[U-Boot] [PATCH v3] usb: lpc32xx: add i2c DM support
Add DM support for i2c functions.
Signed-off-by: Liam Beguin lbeguin@tycoint.com Signed-off-by: Sylvain Lemieux slemieux@tycoint.com --- Changes from v2 to v3: * Code clean-up to remove conditional compile else section (CONFIG_DM_I2C). * As suggested by Marek, added Simon Glass to the list of cc for the patch.
Changes from v1 to v2: * Do not request udevice on each single i2c write.
Note: * This patch is require as part of the DM support of the LPC32xx I2C driver. All I2C drivers should be converted, to DM, by the end of June 2017.
* The USB driver is supporting the DM and non-DM API.
* Once the ustream LPC32xx boards (devkit3250 & work_92105) are migrated to DM (I2C), the non-DM API support can be remove from this driver.
drivers/usb/host/ohci-lpc32xx.c | 64 +++++++++++++++++++++++++++++------------ 1 file changed, 46 insertions(+), 18 deletions(-)
diff --git a/drivers/usb/host/ohci-lpc32xx.c b/drivers/usb/host/ohci-lpc32xx.c index 9245126ed6..c0c423b994 100644 --- a/drivers/usb/host/ohci-lpc32xx.c +++ b/drivers/usb/host/ohci-lpc32xx.c @@ -14,8 +14,10 @@ #include <asm/io.h> #include <asm/arch/cpu.h> #include <asm/arch/clk.h> +#include <asm/arch/i2c.h> #include <usb.h> #include <i2c.h> +#include <dm.h>
/* OTG I2C controller module register structures */ struct otgi2c_regs { @@ -81,14 +83,20 @@ struct otg_regs { static struct otg_regs *otg = (struct otg_regs *)USB_BASE; static struct clk_pm_regs *clk_pwr = (struct clk_pm_regs *)CLK_PM_BASE;
-static int isp1301_set_value(int reg, u8 value) +static int isp1301_set_value(struct udevice *dev, int reg, u8 value) { +#ifndef CONFIG_DM_I2C return i2c_write(ISP1301_I2C_ADDR, reg, 1, &value, 1); +#else + return dm_i2c_write(dev, reg, &value, 1); +#endif }
-static void isp1301_configure(void) +static void isp1301_configure(struct udevice *dev) { +#ifndef CONFIG_DM_I2C i2c_set_bus_num(I2C_2); +#endif
/* * LPC32XX only supports DAT_SE0 USB mode @@ -96,23 +104,23 @@ static void isp1301_configure(void) */
/* Disable transparent UART mode first */ - isp1301_set_value(ISP1301_I2C_MODE_CONTROL_1_CLR, MC1_UART_EN); + isp1301_set_value(dev, ISP1301_I2C_MODE_CONTROL_1_CLR, MC1_UART_EN);
- isp1301_set_value(ISP1301_I2C_MODE_CONTROL_1_CLR, ~MC1_SPEED_REG); - isp1301_set_value(ISP1301_I2C_MODE_CONTROL_1_SET, MC1_SPEED_REG); - isp1301_set_value(ISP1301_I2C_MODE_CONTROL_2_CLR, ~0); - isp1301_set_value(ISP1301_I2C_MODE_CONTROL_2_SET, + isp1301_set_value(dev, ISP1301_I2C_MODE_CONTROL_1_CLR, ~MC1_SPEED_REG); + isp1301_set_value(dev, ISP1301_I2C_MODE_CONTROL_1_SET, MC1_SPEED_REG); + isp1301_set_value(dev, ISP1301_I2C_MODE_CONTROL_2_CLR, ~0); + isp1301_set_value(dev, ISP1301_I2C_MODE_CONTROL_2_SET, MC2_BI_DI | MC2_PSW_EN | MC2_SPD_SUSP_CTRL);
- isp1301_set_value(ISP1301_I2C_OTG_CONTROL_1_CLR, ~0); - isp1301_set_value(ISP1301_I2C_MODE_CONTROL_1_SET, MC1_DAT_SE0); - isp1301_set_value(ISP1301_I2C_OTG_CONTROL_1_SET, + isp1301_set_value(dev, ISP1301_I2C_OTG_CONTROL_1_CLR, ~0); + isp1301_set_value(dev, ISP1301_I2C_MODE_CONTROL_1_SET, MC1_DAT_SE0); + isp1301_set_value(dev, ISP1301_I2C_OTG_CONTROL_1_SET, OTG1_DM_PULLDOWN | OTG1_DP_PULLDOWN); - isp1301_set_value(ISP1301_I2C_OTG_CONTROL_1_CLR, + isp1301_set_value(dev, ISP1301_I2C_OTG_CONTROL_1_CLR, OTG1_DM_PULLUP | OTG1_DP_PULLUP); - isp1301_set_value(ISP1301_I2C_INTERRUPT_LATCH_CLR, ~0); - isp1301_set_value(ISP1301_I2C_INTERRUPT_FALLING_CLR, ~0); - isp1301_set_value(ISP1301_I2C_INTERRUPT_RISING_CLR, ~0); + isp1301_set_value(dev, ISP1301_I2C_INTERRUPT_LATCH_CLR, ~0); + isp1301_set_value(dev, ISP1301_I2C_INTERRUPT_FALLING_CLR, ~0); + isp1301_set_value(dev, ISP1301_I2C_INTERRUPT_RISING_CLR, ~0);
