Re: [PATCH v3] dt-bindings: riscv: deprecate riscv,isa
On Tue, 27 Jun 2023 08:49:06 PDT (-0700), Palmer Dabbelt wrote:
On Mon, 26 Jun 2023 23:52:06 PDT (-0700), apatel@ventanamicro.com wrote:
On Tue, Jun 27, 2023 at 1:23 AM Palmer Dabbelt palmer@rivosinc.com wrote:
On Mon, 26 Jun 2023 10:38:43 PDT (-0700), apatel@ventanamicro.com wrote:
On Mon, Jun 26, 2023 at 3:42 PM Conor Dooley conor.dooley@microchip.com wrote:
intro
When the RISC-V dt-bindings were accepted upstream in Linux, the base ISA etc had yet to be ratified. By the ratification of the base ISA, incompatible changes had snuck into the specifications - for example the Zicsr and Zifencei extensions were spun out of the base ISA.
Fast forward to today, and the reason for this patch. Currently the riscv,isa dt property permits only a specific subset of the ISA string - in particular it excludes version numbering. With the current constraints, it is not possible to discern whether "rv64i" means that the hart supports the fence.i instruction, for example. Future systems may choose to implement their own instruction fencing, perhaps using a vendor extension, or they may not implement the optional counter extensions. Software needs a way to determine this.
versioning schemes
"Use the extension versions that are described in the ISA manual" you may say, and it's not like this has not been considered. Firstly, software that parses the riscv,isa property at runtime will need to contain a lookup table of some sort that maps arbitrary versions to versions it understands. There is not a consistent application of version number applied to extensions, with a higgledy-piggledy collection of tags, "bare" and versioned documents awaiting the reader on the "recently ratified extensions" page: https://wiki.riscv.org/display/HOME/Recently+Ratified+Extensions
As an aside, and this is reflected in the patch too, since many extensions have yet to appear in a release of the ISA specs, they are defined by commits in their respective "working draft" repositories.
Secondly, there is an issue of backwards compatibility, whereby allowing numbers in the ISA string, some parsers may be broken. This would require an additional property to be created to even use the versions in this manner.
~boolean properties~ string array property
If a new property is needed, the whole approach may as well be looked at from the bottom up. A string with limited character choices etc is hardly the best approach for communicating extension information to software.
Switching to using properties that are defined on a per extension basis, allows us to define explicit meanings for the DT representation of each extension - rather than the current situation where different operating systems or other bits of software may impart different meanings to characters in the string. Clearly the best source of meanings is the specifications themselves, this just provides us the ability to choose at what point in time the meaning is set. If an extension changes incompatibility in the future, a new property will be required.
Off-list, some of the RVI folks have committed to shoring up the wording in either the ISA specifications, the riscv-isa-manual or so that in the future, modifications to and additions or removals of features will require a new extension. Codifying that assertion somewhere would make it quite unlikely that compatibility would be broken, but we have the tools required to deal with it, if & when it crops up. It is in our collective interest, as consumers of extension meanings, to define a scheme that enforces compatibility.
The use of individual properties, rather than elements in a single string, will also permit validation that the properties have a meaning, as well as potentially reject mutually exclusive combinations, or enforce dependencies between extensions. That would not have be possible with the current dt-schema infrastructure for arbitrary strings, as we would need to add a riscv,isa parser to dt-validate! That's not implemented in this patch, but rather left as future work (for the brave, or the foolish).
acpi
The current ACPI ECR is based on having a single ISA string unfortunately, but ideally ACPI will move to another method, perhaps GUIDs, that give explicit meaning to extensions.
Drop this paragraph on ACPI.
We clearly mentioned previously that ACPI will follow specs defined by RVI. There are scalability issues in using GUIDs for each ISA extension.
Which spec are we following for the ACPI ISA string?
ACPI RHCT follows the "ISA Extension Naming Conventions" defined by the RISC-V unpriv spec. I understand that there are unresolved issues in the "ISA Extension Naming Conventions" which should be addressed by RVI and we should also try our best to have this fixed in the spec.
Which version of the spec? We've had a ton of issues related to versioning everywhere else the ISA string has been used, we need to know specifically which version we're parsing in order to do anything meaningful with it.
Anup: Can you please provide a pointer to the spec this is supposed to implement? I don't want to end up in the same spot again where we're presuming some spec changes, we've got to support whatever we merge no matter what happens on the spec side.
In theory I'm on vacation today, but I'll try and look at the thread again tonight when I get back.
In any case, ACPI spec is owned by UEFI forum so it does not make sense to define/recommend anything for ACPI in DT bindings.
Unless I missed something this is just a long commit message, it's not even in the docs. If you don't want the DT side to even mention ACPI that's fine with me, though, I don't really care.
Regards, Anup
Regards, Anup
parser simplicity
Many systems that parse DT at runtime already implement an function that can check for the presence of a string in an array of string, as it is similar to the process for parsing a list of compatible strings, so a bunch of new, custom, DT parsing should not be needed. Getting rid of "riscv,isa" parsing would be a nice simplification, but unfortunately for backwards compatibility with old dtbs, existing parsers may not be removable - which may greatly simplify dt parsing code. In Linux, for example, checking for whether a hart supports an extension becomes as simple as: of_property_match_string(node, "riscv,isa-extensions", "zicbom")
vendor extensions
Compared to riscv,isa, this proposed scheme promotes vendor extensions, oft touted as the strength of RISC-V, to first-class citizens. At present, extensions are defined as meaning what the RISC-V ISA specifications say they do. There is no realistic way of using that interface to provide cross-platform definitions for what vendor extensions mean. Vendor extensions may also have even less consistency than RVI do in terms of versioning, or no care about backwards compatibility. The new property allows us to assign explicit meanings on a per vendor extension basis, backed up by a description of their meanings.
fin
Create a new file to store the extension meanings and a new riscv,isa-base property to replace the aspect of riscv,isa that is not represented by the new property - the base ISA implemented by a hart.
As a starting point, add properties for extensions currently used in Linux.
Finally, mark riscv,isa as deprecated, as removing support for it in existing programs would be an ABI break.
CC: Palmer Dabbelt palmer@dabbelt.com CC: Paul Walmsley paul.walmsley@sifive.com CC: Rob Herring robh+dt@kernel.org CC: Krzysztof Kozlowski krzysztof.kozlowski+dt@linaro.org CC: Alistair Francis alistair.francis@wdc.com CC: Andrew Jones ajones@ventanamicro.com CC: Anup Patel apatel@ventanamicro.com CC: Atish Patra atishp@atishpatra.org CC: Jessica Clarke jrtc27@jrtc27.com CC: Rick Chen rick@andestech.com CC: Leo ycliang@andestech.com CC: Oleksii oleksii.kurochko@gmail.com CC: linux-riscv@lists.infradead.org CC: qemu-riscv@nongnu.org CC: u-boot@lists.denx.de CC: devicetree@vger.kernel.org CC: linux-kernel@vger.kernel.org Reviewed-by: Palmer Dabbelt palmer@rivosinc.com Acked-by: Palmer Dabbelt palmer@rivosinc.com Signed-off-by: Conor Dooley conor.dooley@microchip.com
Changes in v3:
- Per Rob's suggestion, switch to an array of strings. Cuts down on the size, compared to booleans. It has a standard mechanism for parsing (you need to parse arrays of strings for compatibles). It still allows for having a limited set of explicitly defined properties - so the advantages over a free-form string still apply.
