[U-Boot] [PATCH v2 1/2] watchdog: driver support for fsl-lsch2
Support watchdog driver for fsl-lsch2. If you want to use it, please enable CONFIG_IMX_WATCHDOG, and CONFIG_HW_WATCHDOG. define CONFIG_WATCHDOG_TIMEOUT_MSECS to set watchdog timeout.
Signed-off-by: Xiaoliang Yang xiaoliang.yang_1@nxp.com --- arch/arm/cpu/armv8/fsl-layerscape/doc/README.lsch2 | 10 ++++++++++ drivers/watchdog/Kconfig | 6 ++++++ drivers/watchdog/Makefile | 2 ++ drivers/watchdog/imx_watchdog.c | 11 +++++++++++ 4 files changed, 29 insertions(+), 0 deletions(-)
diff --git a/arch/arm/cpu/armv8/fsl-layerscape/doc/README.lsch2 b/arch/arm/cpu/armv8/fsl-layerscape/doc/README.lsch2 index a6ef830..87b91eb 100644 --- a/arch/arm/cpu/armv8/fsl-layerscape/doc/README.lsch2 +++ b/arch/arm/cpu/armv8/fsl-layerscape/doc/README.lsch2 @@ -8,3 +8,13 @@ Freescale LayerScape with Chassis Generation 2
This architecture supports Freescale ARMv8 SoCs with Chassis generation 2, for example LS1043A. + +Watchdog support Overview +------------------- +Support watchdog driver for Layerscape. Use following configs to enable it: + #define CONFIG_IMX_WATCHDOG + #define CONFIG_HW_WATCHDOG +Use following config to set watchdog timeout, if this config is not defined, +the default timeout value is 128s which is the maximum. Set 10 seconds for +example: + #define CONFIG_WATCHDOG_TIMEOUT_MSECS 10000 diff --git a/drivers/watchdog/Kconfig b/drivers/watchdog/Kconfig index 148c6a0..a526afd 100644 --- a/drivers/watchdog/Kconfig +++ b/drivers/watchdog/Kconfig @@ -103,4 +103,10 @@ config WDT_CDNS Select this to enable Cadence watchdog timer, which can be found on some Xilinx Microzed Platform.
+config IMX_WATCHDOG + bool "IMX watchdog timer support" + help + Select this to enable IMX watchdog timer, which can be found on + some i.mx and fsl-lsch2 SoCs. + endmenu diff --git a/drivers/watchdog/Makefile b/drivers/watchdog/Makefile index f405f51..159fc11 100644 --- a/drivers/watchdog/Makefile +++ b/drivers/watchdog/Makefile @@ -7,6 +7,8 @@ obj-$(CONFIG_AT91SAM9_WATCHDOG) += at91sam9_wdt.o obj-$(CONFIG_FTWDT010_WATCHDOG) += ftwdt010_wdt.o ifneq (,$(filter $(SOC), mx31 mx35 mx5 mx6 mx7 vf610)) obj-y += imx_watchdog.o +else +obj-$(CONFIG_IMX_WATCHDOG) += imx_watchdog.o endif obj-$(CONFIG_S5P) += s5p_wdt.o obj-$(CONFIG_XILINX_TB_WATCHDOG) += xilinx_tb_wdt.o diff --git a/drivers/watchdog/imx_watchdog.c b/drivers/watchdog/imx_watchdog.c index 3f826d1..3ad4e55 100644 --- a/drivers/watchdog/imx_watchdog.c +++ b/drivers/watchdog/imx_watchdog.c @@ -8,6 +8,13 @@ #include <asm/io.h> #include <watchdog.h> #include <asm/arch/imx-regs.h> +#ifdef CONFIG_FSL_LAYERSCAPE +#ifdef CONFIG_FSL_LSCH3 +#include <asm/arch/immap_lsch3.h> +#elif defined(CONFIG_FSL_LSCH2) +#include <asm/arch/immap_lsch2.h> +#endif +#endif #include <fsl_wdog.h>
#ifdef CONFIG_IMX_WATCHDOG @@ -33,8 +40,12 @@ void hw_watchdog_init(void) #define CONFIG_WATCHDOG_TIMEOUT_MSECS 128000 #endif timeout = (CONFIG_WATCHDOG_TIMEOUT_MSECS / 500) - 1; +#ifdef CONFIG_FSL_LAYERSCAPE + writew((WCR_WDA | WCR_SRS | WCR_WDE) << 8 | timeout, &wdog->wcr); +#else writew(WCR_WDZST | WCR_WDBG | WCR_WDE | WCR_WDT | WCR_SRS | WCR_WDA | SET_WCR_WT(timeout), &wdog->wcr); +#endif /* CONFIG_FSL_LAYERSCAPE*/ hw_watchdog_reset(); } #endif
Add Kconfig support for CONFIG_WATCHDOG_RESET_DISABLE, use this config to disable watchdog reset in imx_watchdog driver, so that the watchdog will not be fed in u-boot.