/* Enable usb_need_clk clock after transceiver is initialized */ setbits_le32(&clk_pwr->usb_ctrl, CLK_USBCTRL_USBDVND_EN); @@ -149,6 +157,15 @@ static int usbpll_setup(void) int usb_cpu_init(void) { u32 ret; + struct udevice *dev = NULL; + +#ifdef CONFIG_DM_I2C + ret = i2c_get_chip_for_busnum(I2C_2, ISP1301_I2C_ADDR, 1, &dev); + if (ret) { + debug("%s: No bus %d\n", __func__, I2C_2); + return ret; + } +#endif
/* * USB pins routing setup is done by "lpc32xx_usb_init()" and should @@ -167,7 +184,7 @@ int usb_cpu_init(void) return ret;
/* Configure ISP1301 */ - isp1301_configure(); + isp1301_configure(dev);
/* setup USB clocks and PLL */ ret = usbpll_setup(); @@ -188,21 +205,32 @@ int usb_cpu_init(void) return ret;
setbits_le32(&otg->otg_sts_ctrl, OTG_HOST_EN); - isp1301_set_value(ISP1301_I2C_OTG_CONTROL_1_SET, OTG1_VBUS_DRV); + isp1301_set_value(dev, ISP1301_I2C_OTG_CONTROL_1_SET, OTG1_VBUS_DRV);
return 0; }
int usb_cpu_stop(void) { + struct udevice *dev = NULL; + int ret = 0; + +#ifdef CONFIG_DM_I2C + ret = i2c_get_chip_for_busnum(I2C_2, ISP1301_I2C_ADDR, 1, &dev); + if (ret) { + debug("%s: No bus %d\n", __func__, I2C_2); + return ret; + } +#endif + /* vbus off */ - isp1301_set_value(ISP1301_I2C_OTG_CONTROL_1_SET, OTG1_VBUS_DRV); + isp1301_set_value(dev, ISP1301_I2C_OTG_CONTROL_1_SET, OTG1_VBUS_DRV);
clrbits_le32(&otg->otg_sts_ctrl, OTG_HOST_EN);
clrbits_le32(&clk_pwr->usb_ctrl, CLK_USBCTRL_HCLK_EN);
- return 0; + return ret; }
int usb_cpu_init_fail(void)
- Code clean-up to remove conditional compile else section (CONFIG_DM_I2C).
- As suggested by Marek, added Simon Glass to the list of cc for the patch.
- Do not request udevice on each single i2c write.
Note:
- return dm_i2c_write(dev, reg, &value, 1);
+#endif }
- isp1301_set_value(dev, ISP1301_I2C_MODE_CONTROL_1_CLR, MC1_UART_EN);
- isp1301_set_value(dev, ISP1301_I2C_MODE_CONTROL_1_CLR, ~MC1_SPEED_REG);
- isp1301_set_value(dev, ISP1301_I2C_MODE_CONTROL_1_SET, MC1_SPEED_REG);
- isp1301_set_value(dev, ISP1301_I2C_MODE_CONTROL_2_CLR, ~0);
- isp1301_set_value(dev, ISP1301_I2C_MODE_CONTROL_2_SET, MC2_BI_DI | MC2_PSW_EN | MC2_SPD_SUSP_CTRL);
- isp1301_set_value(dev, ISP1301_I2C_OTG_CONTROL_1_CLR, ~0);
- isp1301_set_value(dev, ISP1301_I2C_MODE_CONTROL_1_SET, MC1_DAT_SE0);
- isp1301_set_value(dev, ISP1301_I2C_OTG_CONTROL_1_SET, OTG1_DM_PULLDOWN | OTG1_DP_PULLDOWN);
- isp1301_set_value(dev, ISP1301_I2C_OTG_CONTROL_1_CLR, OTG1_DM_PULLUP | OTG1_DP_PULLUP);
- struct udevice *dev = NULL;
- ret = i2c_get_chip_for_busnum(I2C_2, ISP1301_I2C_ADDR, 1, &dev);
- if (ret) {
return ret;
- int ret = 0;
- if (ret) {
return ret;
- /* vbus off */
- return ret;
Note:
Please check header file order.
http://www.denx.de/wiki/U-Boot/CodingStyle
+#endif }
isp1301_set_value(dev, ISP1301_I2C_INTERRUPT_RISING_CLR, ~0); /* Enable usb_need_clk clock after transceiver is initialized */ setbits_le32(&clk_pwr->usb_ctrl, CLK_USBCTRL_USBDVND_EN);
Can you pick this up from the device tree?
if (ret) {
return ret;
isp1301_configure(dev); /* setup USB clocks and PLL */ ret = usbpll_setup();
isp1301_set_value(dev, ISP1301_I2C_OTG_CONTROL_1_SET, OTG1_VBUS_DRV); return 0;
int ret = 0;
if (ret) {
return ret;
/* vbus off */
isp1301_set_value(dev, ISP1301_I2C_OTG_CONTROL_1_SET, OTG1_VBUS_DRV); clrbits_le32(&otg->otg_sts_ctrl, OTG_HOST_EN); clrbits_le32(&clk_pwr->usb_ctrl, CLK_USBCTRL_HCLK_EN);
return ret;
2.11.0
Note:
I will submit a revision 4.
+#endif }
This is not possible; the mainline LPC32xx boards (devkit3250 & work_92105), are not supporting the devicetree bindings.
The I2C & USB drivers are require to work properly with DM for a non-device tree environment.
if (ret) {
return ret;
int ret = 0;
if (ret) {
return ret;
/* vbus off */
return ret;
2.11.0
Regards, Sylvain Lemieux
Sylvain Lemieux
