[U-Boot] Please pull u-boot-sunxi master
Hi Tom,
Here is another sunxi pull-req for v2016.09.
The big commit in this one is syncing the dts files with the kernel. I was planning on doing that after v2016.09, but users are having trouble adding new boards because the dts files in u-boot have gotten so out of sync that certain dtsi files are not available and there are some other changes, so lets do this now.
Besides the big dts sync there is a bugfix to stop the backlight from some tablets turning off for a few seconds while the kernel is booting and there are 2 new boards.
The following changes since commit da968c7bfa4cc1203a4f9f61a97f55c85dfbb3b6:
Merge branch 'master' of git://git.denx.de/u-boot-i2c (2016-08-26 07:42:06 -0400)
http://git.denx.de/u-boot-sunxi.git master
for you to fetch changes up to d5ac6eef91965b519d8f15f17febfa0ea2ee0adc:
sunxi: Tune H3 DRAM PLL to improve lock time (2016-08-26 16:58:37 +0200)
---------------------------------------------------------------- Hans de Goede (4): sun6i: Add defconfig and dts file for tablets using the inet-q972 PCB sunxi: Sync dts files with upstream kernel sun5i: Add defconfig and dts file for the Empire Electronix M712 tablet sunxi: display: Use PWM to drive backlight where applicable
Jens Kuske (1): sunxi: Tune H3 DRAM PLL to improve lock time
arch/arm/dts/Makefile | 5 + arch/arm/dts/axp209.dtsi | 1 + arch/arm/dts/axp809.dtsi | 53 ++ arch/arm/dts/sun4i-a10-a1000.dts | 28 +- arch/arm/dts/sun4i-a10-hackberry.dts | 1 + arch/arm/dts/sun4i-a10-hyundai-a7hd.dts | 34 ++ arch/arm/dts/sun4i-a10-jesurun-q5.dts | 1 + arch/arm/dts/sun4i-a10.dtsi | 286 ++++++++--- arch/arm/dts/sun5i-a10s-mk802.dts | 32 ++ arch/arm/dts/sun5i-a10s-olinuxino-micro.dts | 7 + arch/arm/dts/sun5i-a10s-wobo-i5.dts | 10 +- arch/arm/dts/sun5i-a10s.dtsi | 31 +- arch/arm/dts/sun5i-a13-difrnce-dit4350.dts | 178 +------ arch/arm/dts/sun5i-a13-empire-electronix-m712.dts | 51 ++ arch/arm/dts/sun5i-a13-olinuxino-micro.dts | 41 ++ arch/arm/dts/sun5i-a13-olinuxino.dts | 15 - arch/arm/dts/sun5i-a13-q8-tablet.dts | 40 +- arch/arm/dts/sun5i-a13-utoo-p66.dts | 180 +------ arch/arm/dts/sun5i-a13.dtsi | 188 ++++++- arch/arm/dts/sun5i-r8-chip.dts | 29 +- arch/arm/dts/sun5i-r8.dtsi | 32 +- arch/arm/dts/sun5i-reference-design-tablet.dtsi | 210 ++++++++ arch/arm/dts/sun5i.dtsi | 92 ++-- arch/arm/dts/sun6i-a31-m9.dts | 96 +++- arch/arm/dts/sun6i-a31-mele-a1000g-quad.dts | 96 +++- arch/arm/dts/sun6i-a31.dtsi | 12 +- arch/arm/dts/sun6i-a31s-colorfly-e708-q1.dts | 138 +----- arch/arm/dts/sun6i-a31s-inet-q972.dts | 100 ++++ arch/arm/dts/sun6i-a31s-primo81.dts | 10 - .../arm/dts/sun6i-a31s-yones-toptech-bs1078-v2.dts | 2 - arch/arm/dts/sun6i-reference-design-tablet.dtsi | 193 ++++++++ arch/arm/dts/sun7i-a20-bananapi-m1-plus.dts | 229 +++++++++ arch/arm/dts/sun7i-a20-cubietruck.dts | 24 + arch/arm/dts/sun7i-a20-itead-ibox.dts | 24 + arch/arm/dts/sun7i-a20-lamobo-r1.dts | 80 ++- arch/arm/dts/sun7i-a20-olinuxino-lime2-emmc.dts | 82 ++++ arch/arm/dts/sun7i-a20.dtsi | 546 +++++++++++++++------ arch/arm/dts/sun8i-a23-a33.dtsi | 9 +- arch/arm/dts/sun8i-a23-gt90h-v4.dts | 194 +------- arch/arm/dts/sun8i-a23-inet86dz.dts | 238 +-------- arch/arm/dts/sun8i-a23-polaroid-mid2407pxe03.dts | 243 ++------- arch/arm/dts/sun8i-a23-polaroid-mid2809pxe04.dts | 201 ++------ arch/arm/dts/sun8i-a23-q8-tablet.dts | 15 - arch/arm/dts/sun8i-a33-ga10h-v1.1.dts | 80 +-- arch/arm/dts/sun8i-a33-q8-tablet.dts | 15 - arch/arm/dts/sun8i-h3-bananapi-m2-plus.dts | 195 ++++++++ arch/arm/dts/sun8i-h3-orangepi-2.dts | 23 +- arch/arm/dts/sun8i-h3-orangepi-lite.dts | 2 +- arch/arm/dts/sun8i-h3-orangepi-pc-plus.dts | 3 +- arch/arm/dts/sun8i-h3-orangepi-pc.dts | 30 +- arch/arm/dts/sun8i-h3-orangepi-plus.dts | 34 ++ arch/arm/dts/sun8i-h3.dtsi | 366 ++++---------- arch/arm/dts/sun8i-q8-common.dtsi | 157 ++---- arch/arm/dts/sun8i-r16-parrot.dts | 5 +- arch/arm/dts/sun8i-reference-design-tablet.dtsi | 244 +++++++++ arch/arm/dts/sun9i-a80-cubieboard4.dts | 164 ++++++- arch/arm/dts/sun9i-a80-optimus.dts | 195 ++++++-- arch/arm/dts/sunxi-reference-design-tablet.dtsi | 83 ++++ arch/arm/include/asm/arch-sunxi/clock_sun6i.h | 9 +- arch/arm/include/asm/arch-sunxi/cpu_sun4i.h | 7 + arch/arm/include/asm/arch-sunxi/gpio.h | 3 + arch/arm/include/asm/arch-sunxi/pwm.h | 34 ++ arch/arm/mach-sunxi/clock_sun6i.c | 6 + board/sunxi/MAINTAINERS | 2 + configs/Empire_electronix_m712_defconfig | 22 + configs/MSI_Primo81_defconfig | 1 + configs/inet_q972_defconfig | 23 + drivers/video/sunxi_display.c | 11 + include/dt-bindings/clock/sun8i-h3-ccu.h | 145 ++++++ include/dt-bindings/reset/sun8i-h3-ccu.h | 103 ++++ 70 files changed, 3846 insertions(+), 2193 deletions(-) create mode 100644 arch/arm/dts/axp809.dtsi create mode 100644 arch/arm/dts/sun5i-a13-empire-electronix-m712.dts create mode 100644 arch/arm/dts/sun5i-reference-design-tablet.dtsi create mode 100644 arch/arm/dts/sun6i-a31s-inet-q972.dts create mode 100644 arch/arm/dts/sun6i-reference-design-tablet.dtsi create mode 100644 arch/arm/dts/sun7i-a20-bananapi-m1-plus.dts create mode 100644 arch/arm/dts/sun7i-a20-olinuxino-lime2-emmc.dts create mode 100644 arch/arm/dts/sun8i-h3-bananapi-m2-plus.dts create mode 100644 arch/arm/dts/sun8i-reference-design-tablet.dtsi create mode 100644 arch/arm/dts/sunxi-reference-design-tablet.dtsi create mode 100644 arch/arm/include/asm/arch-sunxi/pwm.h create mode 100644 configs/Empire_electronix_m712_defconfig create mode 100644 configs/inet_q972_defconfig create mode 100644 include/dt-bindings/clock/sun8i-h3-ccu.h create mode 100644 include/dt-bindings/reset/sun8i-h3-ccu.h
Regards,
Hans
On Fri, Aug 26, 2016 at 08:42:03PM +0200, Hans de Goede wrote:
Hi Tom,
FWIW, I've added my A20-OLinuXino-Lime2 into my test.py setup (thanks to FEL mode), and:
Hans de Goede
