[U-Boot] [PATCH v3 0/4] arm64: sun50i: Add support for Orange Pi 3
Changes since v2: * drop "sunxi: board: Use eth_env_set_enetaddr_by_index()" as it breaks compilation without CONFIG_NET * add "sunxi: board: extract creating a unique sid into a helper function" and use it for the the bdaddr so that it work without ethernet devices * use `if (CONFIG_FIXUP_BDADDR[0])` as suggested by Ondřej to give the compiler a better chance of discarding the function if the knob isn't set
Changes since v1: * add CONFIG_FIXUP_BDADDR so fixing up a bdaddr is reusable * try to use "bdaddr" first, then fall back to generating an address
Notes: * the kernel patch for btbcm to accept the "local-bd-address" property is on master and will be in v5.5-rc1
Andre Heider (4): sunxi: board: extract creating a unique sid into a helper function arm: sunxi: add a config option to fixup a Bluetooth address arm64: dts: sync Allwinner H6 files arm64: dts: sun50i: Add support for Orange Pi 3
arch/arm/dts/Makefile | 1 + arch/arm/dts/sun50i-h6-beelink-gs1.dts | 27 +++ arch/arm/dts/sun50i-h6-orangepi-3.dts | 287 +++++++++++++++++++++++++ arch/arm/dts/sun50i-h6-orangepi.dtsi | 4 + arch/arm/dts/sun50i-h6-pine-h64.dts | 4 + arch/arm/dts/sun50i-h6.dtsi | 137 ++++++++++-- arch/arm/mach-sunxi/Kconfig | 11 + board/sunxi/MAINTAINERS | 5 + board/sunxi/board.c | 139 ++++++++---- configs/orangepi_3_defconfig | 18 ++ 10 files changed, 569 insertions(+), 64 deletions(-) create mode 100644 arch/arm/dts/sun50i-h6-orangepi-3.dts create mode 100644 configs/orangepi_3_defconfig
Signed-off-by: Andre Heider a.heider@gmail.com --- board/sunxi/board.c | 105 ++++++++++++++++++++++++-------------------- 1 file changed, 58 insertions(+), 47 deletions(-)
diff --git a/board/sunxi/board.c b/board/sunxi/board.c index b9450a0e36..42bec3a4d8 100644 --- a/board/sunxi/board.c +++ b/board/sunxi/board.c @@ -768,6 +768,38 @@ static void parse_spl_header(const uint32_t spl_addr) env_set_hex("fel_scriptaddr", spl->fel_script_address); }
+static bool get_unique_sid(unsigned int *sid) +{ + if (sunxi_get_sid(sid) != 0) + return false; + + if (!sid[0]) + return false; + + /* + * The single words 1 - 3 of the SID have quite a few bits + * which are the same on many models, so we take a crc32 + * of all 3 words, to get a more unique value. + * + * Note we only do this on newer SoCs as we cannot change + * the algorithm on older SoCs since those have been using + * fixed mac-addresses based on only using word 3 for a + * long time and changing a fixed mac-address with an + * u-boot update is not good. + */ +#if !defined(CONFIG_MACH_SUN4I) && !defined(CONFIG_MACH_SUN5I) && \ + !defined(CONFIG_MACH_SUN6I) && !defined(CONFIG_MACH_SUN7I) && \ + !defined(CONFIG_MACH_SUN8I_A23) && !defined(CONFIG_MACH_SUN8I_A33) + sid[3] = crc32(0, (unsigned char *)&sid[1], 12); +#endif + + /* Ensure the NIC specific bytes of the mac are not all 0 */ + if ((sid[3] & 0xffffff) == 0) + sid[3] |= 0x800000; + + return true; +} + /* * Note this function gets called multiple times. * It must not make any changes to env variables which already exist. @@ -778,61 +810,40 @@ static void setup_environment(const void *fdt) unsigned int sid[4]; uint8_t mac_addr[6]; char ethaddr[16]; - int i, ret; + int i;
- ret = sunxi_get_sid(sid); - if (ret == 0 && sid[0] != 0) { - /* - * The single words 1 - 3 of the SID have quite a few bits - * which are the same on many models, so we take a crc32 - * of all 3 words, to get a more unique value. - * - * Note we only do this on newer SoCs as we cannot change - * the algorithm on older SoCs since those have been using - * fixed mac-addresses based on only using word 3 for a - * long time and changing a fixed mac-address with an - * u-boot update is not good. - */ -#if !defined(CONFIG_MACH_SUN4I) && !defined(CONFIG_MACH_SUN5I) && \ - !defined(CONFIG_MACH_SUN6I) && !defined(CONFIG_MACH_SUN7I) && \ - !defined(CONFIG_MACH_SUN8I_A23) && !defined(CONFIG_MACH_SUN8I_A33) - sid[3] = crc32(0, (unsigned char *)&sid[1], 12); -#endif - - /* Ensure the NIC specific bytes of the mac are not all 0 */ - if ((sid[3] & 0xffffff) == 0) - sid[3] |= 0x800000; + if (!get_unique_sid(sid)) + return;