- Pick up Palmer's Ack and Review (although I expect that he will be the one to apply this).
.../devicetree/bindings/riscv/cpus.yaml | 43 ++- .../devicetree/bindings/riscv/extensions.yaml | 245 ++++++++++++++++++ 2 files changed, 265 insertions(+), 23 deletions(-) create mode 100644 Documentation/devicetree/bindings/riscv/extensions.yaml
diff --git a/Documentation/devicetree/bindings/riscv/cpus.yaml b/Documentation/devicetree/bindings/riscv/cpus.yaml index 67bd239ead0b..74bc92591086 100644 --- a/Documentation/devicetree/bindings/riscv/cpus.yaml +++ b/Documentation/devicetree/bindings/riscv/cpus.yaml @@ -25,6 +25,7 @@ description: |
allOf:
- $ref: /schemas/cpu.yaml#
- $ref: extensions.yaml
properties: compatible: @@ -82,25 +83,6 @@ properties: description: The blocksize in bytes for the Zicboz cache operations.
- riscv,isa:
- description:
Identifies the specific RISC-V instruction set architecture
supported by the hart. These are documented in the RISC-V
User-Level ISA document, available from
https://riscv.org/specifications/
Due to revisions of the ISA specification, some deviations
have arisen over time.
Notably, riscv,isa was defined prior to the creation of the
Zicntr, Zicsr, Zifencei and Zihpm extensions and thus "i"
implies "zicntr_zicsr_zifencei_zihpm".
While the isa strings in ISA specification are case
insensitive, letters in the riscv,isa string must be all
lowercase.
- $ref: /schemas/types.yaml#/definitions/string
- pattern: ^rv(?:64|32)imaf?d?q?c?b?k?j?p?v?h?(?:[hsxz](?:[a-z])+)?(?:_[hsxz](?:[a-z])+)*$
- # RISC-V has multiple properties for cache op block sizes as the sizes # differ between individual CBO extensions cache-op-block-size: false
@@ -139,8 +121,17 @@ properties: DMIPS/MHz, relative to highest capacity-dmips-mhz in the system.
+oneOf:
- required:
- riscv,isa
- required:
- riscv,isa-base
+dependencies:
- riscv,isa-base: [ "riscv,isa-extensions" ]
- riscv,isa-extensions: [ "riscv,isa-base" ]
required:
- riscv,isa
- interrupt-controller
unevaluatedProperties: false @@ -160,7 +151,9 @@ examples: i-cache-sets = <128>; i-cache-size = <16384>; reg = <0>;
riscv,isa = "rv64imac";
riscv,isa-base = "rv64i";
riscv,isa-extensions = "i", "m", "a", "c";
cpu_intc0: interrupt-controller { #interrupt-cells = <1>; compatible = "riscv,cpu-intc";
@@ -183,8 +176,10 @@ examples: i-tlb-size = <32>; mmu-type = "riscv,sv39"; reg = <1>;
riscv,isa = "rv64imafdc"; tlb-split;
riscv,isa-extensions = "i", "m", "a", "f", "d", "c";
cpu_intc1: interrupt-controller { #interrupt-cells = <1>; compatible = "riscv,cpu-intc";
@@ -202,8 +197,10 @@ examples: device_type = "cpu"; reg = <0>; compatible = "riscv";
riscv,isa = "rv64imafdc"; mmu-type = "riscv,sv48";
interrupt-controller { #interrupt-cells = <1>; interrupt-controller;
diff --git a/Documentation/devicetree/bindings/riscv/extensions.yaml b/Documentation/devicetree/bindings/riscv/extensions.yaml new file mode 100644 index 000000000000..af98307f2c2c --- /dev/null +++ b/Documentation/devicetree/bindings/riscv/extensions.yaml @@ -0,0 +1,245 @@ +# SPDX-License-Identifier: (GPL-2.0 OR MIT) +%YAML 1.2 +--- +$id: http://devicetree.org/schemas/riscv/extensions.yaml# +$schema: http://devicetree.org/meta-schemas/core.yaml#
+title: RISC-V ISA extensions
+maintainers:
- Paul Walmsley paul.walmsley@sifive.com
- Palmer Dabbelt palmer@sifive.com
- Conor Dooley conor@kernel.org
+description: |
- RISC-V has a large number of extensions, some of which are "standard"
- extensions, meaning they are ratified by RISC-V International, and others
- are "vendor" extensions.
- This document defines properties that indicate whether a hart supports a
- given extension.
- Once a standard extension has been ratified, no changes in behaviour can be
- made without the creation of a new extension.
- The properties for standard extensions therefore map to their originally
- ratified states, with the exception of the I, Zicntr & Zihpm extensions.
- See the "i" property for more information.
+select:
- properties:
- compatible:
contains:
const: riscv
+properties:
- riscv,isa:
- description:
lowercase.
- deprecated: true
- riscv,isa-base:
- description:
The base ISA implemented by this hart, as described by the 20191213
version of the unprivileged ISA specification.
- enum:
- rv32i
- rv64i
- $ref: /schemas/types.yaml#/definitions/string-array
- minItems: 1
- description: Extensions supported by the hart.
- items:
anyOf:
# single letter extensions, in canonical order
- const: i
description: |
The base integer instruction set, as ratified in the 20191213
version of the unprivileged ISA specification, with the exception of
counter access.
Counter access was removed after the ratification of the 20191213
version of the unprivileged specification and shunted into the
Zicntr and Zihpm extensions.
- const: m
description:
The standard M extension for integer multiplication and division, as
ratified in the 20191213 version of the unprivileged ISA
specification.
- const: a
description:
The standard A extension for atomic instructions, as ratified in the
20191213 version of the unprivileged ISA specification.
- const: f
description:
The standard F extension for single-precision floating point, as
specification.
- const: d
description:
The standard D extension for double-precision floating-point, as
specification.
- const: q
description:
The standard Q extension for quad-precision floating-point, as
specification.
- const: c
description:
The standard C extension for compressed instructions, as ratified in
the 20191213 version of the unprivileged ISA specification.
- const: v
description:
The standard V extension for vector operations, as ratified
in-and-around commit 7a6c8ae ("Fix text that describes vfmv.v.f
encoding") of the riscv-v-spec.
- const: h
description:
The standard H extension for hypervisors as ratified in the 20191213
version of the privileged ISA specification.
# multi-letter extensions, sorted alphanumerically
- const: smaia
description: |
The standard Smaia supervisor-level extension for the advanced
interrupt architecture for machine-mode-visible csr and behavioural
changes to interrupts as frozen at commit ccbddab ("Merge pull
request #42 from riscv/jhauser-2023-RC4") of riscv-aia.
- const: ssaia
description: |
The standard Ssaia supervisor-level extension for the advanced
interrupt architecture for supervisor-mode-visible csr and
behavioural changes to interrupts as frozen at commit ccbddab
("Merge pull request #42 from riscv/jhauser-2023-RC4") of riscv-aia.
