[U-Boot] [PATCH] powerpc/tools/pblimage: use SYS_TEXT_BASE instead of hardcoded value
That the pblimage can be built according to the SYS_TEXT_BASE, then building a different size of pblimage is available.
Signed-off-by: Shaohui Xie Shaohui.Xie@freescale.com --- tools/pblimage.c | 5 ++--- 1 file changed, 2 insertions(+), 3 deletions(-)
diff --git a/tools/pblimage.c b/tools/pblimage.c index 508a747..60277a4 100644 --- a/tools/pblimage.c +++ b/tools/pblimage.c @@ -29,10 +29,9 @@ * The PBL can load up to 64 bytes at a time, so we split the U-Boot * image into 64 byte chunks. PBL needs a command for each piece, of * the form "81xxxxxx", where "xxxxxx" is the offset. SYS_TEXT_BASE - * is 0xFFF80000 for PBL boot, and PBL only cares about low 24-bit, - * so it starts from 0x81F80000. + * is the start offset and PBL only cares about low 24-bit. */ -static uint32_t next_pbl_cmd = 0x81F80000; +static uint32_t next_pbl_cmd = 0x81000000 | (CONFIG_SYS_TEXT_BASE & 0xFFFFFF); /* * need to store all bytes in memory for calculating crc32, then write the * bytes to image file for PBL boot.
Shaohui Xie