- for (i = 0; i < 4; i++) { - sprintf(ethaddr, "ethernet%d", i); - if (!fdt_get_alias(fdt, ethaddr)) - continue; + for (i = 0; i < 4; i++) { + sprintf(ethaddr, "ethernet%d", i); + if (!fdt_get_alias(fdt, ethaddr)) + continue;
- if (i == 0) - strcpy(ethaddr, "ethaddr"); - else - sprintf(ethaddr, "eth%daddr", i); + if (i == 0) + strcpy(ethaddr, "ethaddr"); + else + sprintf(ethaddr, "eth%daddr", i);
- if (env_get(ethaddr)) - continue; + if (env_get(ethaddr)) + continue;
- /* Non OUI / registered MAC address */ - mac_addr[0] = (i << 4) | 0x02; - mac_addr[1] = (sid[0] >> 0) & 0xff; - mac_addr[2] = (sid[3] >> 24) & 0xff; - mac_addr[3] = (sid[3] >> 16) & 0xff; - mac_addr[4] = (sid[3] >> 8) & 0xff; - mac_addr[5] = (sid[3] >> 0) & 0xff; + /* Non OUI / registered MAC address */ + mac_addr[0] = (i << 4) | 0x02; + mac_addr[1] = (sid[0] >> 0) & 0xff; + mac_addr[2] = (sid[3] >> 24) & 0xff; + mac_addr[3] = (sid[3] >> 16) & 0xff; + mac_addr[4] = (sid[3] >> 8) & 0xff; + mac_addr[5] = (sid[3] >> 0) & 0xff;
- eth_env_set_enetaddr(ethaddr, mac_addr); - } + eth_env_set_enetaddr(ethaddr, mac_addr); + }
- if (!env_get("serial#")) { - snprintf(serial_string, sizeof(serial_string), - "%08x%08x", sid[0], sid[3]); + if (!env_get("serial#")) { + snprintf(serial_string, sizeof(serial_string), + "%08x%08x", sid[0], sid[3]);
- env_set("serial#", serial_string); - } + env_set("serial#", serial_string); } }
Please add commit message, it looks hard to get what this patch is doing?
Some Bluetooth controllers, like the BCM4345C5 of the Orange Pi 3, ship with the controller default address.
Add a config option to fix it up so it can function properly.
Tested-by: Ondrej Jirman megous@megous.com Signed-off-by: Andre Heider a.heider@gmail.com --- arch/arm/mach-sunxi/Kconfig | 11 +++++++++++ board/sunxi/board.c | 34 ++++++++++++++++++++++++++++++++++ 2 files changed, 45 insertions(+)
diff --git a/arch/arm/mach-sunxi/Kconfig b/arch/arm/mach-sunxi/Kconfig index 16d41b83af..4513c07ffb 100644 --- a/arch/arm/mach-sunxi/Kconfig +++ b/arch/arm/mach-sunxi/Kconfig @@ -1009,4 +1009,15 @@ config PINE64_DT_SELECTION option, the device tree selection code specific to Pine64 which utilizes the DRAM size will be enabled.
+config FIXUP_BDADDR + string "Fixup the Bluetooth controller address" + default "" + help + This option specifies the DT compatible name of the Bluetooth + controller for which to set the "local-bd-address" property. + Set this option if your device ships with the Bluetooth controller + default address. + The used address is "bdaddr" if set, and "ethaddr" with the LSB + flipped elsewise. + endif diff --git a/board/sunxi/board.c b/board/sunxi/board.c index 42bec3a4d8..4311d4cba2 100644 --- a/board/sunxi/board.c +++ b/board/sunxi/board.c @@ -876,6 +876,38 @@ int misc_init_r(void) return 0; }
+static void fixup_bd_address(void *blob) +{ + /* Some devices ship with a Bluetooth controller default address. + * Set a valid address through the device tree. + */ + uchar tmp[ETH_ALEN], bdaddr[ETH_ALEN]; + unsigned int sid[4]; + int i; + + if (!CONFIG_FIXUP_BDADDR[0]) + return; + + if (eth_env_get_enetaddr("bdaddr", tmp)) { + /* Convert between the binary formats of the corresponding stacks */ + for (i = 0; i < ETH_ALEN; ++i) + bdaddr[i] = tmp[ETH_ALEN - i - 1]; + } else { + if (!get_unique_sid(sid)) + return; + + bdaddr[0] = ((sid[3] >> 0) & 0xff) ^ 1; + bdaddr[1] = (sid[3] >> 8) & 0xff; + bdaddr[2] = (sid[3] >> 16) & 0xff; + bdaddr[3] = (sid[3] >> 24) & 0xff; + bdaddr[4] = (sid[0] >> 0) & 0xff; + bdaddr[5] = 0x02; + } + + do_fixup_by_compat(blob, CONFIG_FIXUP_BDADDR, + "local-bd-address", bdaddr, ETH_ALEN, 1); +} + int ft_board_setup(void *blob, bd_t *bd) { int __maybe_unused r; @@ -886,6 +918,8 @@ int ft_board_setup(void *blob, bd_t *bd) */ setup_environment(blob);
+ fixup_bd_address(blob); + #ifdef CONFIG_VIDEO_DT_SIMPLEFB r = sunxi_simplefb_setup(blob); if (r)
You mean that the default factory address can't make functioning? also does it affect the boot process?