- const: sscofpmf
description: |
The standard Sscofpmf supervisor-level extension for count overflow
and mode-based filtering as ratified at commit 01d1df0 ("Add ability
to manually trigger workflow. (#2)") of riscv-count-overflow.
- const: sstc
description: |
The standard Sstc supervisor-level extension for time compare as
ratified at commit 3f9ed34 ("Add ability to manually trigger
workflow. (#2)") of riscv-time-compare.
- const: svinval
description:
The standard Svinval supervisor-level extension for fine-grained
address-translation cache invalidation as ratified in the 20191213
- const: svnapot
description:
The standard Svnapot supervisor-level extensions for napot
translation contiguity as ratified in the 20191213 version of the
- const: svpbmt
description:
The standard Svpbmt supervisor-level extensions for page-based
memory types as ratified in the 20191213 version of the privileged
ISA specification.
- const: zba
description: |
The standard Zba bit-manipulation extension for address generation
acceleration instructions as ratified at commit 6d33919 ("Merge pull
request #158 from hirooih/clmul-fix-loop-end-condition") of
riscv-bitmanip.
- const: zbb
description: |
The standard Zbb bit-manipulation extension for basic bit-manipulation
as ratified at commit 6d33919 ("Merge pull request #158 from
hirooih/clmul-fix-loop-end-condition") of riscv-bitmanip.
- const: zbc
description: |
The standard Zbc bit-manipulation extension for carry-less
multiplication as ratified at commit 6d33919 ("Merge pull request
#158 from hirooih/clmul-fix-loop-end-condition") of riscv-bitmanip.
- const: zbs
description: |
The standard Zbs bit-manipulation extension for single-bit
instructions as ratified at commit 6d33919 ("Merge pull request #158
- const: zicbom
description:
The standard Zicbom extension for base cache management operations as
ratified in commit 3dd606f ("Create cmobase-v1.0.pdf") of riscv-CMOs.
- const: zicbop
description:
The standard Zicbop extension for cache-block prefetch instructions
as ratified in commit 3dd606f ("Create cmobase-v1.0.pdf") of
riscv-CMOs.
- const: zicboz
description:
The standard Zicboz extension for cache-block zeroing as ratified
- const: zicntr
description:
The standard Zicntr extension for base counters and timers, as
specification.
- const: zicsr
description:
The standard Zicsr extension for control and status register
instructions, as ratified in the 20191213 version of the
- const: zifencei
description:
The standard Zifencei extension for instruction-fetch fence, as
specification.
- const: zihintpause
description:
The standard Zihintpause extension for pause hints, as ratified in
commit d8ab5c7 ("Zihintpause is ratified") of the riscv-isa-manual.
- const: zihpm
description:
The standard Zihpm extension for hardware performance counters, as
specification.
- const: ztso
description:
The standard Ztso extension for total store ordering, as ratified
in commit 2e5236 ("Ztso is now ratified.") of the
riscv-isa-manual.
+additionalProperties: true
2.40.1
intro
versioning schemes
acpi
It is the "Chapter 29. ISA Extension Naming Conventions" of the RISC-V unpriv specification. (https://github.com/riscv/riscv-isa-manual/releases/download/riscv-isa-releas...)
The RISC-V unpriv specification is only a collection of extensions hence it does not have its own version.
We should work with RVI to address the concerns/clarifications that we need in "Chapter 29. ISA Extension Naming Conventions".
We can also create GitHub issues for unpriv spec if that helps.
Regards, Anup
Regards, Anup
Regards, Anup
parser simplicity
vendor extensions
fin
Changes in v3:
allOf:
- riscv,isa:
- description:
lowercase.
+oneOf:
- required:
- riscv,isa
- required:
- riscv,isa-base
+dependencies:
required:
- riscv,isa
+maintainers:
+description: |
- given extension.
+select:
- properties:
- compatible:
contains:
const: riscv
+properties:
- riscv,isa:
- description:
lowercase.
- deprecated: true
- riscv,isa-base:
- description:
- enum:
- rv32i
- rv64i
- minItems: 1
- items:
anyOf:
- const: i
description: |
counter access.
- const: m
description:
specification.
- const: a
description:
- const: f
description:
specification.
- const: d
description:
specification.
- const: q
description:
specification.
- const: c
description:
- const: v
description:
- const: h
description:
- const: smaia
description: |
- const: ssaia
description: |
- const: sscofpmf
description: |
- const: sstc
description: |
- const: svinval
description:
- const: svnapot
description:
- const: svpbmt
description:
ISA specification.
- const: zba
description: |
riscv-bitmanip.
- const: zbb
description: |
- const: zbc
description: |
- const: zbs
description: |
- const: zicbom
description:
- const: zicbop
description:
riscv-CMOs.
- const: zicboz
description:
- const: zicntr
description:
specification.
- const: zicsr
description:
- const: zifencei
description:
specification.
description:
- const: zihpm
description:
specification.
- const: ztso
description:
riscv-isa-manual.
2.40.1
On Mon, Jun 26, 2023 at 3:42 PM Conor Dooley conor.dooley@microchip.com wrote: > > intro > ===== > > When the RISC-V dt-bindings were accepted upstream in Linux, the base > ISA etc had yet to be ratified. By the ratification of the base ISA, > incompatible changes had snuck into the specifications - for example the > Zicsr and Zifencei extensions were spun out of the base ISA. > > Fast forward to today, and the reason for this patch. > Currently the riscv,isa dt property permits only a specific subset of > the ISA string - in particular it excludes version numbering. > With the current constraints, it is not possible to discern whether > "rv64i" means that the hart supports the fence.i instruction, for > example. > Future systems may choose to implement their own instruction fencing, > perhaps using a vendor extension, or they may not implement the optional > counter extensions. Software needs a way to determine this. > > versioning schemes > ================== > > "Use the extension versions that are described in the ISA manual" you > may say, and it's not like this has not been considered. > Firstly, software that parses the riscv,isa property at runtime will > need to contain a lookup table of some sort that maps arbitrary versions > to versions it understands. There is not a consistent application of > version number applied to extensions, with a higgledy-piggledy > collection of tags, "bare" and versioned documents awaiting the reader > on the "recently ratified extensions" page: > https://wiki.riscv.org/display/HOME/Recently+Ratified+Extensions > > As an aside, and this is reflected in the patch too, since many > extensions have yet to appear in a release of the ISA specs, > they are defined by commits in their respective "working draft" > repositories. > > Secondly, there is an issue of backwards compatibility, whereby allowing > numbers in the ISA string, some parsers may be broken. This would > require an additional property to be created to even use the versions in > this manner. > > ~boolean properties~ string array property > ========================================== > > If a new property is needed, the whole approach may as well be looked at > from the bottom up. A string with limited character choices etc is > hardly the best approach for communicating extension information to > software. > > Switching to using properties that are defined on a per extension basis, > allows us to define explicit meanings for the DT representation of each > extension - rather than the current situation where different operating > systems or other bits of software may impart different meanings to > characters in the string. > Clearly the best source of meanings is the specifications themselves, > this just provides us the ability to choose at what point in time the > meaning is set. If an extension changes incompatibility in the future, > a new property will be required. > > Off-list, some of the RVI folks have committed to shoring up the wording > in either the ISA specifications, the riscv-isa-manual or > so that in the future, modifications to and additions or removals of > features will require a new extension. Codifying that assertion > somewhere would make it quite unlikely that compatibility would be > broken, but we have the tools required to deal with it, if & when it > crops up. > It is in our collective interest, as consumers of extension meanings, to > define a scheme that enforces compatibility. > > The use of individual properties, rather than elements in a single > string, will also permit validation that the properties have a meaning, > as well as potentially reject mutually exclusive combinations, or > enforce dependencies between extensions. That would not have be possible > with the current dt-schema infrastructure for arbitrary strings, as we > would need to add a riscv,isa parser to dt-validate! > That's not implemented in this patch, but rather left as future work (for > the brave, or the foolish). > > acpi > ==== > > The current ACPI ECR is based on having a single ISA string unfortunately, > but ideally ACPI will move to another method, perhaps GUIDs, that give > explicit meaning to extensions.
