROWADR_END_MASK 0x00400000 + +#define ARASAN_NAND_CMD_ECC_ON_MASK 0x80000000 +#define ARASAN_NAND_CMD_CMD12_MASK 0xFFFF +#define ARASAN_NAND_CMD_PG_SIZE_MASK 0x3800000 +#define ARASAN_NAND_CMD_PG_SIZE_SHIFT 23 +#define ARASAN_NAND_CMD_CMD2_SHIFT 8 +#define ARASAN_NAND_CMD_ADDR_CYCL_MASK 0x70000000 +#define ARASAN_NAND_CMD_ADDR_CYCL_SHIFT 28 + +#define ARASAN_NAND_MEM_ADDR1_PAGE_MASK 0xFFFF0000 +#define ARASAN_NAND_MEM_ADDR1_COL_MASK 0xFFFF +#define ARASAN_NAND_MEM_ADDR1_PAGE_SHIFT 16 +#define ARASAN_NAND_MEM_ADDR2_PAGE_MASK 0xFF +#define ARASAN_NAND_MEM_ADDR2_CS_MASK 0xC0000000 +#define ARASAN_NAND_MEM_ADDR2_BCH_MASK 0xE000000 +#define ARASAN_NAND_MEM_ADDR2_BCH_SHIFT 25 + +#define ARASAN_NAND_INT_STS_ERR_EN_MASK 0x10 +#define ARASAN_NAND_INT_STS_MUL_BIT_ERR_MASK 0x08 +#define ARASAN_NAND_INT_STS_BUF_RD_RDY_MASK 0x02 +#define ARASAN_NAND_INT_STS_BUF_WR_RDY_MASK 0x01 +#define ARASAN_NAND_INT_STS_XFR_CMPLT_MASK 0x04 + +#define ARASAN_NAND_PKT_REG_PKT_CNT_MASK 0xFFF000 +#define ARASAN_NAND_PKT_REG_PKT_SIZE_MASK 0x7FF +#define ARASAN_NAND_PKT_REG_PKT_CNT_SHFT 12 + +#define ARASAN_NAND_ROW_ADDR_CYCL_MASK 0x0F +#define ARASAN_NAND_COL_ADDR_CYCL_MASK 0xF0 +#define ARASAN_NAND_COL_ADDR_CYCL_SHIFT 4 + +#define ARASAN_NAND_PKTSIZE_1K 1024 +#define ARASAN_NAND_PKTSIZE_512 512 + +#define ARASAN_NAND_POLL_TIMEOUT 1000000 +#define ARASAN_NAND_INVALID_ADDR_CYCL 0xFF + +#define ERR_ADDR_CYCLE -1 +#define READ_BUFF_SIZE 0x4000 + +static struct arasan_nand_command_format *curr_cmd; + +typedef enum { + NAND_ADDR_CYCL_NONE, + NAND_ADDR_CYCL_ONE, + NAND_ADDR_CYCL_ROW, + NAND_ADDR_CYCL_COL, + NAND_ADDR_CYCL_BOTH, +} addr_cycles_t; + +static struct arasan_nand_command_format arasan_nand_commands[] = { + {NAND_CMD_READ0, NAND_CMD_READSTART, NAND_ADDR_CYCL_BOTH, + ARASAN_PROG_RD_MASK}, + {NAND_CMD_RNDOUT, NAND_CMD_RNDOUTSTART, NAND_ADDR_CYCL_COL, + ARASAN_PROG_RD_MASK}, + {NAND_CMD_READID, NAND_CMD_NONE, NAND_ADDR_CYCL_ONE, + ARASAN_PROG_RD_ID_MASK}, + {NAND_CMD_STATUS, NAND_CMD_NONE, NAND_ADDR_CYCL_NONE, + ARASAN_PROG_RD_STS_MASK}, + {NAND_CMD_SEQIN, NAND_CMD_PAGEPROG, NAND_ADDR_CYCL_BOTH, + ARASAN_PROG_PG_PROG_MASK}, + {NAND_CMD_RNDIN, NAND_CMD_NONE, NAND_ADDR_CYCL_COL, + ARASAN_PROG_CHNG_ROWADR_END_MASK}, + {NAND_CMD_ERASE1, NAND_CMD_ERASE2, NAND_ADDR_CYCL_ROW, + ARASAN_PROG_BLK_ERS_MASK}, + {NAND_CMD_RESET, NAND_CMD_NONE, NAND_ADDR_CYCL_NONE, + ARASAN_PROG_RST_MASK}, + {NAND_CMD_PARAM, NAND_CMD_NONE, NAND_ADDR_CYCL_ONE, + ARASAN_PROG_RD_PARAM_PG_MASK}, + {NAND_CMD_GET_FEATURES, NAND_CMD_NONE, NAND_ADDR_CYCL_ONE, + ARASAN_PROG_GET_FTRS_MASK}, + {NAND_CMD_SET_FEATURES, NAND_CMD_NONE, NAND_ADDR_CYCL_ONE, + ARASAN_PROG_SET_FTRS_MASK}, + {NAND_CMD_NONE, NAND_CMD_NONE, NAND_ADDR_CYCL_NONE, 0}, +}; + +struct arasan_ecc_matrix { + u32 pagesize; + u8 ecc_codeword_size; + u8 eccbits; + u8 slcmlc; + u16 eccaddr; + u16 eccsize; +}; + +static const struct arasan_ecc_matrix ecc_matrix[] = { + {512, 9, 1, 0, 0x20D, 0x3}, + {512, 9, 4, 1, 0x209, 0x7}, + {512, 9, 8, 1, 0x203, 0xD}, + /* + * 2K byte page + */ + {2048, 9, 1, 0, 0x834, 0xC}, + {2048, 9, 4, 1, 0x826, 0x1A}, + {2048, 9, 8, 1, 0x80c, 0x34}, + {2048, 9, 12, 1, 0x822, 0x4E}, + {2048, 9, 16, 1, 0x808, 0x68}, + {2048, 10, 24, 1, 0x81c, 0x54}, + /* + * 4K byte page + */ + {4096, 9, 1, 0, 0x1068, 0x18}, + {4096, 9, 4, 1, 0x104c, 0x34}, + {4096, 9, 8, 1, 0x1018, 0x68}, + {4096, 9, 12, 1, 0x1044, 0x9C}, + {4096, 9, 16, 1, 0x1010, 0xD0}, + {4096, 10, 24, 1, 0x1038, 0xA8}, + /* + * 8K byte page + */ + {8192, 9, 1, 0, 0x20d0, 0x30}, + {8192, 9, 4, 1, 0x2098, 0x68}, + {8192, 9, 8, 1, 0x2030, 0xD0}, + {8192, 9, 12, 1, 0x2088, 0x138}, + {8192, 9, 16, 1, 0x2020, 0x1A0}, + {8192, 24, 10, 1, 0x2070, 0x150}, + /* + * 16K byte page + */ + {16384, 9, 1, 0, 0x4460, 0x60}, + {16384, 9, 4, 1, 0x43f0, 0xD0}, + {16384, 9, 8, 1, 0x4320, 0x1A0}, + {16384, 9, 12, 1, 0x4250, 0x270}, + {16384, 9, 16, 1, 0x4180, 0x340}, + {16384, 10, 24, 1, 0x4220, 0x2A0} +}; + +static u8 buf_data[READ_BUFF_SIZE]; +static u32 buf_index = 0; + +static struct nand_ecclayout nand_oob; + +static struct nand_chip nand_chip[CONFIG_SYS_MAX_NAND_DEVICE]; + +static void arasan_nand_select_chip(struct mtd_info *mtd, int chip) +{ +} + +static void arasan_nand_enable_ecc(void) +{ + u32 reg_val; + + reg_val = readl(&arasan_nand_base->cmd_reg); + reg_val |= ARASAN_NAND_CMD_ECC_ON_MASK; + + writel(reg_val, &arasan_nand_base->cmd_reg); +} + +static u8 arasan_nand_get_addrcycle(struct mtd_info *mtd) +{ + u8 addrcycles; + struct nand_chip *chip = mtd->priv; + + switch (curr_cmd->addr_cycles) { + case NAND_ADDR_CYCL_NONE: + addrcycles = 0; + break; + case NAND_ADDR_CYCL_ONE: + addrcycles = 1; + break; + case NAND_ADDR_CYCL_ROW: + addrcycles = chip->onfi_params.addr_cycles & + ARASAN_NAND_ROW_ADDR_CYCL_MASK; + break; + case NAND_ADDR_CYCL_COL: + addrcycles = (chip->onfi_params.addr_cycles & + ARASAN_NAND_COL_ADDR_CYCL_MASK) >> + ARASAN_NAND_COL_ADDR_CYCL_SHIFT; + break; + case NAND_ADDR_CYCL_BOTH: + addrcycles = chip->onfi_params.addr_cycles & + ARASAN_NAND_ROW_ADDR_CYCL_MASK; + addrcycles += (chip->onfi_params.addr_cycles & + ARASAN_NAND_COL_ADDR_CYCL_MASK) >> + ARASAN_NAND_COL_ADDR_CYCL_SHIFT; + break; + default: + addrcycles = ARASAN_NAND_INVALID_ADDR_CYCL; + break; + } + return addrcycles; +} + +static int arasan_nand_read_page(struct mtd_info *mtd, u8 *buf, u32 size) +{ + struct nand_chip *chip = mtd->priv; + u32 reg_val, i, pktsize, pktnum; + u32 *bufptr = (u32 *)buf; + u32 timeout; + u32 rdcount = 0; + u8 addr_cycles; + + if (chip->ecc_step_ds >= ARASAN_NAND_PKTSIZE_1K) + pktsize = ARASAN_NAND_PKTSIZE_1K; + else + pktsize = ARASAN_NAND_PKTSIZE_512; + + if (size % pktsize) + pktnum = size/pktsize + 1; + else + pktnum = size/pktsize; + + reg_val = readl(&arasan_nand_base->intsts_enr); + reg_val |= ARASAN_NAND_INT_STS_ERR_EN_MASK | + ARASAN_NAND_INT_STS_MUL_BIT_ERR_MASK; + writel(reg_val, &arasan_nand_base->intsts_enr); + + reg_val = readl(&arasan_nand_base->pkt_reg); + reg_val &= ~(ARASAN_NAND_PKT_REG_PKT_CNT_MASK | + ARASAN_NAND_PKT_REG_PKT_SIZE_MASK); + reg_val |= (pktnum << ARASAN_NAND_PKT_REG_PKT_CNT_SHFT) | + pktsize; + writel(reg_val, &arasan_nand_base->pkt_reg); + + arasan_nand_enable_ecc(); + addr_cycles = arasan_nand_get_addrcycle(mtd); + if (addr_cycles == ARASAN_NAND_INVALID_ADDR_CYCL) + return ERR_ADDR_CYCLE; + + writel((NAND_CMD_RNDOUTSTART << ARASAN_NAND_CMD_CMD2_SHIFT) | + NAND_CMD_RNDOUT |(addr_cycles << + ARASAN_NAND_CMD_ADDR_CYCL_SHIFT), + &arasan_nand_base->ecc_sprcmd_reg); + writel(curr_cmd->pgm, &arasan_nand_base->pgm_reg); + + while (rdcount < pktnum) { + timeout = ARASAN_NAND_POLL_TIMEOUT; + while (!(readl(&arasan_nand_base->intsts_reg) & + ARASAN_NAND_INT_STS_BUF_RD_RDY_MASK) && timeout) { + udelay(1); + timeout--; + } + if (!timeout) { + puts("arasan_read_page: timedout:Buff RDY\n"); + return -ETIMEDOUT; + } + + rdcount++; + + if (pktnum == rdcount) { + reg_val = readl(&arasan_nand_base->intsts_enr); + reg_val |= ARASAN_NAND_INT_STS_XFR_CMPLT_MASK; + writel(reg_val, &arasan_nand_base->intsts_enr); + } else { + reg_val = readl(&arasan_nand_base->intsts_enr); + writel(reg_val | ARASAN_NAND_INT_STS_BUF_RD_RDY_MASK, + &arasan_nand_base->intsts_enr); + } + reg_val = readl(&arasan_nand_base->intsts_reg); + writel(reg_val | ARASAN_NAND_INT_STS_BUF_RD_RDY_MASK, + &arasan_nand_base->intsts_reg); + + for (i = 0; i < pktsize/4; i++) + bufptr[i] = readl(&arasan_nand_base->buf_dataport); + + + bufptr += pktsize/4; + + if (rdcount >= pktnum) + break; + + writel(ARASAN_NAND_INT_STS_BUF_RD_RDY_MASK, + &arasan_nand_base->intsts_enr); + } + + timeout = ARASAN_NAND_POLL_TIMEOUT; + + while (!(readl(&arasan_nand_base->intsts_reg) & + ARASAN_NAND_INT_STS_XFR_CMPLT_MASK) && timeout) { + udelay(1); + timeout--; + } + if (!timeout) { + puts("arasan rd_page timedout:Xfer CMPLT\n"); + return -ETIMEDOUT; + } + + reg_val = readl(&arasan_nand_base->intsts_enr); + writel(reg_val | ARASAN_NAND_INT_STS_XFR_CMPLT_MASK, + &arasan_nand_base->intsts_enr); + reg_val = readl(&arasan_nand_base->intsts_reg); + writel(reg_val | ARASAN_NAND_INT_STS_XFR_CMPLT_MASK, + &arasan_nand_base->intsts_reg); + + if (readl(&arasan_nand_base->intsts_reg) & + ARASAN_NAND_INT_STS_MUL_BIT_ERR_MASK) { + printf("arasan rd_page:sbiterror\n"); + return -1; + } + + if (readl(&arasan_nand_base->intsts_reg) & + ARASAN_NAND_INT_STS_ERR_EN_MASK) { + mtd->ecc_stats.failed++; + printf("arasan rd_page:multibiterror\n"); + return -1; + } + + return 0; +} + +static int arasan_nand_read_page_hwecc(struct mtd_info *mtd, + struct nand_chip *chip, u8 *buf, int oob_required, int page) +{ + int status; + + status = arasan_nand_read_page(mtd, buf, (mtd->writesize)); + + if (oob_required) + chip->ecc.read_oob(mtd, chip, page); + + return status; +} + +static void arasan_nand_fill_tx(const u8 *buf, int len) +{ + u32 __iomem *nand = (u32 __iomem *)&arasan_nand_base->buf_dataport; + + if (((unsigned long)buf & 0x3) != 0) { + if (((unsigned long)buf & 0x1) != 0) { + if (len) { + writeb(*buf, nand); + buf += 1; + len--; + } + } + + if (((unsigned long)buf & 0x3) != 0) { + if (len >= 2) { + writew(*(u16 *)buf, nand); + buf += 2; + len -= 2; + } + } + } + + while (len >= 4) { + writel(*(u32 *)buf, nand); + buf += 4; + len -= 4; + } + + if (len) { + if (len >= 2) { + writew(*(u16 *)buf, nand); + buf += 2; + len -= 2; + } + + if (len) + writeb(*buf, nand); + } +} + +static int arasan_nand_write_page_hwecc(struct mtd_info *mtd, + struct nand_chip *chip, const u8 *buf, int oob_required) +{ + u32 reg_val, i, pktsize, pktnum; + const u32 *bufptr = (u32 *)buf; + u32 timeout = ARASAN_NAND_POLL_TIMEOUT; + u32 size = mtd->writesize; + u32 rdcount = 0; + u8 column_addr_cycles; + struct arasan_nand_info *nand = chip->priv; + + if (chip->ecc_step_ds >= ARASAN_NAND_PKTSIZE_1K) + pktsize = ARASAN_NAND_PKTSIZE_1K; + else + pktsize = ARASAN_NAND_PKTSIZE_512; + + if (size % pktsize) + pktnum = size/pktsize + 1; + else + pktnum = size/pktsize; + + reg_val = readl(&arasan_nand_base->pkt_reg); + reg_val &= ~(ARASAN_NAND_PKT_REG_PKT_CNT_MASK | + ARASAN_NAND_PKT_REG_PKT_SIZE_MASK); + reg_val |= (pktnum << ARASAN_NAND_PKT_REG_PKT_CNT_SHFT) | pktsize; + writel(reg_val, &arasan_nand_base->pkt_reg); + + arasan_nand_enable_ecc(); + column_addr_cycles = (chip->onfi_params.addr_cycles & + ARASAN_NAND_COL_ADDR_CYCL_MASK) >> + ARASAN_NAND_COL_ADDR_CYCL_SHIFT; + writel((NAND_CMD_RNDIN | (column_addr_cycles << 28)), + &arasan_nand_base->ecc_sprcmd_reg); + writel(curr_cmd->pgm, &arasan_nand_base->pgm_reg); + + while (rdcount < pktnum) { + timeout = ARASAN_NAND_POLL_TIMEOUT; + while (!(readl(&arasan_nand_base->intsts_reg) & + ARASAN_NAND_INT_STS_BUF_WR_RDY_MASK) && timeout) { + udelay(1); + timeout--; + } + + if (!timeout) { + puts("arasan_write_page: timedout:Buff RDY\n"); + return -ETIMEDOUT; + } + + rdcount++; + + if (pktnum == rdcount) { + reg_val = readl(&arasan_nand_base->intsts_enr); + reg_val |= ARASAN_NAND_INT_STS_XFR_CMPLT_MASK; + writel(reg_val, &arasan_nand_base->intsts_enr); + } else { + reg_val = readl(&arasan_nand_base->intsts_enr); + writel(reg_val | ARASAN_NAND_INT_STS_BUF_WR_RDY_MASK, + &arasan_nand_base->intsts_enr); + } + + reg_val = readl(&arasan_nand_base->intsts_reg); + writel(reg_val | ARASAN_NAND_INT_STS_BUF_WR_RDY_MASK, + &arasan_nand_base->intsts_reg); + + for (i = 0; i < pktsize/4; i++) + writel(bufptr[i], &arasan_nand_base->buf_dataport); + + bufptr += pktsize/4; + + if (rdcount >= pktnum) + break; + + writel(ARASAN_NAND_INT_STS_BUF_WR_RDY_MASK, + &arasan_nand_base->intsts_enr); + } + + timeout = ARASAN_NAND_POLL_TIMEOUT; + + while (!(readl(&arasan_nand_base->intsts_reg) & + ARASAN_NAND_INT_STS_XFR_CMPLT_MASK) && timeout) { + udelay(1); + timeout--; + } + if (!timeout) { + puts("arasan write_page timedout:Xfer CMPLT\n"); + return -ETIMEDOUT; + } + + reg_val = readl(&arasan_nand_base->intsts_enr); + writel(reg_val | ARASAN_NAND_INT_STS_XFR_CMPLT_MASK, + &arasan_nand_base->intsts_enr); + reg_val = readl(&arasan_nand_base->intsts_reg); + writel(reg_val | ARASAN_NAND_INT_STS_XFR_CMPLT_MASK, + &arasan_nand_base->intsts_reg); + + if (oob_required) + chip->ecc.write_oob(mtd, chip, nand->page); + + return 0; +} + +static int arasan_nand_read_oob(struct mtd_info *mtd, struct nand_chip *chip, + int page) +{ + chip->cmdfunc(mtd, NAND_CMD_READOOB, 0, page); + chip->read_buf(mtd, chip->oob_poi, (mtd->oobsize)); + + return 0; +} + +static int arasan_nand_write_oob(struct mtd_info *mtd, struct nand_chip *chip, + int page) +{ + int status = 0; + const u8 *buf = chip->oob_poi; + + chip->cmdfunc(mtd, NAND_CMD_SEQIN, mtd->writesize, page); + chip->write_buf(mtd, buf, mtd->oobsize); + + return status; +} + +static int arasan_nand_reset(struct arasan_nand_command_format *curr_cmd) +{ + u32 timeout = ARASAN_NAND_POLL_TIMEOUT; + u32 cmd_reg = 0; + + writel(ARASAN_NAND_INT_STS_XFR_CMPLT_MASK, + &arasan_nand_base->intsts_enr); + cmd_reg = readl(&arasan_nand_base->cmd_reg); + cmd_reg &= ~ARASAN_NAND_CMD_CMD12_MASK; + + cmd_reg |= curr_cmd->cmd1 | + (curr_cmd->cmd2 << ARASAN_NAND_CMD_CMD2_SHIFT); + writel(cmd_reg, &arasan_nand_base->cmd_reg); + writel(curr_cmd->pgm, &arasan_nand_base->pgm_reg); + + while (!