Yes. With the default address, bluetooth functionality is disabled in the controller, unless some other address is set.
o.
What about adding u-boot property instead of CONFIG macro. it would be easy to add it on board spec -u-boot.dtsi.
Taken from the kernel tag v5.4. Drop the /omit-if-no-ref/ keyword as it's not supported by u-boot.
Signed-off-by: Andre Heider a.heider@gmail.com --- arch/arm/dts/sun50i-h6-beelink-gs1.dts | 27 +++++ arch/arm/dts/sun50i-h6-orangepi.dtsi | 4 + arch/arm/dts/sun50i-h6-pine-h64.dts | 4 + arch/arm/dts/sun50i-h6.dtsi | 137 ++++++++++++++++++++++--- 4 files changed, 155 insertions(+), 17 deletions(-)
diff --git a/arch/arm/dts/sun50i-h6-beelink-gs1.dts b/arch/arm/dts/sun50i-h6-beelink-gs1.dts index 0dc33c90dd..1d05d57014 100644 --- a/arch/arm/dts/sun50i-h6-beelink-gs1.dts +++ b/arch/arm/dts/sun50i-h6-beelink-gs1.dts @@ -25,6 +25,7 @@ connector { compatible = "hdmi-connector"; type = "a"; + ddc-en-gpios = <&pio 7 2 GPIO_ACTIVE_HIGH>; /* PH2 */
port { hdmi_con_in: endpoint { @@ -51,6 +52,24 @@ regulator-max-microvolt = <5000000>; regulator-always-on; }; + + sound-spdif { + compatible = "simple-audio-card"; + simple-audio-card,name = "sun50i-h6-spdif"; + + simple-audio-card,cpu { + sound-dai = <&spdif>; + }; + + simple-audio-card,codec { + sound-dai = <&spdif_out>; + }; + }; + + spdif_out: spdif-out { + #sound-dai-cells = <0>; + compatible = "linux,spdif-dit"; + }; };
&de { @@ -232,6 +251,10 @@ }; };
+&r_ir { + status = "okay"; +}; + &r_pio { /* * PL0 and PL1 are used for PMIC I2C @@ -243,6 +266,10 @@ vcc-pm-supply = <®_aldo1>; };
+&spdif { + status = "okay"; +}; + &uart0 { pinctrl-names = "default"; pinctrl-0 = <&uart0_ph_pins>; diff --git a/arch/arm/dts/sun50i-h6-orangepi.dtsi b/arch/arm/dts/sun50i-h6-orangepi.dtsi index 62e27948a3..ec9b6a578e 100644 --- a/arch/arm/dts/sun50i-h6-orangepi.dtsi +++ b/arch/arm/dts/sun50i-h6-orangepi.dtsi @@ -189,6 +189,10 @@ }; };
+&r_ir { + status = "okay"; +}; + &uart0 { pinctrl-names = "default"; pinctrl-0 = <&uart0_ph_pins>; diff --git a/arch/arm/dts/sun50i-h6-pine-h64.dts b/arch/arm/dts/sun50i-h6-pine-h64.dts index 1898345183..30102daf83 100644 --- a/arch/arm/dts/sun50i-h6-pine-h64.dts +++ b/arch/arm/dts/sun50i-h6-pine-h64.dts @@ -255,6 +255,10 @@ }; };
+&r_ir { + status = "okay"; +}; + &r_pio { vcc-pm-supply = <®_aldo1>; }; diff --git a/arch/arm/dts/sun50i-h6.dtsi b/arch/arm/dts/sun50i-h6.dtsi index a117f479ae..bdba221a67 100644 --- a/arch/arm/dts/sun50i-h6.dtsi +++ b/arch/arm/dts/sun50i-h6.dtsi @@ -56,14 +56,6 @@ status = "disabled"; };
- iosc: internal-osc-clk { - #clock-cells = <0>; - compatible = "fixed-clock"; - clock-frequency = <16000000>; - clock-accuracy = <300000000>; - clock-output-names = "iosc"; - }; - osc24M: osc24M_clk { #clock-cells = <0>; compatible = "fixed-clock"; @@ -71,11 +63,11 @@ clock-output-names = "osc24M"; };
- osc32k: osc32k_clk { + ext_osc32k: ext_osc32k_clk { #clock-cells = <0>; compatible = "fixed-clock"; clock-frequency = <32768>; - clock-output-names = "osc32k"; + clock-output-names = "ext_osc32k"; };
