[U-Boot] [PATCH] tbs2910: Fix error handling in board_mmc_init()
When an invalid USDHC port is passed we should return -EINVAL instead of 0. Also, return the error immediately on fsl_esdhc_initialize() failure.
Based on similar patches by Fabio Estevam for mx6sabresd, mx53loco, wandboard
Signed-off-by: Soeren Moch smoch@web.de -- Cc: Stefano Babic sbabic@denx.de Cc: Fabio Estevam festevam@gmail.com --- board/tbs/tbs2910/tbs2910.c | 13 ++++++------- 1 file changed, 6 insertions(+), 7 deletions(-)
diff --git a/board/tbs/tbs2910/tbs2910.c b/board/tbs/tbs2910/tbs2910.c index daf8ff4..dfa430e 100644 --- a/board/tbs/tbs2910/tbs2910.c +++ b/board/tbs/tbs2910/tbs2910.c @@ -219,15 +219,13 @@ int board_mmc_getcd(struct mmc *mmc)
int board_mmc_init(bd_t *bis) { - s32 status = 0; - int i; - /* * (U-boot device node) (Physical Port) * mmc0 SD2 * mmc1 SD3 * mmc2 eMMC */ + int i, ret; for (i = 0; i < CONFIG_SYS_FSL_USDHC_NUM; i++) { switch (i) { case 0: @@ -251,12 +249,13 @@ int board_mmc_init(bd_t *bis) printf("Warning: you configured more USDHC controllers" "(%d) then supported by the board (%d)\n", i + 1, CONFIG_SYS_FSL_USDHC_NUM); - return status; + return -EINVAL; } - - status |= fsl_esdhc_initialize(bis, &usdhc_cfg[i]); + ret = fsl_esdhc_initialize(bis, &usdhc_cfg[i]); + if (ret) + return ret; } - return status; + return 0; } #endif /* CONFIG_FSL_ESDHC */
Hi Soeren,
- s32 status = 0;
- int i;
- (U-boot device node) (Physical Port)
- mmc0 SD2
- mmc1 SD3
- mmc2 eMMC
- int i, ret; for (i = 0; i < CONFIG_SYS_FSL_USDHC_NUM; i++) { switch (i) { case 0:
return status;
}return -EINVAL;
if (ret)
}return ret;
- return status;
ok, I'll merge in the next iteration.
Acked-by: Stefano Babic sbabic@denx.de
Best regards, Stefano Babic
Soeren Moch
Stefano Babic
