[U-Boot] [PATCH 1/2] i2c: Drop redundant platform data setting in drivers
The i2c uclass has a default setting for per_child_platdata_auto_alloc_size so drivers do not need to set it. Remove this from drivers to avoid confusion.
drivers/i2c/cros_ec_ldo.c | 1 - drivers/i2c/cros_ec_tunnel.c | 1 - drivers/i2c/intel_i2c.c | 1 - drivers/i2c/muxes/i2c-mux-uclass.c | 1 - drivers/i2c/s3c24x0_i2c.c | 2 -- 5 files changed, 6 deletions(-)
diff --git a/drivers/i2c/cros_ec_ldo.c b/drivers/i2c/cros_ec_ldo.c index b817c61..a4cd660 100644 --- a/drivers/i2c/cros_ec_ldo.c +++ b/drivers/i2c/cros_ec_ldo.c @@ -72,6 +72,5 @@ U_BOOT_DRIVER(cros_ec_ldo) = { .name = "cros_ec_ldo_tunnel", .id = UCLASS_I2C, .of_match = cros_ec_i2c_ids, - .per_child_auto_alloc_size = sizeof(struct dm_i2c_chip), .ops = &cros_ec_i2c_ops, }; diff --git a/drivers/i2c/cros_ec_tunnel.c b/drivers/i2c/cros_ec_tunnel.c index 7ab1fd8..e2c6e44 100644 --- a/drivers/i2c/cros_ec_tunnel.c +++ b/drivers/i2c/cros_ec_tunnel.c @@ -36,6 +36,5 @@ U_BOOT_DRIVER(cros_ec_tunnel) = { .name = "cros_ec_tunnel", .id = UCLASS_I2C, .of_match = cros_ec_i2c_ids, - .per_child_auto_alloc_size = sizeof(struct dm_i2c_chip), .ops = &cros_ec_i2c_ops, }; diff --git a/drivers/i2c/intel_i2c.c b/drivers/i2c/intel_i2c.c index 8b63916..5b7953a 100644 --- a/drivers/i2c/intel_i2c.c +++ b/drivers/i2c/intel_i2c.c @@ -325,7 +325,6 @@ U_BOOT_DRIVER(intel_i2c) = { .name = "i2c_intel", .id = UCLASS_I2C, .of_match = intel_i2c_ids, - .per_child_auto_alloc_size = sizeof(struct dm_i2c_chip), .ops = &intel_i2c_ops, .priv_auto_alloc_size = sizeof(struct intel_i2c), .bind = intel_i2c_bind, diff --git a/drivers/i2c/muxes/i2c-mux-uclass.c b/drivers/i2c/muxes/i2c-mux-uclass.c index 3f52bff..7a698b6 100644 --- a/drivers/i2c/muxes/i2c-mux-uclass.c +++ b/drivers/i2c/muxes/i2c-mux-uclass.c @@ -183,7 +183,6 @@ static const struct dm_i2c_ops i2c_mux_bus_ops = { U_BOOT_DRIVER(i2c_mux_bus) = { .name = "i2c_mux_bus_drv", .id = UCLASS_I2C, - .per_child_auto_alloc_size = sizeof(struct dm_i2c_chip), .ops = &i2c_mux_bus_ops, };
diff --git a/drivers/i2c/s3c24x0_i2c.c b/drivers/i2c/s3c24x0_i2c.c index dc9b661..eab49d0 100644 --- a/drivers/i2c/s3c24x0_i2c.c +++ b/drivers/i2c/s3c24x0_i2c.c @@ -1433,7 +1433,6 @@ U_BOOT_DRIVER(i2c_s3c) = { .id = UCLASS_I2C, .of_match = s3c_i2c_ids, .ofdata_to_platdata = s3c_i2c_ofdata_to_platdata, - .per_child_auto_alloc_size = sizeof(struct dm_i2c_chip), .priv_auto_alloc_size = sizeof(struct s3c24x0_i2c_bus), .ops = &s3c_i2c_ops, }; @@ -1458,7 +1457,6 @@ U_BOOT_DRIVER(hs_i2c) = { .id = UCLASS_I2C, .of_match = exynos_hs_i2c_ids, .ofdata_to_platdata = s3c_i2c_ofdata_to_platdata, - .per_child_auto_alloc_size = sizeof(struct dm_i2c_chip), .priv_auto_alloc_size = sizeof(struct s3c24x0_i2c_bus), .ops = &exynos_hs_i2c_ops, };
If intel_i2c_bind() is called before relocation there is no BSS section available. Use the data section instead, which is always available.
A better fix might be to use global_data, perhaps a new member in x86's struct arch_global_data. Comments welcome.
drivers/i2c/intel_i2c.c | 2 +- 1 file changed, 1 insertion(+), 1 deletion(-)
diff --git a/drivers/i2c/intel_i2c.c b/drivers/i2c/intel_i2c.c index 5b7953a..01badf2 100644 --- a/drivers/i2c/intel_i2c.c +++ b/drivers/i2c/intel_i2c.c @@ -289,7 +289,7 @@ static int intel_i2c_probe(struct udevice *dev)
static int intel_i2c_bind(struct udevice *dev) { - static int num_cards; + static int num_cards __attribute__ ((section(".data"))); char name[20];
/* Create a unique device name for PCI type devices */
Hello Simon,
Am 07.08.2016 um 08:54 schrieb Bin Meng:
Hmm... I see no i2c_bind() in mainline U-Boot drivers/i2c/intel_i2c.c driver ?
Is this patch and also patch: http://patchwork.ozlabs.org/patch/656335/
dependend on another patch(or patchserie) ?
bye, Heiko
Hi Heiko,
On 8 August 2016 at 08:45, Heiko Schocher hs@denx.de wrote:
Hello Simon,
Yes it depends on Stefan's x86 i2c driver. He asked me to take a look. It can be squashed in - will leave this to Stefan.
Hi Simon,
Hello Simon,
I have squashed it in v2 of the SMBus I2C driver patch which will hit the list very soon.
Thanks, Stefan Avoid
Bin Meng
Heiko Schocher
Stefan Roese