psci { @@ -197,7 +189,7 @@ ccu: clock@3001000 { compatible = "allwinner,sun50i-h6-ccu"; reg = <0x03001000 0x1000>; - clocks = <&osc24M>, <&osc32k>, <&iosc>; + clocks = <&osc24M>, <&rtc 0>, <&rtc 2>; clock-names = "hosc", "losc", "iosc"; #clock-cells = <1>; #reset-cells = <1>; @@ -215,7 +207,7 @@ #dma-cells = <1>; };
- sid: sid@3006000 { + sid: efuse@3006000 { compatible = "allwinner,sun50i-h6-sid"; reg = <0x03006000 0x400>; }; @@ -225,6 +217,7 @@ "allwinner,sun6i-a31-wdt"; reg = <0x030090a0 0x20>; interrupts = <GIC_SPI 50 IRQ_TYPE_LEVEL_HIGH>; + clocks = <&osc24M>; /* Broken on some H6 boards */ status = "disabled"; }; @@ -236,7 +229,7 @@ <GIC_SPI 53 IRQ_TYPE_LEVEL_HIGH>, <GIC_SPI 54 IRQ_TYPE_LEVEL_HIGH>, <GIC_SPI 59 IRQ_TYPE_LEVEL_HIGH>; - clocks = <&ccu CLK_APB1>, <&osc24M>, <&osc32k>; + clocks = <&ccu CLK_APB1>, <&osc24M>, <&rtc 0>; clock-names = "apb", "hosc", "losc"; gpio-controller; #gpio-cells = <3>; @@ -256,6 +249,21 @@ function = "hdmi"; };
+ i2c0_pins: i2c0-pins { + pins = "PD25", "PD26"; + function = "i2c0"; + }; + + i2c1_pins: i2c1-pins { + pins = "PH5", "PH6"; + function = "i2c1"; + }; + + i2c2_pins: i2c2-pins { + pins = "PD23", "PD24"; + function = "i2c2"; + }; + mmc0_pins: mmc0-pins { pins = "PF0", "PF1", "PF2", "PF3", "PF4", "PF5"; @@ -285,6 +293,11 @@ bias-pull-up; };
+ spdif_tx_pin: spdif-tx-pin { + pins = "PH7"; + function = "spdif"; + }; + uart0_ph_pins: uart0-ph-pins { pins = "PH0", "PH1"; function = "uart0"; @@ -394,6 +407,48 @@ status = "disabled"; };
+ i2c0: i2c@5002000 { + compatible = "allwinner,sun50i-h6-i2c", + "allwinner,sun6i-a31-i2c"; + reg = <0x05002000 0x400>; + interrupts = <GIC_SPI 4 IRQ_TYPE_LEVEL_HIGH>; + clocks = <&ccu CLK_BUS_I2C0>; + resets = <&ccu RST_BUS_I2C0>; + pinctrl-names = "default"; + pinctrl-0 = <&i2c0_pins>; + status = "disabled"; + #address-cells = <1>; + #size-cells = <0>; + }; + + i2c1: i2c@5002400 { + compatible = "allwinner,sun50i-h6-i2c", + "allwinner,sun6i-a31-i2c"; + reg = <0x05002400 0x400>; + interrupts = <GIC_SPI 5 IRQ_TYPE_LEVEL_HIGH>; + clocks = <&ccu CLK_BUS_I2C1>; + resets = <&ccu RST_BUS_I2C1>; + pinctrl-names = "default"; + pinctrl-0 = <&i2c1_pins>; + status = "disabled"; + #address-cells = <1>; + #size-cells = <0>; + }; + + i2c2: i2c@5002800 { + compatible = "allwinner,sun50i-h6-i2c", + "allwinner,sun6i-a31-i2c"; + reg = <0x05002800 0x400>; + interrupts = <GIC_SPI 6 IRQ_TYPE_LEVEL_HIGH>; + clocks = <&ccu CLK_BUS_I2C2>; + resets = <&ccu RST_BUS_I2C2>; + pinctrl-names = "default"; + pinctrl-0 = <&i2c2_pins>; + status = "disabled"; + #address-cells = <1>; + #size-cells = <0>; + }; + emac: ethernet@5020000 { compatible = "allwinner,sun50i-h6-emac", "allwinner,sun50i-a64-emac"; @@ -414,6 +469,21 @@ }; };