(readl(&arasan_nand_base->intsts_reg) & + ARASAN_NAND_INT_STS_XFR_CMPLT_MASK) && timeout) { + udelay(1); + timeout--; + } + if (!timeout) { + printf("ERROR:%s timedout\n", __func__); + return -ETIMEDOUT; + } + + writel(ARASAN_NAND_INT_STS_XFR_CMPLT_MASK, + &arasan_nand_base->intsts_enr); + + writel(ARASAN_NAND_INT_STS_XFR_CMPLT_MASK, + &arasan_nand_base->intsts_reg); + + return 0; +} + +static u8 arasan_nand_page(struct mtd_info *mtd) +{ + u8 page_val = 0; + + switch (mtd->writesize) { + case 512: + page_val = 0; + break; + case 2048: + page_val = 1; + break; + case 4096: + page_val = 2; + break; + case 8192: + page_val = 3; + break; + case 16384: + page_val = 4; + break; + case 1024: + page_val = 5; + break; + default: + printf("%s:Pagesize>16K\n",__func__); + break; + } + + return page_val; +} + +static int arasan_nand_send_wrcmd(struct arasan_nand_command_format *curr_cmd, + int column, int page_addr, struct mtd_info *mtd) +{ + u32 reg_val, page; + u8 page_val, addr_cycles; + + writel(ARASAN_NAND_INT_STS_BUF_WR_RDY_MASK, + &arasan_nand_base->intsts_enr); + reg_val = readl(&arasan_nand_base->cmd_reg); + reg_val &= ~ARASAN_NAND_CMD_CMD12_MASK; + reg_val |= curr_cmd->cmd1 | + (curr_cmd->cmd2 << ARASAN_NAND_CMD_CMD2_SHIFT); + if (curr_cmd->cmd1 == NAND_CMD_SEQIN) { + reg_val &= ~ARASAN_NAND_CMD_PG_SIZE_MASK; + page_val = arasan_nand_page(mtd); + reg_val |= (page_val << ARASAN_NAND_CMD_PG_SIZE_SHIFT); + } + + reg_val &= ~ARASAN_NAND_CMD_ADDR_CYCL_MASK; + addr_cycles = arasan_nand_get_addrcycle(mtd); + + if(addr_cycles == ARASAN_NAND_INVALID_ADDR_CYCL) + return ERR_ADDR_CYCLE; + + reg_val |= (addr_cycles << + ARASAN_NAND_CMD_ADDR_CYCL_SHIFT); + writel(reg_val, &arasan_nand_base->cmd_reg); + + if (page_addr == -1) + page_addr = 0; + + page = (page_addr << ARASAN_NAND_MEM_ADDR1_PAGE_SHIFT) & + ARASAN_NAND_MEM_ADDR1_PAGE_MASK; + column &= ARASAN_NAND_MEM_ADDR1_COL_MASK; + writel(page|column, &arasan_nand_base->memadr_reg1); + + reg_val = readl(&arasan_nand_base->memadr_reg2); + reg_val &= ~ARASAN_NAND_MEM_ADDR2_PAGE_MASK; + reg_val |= (page_addr >> ARASAN_NAND_MEM_ADDR1_PAGE_SHIFT); + writel(reg_val, &arasan_nand_base->memadr_reg2); + reg_val = readl(&arasan_nand_base->memadr_reg2); + reg_val &= ~ARASAN_NAND_MEM_ADDR2_CS_MASK; + writel(reg_val, &arasan_nand_base->memadr_reg2); + + return 0; +} + +static void arasan_nand_write_buf(struct mtd_info *mtd, const u8 *buf, int len) +{ + u32 reg_val; + u32 timeout = ARASAN_NAND_POLL_TIMEOUT; + + reg_val = readl(&arasan_nand_base->pkt_reg); + reg_val &= ~(ARASAN_NAND_PKT_REG_PKT_CNT_MASK | + ARASAN_NAND_PKT_REG_PKT_SIZE_MASK); + + reg_val |= (1 << ARASAN_NAND_PKT_REG_PKT_CNT_SHFT) | len; + writel(reg_val, &arasan_nand_base->pkt_reg); + writel(curr_cmd->pgm, &arasan_nand_base->pgm_reg); + + while (!(readl(&arasan_nand_base->intsts_reg) & + ARASAN_NAND_INT_STS_BUF_WR_RDY_MASK) && timeout) { + udelay(1); + timeout--; + } + + if (!timeout) + puts("ERROR:arasan_nand_write_buf timedout:Buff RDY\n"); + + reg_val = readl(&arasan_nand_base->intsts_enr); + reg_val |= ARASAN_NAND_INT_STS_XFR_CMPLT_MASK; + writel(reg_val, &arasan_nand_base->intsts_enr); + writel(reg_val | ARASAN_NAND_INT_STS_BUF_WR_RDY_MASK, + &arasan_nand_base->intsts_enr); + reg_val = readl(&arasan_nand_base->intsts_reg); + writel(reg_val | ARASAN_NAND_INT_STS_BUF_WR_RDY_MASK, + &arasan_nand_base->intsts_reg); + + arasan_nand_fill_tx(buf, len); + + timeout = ARASAN_NAND_POLL_TIMEOUT; + while (!