There's a version right on the front page, it says "Version ASCIIDOC Conversion, 12/2022". There's a few with that version, but versioning is pretty broken in RISC-V land so we've mostly just started running with the commits/tags.
It also says it's a pre release version, but if that's what ACPI is using then I'm fine with it -- the key is that whatever we're supporting we're stuck with, as we have to maintain compatibility here.
The nice thing about starting with a new interface is that there's nothing to be compatible with, so there's no issues. Given what a mess ISA strings have been everywhere else I'm sure we'll have some, but that's problem for later.
I couldn't find anywhere else this was written down, so I started an ACPI doc -- as usual maybe a bit odd for just the one thing, but we usually end up with more.
https://lore.kernel.org/r/20230629031705.15575-1-palmer@rivosinc.com/
Regards, Anup
Regards, Anup
Regards, Anup
> > parser simplicity > ================= > > Many systems that parse DT at runtime already implement an function that > can check for the presence of a string in an array of string, as it is > similar to the process for parsing a list of compatible strings, so a > bunch of new, custom, DT parsing should not be needed. > Getting rid of "riscv,isa" parsing would be a nice simplification, but > unfortunately for backwards compatibility with old dtbs, existing > parsers may not be removable - which may greatly simplify > dt parsing code. In Linux, for example, checking for whether a hart > supports an extension becomes as simple as: > of_property_match_string(node, "riscv,isa-extensions", "zicbom") > > vendor extensions > ================= > > Compared to riscv,isa, this proposed scheme promotes vendor extensions, > oft touted as the strength of RISC-V, to first-class citizens. > At present, extensions are defined as meaning what the RISC-V ISA > specifications say they do. There is no realistic way of using that > interface to provide cross-platform definitions for what vendor > extensions mean. Vendor extensions may also have even less consistency > than RVI do in terms of versioning, or no care about backwards > compatibility. > The new property allows us to assign explicit meanings on a per vendor > extension basis, backed up by a description of their meanings. > > fin > === > > Create a new file to store the extension meanings and a new > riscv,isa-base property to replace the aspect of riscv,isa that is > not represented by the new property - the base ISA implemented by a hart. > > As a starting point, add properties for extensions currently used in > Linux. > > Finally, mark riscv,isa as deprecated, as removing support for it in > existing programs would be an ABI break. > > CC: Palmer Dabbelt palmer@dabbelt.com > CC: Paul Walmsley paul.walmsley@sifive.com > CC: Rob Herring robh+dt@kernel.org > CC: Krzysztof Kozlowski krzysztof.kozlowski+dt@linaro.org > CC: Alistair Francis alistair.francis@wdc.com > CC: Andrew Jones ajones@ventanamicro.com > CC: Anup Patel apatel@ventanamicro.com > CC: Atish Patra atishp@atishpatra.org > CC: Jessica Clarke jrtc27@jrtc27.com > CC: Rick Chen rick@andestech.com > CC: Leo ycliang@andestech.com > CC: Oleksii oleksii.kurochko@gmail.com > CC: linux-riscv@lists.infradead.org > CC: qemu-riscv@nongnu.org > CC: u-boot@lists.denx.de > CC: devicetree@vger.kernel.org > CC: linux-kernel@vger.kernel.org > Reviewed-by: Palmer Dabbelt palmer@rivosinc.com > Acked-by: Palmer Dabbelt palmer@rivosinc.com > Signed-off-by: Conor Dooley conor.dooley@microchip.com > --- > Changes in v3: > - Per Rob's suggestion, switch to an array of strings. Cuts down on the > size, compared to booleans. It has a standard mechanism for parsing > (you need to parse arrays of strings for compatibles). It still allows > for having a limited set of explicitly defined properties - so the > advantages over a free-form string still apply. > - Pick up Palmer's Ack and Review (although I expect that he will be the > one to apply this). > --- > .../devicetree/bindings/riscv/cpus.yaml | 43 ++- > .../devicetree/bindings/riscv/extensions.yaml | 245 ++++++++++++++++++ > 2 files changed, 265 insertions(+), 23 deletions(-) > create mode 100644 Documentation/devicetree/bindings/riscv/extensions.yaml > > diff --git a/Documentation/devicetree/bindings/riscv/cpus.yaml b/Documentation/devicetree/bindings/riscv/cpus.yaml > index 67bd239ead0b..74bc92591086 100644 > --- a/Documentation/devicetree/bindings/riscv/cpus.yaml > +++ b/Documentation/devicetree/bindings/riscv/cpus.yaml > @@ -25,6 +25,7 @@ description: | > > allOf: > - $ref: /schemas/cpu.yaml# > + - $ref: extensions.yaml > > properties: > compatible: > @@ -82,25 +83,6 @@ properties: > description: > The blocksize in bytes for the Zicboz cache operations. > > - riscv,isa: > - description: > - Identifies the specific RISC-V instruction set architecture > - supported by the hart. These are documented in the RISC-V > - User-Level ISA document, available from > - https://riscv.org/specifications/ > - > - Due to revisions of the ISA specification, some deviations > - have arisen over time. > - Notably, riscv,isa was defined prior to the creation of the > - Zicntr, Zicsr, Zifencei and Zihpm extensions and thus "i" > - implies "zicntr_zicsr_zifencei_zihpm". > - > - While the isa strings in ISA specification are case > - insensitive, letters in the riscv,isa string must be all > - lowercase. > - $ref: /schemas/types.yaml#/definitions/string > - pattern: ^rv(?:64|32)imaf?d?q?c?b?k?j?p?v?h?(?:[hsxz](?:[a-z])+)?(?:_[hsxz](?:[a-z])+)*$ > - > # RISC-V has multiple properties for cache op block sizes as the sizes > # differ between individual CBO extensions > cache-op-block-size: false > @@ -139,8 +121,17 @@ properties: > DMIPS/MHz, relative to highest capacity-dmips-mhz > in the system. > > +oneOf: > + - required: > + - riscv,isa > + - required: > + - riscv,isa-base > + > +dependencies: > + riscv,isa-base: [ "riscv,isa-extensions" ] > + riscv,isa-extensions: [ "riscv,isa-base" ] > + > required: > - - riscv,isa > - interrupt-controller > > unevaluatedProperties: false > @@ -160,7 +151,9 @@ examples: > i-cache-sets = <128>; > i-cache-size = <16384>; > reg = <0>; > - riscv,isa = "rv64imac"; > + riscv,isa-base = "rv64i"; > + riscv,isa-extensions = "i", "m", "a", "c"; > + > cpu_intc0: interrupt-controller { > #interrupt-cells = <1>; > compatible = "riscv,cpu-intc"; > @@ -183,8 +176,10 @@ examples: > i-tlb-size = <32>; > mmu-type = "riscv,sv39"; > reg = <1>; > - riscv,isa = "rv64imafdc"; > tlb-split; > + riscv,isa-base = "rv64i"; > + riscv,isa-extensions = "i", "m", "a", "f", "d", "c"; > + > cpu_intc1: interrupt-controller { > #interrupt-cells = <1>; > compatible = "riscv,cpu-intc"; > @@ -202,8 +197,10 @@ examples: > device_type = "cpu"; > reg = <0>; > compatible = "riscv"; > - riscv,isa = "rv64imafdc"; > mmu-type = "riscv,sv48"; > + riscv,isa-base = "rv64i"; > + riscv,isa-extensions = "i", "m", "a", "f", "d", "c"; > + > interrupt-controller { > #interrupt-cells = <1>; > interrupt-controller; > diff --git a/Documentation/devicetree/bindings/riscv/extensions.yaml b/Documentation/devicetree/bindings/riscv/extensions.yaml > new file mode 100644 > index 000000000000..af98307f2c2c > --- /dev/null > +++ b/Documentation/devicetree/bindings/riscv/extensions.yaml > @@ -0,0 +1,245 @@ > +# SPDX-License-Identifier: (GPL-2.0 OR MIT) > +%YAML 1.2 > +--- > +$id: http://devicetree.org/schemas/riscv/extensions.yaml# > +$schema: http://devicetree.org/meta-schemas/core.yaml# > + > +title: RISC-V ISA extensions > + > +maintainers: > + - Paul Walmsley paul.walmsley@sifive.com > + - Palmer Dabbelt palmer@sifive.com > + - Conor Dooley conor@kernel.org > + > +description: | > + RISC-V has a large number of extensions, some of which are "standard" > + extensions, meaning they are ratified by RISC-V International, and others > + are "vendor" extensions. > + This document defines properties that indicate whether a hart supports a > + given extension. > + > + Once a standard extension has been ratified, no changes in behaviour can be > + made without the creation of a new extension. > + The properties for standard extensions therefore map to their originally > + ratified states, with the exception of the I, Zicntr & Zihpm extensions. > + See the "i" property for more information. > + > +select: > + properties: > + compatible: > + contains: > + const: riscv > + > +properties: > + riscv,isa: > + description: > + Identifies the specific RISC-V instruction set architecture > + supported by the hart. These are documented in the RISC-V > + User-Level ISA document, available from > + https://riscv.org/specifications/ > + > + Due to revisions of the ISA specification, some deviations > + have arisen over time. > + Notably, riscv,isa was defined prior to the creation of the > + Zicntr, Zicsr, Zifencei and Zihpm extensions and thus "i" > + implies "zicntr_zicsr_zifencei_zihpm". > + > + While the isa strings in ISA specification are case > + insensitive, letters in the riscv,isa string must be all > + lowercase. > + $ref: /schemas/types.yaml#/definitions/string > + pattern: ^rv(?:64|32)imaf?d?q?c?b?k?j?p?v?h?(?:[hsxz](?:[a-z])+)?(?:_[hsxz](?:[a-z])+)*$ > + deprecated: true > + > + riscv,isa-base: > + description: > + The base ISA implemented by this hart, as described by the 20191213 > + version of the unprivileged ISA specification. > + enum: > + - rv32i > + - rv64i > + > + riscv,isa-extensions: > + $ref: /schemas/types.yaml#/definitions/string-array > + minItems: 1 > + description: Extensions supported by the hart. > + items: > + anyOf: > + # single letter extensions, in canonical order > + - const: i > + description: | > + The base integer instruction set, as ratified in the 20191213 > + version of the unprivileged ISA specification, with the exception of > + counter access. > + Counter access was removed after the ratification of the 20191213 > + version of the unprivileged specification and shunted into the > + Zicntr and Zihpm extensions. > + > + - const: m > + description: > + The standard M extension for integer multiplication and division, as > + ratified in the 20191213 version of the unprivileged ISA > + specification. > + > + - const: a > + description: > + The standard A extension for atomic instructions, as ratified in the > + 20191213 version of the unprivileged ISA specification. > + > + - const: f > + description: > + The standard F extension for single-precision floating point, as > + ratified in the 20191213 version of the unprivileged ISA > + specification. > + > + - const: d > + description: > + The standard D extension for double-precision floating-point, as > + ratified in the 20191213 version of the unprivileged ISA > + specification. > + > + - const: q > + description: > + The standard Q extension for quad-precision floating-point, as > + ratified in the 20191213 version of the unprivileged ISA > + specification. > + > + - const: c > + description: > + The standard C extension for compressed instructions, as ratified in > + the 20191213 version of the unprivileged ISA specification. > + > + - const: v > + description: > + The standard V extension for vector operations, as ratified > + in-and-around commit 7a6c8ae ("Fix text that describes vfmv.v.f > + encoding") of the riscv-v-spec. > + > + - const: h > + description: > + The standard H extension for hypervisors as ratified in the 20191213 > + version of the privileged ISA specification. > + > + # multi-letter extensions, sorted alphanumerically > + - const: smaia > + description: | > + The standard Smaia supervisor-level extension for the advanced > + interrupt architecture for machine-mode-visible csr and behavioural > + changes to interrupts as frozen at commit ccbddab ("Merge pull > + request #42 from riscv/jhauser-2023-RC4") of riscv-aia. > + > + - const: ssaia > + description: | > + The standard Ssaia supervisor-level extension for the advanced > + interrupt architecture for supervisor-mode-visible csr and > + behavioural changes to interrupts as frozen at commit ccbddab > + ("Merge pull request #42 from riscv/jhauser-2023-RC4") of riscv-aia. > + > + - const: sscofpmf > + description: | > + The standard Sscofpmf supervisor-level extension for count overflow > + and mode-based filtering as ratified at commit 01d1df0 ("Add ability > + to manually trigger workflow. (#2)") of riscv-count-overflow. > + > + - const: sstc > + description: | > + The standard Sstc supervisor-level extension for time compare as > + ratified at commit 3f9ed34 ("Add ability to manually trigger > + workflow. (#2)") of riscv-time-compare. > + > + - const: svinval > + description: > + The standard Svinval supervisor-level extension for fine-grained > + address-translation cache invalidation as ratified in the 20191213 > + version of the privileged ISA specification. > + > + - const: svnapot > + description: > + The standard Svnapot supervisor-level extensions for napot > + translation contiguity as ratified in the 20191213 version of the > + privileged ISA specification. > + > + - const: svpbmt > + description: > + The standard Svpbmt supervisor-level extensions for page-based > + memory types as ratified in the 20191213 version of the privileged > + ISA specification. > + > + - const: zba > + description: | > + The standard Zba bit-manipulation extension for address generation > + acceleration instructions as ratified at commit 6d33919 ("Merge pull > + request #158 from hirooih/clmul-fix-loop-end-condition") of > + riscv-bitmanip. > + > + - const: zbb > + description: | > + The standard Zbb bit-manipulation extension for basic bit-manipulation > + as ratified at commit 6d33919 ("Merge pull request #158 from > + hirooih/clmul-fix-loop-end-condition") of riscv-bitmanip. > + > + - const: zbc > + description: | > + The standard Zbc bit-manipulation extension for carry-less > + multiplication as ratified at commit 6d33919 ("Merge pull request > + #158 from hirooih/clmul-fix-loop-end-condition") of riscv-bitmanip. > + > + - const: zbs > + description: | > + The standard Zbs bit-manipulation extension for single-bit > + instructions