[U-Boot-Users] [PATCH] Resize device tree to allow space for board changes and the chosen node
Current code requires that a compiled device tree have space added to the end to leave room for extra nodes added by board code (and the chosen node). This requires that device tree creators anticipate how much space U-Boot will add to the tree, which is absurd. Ideally, the code would resize and/or relocate the tree when it needed more space, but this would require a systemic change to the fdt code, which is non-trivial. Instead, we resize the tree inside boot_relocate_fdt, reserving either the remainder of the bootmap (in the case where the fdt is inside the bootmap), or adding CFG_FDT_PAD bytes to the size.
Signed-off-by: Andy Fleming afleming@freescale.com --- lib_ppc/bootm.c | 66 ++++++++++++++++++++++++++++++++++++++++++++++++------ 1 files changed, 58 insertions(+), 8 deletions(-)
diff --git a/lib_ppc/bootm.c b/lib_ppc/bootm.c index 9194fd8..85e959a 100644 --- a/lib_ppc/bootm.c +++ b/lib_ppc/bootm.c @@ -51,6 +51,10 @@ static int boot_relocate_fdt (struct lmb *lmb, ulong bootmap_base, #include <asm/cache.h> #endif
+#ifndef CFG_FDT_PAD +#define CFG_FDT_PAD 0x3000 +#endif + DECLARE_GLOBAL_DATA_PTR;
extern int do_reset (cmd_tbl_t *cmdtp, int flag, int argc, char *argv[]); @@ -189,6 +193,44 @@ do_bootm_linux(cmd_tbl_t *cmdtp, int flag, int argc, char *argv[], ft_board_setup(of_flat_tree, gd->bd); #endif } + + /* Fixup the fdt memreserve now that we know how big it is */ + if (of_flat_tree) { + int j; + uint64_t addr, size; + int total = fdt_num_mem_rsv(of_flat_tree); + uint actualsize; + + for (j = 0; j < total; j++) { + fdt_get_mem_rsv(of_flat_tree, j, &addr, &size); + if (addr == (uint64_t)of_flat_tree) { + fdt_del_mem_rsv(of_flat_tree, j); + break; + } + } + + /* Delete the old LMB reservation */ + lmb_free(lmb, of_flat_tree, fdt_totalsize(of_flat_tree)); + + /* Calculate the actual size of the fdt */ + actualsize = fdt_off_dt_strings(of_flat_tree) + + fdt_size_dt_strings(of_flat_tree); + + /* Make it so the fdt ends on a page boundary */ + actualsize = ALIGN(actualsize, 0x1000); + actualsize = actualsize - ((uint)of_flat_tree & 0xfff); + + /* Change the fdt header to reflect the correct size */ + fdt_set_totalsize(of_flat_tree, actualsize); + of_size = actualsize; + + /* Add the new reservation */ + ret = fdt_add_mem_rsv(of_flat_tree, (uint)of_flat_tree, + of_size); + + /* Create a new LMB reservation */ + lmb_reserve(lmb, (ulong)of_flat_tree, of_size); + } #endif /* CONFIG_OF_LIBFDT */
ret = boot_ramdisk_high (lmb, rd_data_start, rd_len, &initrd_start, &initrd_end); @@ -711,22 +753,25 @@ static int boot_relocate_fdt (struct lmb *lmb, ulong bootmap_base, #endif
/* - * The blob must be within CFG_BOOTMAPSZ, - * so we flag it to be copied if it is not. + * The blob needs to be inside the boot mapping. */ - if (fdt_blob >= (char *)CFG_BOOTMAPSZ) + if (fdt_blob < (char *)bootmap_base) relocate = 1;
- of_len = be32_to_cpu (fdt_totalsize (fdt_blob)); + if ((fdt_blob + *of_size + CFG_FDT_PAD) >= + ((char *)CFG_BOOTMAPSZ + bootmap_base)) + relocate = 1;
/* move flattend device tree if needed */ if (relocate) { int err; - ulong of_start; + ulong of_start = 0;
/* position on a 4K boundary before the alloc_current */ + /* Make the fdt as large as possible */ + of_len = *of_size + CFG_FDT_PAD; of_start = lmb_alloc_base(lmb, of_len, 0x1000, - (CFG_BOOTMAPSZ + bootmap_base)); + (CFG_BOOTMAPSZ + bootmap_base));
if (of_start == 0) { puts("device tree - allocation error\n"); @@ -734,7 +779,7 @@ static int boot_relocate_fdt (struct lmb *lmb, ulong bootmap_base, }
debug ("## device tree at 0x%08lX ... 0x%08lX (len=%ld=0x%lX)\n", - (ulong)fdt_blob, (ulong)fdt_blob + of_len - 1, + (ulong)fdt_blob, (ulong)fdt_blob + *of_size - 1, of_len, of_len);
printf (" Loading Device Tree to %08lx, end %08lx ... ", @@ -748,9 +793,14 @@ static int boot_relocate_fdt (struct lmb *lmb, ulong bootmap_base, puts ("OK\n");
*of_flat_tree = (char *)of_start; + *of_size = of_len; } else { *of_flat_tree = fdt_blob; - lmb_reserve(lmb, (ulong)fdt, of_len); + of_len = (CFG_BOOTMAPSZ + bootmap_base) - (ulong)fdt_blob; + lmb_reserve(lmb, (ulong)fdt_blob, of_len); + fdt_set_totalsize(*of_flat_tree, of_len); + + *of_size = of_len; }
Andy Fleming