(readl(&arasan_nand_base->intsts_reg) & + ARASAN_NAND_INT_STS_XFR_CMPLT_MASK) && timeout) { + udelay(1); + timeout--; + } + if (!timeout) + puts("ERROR:arasan_nand_write_buf timedout:Xfer CMPLT\n"); + + writel(readl(&arasan_nand_base->intsts_enr) | + ARASAN_NAND_INT_STS_XFR_CMPLT_MASK, + &arasan_nand_base->intsts_enr); + writel(readl(&arasan_nand_base->intsts_reg) | + ARASAN_NAND_INT_STS_XFR_CMPLT_MASK, + &arasan_nand_base->intsts_reg); +} + +static int arasan_nand_erase(struct arasan_nand_command_format *curr_cmd, + int column, int page_addr, struct mtd_info *mtd) +{ + u32 reg_val, page; + u32 timeout = ARASAN_NAND_POLL_TIMEOUT; + u8 row_addr_cycles; + + writel(ARASAN_NAND_INT_STS_XFR_CMPLT_MASK, + &arasan_nand_base->intsts_enr); + reg_val = readl(&arasan_nand_base->cmd_reg); + reg_val &= ~ARASAN_NAND_CMD_CMD12_MASK; + reg_val |= curr_cmd->cmd1 | + (curr_cmd->cmd2 << ARASAN_NAND_CMD_CMD2_SHIFT); + row_addr_cycles = arasan_nand_get_addrcycle(mtd); + + if (row_addr_cycles == ARASAN_NAND_INVALID_ADDR_CYCL) + return ERR_ADDR_CYCLE; + + reg_val &= ~ARASAN_NAND_CMD_ADDR_CYCL_MASK; + reg_val |= (row_addr_cycles << + ARASAN_NAND_CMD_ADDR_CYCL_SHIFT); + + writel(reg_val, &arasan_nand_base->cmd_reg); + + page = (page_addr << ARASAN_NAND_MEM_ADDR1_PAGE_SHIFT) & + ARASAN_NAND_MEM_ADDR1_PAGE_MASK; + column = page_addr & ARASAN_NAND_MEM_ADDR1_COL_MASK; + writel(page | column, &arasan_nand_base->memadr_reg1); + + reg_val = readl(&arasan_nand_base->memadr_reg2); + reg_val &= ~ARASAN_NAND_MEM_ADDR2_PAGE_MASK; + reg_val |= (page_addr >> ARASAN_NAND_MEM_ADDR1_PAGE_SHIFT); + writel(reg_val, &arasan_nand_base->memadr_reg2); + reg_val = readl(&arasan_nand_base->memadr_reg2); + reg_val &= ~ARASAN_NAND_MEM_ADDR2_CS_MASK; + writel(reg_val, &arasan_nand_base->memadr_reg2); + writel(curr_cmd->pgm, &arasan_nand_base->pgm_reg); + + while (!(readl(&arasan_nand_base->intsts_reg) & + ARASAN_NAND_INT_STS_XFR_CMPLT_MASK) && timeout) { + udelay(1); + timeout--; + } + if (!timeout) { + printf("ERROR:%s timedout:Xfer CMPLT\n",__func__); + return -ETIMEDOUT; + } + + reg_val = readl(&arasan_nand_base->intsts_enr); + writel(reg_val | ARASAN_NAND_INT_STS_XFR_CMPLT_MASK, + &arasan_nand_base->intsts_enr); + reg_val = readl(&arasan_nand_base->intsts_reg); + writel(reg_val | ARASAN_NAND_INT_STS_XFR_CMPLT_MASK, + &arasan_nand_base->intsts_reg); + + return 0; +} + +static int arasan_nand_read_status(struct arasan_nand_command_format *curr_cmd, + int column, int page_addr, struct mtd_info *mtd) +{ + u32 reg_val; + u32 timeout = ARASAN_NAND_POLL_TIMEOUT; + u8 addr_cycles; + + writel(ARASAN_NAND_INT_STS_XFR_CMPLT_MASK, + &arasan_nand_base->intsts_enr); + reg_val = readl(&arasan_nand_base->cmd_reg); + reg_val &= ~ARASAN_NAND_CMD_CMD12_MASK; + reg_val |= curr_cmd->cmd1 | + (curr_cmd->cmd2 << ARASAN_NAND_CMD_CMD2_SHIFT); + addr_cycles = arasan_nand_get_addrcycle(mtd); + + if (addr_cycles == ARASAN_NAND_INVALID_ADDR_CYCL) + return ERR_ADDR_CYCLE; + + reg_val &= ~ARASAN_NAND_CMD_ADDR_CYCL_MASK; + reg_val |= (addr_cycles << + ARASAN_NAND_CMD_ADDR_CYCL_SHIFT); + + writel(reg_val, &arasan_nand_base->cmd_reg); + + reg_val = readl(&arasan_nand_base->pkt_reg); + reg_val &= ~(ARASAN_NAND_PKT_REG_PKT_CNT_MASK | + ARASAN_NAND_PKT_REG_PKT_SIZE_MASK); + reg_val |= (1 << ARASAN_NAND_PKT_REG_PKT_CNT_SHFT) | 1; + writel(reg_val, &arasan_nand_base->pkt_reg); + + reg_val = readl(&arasan_nand_base->memadr_reg2); + reg_val &= ~ARASAN_NAND_MEM_ADDR2_CS_MASK; + writel(reg_val, &arasan_nand_base->memadr_reg2); + + writel(curr_cmd->pgm, &arasan_nand_base->pgm_reg); + while (!(readl(&arasan_nand_base->intsts_reg) & + ARASAN_NAND_INT_STS_XFR_CMPLT_MASK) && timeout) { + udelay(1); + timeout--; + } + + if (!timeout) { + printf("ERROR:%s: timedout:Xfer CMPLT\n", __func__); + return -ETIMEDOUT; + } + + reg_val = readl(&arasan_nand_base->intsts_enr); + writel(reg_val | ARASAN_NAND_INT_STS_XFR_CMPLT_MASK, + &arasan_nand_base->intsts_enr); + reg_val = readl(&arasan_nand_base->intsts_reg); + writel(reg_val | ARASAN_NAND_INT_STS_XFR_CMPLT_MASK, + &arasan_nand_base->intsts_reg); + + return 0; +} + +static int arasan_nand_send_rdcmd(struct arasan_nand_command_format *curr_cmd, + int column, int page_addr, struct mtd_info *mtd) +{ + u32 reg_val, addr_cycles, page; + u8 page_val; + + reg_val = readl(&arasan_nand_base->intsts_enr); + writel(reg_val | ARASAN_NAND_INT_STS_BUF_RD_RDY_MASK, + &arasan_nand_base->intsts_enr); + + reg_val = readl(&arasan_nand_base->cmd_reg); + reg_val &= ~ARASAN_NAND_CMD_CMD12_MASK; + reg_val |= curr_cmd->cmd1 | + (curr_cmd->cmd2 << ARASAN_NAND_CMD_CMD2_SHIFT); + + if (curr_cmd->cmd1 == NAND_CMD_RNDOUT || + curr_cmd->cmd1 == NAND_CMD_READ0) { + reg_val &= ~ARASAN_NAND_CMD_PG_SIZE_MASK; + page_val = arasan_nand_page(mtd); + reg_val |= (page_val << ARASAN_NAND_CMD_PG_SIZE_SHIFT); + } + + reg_val &= ~ARASAN_NAND_CMD_ADDR_CYCL_MASK; + + addr_cycles = arasan_nand_get_addrcycle(mtd); + + if (addr_cycles == ARASAN_NAND_INVALID_ADDR_CYCL) + return ERR_ADDR_CYCLE; + + reg_val |= (addr_cycles << 28); + writel(reg_val, &arasan_nand_base->cmd_reg); + + if (page_addr == -1) + page_addr = 0; + + page = (page_addr << ARASAN_NAND_MEM_ADDR1_PAGE_SHIFT) & + ARASAN_NAND_MEM_ADDR1_PAGE_MASK; + column &= ARASAN_NAND_MEM_ADDR1_COL_MASK; + writel(page | column, &arasan_nand_base->memadr_reg1); + + reg_val = readl(&arasan_nand_base->memadr_reg2); + reg_val &= ~ARASAN_NAND_MEM_ADDR2_PAGE_MASK; + reg_val |= (page_addr >> ARASAN_NAND_MEM_ADDR1_PAGE_SHIFT); + writel(reg_val, &arasan_nand_base->memadr_reg2); + + reg_val = readl(&arasan_nand_base->memadr_reg2); + reg_val &= ~ARASAN_NAND_MEM_ADDR2_CS_MASK; + writel(reg_val, &arasan_nand_base->memadr_reg2); + buf_index = 0; + + return 0; +} + +static void arasan_nand_read_buf(struct mtd_info *mtd, u8 *buf, int size) +{ + u32 reg_val, i; + u32 *bufptr = (u32 *)buf; + u32 timeout = ARASAN_NAND_POLL_TIMEOUT; + + reg_val = readl(&arasan_nand_base->pkt_reg); + reg_val &= ~(ARASAN_NAND_PKT_REG_PKT_CNT_MASK | + ARASAN_NAND_PKT_REG_PKT_SIZE_MASK); + reg_val |= (1 << ARASAN_NAND_PKT_REG_PKT_CNT_SHFT) | size; + writel(reg_val, &arasan_nand_base->pkt_reg); + + writel(curr_cmd->pgm, &arasan_nand_base->pgm_reg); + + while (!(readl(&arasan_nand_base->intsts_reg) & + ARASAN_NAND_INT_STS_BUF_RD_RDY_MASK) && timeout) { + udelay(1); + timeout--; + } + + if (!timeout) + puts("ERROR:arasan_nand_read_buf timedout:Buff RDY\n"); + + reg_val = readl(&arasan_nand_base->intsts_enr); + reg_val |= ARASAN_NAND_INT_STS_XFR_CMPLT_MASK; + writel(reg_val, &arasan_nand_base->intsts_enr); + + writel(reg_val | ARASAN_NAND_INT_STS_BUF_RD_RDY_MASK, + &arasan_nand_base->intsts_enr); + reg_val = readl(&arasan_nand_base->intsts_reg); + writel(reg_val | ARASAN_NAND_INT_STS_BUF_RD_RDY_MASK, + &arasan_nand_base->intsts_reg); + + buf_index = 0; + for (i = 0; i < size / 4; i++) + bufptr[i] = readl(&arasan_nand_base->buf_dataport); + + if (size & 0x03) + bufptr[i] = readl(&arasan_nand_base->buf_dataport); + + timeout = ARASAN_NAND_POLL_TIMEOUT; + + while (!(readl(&arasan_nand_base->intsts_reg) & + ARASAN_NAND_INT_STS_XFR_CMPLT_MASK) && timeout) { + udelay(1); + timeout--; + } + + if (!timeout) + puts("ERROR:arasan_nand_read_buf timedout:Xfer CMPLT\n"); + + reg_val = readl(&arasan_nand_base->intsts_enr); + writel(reg_val | ARASAN_NAND_INT_STS_XFR_CMPLT_MASK, + &arasan_nand_base->intsts_enr); + reg_val = readl(&arasan_nand_base->intsts_reg); + writel(reg_val | ARASAN_NAND_INT_STS_XFR_CMPLT_MASK, + &arasan_nand_base->intsts_reg); +} + +static u8 arasan_nand_read_byte(struct mtd_info *mtd) +{ + struct nand_chip *chip = mtd->priv; + u32 size; + u8 val; + struct nand_onfi_params *p; + + if (buf_index == 0) { + p = &chip->onfi_params; + if (curr_cmd->cmd1 == NAND_CMD_READID) + size = 4; + else if (curr_cmd->cmd1 == NAND_CMD_PARAM) + size = sizeof(struct nand_onfi_params); + else if (curr_cmd->cmd1 == NAND_CMD_RNDOUT) + size = le16_to_cpu(p->ext_param_page_length) * 16; + else if (curr_cmd->cmd1 == NAND_CMD_GET_FEATURES) + size = 4; + else if (curr_cmd->cmd1 == NAND_CMD_STATUS) + return readb(&arasan_nand_base->flash_sts_reg); + else + size = 8; + chip->read_buf(mtd, &buf_data[0], size); + } + + val = *(&buf_data[0] + buf_index); + buf_index++; + + return val; +} + +static void arasan_nand_cmd_function(struct mtd_info *mtd, unsigned int command, + int column, int page_addr) +{ + u32 i, ret = 0; + struct nand_chip *chip = mtd->priv; + struct arasan_nand_info *nand = chip->priv; + + curr_cmd = NULL; + writel(ARASAN_NAND_INT_STS_XFR_CMPLT_MASK, + &arasan_nand_base->intsts_enr); + + if ((command == NAND_CMD_READOOB) && + (mtd->writesize > 512)) { + column += mtd->writesize; + command = NAND_CMD_READ0; + } + + /* Get the command format */ + for (i = 0; (arasan_nand_commands[i].cmd1 != NAND_CMD_NONE || + arasan_nand_commands[i].cmd2 != NAND_CMD_NONE); i++) { + if (command == arasan_nand_commands[i].cmd1) { + curr_cmd = &arasan_nand_commands[i]; + break; + } + } + + if (curr_cmd == NULL) { + printf("Unsupported Command; 0x%x\n", command); + return; + } + + if (curr_cmd->cmd1 == NAND_CMD_RESET) + ret = arasan_nand_reset(curr_cmd); + + if ((curr_cmd->cmd1 == NAND_CMD_READID) || + (curr_cmd->cmd1 == NAND_CMD_PARAM) || + (curr_cmd->cmd1 == NAND_CMD_RNDOUT) || + (curr_cmd->cmd1 == NAND_CMD_GET_FEATURES) || + (curr_cmd->cmd1 == NAND_CMD_READ0)) + ret = arasan_nand_send_rdcmd(curr_cmd, column, page_addr, mtd); + + if ((curr_cmd->cmd1 == NAND_CMD_SET_FEATURES) || + (curr_cmd->cmd1 == NAND_CMD_SEQIN)) { + nand->page = page_addr; + ret = arasan_nand_send_wrcmd(curr_cmd, column, page_addr, mtd); + } + + if (curr_cmd->cmd1 == NAND_CMD_ERASE1) + ret = arasan_nand_erase(curr_cmd, column, page_addr, mtd); + + if (curr_cmd->cmd1 == NAND_CMD_STATUS) + ret = arasan_nand_read_status(curr_cmd, column, page_addr, mtd); + + if (ret != 0) + printf("ERROR:%s:command:0x%x\n", __func__, curr_cmd->cmd1); + +} + +static void arasan_nand_ecc_init(struct mtd_info *mtd) +{ + u32 found = 0; + u8 bchmodeval = 0; + u32 regval, eccpos_start, i; + struct nand_chip *nand_chip = mtd->priv; + + for (i = 0; i < ARRAY_SIZE(ecc_matrix);i++) { + if ((ecc_matrix[i].pagesize == mtd->writesize) && + ((1 << ecc_matrix[i].ecc_codeword_size) >= + nand_chip->ecc_step_ds)) { + if (ecc_matrix[i].eccbits >= + nand_chip->ecc_strength_ds) { + found = i; + break; + } + found = i; + } + } + + if (found) { + regval = ecc_matrix[i].eccaddr | (ecc_matrix[i].eccsize << 16) | + (ecc_matrix[i].slcmlc << 27); + writel(regval, &arasan_nand_base->ecc_reg); + + if (ecc_matrix[i].slcmlc) { + switch (ecc_matrix[i].eccbits) { + case 16: + bchmodeval = 0x0; + break; + case 12: + bchmodeval = 0x1; + break; + case 8: + bchmodeval = 0x2; + break; + case 4: + bchmodeval = 0x3; + break; + case 24: + bchmodeval = 0x4; + break; + default: + break; + } + regval = readl(&arasan_nand_base->memadr_reg2); + regval &= ~ARASAN_NAND_MEM_ADDR2_BCH_MASK; + regval |= (bchmodeval << + ARASAN_NAND_MEM_ADDR2_BCH_SHIFT); + writel(regval, &arasan_nand_base->memadr_reg2); + } + + nand_oob.eccbytes = ecc_matrix[i].eccsize; + eccpos_start = mtd->oobsize - nand_oob.eccbytes; + + for (i = 0; i < nand_oob.eccbytes; i++) + nand_oob.eccpos[i] = eccpos_start + i; + + nand_oob.oobfree[0].offset = 2; + nand_oob.oobfree[0].length = eccpos_start - 2; + + if (ecc_matrix[i].eccbits == 24) + nand_chip->ecc.size = 1024; + else + nand_chip->ecc.size = 512; + + nand_chip->ecc.bytes = ecc_matrix[i].eccsize; + nand_chip->ecc.layout = &nand_oob; + } +} + +static int arasan_nand_init(struct nand_chip *nand_chip, int devnum) +{ + struct arasan_nand_info *nand; + struct mtd_info *mtd; + int err = -1; + + nand = calloc(1, sizeof(struct arasan_nand_info)); + if (!nand) { + printf("%s: failed to allocate\n", __func__); + return err; + } + + nand->nand_base = (void *)ARASAN_NAND_BASEADDR; + mtd = &nand_info[0]; + nand_chip->priv = nand; + mtd->priv = nand_chip; + + /* Set address of NAND IO lines */ + nand_chip->IO_ADDR_R = (void *)&arasan_nand_base->buf_dataport; + nand_chip->IO_ADDR_W = (void *)&arasan_nand_base->buf_dataport; + + /* Set the driver entry points for MTD */ + nand_chip->cmdfunc = arasan_nand_cmd_function; + nand_chip->select_chip = arasan_nand_select_chip; + nand_chip->read_byte = arasan_nand_read_byte; + + /* Buffer read/write routines */ + nand_chip->read_buf = arasan_nand_read_buf; + nand_chip->write_buf = arasan_nand_write_buf; + nand_chip->bbt_options = NAND_BBT_USE_FLASH; + + writel(0x0, &arasan_nand_base->cmd_reg); + writel(0x0, &arasan_nand_base->pgm_reg); + + /* first scan to find the device and get the page size */ + if (nand_scan_ident(mtd, 1, NULL)) { + printf("%s: nand_scan_ident failed\n", __func__); + goto fail; + } + + mtd->size = nand_chip->chipsize; + + nand_chip->ecc.mode = NAND_ECC_HW; + nand_chip->ecc.strength = 1; + nand_chip->ecc.hwctl = NULL; + nand_chip->ecc.read_page = arasan_nand_read_page_hwecc; + nand_chip->ecc.write_page = arasan_nand_write_page_hwecc; + nand_chip->ecc.read_oob = arasan_nand_read_oob; + nand_chip->ecc.write_oob = arasan_nand_write_oob; + + arasan_nand_ecc_init(mtd); + + if (nand_scan_tail(mtd)) { + printf("%s: nand_scan_tail failed\n", __func__); + goto fail; + } + if (nand_register(devnum)) { + printf("Nand Register Fail\n"); + goto fail; + } + + return 0; +fail: + free(nand); + return err; +} + +void board_nand_init(void) +{ + struct nand_chip *nand = &nand_chip[0]; + + if (arasan_nand_init(nand, 0)) + puts("NAND init failed\n"); +}
Changes from v1:
- Arasan NAND Flash Controller Driver
- Copyright (C) 2014 - 2015 Xilinx, Inc.