as ratified at commit 6d33919 ("Merge pull request #158 > + from hirooih/clmul-fix-loop-end-condition") of riscv-bitmanip. > + > + - const: zicbom > + description: > + The standard Zicbom extension for base cache management operations as > + ratified in commit 3dd606f ("Create cmobase-v1.0.pdf") of riscv-CMOs. > + > + - const: zicbop > + description: > + The standard Zicbop extension for cache-block prefetch instructions > + as ratified in commit 3dd606f ("Create cmobase-v1.0.pdf") of > + riscv-CMOs. > + > + - const: zicboz > + description: > + The standard Zicboz extension for cache-block zeroing as ratified > + in commit 3dd606f ("Create cmobase-v1.0.pdf") of riscv-CMOs. > + > + - const: zicntr > + description: > + The standard Zicntr extension for base counters and timers, as > + ratified in the 20191213 version of the unprivileged ISA > + specification. > + > + - const: zicsr > + description: > + The standard Zicsr extension for control and status register > + instructions, as ratified in the 20191213 version of the > + unprivileged ISA specification. > + > + - const: zifencei > + description: > + The standard Zifencei extension for instruction-fetch fence, as > + ratified in the 20191213 version of the unprivileged ISA > + specification. > + > + - const: zihintpause > + description: > + The standard Zihintpause extension for pause hints, as ratified in > + commit d8ab5c7 ("Zihintpause is ratified") of the riscv-isa-manual. > + > + - const: zihpm > + description: > + The standard Zihpm extension for hardware performance counters, as > + ratified in the 20191213 version of the unprivileged ISA > + specification. > + > + - const: ztso > + description: > + The standard Ztso extension for total store ordering, as ratified > + in commit 2e5236 ("Ztso is now ratified.") of the > + riscv-isa-manual. > + > +additionalProperties: true > +... > -- > 2.40.1 >
On Mon, 26 Jun 2023 10:38:43 PDT (-0700), apatel@ventanamicro.com wrote: > On Mon, Jun 26, 2023 at 3:42 PM Conor Dooley conor.dooley@microchip.com wrote: >> >> intro >> ===== >> >> When the RISC-V dt-bindings were accepted upstream in Linux, the base >> ISA etc had yet to be ratified. By the ratification of the base ISA, >> incompatible changes had snuck into the specifications - for example the >> Zicsr and Zifencei extensions were spun out of the base ISA. >> >> Fast forward to today, and the reason for this patch. >> Currently the riscv,isa dt property permits only a specific subset of >> the ISA string - in particular it excludes version numbering. >> With the current constraints, it is not possible to discern whether >> "rv64i" means that the hart supports the fence.i instruction, for >> example. >> Future systems may choose to implement their own instruction fencing, >> perhaps using a vendor extension, or they may not implement the optional >> counter extensions. Software needs a way to determine this. >> >> versioning schemes >> ================== >> >> "Use the extension versions that are described in the ISA manual" you >> may say, and it's not like this has not been considered. >> Firstly, software that parses the riscv,isa property at runtime will >> need to contain a lookup table of some sort that maps arbitrary versions >> to versions it understands. There is not a consistent application of >> version number applied to extensions, with a higgledy-piggledy >> collection of tags, "bare" and versioned documents awaiting the reader >> on the "recently ratified extensions" page: >> https://wiki.riscv.org/display/HOME/Recently+Ratified+Extensions >> >> As an aside, and this is reflected in the patch too, since many >> extensions have yet to appear in a release of the ISA specs, >> they are defined by commits in their respective "working draft" >> repositories. >> >> Secondly, there is an issue of backwards compatibility, whereby allowing >> numbers in the ISA string, some parsers may be broken. This would >> require an additional property to be created to even use the versions in >> this manner. >> >> ~boolean properties~ string array property >> ========================================== >> >> If a new property is needed, the whole approach may as well be looked at >> from the bottom up. A string with limited character choices etc is >> hardly the best approach for communicating extension information to >> software. >> >> Switching to using properties that are defined on a per extension basis, >> allows us to define explicit meanings for the DT representation of each >> extension - rather than the current situation where different operating >> systems or other bits of software may impart different meanings to >> characters in the string. >> Clearly the best source of meanings is the specifications themselves, >> this just provides us the ability to choose at what point in time the >> meaning is set. If an extension changes incompatibility in the future, >> a new property will be required. >> >> Off-list, some of the RVI folks have committed to shoring up the wording >> in either the ISA specifications, the riscv-isa-manual or >> so that in the future, modifications to and additions or removals of >> features will require a new extension. Codifying that assertion >> somewhere would make it quite unlikely that compatibility would be >> broken, but we have the tools required to deal with it, if & when it >> crops up. >> It is in our collective interest, as consumers of extension meanings, to >> define a scheme that enforces compatibility. >> >> The use of individual properties, rather than elements in a single >> string, will also permit validation that the properties have a meaning, >> as well as potentially reject mutually exclusive combinations, or >> enforce dependencies between extensions. That would not have be possible >> with the current dt-schema infrastructure for arbitrary strings, as we >> would need to add a riscv,isa parser to dt-validate! >> That's not implemented in this patch, but rather left as future work (for >> the brave, or the foolish). >> >> acpi >> ==== >> >> The current ACPI ECR is based on having a single ISA string unfortunately, >> but ideally ACPI will move to another method, perhaps GUIDs, that give >> explicit meaning to extensions. > > Drop this paragraph on ACPI. > > We clearly mentioned previously that ACPI will follow specs defined by RVI. > There are scalability issues in using GUIDs for each ISA extension.
The "ISA string node structure" does mention that "ISA string" is "Null-terminated ASCII Instruction Set Architecture (ISA) string for this hart. The format of the ISA string is defined in the RISC-V unprivileged specification." (Refer, page6 of https://docs.google.com/document/d/1zSw9eaW3tlrdGxkclo9FsLvYxUvhAjRCR8_71EfR...)
Currently, the ACPI spec does not mention the exact version of the "ISA string" chapter in the RISC-V unprivileged specification which can be improved.
Also, there is a 2-byte "revision" field in the "ISA string node structure" which can be used in the future to specify a different version of the "ISA string" chapter.