+ spdif: spdif@5093000 { + #sound-dai-cells = <0>; + compatible = "allwinner,sun50i-h6-spdif"; + reg = <0x05093000 0x400>; + interrupts = <GIC_SPI 21 IRQ_TYPE_LEVEL_HIGH>; + clocks = <&ccu CLK_BUS_SPDIF>, <&ccu CLK_SPDIF>; + clock-names = "apb", "spdif"; + resets = <&ccu RST_BUS_SPDIF>; + dmas = <&dma 2>; + dma-names = "tx"; + pinctrl-names = "default"; + pinctrl-0 = <&spdif_tx_pin>; + status = "disabled"; + }; + usb2otg: usb@5100000 { compatible = "allwinner,sun50i-h6-musb", "allwinner,sun8i-a33-musb"; @@ -480,6 +550,7 @@ resets = <&ccu RST_BUS_OHCI3>, <&ccu RST_BUS_EHCI3>; phys = <&usb2phy 3>; + phy-names = "usb"; status = "disabled"; };
@@ -491,6 +562,7 @@ <&ccu CLK_USB_OHCI3>; resets = <&ccu RST_BUS_OHCI3>; phys = <&usb2phy 3>; + phy-names = "usb"; status = "disabled"; };
@@ -507,7 +579,7 @@ resets = <&ccu RST_BUS_HDMI_SUB>, <&ccu RST_BUS_HDCP>; reset-names = "ctrl", "hdcp"; phys = <&hdmi_phy>; - phy-names = "hdmi-phy"; + phy-names = "phy"; pinctrl-names = "default"; pinctrl-0 = <&hdmi_pins>; status = "disabled"; @@ -636,10 +708,20 @@ }; };
+ rtc: rtc@7000000 { + compatible = "allwinner,sun50i-h6-rtc"; + reg = <0x07000000 0x400>; + interrupts = <GIC_SPI 101 IRQ_TYPE_LEVEL_HIGH>, + <GIC_SPI 102 IRQ_TYPE_LEVEL_HIGH>; + clock-output-names = "osc32k", "osc32k-out", "iosc"; + clocks = <&ext_osc32k>; + #clock-cells = <1>; + }; + r_ccu: clock@7010000 { compatible = "allwinner,sun50i-h6-r-ccu"; reg = <0x07010000 0x400>; - clocks = <&osc24M>, <&osc32k>, <&iosc>, + clocks = <&osc24M>, <&rtc 0>, <&rtc 2>, <&ccu CLK_PLL_PERIPH0>; clock-names = "hosc", "losc", "iosc", "pll-periph"; #clock-cells = <1>; @@ -651,6 +733,7 @@ "allwinner,sun6i-a31-wdt"; reg = <0x07020400 0x20>; interrupts = <GIC_SPI 103 IRQ_TYPE_LEVEL_HIGH>; + clocks = <&osc24M>; };
r_intc: interrupt-controller@7021000 { @@ -667,7 +750,7 @@ reg = <0x07022000 0x400>; interrupts = <GIC_SPI 105 IRQ_TYPE_LEVEL_HIGH>, <GIC_SPI 111 IRQ_TYPE_LEVEL_HIGH>; - clocks = <&r_ccu CLK_R_APB1>, <&osc24M>, <&osc32k>; + clocks = <&r_ccu CLK_R_APB1>, <&osc24M>, <&rtc 0>; clock-names = "apb", "hosc", "losc"; gpio-controller; #gpio-cells = <3>; @@ -678,10 +761,30 @@ pins = "PL0", "PL1"; function = "s_i2c"; }; + + r_ir_rx_pin: r-ir-rx-pin { + pins = "PL9"; + function = "s_cir_rx"; + }; + }; + + r_ir: ir@7040000 { + compatible = "allwinner,sun50i-h6-ir", + "allwinner,sun6i-a31-ir"; + reg = <0x07040000 0x400>; + interrupts = <GIC_SPI 109 IRQ_TYPE_LEVEL_HIGH>; + clocks = <&r_ccu CLK_R_APB1_IR>, + <&r_ccu CLK_IR>; + clock-names = "apb", "ir"; + resets = <&r_ccu RST_R_APB1_IR>; + pinctrl-names = "default"; + pinctrl-0 = <&r_ir_rx_pin>; + status = "disabled"; };
r_i2c: i2c@7081400 { - compatible = "allwinner,sun6i-a31-i2c"; + compatible = "allwinner,sun50i-h6-i2c", + "allwinner,sun6i-a31-i2c"; reg = <0x07081400 0x400>; interrupts = <GIC_SPI 107 IRQ_TYPE_LEVEL_HIGH>; clocks = <&r_ccu CLK_R_APB2_I2C>;
Please sync it from v5.6 98d25b0b266d Merge branch 'sunxi/dt-for-5.6' into sunxi/for-next
Hi Jagan,
I assume you mean the sunxi tree[0], but there is no such commit? Why not just a stable hash from Linus' tree?