Signed-off-by: Xiaoliang Yang xiaoliang.yang_1@nxp.com --- arch/arm/cpu/armv8/fsl-layerscape/doc/README.lsch2 | 3 +++ drivers/watchdog/Kconfig | 6 ++++++ drivers/watchdog/imx_watchdog.c | 2 ++ 3 files changed, 11 insertions(+), 0 deletions(-)
diff --git a/arch/arm/cpu/armv8/fsl-layerscape/doc/README.lsch2 b/arch/arm/cpu/armv8/fsl-layerscape/doc/README.lsch2 index 87b91eb..c43a99b 100644 --- a/arch/arm/cpu/armv8/fsl-layerscape/doc/README.lsch2 +++ b/arch/arm/cpu/armv8/fsl-layerscape/doc/README.lsch2 @@ -18,3 +18,6 @@ Use following config to set watchdog timeout, if this config is not defined, the default timeout value is 128s which is the maximum. Set 10 seconds for example: #define CONFIG_WATCHDOG_TIMEOUT_MSECS 10000 +Use following config to disable reset watchdog, so that the watchdog will +not be fed in u-boot: + #define CONFIG_WATCHDOG_RESET_DISABLE diff --git a/drivers/watchdog/Kconfig b/drivers/watchdog/Kconfig index a526afd..1958c17 100644 --- a/drivers/watchdog/Kconfig +++ b/drivers/watchdog/Kconfig @@ -109,4 +109,10 @@ config IMX_WATCHDOG Select this to enable IMX watchdog timer, which can be found on some i.mx and fsl-lsch2 SoCs.
+config WATCHDOG_RESET_DISABLE + bool "Disable reset watchdog" + help + Disable reset watchdog, which can let WATCHDOG_RESET invalid, so + that the watchdog will not be fed in u-boot. + endmenu diff --git a/drivers/watchdog/imx_watchdog.c b/drivers/watchdog/imx_watchdog.c index 3ad4e55..6691ee9 100644 --- a/drivers/watchdog/imx_watchdog.c +++ b/drivers/watchdog/imx_watchdog.c @@ -20,10 +20,12 @@ #ifdef CONFIG_IMX_WATCHDOG void hw_watchdog_reset(void) { +#ifndef CONFIG_WATCHDOG_RESET_DISABLE struct watchdog_regs *wdog = (struct watchdog_regs *)WDOG1_BASE_ADDR;
writew(0x5555, &wdog->wsr); writew(0xaaaa, &wdog->wsr); +#endif /* CONFIG_WATCHDOG_RESET_DISABLE*/ }
v1 -> v2: Because of imx_watchdog.c driver not supports all layerscape SoCs, change to build imx_watchdog.o only when enable IMX_WATCHDOG for fsl-lsch2 SoCs. Add IMX_WATCHDOG in drivers/watchdog/Kconfig. Changes in v2: drivers/watchdog/Kconfig | 6 ++++++ drivers/watchdog/Makefile | 2 ++
- #define CONFIG_IMX_WATCHDOG
- #define CONFIG_HW_WATCHDOG
- #define CONFIG_WATCHDOG_TIMEOUT_MSECS 10000
- bool "IMX watchdog timer support"
- help
It is good to see you convert this macro to Kconfig option. But it is not right to mix these two. You should create a patch before this one to convert this macro to Kconfig (and remove it from whitelist). It shouldn't be hard, I only see 7 files defining this macro. Please make sure you CC maintainers for the Kconfig change.
You said LSCH3 doesn't support this watchdog.
York
Xiaoliang Yang
York Sun