Regards, Anup
Regards, Anup
Regards, Anup
> Regards, > Anup > >> >> parser simplicity >> ================= >> >> Many systems that parse DT at runtime already implement an function that >> can check for the presence of a string in an array of string, as it is >> similar to the process for parsing a list of compatible strings, so a >> bunch of new, custom, DT parsing should not be needed. >> Getting rid of "riscv,isa" parsing would be a nice simplification, but >> unfortunately for backwards compatibility with old dtbs, existing >> parsers may not be removable - which may greatly simplify >> dt parsing code. In Linux, for example, checking for whether a hart >> supports an extension becomes as simple as: >> of_property_match_string(node, "riscv,isa-extensions", "zicbom") >> >> vendor extensions >> ================= >> >> Compared to riscv,isa, this proposed scheme promotes vendor extensions, >> oft touted as the strength of RISC-V, to first-class citizens. >> At present, extensions are defined as meaning what the RISC-V ISA >> specifications say they do. There is no realistic way of using that >> interface to provide cross-platform definitions for what vendor >> extensions mean. Vendor extensions may also have even less consistency >> than RVI do in terms of versioning, or no care about backwards >> compatibility. >> The new property allows us to assign explicit meanings on a per vendor >> extension basis, backed up by a description of their meanings. >> >> fin >> === >> >> Create a new file to store the extension meanings and a new >> riscv,isa-base property to replace the aspect of riscv,isa that is >> not represented by the new property - the base ISA implemented by a hart. >> >> As a starting point, add properties for extensions currently used in >> Linux. >> >> Finally, mark riscv,isa as deprecated, as removing support for it in >> existing programs would be an ABI break. >> >> CC: Palmer Dabbelt palmer@dabbelt.com >> CC: Paul Walmsley paul.walmsley@sifive.com >> CC: Rob Herring robh+dt@kernel.org >> CC: Krzysztof Kozlowski krzysztof.kozlowski+dt@linaro.org >> CC: Alistair Francis alistair.francis@wdc.com >> CC: Andrew Jones ajones@ventanamicro.com >> CC: Anup Patel apatel@ventanamicro.com >> CC: Atish Patra atishp@atishpatra.org >> CC: Jessica Clarke jrtc27@jrtc27.com >> CC: Rick Chen rick@andestech.com >> CC: Leo ycliang@andestech.com >> CC: Oleksii oleksii.kurochko@gmail.com >> CC: linux-riscv@lists.infradead.org >> CC: qemu-riscv@nongnu.org >> CC: u-boot@lists.denx.de >> CC: devicetree@vger.kernel.org >> CC: linux-kernel@vger.kernel.org >> Reviewed-by: Palmer Dabbelt palmer@rivosinc.com >> Acked-by: Palmer Dabbelt palmer@rivosinc.com >> Signed-off-by: Conor Dooley conor.dooley@microchip.com >> --- >> Changes in v3: >> - Per Rob's suggestion, switch to an array of strings. Cuts down on the >> size, compared to booleans. It has a standard mechanism for parsing >> (you need to parse arrays of strings for compatibles). It still allows >> for having a limited set of explicitly defined properties - so the >> advantages over a free-form string still apply. >> - Pick up Palmer's Ack and Review (although I expect that he will be the >> one to apply this). >> --- >> .../devicetree/bindings/riscv/cpus.yaml | 43 ++- >> .../devicetree/bindings/riscv/extensions.yaml | 245 ++++++++++++++++++ >> 2 files changed, 265 insertions(+), 23 deletions(-) >> create mode 100644 Documentation/devicetree/bindings/riscv/extensions.yaml >> >> diff --git a/Documentation/devicetree/bindings/riscv/cpus.yaml b/Documentation/devicetree/bindings/riscv/cpus.yaml >> index 67bd239ead0b..74bc92591086 100644 >> --- a/Documentation/devicetree/bindings/riscv/cpus.yaml >> +++ b/Documentation/devicetree/bindings/riscv/cpus.yaml >> @@ -25,6 +25,7 @@ description: | >> >> allOf: >> - $ref: /schemas/cpu.yaml# >> + - $ref: extensions.yaml >> >> properties: >> compatible: >> @@ -82,25 +83,6 @@ properties: >> description: >> The blocksize in bytes for the Zicboz cache operations. >> >> - riscv,isa: >> - description: >> - Identifies the specific RISC-V instruction set architecture >> - supported by the hart. These are documented in the RISC-V >> - User-Level ISA document, available from >> - https://riscv.org/specifications/ >> - >> - Due to revisions of the ISA specification, some deviations >> - have arisen over time. >> - Notably, riscv,isa was defined prior to the creation of the >> - Zicntr, Zicsr, Zifencei and Zihpm extensions and thus "i" >> - implies "zicntr_zicsr_zifencei_zihpm". >> - >> - While the isa strings in ISA specification are case >> - insensitive, letters in the riscv,isa string must be all >> - lowercase. >> - $ref: /schemas/types.yaml#/definitions/string >> - pattern: ^rv(?:64|32)imaf?d?q?c?b?k?j?p?v?h?(?:[hsxz](?:[a-z])+)?(?:_[hsxz](?:[a-z])+)*$ >> - >> # RISC-V has multiple properties for cache op block sizes as the sizes >> # differ between individual CBO extensions >> cache-op-block-size: false >> @@ -139,8 +121,17 @@ properties: >> DMIPS/MHz, relative to highest capacity-dmips-mhz >> in the system. >> >> +oneOf: >> + - required: >> + - riscv,isa >> + - required: >> + - riscv,isa-base >> + >> +dependencies: >> + riscv,isa-base: [ "riscv,isa-extensions" ] >> + riscv,isa-extensions: [ "riscv,isa-base" ] >> + >> required: >> - - riscv,isa >> - interrupt-controller >> >> unevaluatedProperties: false >> @@ -160,7 +151,9 @@ examples: >> i-cache-sets = <128>; >> i-cache-size = <16384>; >> reg = <0>; >> - riscv,isa = "rv64imac"; >> + riscv,isa-base = "rv64i"; >> + riscv,isa-extensions = "i", "m", "a", "c"; >> + >> cpu_intc0: interrupt-controller { >> #interrupt-cells = <1>; >> compatible = "riscv,cpu-intc"; >> @@ -183,8 +176,10 @@ examples: >> i-tlb-size = <32>; >> mmu-type = "riscv,sv39"; >> reg = <1>; >> - riscv,isa = "rv64imafdc"; >> tlb-split; >> + riscv,isa-base = "rv64i"; >> + riscv,isa-extensions = "i", "m", "a", "f", "d", "c"; >> + >> cpu_intc1: interrupt-controller { >> #interrupt-cells = <1>; >> compatible = "riscv,cpu-intc"; >> @@ -202,8 +197,10 @@ examples: >> device_type = "cpu"; >> reg = <0>; >> compatible = "riscv"; >> - riscv,isa = "rv64imafdc"; >> mmu-type = "riscv,sv48"; >> + riscv,isa-base = "rv64i"; >> + riscv,isa-extensions = "i", "m", "a", "f", "d", "c"; >> + >> interrupt-controller { >> #interrupt-cells = <1>; >> interrupt-controller; >> diff --git a/Documentation/devicetree/bindings/riscv/extensions.yaml b/Documentation/devicetree/bindings/riscv/extensions.yaml >> new file mode 100644 >> index 000000000000..af98307f2c2c >> --- /dev/null >> +++ b/Documentation/devicetree/bindings/riscv/extensions.yaml >> @@ -0,0 +1,245 @@ >> +# SPDX-License-Identifier: (GPL-2.0 OR MIT) >> +%YAML 1.2 >> +--- >> +$id: http://devicetree.org/schemas/riscv/extensions.yaml# >> +$schema: http://devicetree.org/meta-schemas/core.yaml# >> + >> +title: RISC-V ISA extensions >> + >> +maintainers: >> + - Paul Walmsley paul.walmsley@sifive.com >> + - Palmer Dabbelt palmer@sifive.com >> + - Conor Dooley conor@kernel.org >> + >> +description: | >> + RISC-V