- SPDX-License-Identifier: GPL-2.0
Usually U-Boot contributions are requested to be "GPL-2.0+". Is there any particular reason why this can't be?
- u32 pagesize;
- u8 ecc_codeword_size;
- u8 eccbits;
- u8 slcmlc;
- u16 eccaddr;
- u16 eccsize;
- {512, 9, 1, 0, 0x20D, 0x3},
- {512, 9, 4, 1, 0x209, 0x7},
- {512, 9, 8, 1, 0x203, 0xD},
* 2K byte page
- {2048, 9, 1, 0, 0x834, 0xC},
- {2048, 9, 4, 1, 0x826, 0x1A},
- {2048, 9, 8, 1, 0x80c, 0x34},
- {2048, 9, 12, 1, 0x822, 0x4E},
- {2048, 9, 16, 1, 0x808, 0x68},
- {2048, 10, 24, 1, 0x81c, 0x54},
* 4K byte page
- {4096, 9, 1, 0, 0x1068, 0x18},
- {4096, 9, 4, 1, 0x104c, 0x34},
- {4096, 9, 8, 1, 0x1018, 0x68},
- {4096, 9, 12, 1, 0x1044, 0x9C},
- {4096, 9, 16, 1, 0x1010, 0xD0},
- {4096, 10, 24, 1, 0x1038, 0xA8},
* 8K byte page
- {8192, 9, 1, 0, 0x20d0, 0x30},
- {8192, 9, 4, 1, 0x2098, 0x68},
- {8192, 9, 8, 1, 0x2030, 0xD0},
- {8192, 9, 12, 1, 0x2088, 0x138},
- {8192, 9, 16, 1, 0x2020, 0x1A0},
- {8192, 24, 10, 1, 0x2070, 0x150},
* 16K byte page
- {16384, 9, 1, 0, 0x4460, 0x60},
- {16384, 9, 4, 1, 0x43f0, 0xD0},
- {16384, 9, 8, 1, 0x4320, 0x1A0},
- {16384, 9, 12, 1, 0x4250, 0x270},
- {16384, 9, 16, 1, 0x4180, 0x340},
- {16384, 10, 24, 1, 0x4220, 0x2A0}
That last line of the 8k section looks suspicious with 24, 10 being reversed compared to the others.
- u32 __iomem *nand = (u32 __iomem *)&arasan_nand_base->buf_dataport;
Unnecessary cast.
- u32 reg_val, i, pktsize, pktnum;
- const u32 *bufptr = (u32 *)buf;
Cast is missing "const".
- u32 found = 0;
- u8 bchmodeval = 0;
- u32 regval, eccpos_start, i;
- struct nand_chip *nand_chip = mtd->priv;
- for (i = 0; i < ARRAY_SIZE(ecc_matrix);i++) {
Space after ;
found = i;
break;
found = i;
- if (found) {
if (!found) return;
...rather than indenting the rest of the function.
Shouldn't there be some sort of warning if you're unable to provide an ECC strength that meets the chips requirement? Or if ECC was not initialized at all?
case 16:
bchmodeval = 0x0;
break;
case 12:
bchmodeval = 0x1;
break;
case 8:
bchmodeval = 0x2;
break;
case 4:
bchmodeval = 0x3;
break;
case 24:
bchmodeval = 0x4;
break;
default:
break;
This is a useless default clause.
Shouldn't there be some sort of error handling there instead of silently using zero?
Or better yet, why isn't bchmodeval a field in struct arasan_ecc_matrix?
else
Why not just use 1 << ecc_matrix[i].ecc_codeword_size?
Why is ecc_codeword_size stored as a logarithm when the only place that uses it turns it back into a byte count?
- struct arasan_nand_info *nand;
- struct mtd_info *mtd;
- int err = -1;
- nand = calloc(1, sizeof(struct arasan_nand_info));
- if (!nand) {
return err;
- nand->nand_base = (void *)ARASAN_NAND_BASEADDR;
You already have arsan_nand_base with the proper cast. Why not use it?
- mtd = &nand_info[0];
- nand_chip->priv = nand;
- mtd->priv = nand_chip;
- /* Set address of NAND IO lines */
- nand_chip->IO_ADDR_R = (void *)&arasan_nand_base->buf_dataport;
- nand_chip->IO_ADDR_W = (void *)&arasan_nand_base->buf_dataport;
Where do these get used?
- /* Set the driver entry points for MTD */
- nand_chip->cmdfunc = arasan_nand_cmd_function;
- nand_chip->select_chip = arasan_nand_select_chip;
- nand_chip->read_byte = arasan_nand_read_byte;
- /* Buffer read/write routines */
- nand_chip->read_buf = arasan_nand_read_buf;
- nand_chip->write_buf = arasan_nand_write_buf;
- nand_chip->bbt_options = NAND_BBT_USE_FLASH;
- writel(0x0, &arasan_nand_base->cmd_reg);
- writel(0x0, &arasan_nand_base->pgm_reg);
- /* first scan to find the device and get the page size */
- if (nand_scan_ident(mtd, 1, NULL)) {
goto fail;
- mtd->size = nand_chip->chipsize;
nand_scan_ident() already takes care of setting mtd->size.
- nand_chip->ecc.mode = NAND_ECC_HW;
- nand_chip->ecc.strength = 1;
- nand_chip->ecc.hwctl = NULL;
- nand_chip->ecc.read_page = arasan_nand_read_page_hwecc;
- nand_chip->ecc.write_page = arasan_nand_write_page_hwecc;
- nand_chip->ecc.read_oob = arasan_nand_read_oob;
- nand_chip->ecc.write_oob = arasan_nand_write_oob;
None of this needs to be after nand_scan_ident(). Why not keep it together with the other nand_chip init?
Why is ecc.strength being set to 1 when other parts of the code make it look like stronger ECC is supported?
-Scott
Changes from v1:
+config NAND_ARASAN
endif
This should go in drivers/mtd/nand/Kconfig.
-Scott
Hi Scott,
-----Original Message----- From: Scott Wood [mailto:scottwood@freescale.com] Sent: Friday, November 06, 2015 10:33 PM To: Siva Durga Prasad Paladugu Cc: u-boot@lists.denx.de; Michal Simek; Siva Durga Prasad Paladugu Subject: Re: [UBOOT PATCH v2 1/2] zynqmp: nand: Add Nand driver support for zynqmp
Changes from v1:
+config NAND_ARASAN
endif
Ok, I will consider it in V2. Do you have any further comments on 2nd patch in the series? If not, please take it up.
Regards, Siva
-Scott
Scott Wood
