[U-Boot] [PATCH] ARM: zynq: Add missing pl353-smc node
DT binding was reviewed in Linux by commit b0b41af12a1b ("dt-bindings: memory: Add pl353 smc controller devicetree binding information") that's why this fragment can be also added to U-Boot repository.
arch/arm/dts/zynq-7000.dtsi | 27 +++++++++++++++++++++++++++ 1 file changed, 27 insertions(+)
diff --git a/arch/arm/dts/zynq-7000.dtsi b/arch/arm/dts/zynq-7000.dtsi index e1b0816a3459..07dfa0d1074f 100644 --- a/arch/arm/dts/zynq-7000.dtsi +++ b/arch/arm/dts/zynq-7000.dtsi @@ -213,6 +213,33 @@ #size-cells = <0>; };
+ smcc: memory-controller@e000e000 { + #address-cells = <1>; + #size-cells = <1>; + status = "disabled"; + clock-names = "memclk", "apb_pclk"; + clocks = <&clkc 11>, <&clkc 44>; + compatible = "arm,pl353-smc-r2p1", "arm,primecell"; + interrupt-parent = <&intc>; + interrupts = <0 18 4>; + ranges ; + reg = <0xe000e000 0x1000>; + nand0: flash@e1000000 { + status = "disabled"; + compatible = "arm,pl353-nand-r2p1"; + reg = <0xe1000000 0x1000000>; + #address-cells = <1>; + #size-cells = <1>; + }; + nor0: flash@e2000000 { + status = "disabled"; + compatible = "cfi-flash"; + reg = <0xe2000000 0x2000000>; + #address-cells = <1>; + #size-cells = <1>; + }; + }; + gem0: ethernet@e000b000 { compatible = "cdns,zynq-gem", "cdns,gem"; reg = <0xe000b000 0x1000>;
po 14. 10. 2019 v 11:30 odesÃlatel Michal Simek michal.simek@xilinx.com napsal:
#size-cells = <1>;
ranges ;
#size-cells = <1>;
#size-cells = <1>;
-- 2.17.1
Applied. M
Michal Simek
Michal Simek