[0] https://git.kernel.org/pub/scm/linux/kernel/git/sunxi/linux.git/
Thanks, Andre
On 04/02/2020 09:02, Andre Heider wrote:
Hi Jagan,
nvm, found it in linux-next, will update the patches...
The dts is taken from kernel tag v5.4.
The Bluetooth controller of this device ships with a default adress, use the new CONFIG_FIXUP_BDADDR option to fix it up.
Signed-off-by: Andre Heider a.heider@gmail.com --- arch/arm/dts/Makefile | 1 + arch/arm/dts/sun50i-h6-orangepi-3.dts | 287 ++++++++++++++++++++++++++ board/sunxi/MAINTAINERS | 5 + configs/orangepi_3_defconfig | 18 ++ 4 files changed, 311 insertions(+) create mode 100644 arch/arm/dts/sun50i-h6-orangepi-3.dts create mode 100644 configs/orangepi_3_defconfig
diff --git a/arch/arm/dts/Makefile b/arch/arm/dts/Makefile index d8846df1bd..5040d4f50d 100644 --- a/arch/arm/dts/Makefile +++ b/arch/arm/dts/Makefile @@ -540,6 +540,7 @@ dtb-$(CONFIG_MACH_SUN50I_H5) += \ sun50i-h5-orangepi-zero-plus2.dtb dtb-$(CONFIG_MACH_SUN50I_H6) += \ sun50i-h6-beelink-gs1.dtb \ + sun50i-h6-orangepi-3.dtb \ sun50i-h6-orangepi-lite2.dtb \ sun50i-h6-orangepi-one-plus.dtb \ sun50i-h6-pine-h64.dtb diff --git a/arch/arm/dts/sun50i-h6-orangepi-3.dts b/arch/arm/dts/sun50i-h6-orangepi-3.dts new file mode 100644 index 0000000000..eb379cd402 --- /dev/null +++ b/arch/arm/dts/sun50i-h6-orangepi-3.dts @@ -0,0 +1,287 @@ +// SPDX-License-Identifier: (GPL-2.0+ or MIT) +/* + * Copyright (C) 2019 Ondřej Jirman megous@megous.com + */ + +/dts-v1/; + +#include "sun50i-h6.dtsi" + +#include <dt-bindings/gpio/gpio.h> + +/ { + model = "OrangePi 3"; + compatible = "xunlong,orangepi-3", "allwinner,sun50i-h6"; + + aliases { + serial0 = &uart0; + }; + + chosen { + stdout-path = "serial0:115200n8"; + }; + + connector { + compatible = "hdmi-connector"; + ddc-en-gpios = <&pio 7 2 GPIO_ACTIVE_HIGH>; /* PH2 */ + type = "a"; + + port { + hdmi_con_in: endpoint { + remote-endpoint = <&hdmi_out_con>; + }; + }; + }; + + leds { + compatible = "gpio-leds"; + + power { + label = "orangepi:red:power"; + gpios = <&r_pio 0 4 GPIO_ACTIVE_HIGH>; /* PL4 */ + default-state = "on"; + }; + + status { + label = "orangepi:green:status"; + gpios = <&r_pio 0 7 GPIO_ACTIVE_HIGH>; /* PL7 */ + }; + }; + + reg_vcc5v: vcc5v { + /* board wide 5V supply directly from the DC jack */ + compatible = "regulator-fixed"; + regulator-name = "vcc-5v"; + regulator-min-microvolt = <5000000>; + regulator-max-microvolt = <5000000>; + regulator-always-on; + }; + + reg_vcc33_wifi: vcc33-wifi { + /* Always on 3.3V regulator for WiFi and BT */ + compatible = "regulator-fixed"; + regulator-name = "vcc33-wifi"; + regulator-min-microvolt = <3300000>; + regulator-max-microvolt = <3300000>; + regulator-always-on; + vin-supply = <®_vcc5v>; + }; + + reg_vcc_wifi_io: vcc-wifi-io { + /* Always on 1.8V/300mA regulator for WiFi and BT IO */ + compatible = "regulator-fixed"; + regulator-name = "vcc-wifi-io"; + regulator-min-microvolt = <1800000>; + regulator-max-microvolt = <1800000>; + regulator-always-on; + vin-supply = <®_vcc33_wifi>; + }; + + wifi_pwrseq: wifi-pwrseq { + compatible = "mmc-pwrseq-simple"; + clocks = <&rtc 1>; + clock-names = "ext_clock"; + reset-gpios = <&r_pio 1 3 GPIO_ACTIVE_LOW>; /* PM3 */ + post-power-on-delay-ms = <200>; + }; +}; + +&cpu0 { + cpu-supply = <®_dcdca>; +}; + +&de { + status = "okay"; +}; + +&ehci0 { + status = "okay"; +}; + +&ehci3 { + status = "okay"; +}; + +&hdmi { + status = "okay"; +}; + +&hdmi_out { + hdmi_out_con: endpoint { + remote-endpoint = <&hdmi_con_in>; + }; +}; + +&mmc0 { + vmmc-supply = <®_cldo1>; + cd-gpios = <&pio 5 6 GPIO_ACTIVE_LOW>; /* PF6 */ + bus-width = <4>; + status = "okay"; +}; + +&mmc1 { + vmmc-supply = <®_vcc33_wifi>; + vqmmc-supply = <®_vcc_wifi_io>; + mmc-pwrseq = <&wifi_pwrseq>; + bus-width = <4>; + non-removable; + status = "okay"; + + brcm: sdio-wifi@1 { + reg = <1>; + compatible = "brcm,bcm4329-fmac"; + interrupt-parent = <&r_pio>; + interrupts = <1 0 IRQ_TYPE_LEVEL_LOW>; /* PM0 */ + interrupt-names = "host-wake"; + }; +}; + +&ohci0 { + status = "okay"; +}; + +&ohci3 { + status = "okay"; +}; + +&pio { + vcc-pc-supply = <®_bldo2>; + vcc-pd-supply = <®_cldo1>; + vcc-pg-supply = <®_vcc_wifi_io>; +}; + +&r_i2c { + status = "okay"; + + axp805: pmic@36 { + compatible = "x-powers,axp805", "x-powers,axp806"; + reg = <0x36>; + interrupt-parent = <&r_intc>; + interrupts = <0 IRQ_TYPE_LEVEL_LOW>; + interrupt-controller; + #interrupt-cells = <1>; + x-powers,self-working-mode; + vina-supply = <®_vcc5v>; + vinb-supply = <®_vcc5v>; + vinc-supply = <®_vcc5v>; + vind-supply = <®_vcc5v>; + vine-supply = <®_vcc5v>; + aldoin-supply = <®_vcc5v>; + bldoin-supply = <®_vcc5v>; + cldoin-supply = <®_vcc5v>; + + regulators { + reg_aldo1: aldo1 { + regulator-always-on; + regulator-min-microvolt = <3300000>; + regulator-max-microvolt = <3300000>; + regulator-name = "vcc-pl-led-ir"; + }; + + reg_aldo2: aldo2 { + regulator-min-microvolt = <3300000>; + regulator-max-microvolt = <3300000>; + regulator-name = "vcc33-audio-tv-ephy-mac"; + }; + + /* ALDO3 is shorted to CLDO1 */ + reg_aldo3: aldo3 { + regulator-always-on; + regulator-min-microvolt = <3300000>; + regulator-max-microvolt = <3300000>; + regulator-name = "vcc33-io-pd-emmc-sd-usb-uart-1"; + }; + + reg_bldo1: bldo1 { + regulator-always-on; + regulator-min-microvolt = <1800000>; + regulator-max-microvolt = <1800000>; + regulator-name = "vcc18-dram-bias-pll"; + }; + + reg_bldo2: bldo2 { + regulator-always-on; + regulator-min-microvolt = <1800000>; + regulator-max-microvolt = <1800000>; + regulator-name = "vcc-efuse-pcie-hdmi-pc"; + }; + + bldo3 { + /* unused */ + }; + + bldo4 { + /* unused */ + }; + + reg_cldo1: cldo1 { + regulator-always-on; + regulator-min-microvolt = <3300000>; + regulator-max-microvolt = <3300000>; + regulator-name = "vcc33-io-pd-emmc-sd-usb-uart-2"; + }; + + cldo2 { + /* unused */ + }; + + cldo3 { + /* unused */ + }; + + reg_dcdca: dcdca { + regulator-always-on; + regulator-min-microvolt = <800000>; + regulator-max-microvolt = <1160000>; + regulator-name = "vdd-cpu"; + }; + + reg_dcdcc: dcdcc { + regulator-min-microvolt = <810000>; + regulator-max-microvolt = <1080000>; + regulator-name = "vdd-gpu"; + }; + + reg_dcdcd: dcdcd { + regulator-always-on; + regulator-min-microvolt = <960000>; + regulator-max-microvolt = <960000>; + regulator-name = "vdd-sys"; + }; + + reg_dcdce: dcdce { + regulator-always-on; + regulator-min-microvolt = <1200000>; + regulator-max-microvolt = <1200000>; + regulator-name = "vcc-dram"; + }; + + sw { + /* unused */ + }; + }; + }; +}; + +&uart0 { + pinctrl-names = "default"; + pinctrl-0 = <&uart0_ph_pins>; + status = "okay"; +}; + +&usb2otg { + /* + * This board doesn't have a controllable VBUS even though it + * does have an ID pin. Using it as anything but a USB host is + * unsafe. + */ + dr_mode = "host"; + status = "okay"; +}; + +&usb2phy { + usb0_id_det-gpios = <&pio 2 15 GPIO_ACTIVE_HIGH>; /* PC15 */ + usb0_vbus-supply = <®_vcc5v>; + usb3_vbus-supply = <®_vcc5v>; + status = "okay"; +}; diff --git a/board/sunxi/MAINTAINERS b/board/sunxi/MAINTAINERS index a2adf89b5d..3c0fd0cae8 100644 --- a/board/sunxi/MAINTAINERS +++ b/board/sunxi/MAINTAINERS @@ -375,6 +375,11 @@ M: Icenowy Zheng icenowy@aosc.io S: Maintained F: configs/teres_i_defconfig
+ORANGEPI 3 BOARD +M: Andre Heider a.heider@gmail.com +S: Maintained +F: configs/orangepi_3_defconfig + ORANGEPI LITE2 BOARD M: Jagan Teki jagan@amarulasolutions.com S: Maintained diff --git a/configs/orangepi_3_defconfig b/configs/orangepi_3_defconfig new file mode 100644 index 0000000000..c9db0abb77 --- /dev/null +++ b/configs/orangepi_3_defconfig @@ -0,0 +1,18 @@ +CONFIG_ARM=y +CONFIG_ARCH_SUNXI=y +CONFIG_NR_DRAM_BANKS=1 +CONFIG_SPL=y +CONFIG_MACH_SUN50I_H6=y +CONFIG_SUNXI_DRAM_H6_LPDDR3=y +CONFIG_MMC0_CD_PIN="PF6" +CONFIG_MMC_SUNXI_SLOT_EXTRA=2 +CONFIG_FIXUP_BDADDR="brcm,bcm4345c5" +# CONFIG_PSCI_RESET is not set +# CONFIG_SYS_MALLOC_CLEAR_ON_INIT is not set +CONFIG_USE_PREBOOT=y +# CONFIG_CMD_FLASH is not set +# CONFIG_SPL_DOS_PARTITION is not set +# CONFIG_SPL_EFI_PARTITION is not set +CONFIG_DEFAULT_DEVICE_TREE="sun50i-h6-orangepi-3" +CONFIG_USB_EHCI_HCD=y +CONFIG_USB_OHCI_HCD=y
On 03/12/2019 09:45, Andre Heider wrote:
Changes since v2:
- drop "sunxi: board: Use eth_env_set_enetaddr_by_index()" as it breaks compilation without CONFIG_NET
- add "sunxi: board: extract creating a unique sid into a helper function" and use it for the the bdaddr so that it work without ethernet devices
- use `if (CONFIG_FIXUP_BDADDR[0])` as suggested by Ondřej to give the compiler a better chance of discarding the function if the knob isn't set
Jagan, Maxime,
does v3 look okay to you guys? Anything I need to address to get this in?
Thanks! Andre
Changes since v1:
- add CONFIG_FIXUP_BDADDR so fixing up a bdaddr is reusable
- try to use "bdaddr" first, then fall back to generating an address
Notes:
- the kernel patch for btbcm to accept the "local-bd-address" property is on master and will be in v5.5-rc1
Changes since v2:
Jagan, Maxime,
How about this year? ;) Anyone? Bueller?
Thanks! Andre
Changes since v1:
Notes:
Changes since v2:
Jagan, Maxime,
Yeah, it looks good to me
Acked-by: Maxime Ripard mripard@kernel.org
Maxime
Andre Heider
Jagan Teki
Maxime Ripard
Ondřej Jirman
