[U-Boot] [PATCH v2] arm: mx6: Change defines ENET_xxMHz to ENET_xxMHZ (no CamelCase)
As checkpatch complaines about these camel-case defines, lets change them to only use upper-case characters.
Signed-off-by: Stefan Roese sr@denx.de Acked-by: Heiko Schocher hs@denx.de Cc: Fabio Estevam fabio.estevam@freescale.com Cc: Jon Nettleton jon.nettleton@gmail.com Cc: Stefano Babic sbabic@denx.de --- v2: - Rebased on current master
arch/arm/cpu/armv7/mx6/clock.c | 2 +- arch/arm/include/asm/arch-mx6/clock.h | 8 ++++---- board/aristainetos/aristainetos.c | 2 +- board/freescale/mx6slevk/mx6slevk.c | 2 +- board/freescale/mx6sxsabresd/mx6sxsabresd.c | 2 +- board/solidrun/hummingboard/hummingboard.c | 2 +- 6 files changed, 9 insertions(+), 9 deletions(-)
diff --git a/arch/arm/cpu/armv7/mx6/clock.c b/arch/arm/cpu/armv7/mx6/clock.c index ab7ac3d..93a02ad 100644 --- a/arch/arm/cpu/armv7/mx6/clock.c +++ b/arch/arm/cpu/armv7/mx6/clock.c @@ -443,7 +443,7 @@ int enable_fec_anatop_clock(enum enet_freq freq) struct anatop_regs __iomem *anatop = (struct anatop_regs __iomem *)ANATOP_BASE_ADDR;
- if (freq < ENET_25MHz || freq > ENET_125MHz) + if (freq < ENET_25MHZ || freq > ENET_125MHZ) return -EINVAL;
reg = readl(&anatop->pll_enet); diff --git a/arch/arm/include/asm/arch-mx6/clock.h b/arch/arm/include/asm/arch-mx6/clock.h index 323805c..226a4cd 100644 --- a/arch/arm/include/asm/arch-mx6/clock.h +++ b/arch/arm/include/asm/arch-mx6/clock.h @@ -43,10 +43,10 @@ enum mxc_clock { };
enum enet_freq { - ENET_25MHz, - ENET_50MHz, - ENET_100MHz, - ENET_125MHz, + ENET_25MHZ, + ENET_50MHZ, + ENET_100MHZ, + ENET_125MHZ, };
u32 imx_get_uartclk(void); diff --git a/board/aristainetos/aristainetos.c b/board/aristainetos/aristainetos.c index 06922c0..67ac260 100644 --- a/board/aristainetos/aristainetos.c +++ b/board/aristainetos/aristainetos.c @@ -301,7 +301,7 @@ int board_eth_init(bd_t *bis) /* clear gpr1[14], gpr1[18:17] to select anatop clock */ clrsetbits_le32(&iomuxc_regs->gpr[1], IOMUX_GPR1_FEC_MASK, 0);
- ret = enable_fec_anatop_clock(ENET_50MHz); + ret = enable_fec_anatop_clock(ENET_50MHZ); if (ret) return ret;
diff --git a/board/freescale/mx6slevk/mx6slevk.c b/board/freescale/mx6slevk/mx6slevk.c index 8111edf..cac6d73 100644 --- a/board/freescale/mx6slevk/mx6slevk.c +++ b/board/freescale/mx6slevk/mx6slevk.c @@ -234,7 +234,7 @@ static int setup_fec(void) /* clear gpr1[14], gpr1[18:17] to select anatop clock */ clrsetbits_le32(&iomuxc_regs->gpr[1], IOMUX_GPR1_FEC_MASK, 0);
- return enable_fec_anatop_clock(ENET_50MHz); + return enable_fec_anatop_clock(ENET_50MHZ); } #endif
diff --git a/board/freescale/mx6sxsabresd/mx6sxsabresd.c b/board/freescale/mx6sxsabresd/mx6sxsabresd.c index 7aee074..8b959b9 100644 --- a/board/freescale/mx6sxsabresd/mx6sxsabresd.c +++ b/board/freescale/mx6sxsabresd/mx6sxsabresd.c @@ -168,7 +168,7 @@ static int setup_fec(void) reg |= BM_ANADIG_PLL_ENET_REF_25M_ENABLE; writel(reg, &anatop->pll_enet);
- return enable_fec_anatop_clock(ENET_125MHz); + return enable_fec_anatop_clock(ENET_125MHZ); }
int board_eth_init(bd_t *bis) diff --git a/board/solidrun/hummingboard/hummingboard.c b/board/solidrun/hummingboard/hummingboard.c index 6d204b3..52c384b 100644 --- a/board/solidrun/hummingboard/hummingboard.c +++ b/board/solidrun/hummingboard/hummingboard.c @@ -146,7 +146,7 @@ int board_eth_init(bd_t *bis) { struct iomuxc *const iomuxc_regs = (struct iomuxc *)IOMUXC_BASE_ADDR;
- int ret = enable_fec_anatop_clock(ENET_25MHz); + int ret = enable_fec_anatop_clock(ENET_25MHZ); if (ret) return ret;
Reviewed-by: Fabio Estevam fabio.estevam@freescale.com
v2:
enum enet_freq {
- ENET_25MHz,
- ENET_50MHz,
- ENET_100MHz,
- ENET_125MHz,
- ENET_25MHZ,
- ENET_50MHZ,
- ENET_100MHZ,
- ENET_125MHZ,
- ret = enable_fec_anatop_clock(ENET_50MHZ); if (ret) return ret;
- return enable_fec_anatop_clock(ENET_50MHZ);
} #endif
- return enable_fec_anatop_clock(ENET_125MHZ);
- int ret = enable_fec_anatop_clock(ENET_25MHZ); if (ret) return ret;
Best regards, Stefano Babic
Actually, it would be better to fix checkpatch. MHz is not camelcase... Fortunately MHZ is unique, but theres real difference between MB and Mb...
Pavel
Fabio Estevam
Pavel Machek
Stefan Roese
Stefano Babic