has a large number of extensions, some of which are "standard" >> + extensions, meaning they are ratified by RISC-V International, and others >> + are "vendor" extensions. >> + This document defines properties that indicate whether a hart supports a >> + given extension. >> + >> + Once a standard extension has been ratified, no changes in behaviour can be >> + made without the creation of a new extension. >> + The properties for standard extensions therefore map to their originally >> + ratified states, with the exception of the I, Zicntr & Zihpm extensions. >> + See the "i" property for more information. >> + >> +select: >> + properties: >> + compatible: >> + contains: >> + const: riscv >> + >> +properties: >> + riscv,isa: >> + description: >> + Identifies the specific RISC-V instruction set architecture >> + supported by the hart. These are documented in the RISC-V >> + User-Level ISA document, available from >> + https://riscv.org/specifications/ >> + >> + Due to revisions of the ISA specification, some deviations >> + have arisen over time. >> + Notably, riscv,isa was defined prior to the creation of the >> + Zicntr, Zicsr, Zifencei and Zihpm extensions and thus "i" >> + implies "zicntr_zicsr_zifencei_zihpm". >> + >> + While the isa strings in ISA specification are case >> + insensitive, letters in the riscv,isa string must be all >> + lowercase. >> + $ref: /schemas/types.yaml#/definitions/string >> + pattern: ^rv(?:64|32)imaf?d?q?c?b?k?j?p?v?h?(?:[hsxz](?:[a-z])+)?(?:_[hsxz](?:[a-z])+)*$ >> + deprecated: true >> + >> + riscv,isa-base: >> + description: >> + The base ISA implemented by this hart, as described by the 20191213 >> + version of the unprivileged ISA specification. >> + enum: >> + - rv32i >> + - rv64i >> + >> + riscv,isa-extensions: >> + $ref: /schemas/types.yaml#/definitions/string-array >> + minItems: 1 >> + description: Extensions supported by the hart. >> + items: >> + anyOf: >> + # single letter extensions, in canonical order >> + - const: i >> + description: | >> + The base integer instruction set, as ratified in the 20191213 >> + version of the unprivileged ISA specification, with the exception of >> + counter access. >> + Counter access was removed after the ratification of the 20191213 >> + version of the unprivileged specification and shunted into the >> + Zicntr and Zihpm extensions. >> + >> + - const: m >> + description: >> + The standard M extension for integer multiplication and division, as >> + ratified in the 20191213 version of the unprivileged ISA >> + specification. >> + >> + - const: a >> + description: >> + The standard A extension for atomic instructions, as ratified in the >> + 20191213 version of the unprivileged ISA specification. >> + >> + - const: f >> + description: >> + The standard F extension for single-precision floating point, as >> + ratified in the 20191213 version of the unprivileged ISA >> + specification. >> + >> + - const: d >> + description: >> + The standard D extension for double-precision floating-point, as >> + ratified in the 20191213 version of the unprivileged ISA >> + specification. >> + >> + - const: q >> + description: >> + The standard Q extension for quad-precision floating-point, as >> + ratified in the 20191213 version of the unprivileged ISA >> + specification. >> + >> + - const: c >> + description: >> + The standard C extension for compressed instructions, as ratified in >> + the 20191213 version of the unprivileged ISA specification. >> + >> + - const: v >> + description: >> + The standard V extension for vector operations, as ratified >> + in-and-around commit 7a6c8ae ("Fix text that describes vfmv.v.f >> + encoding") of the riscv-v-spec. >> + >> + - const: h >> + description: >> + The standard H extension for hypervisors as ratified in the 20191213 >> + version of the privileged ISA specification. >> + >> + # multi-letter extensions, sorted alphanumerically >> + - const: smaia >> + description: | >> + The standard Smaia supervisor-level extension for the advanced >> + interrupt architecture for machine-mode-visible csr and behavioural >> + changes to interrupts as frozen at commit ccbddab ("Merge pull >> + request #42 from riscv/jhauser-2023-RC4") of riscv-aia. >> + >> + - const: ssaia >> + description: | >> + The standard Ssaia supervisor-level extension for the advanced >> + interrupt architecture for supervisor-mode-visible csr and >> + behavioural changes to interrupts as frozen at commit ccbddab >> + ("Merge pull request #42 from riscv/jhauser-2023-RC4") of riscv-aia. >> + >> + - const: sscofpmf >> + description: | >> + The standard Sscofpmf supervisor-level extension for count overflow >> + and mode-based filtering as ratified at commit 01d1df0 ("Add ability >> + to manually trigger workflow. (#2)") of riscv-count-overflow. >> + >> + - const: sstc >> + description: | >> + The standard Sstc supervisor-level extension for time compare as >> + ratified at commit 3f9ed34 ("Add ability to manually trigger >> + workflow. (#2)") of riscv-time-compare. >> + >> + - const: svinval >> + description: >> + The standard Svinval supervisor-level extension for fine-grained >> + address-translation cache invalidation as ratified in the 20191213 >> + version of the privileged ISA specification. >> + >> + - const: svnapot >> + description: >> + The standard Svnapot supervisor-level extensions for napot >> + translation contiguity as ratified in the 20191213 version of the >> + privileged ISA specification. >> + >> + - const: svpbmt >> + description: >> + The standard Svpbmt supervisor-level extensions for page-based >> + memory types as ratified in the 20191213 version of the privileged >> + ISA specification. >> + >> + - const: zba >> + description: | >> + The standard Zba bit-manipulation extension for address generation >> + acceleration instructions as ratified at commit 6d33919 ("Merge pull >> + request #158 from hirooih/clmul-fix-loop-end-condition") of >> + riscv-bitmanip. >> + >> + - const: zbb >> + description: | >> + The standard Zbb bit-manipulation extension for basic bit-manipulation >> + as ratified at commit 6d33919 ("Merge pull request #158 from >> + hirooih/clmul-fix-loop-end-condition") of riscv-bitmanip. >> + >> + - const: zbc >> + description: | >> + The standard Zbc bit-manipulation extension for carry-less >> + multiplication as ratified at commit 6d33919 ("Merge pull request >> + #158 from hirooih/clmul-fix-loop-end-condition") of riscv-bitmanip. >> + >> + - const: zbs >> + description: | >> + The standard Zbs bit-manipulation extension for single-bit >> + instructions as ratified at commit 6d33919 ("Merge pull request #158 >> + from hirooih/clmul-fix-loop-end-condition") of riscv-bitmanip. >> + >> + - const: zicbom >> + description: >> + The standard Zicbom extension for base cache management operations as >> + ratified in commit 3dd606f ("Create cmobase-v1.0.pdf") of riscv-CMOs. >> + >> + - const: zicbop >> + description: >> + The standard Zicbop extension for cache-block prefetch instructions >> + as ratified in commit 3dd606f ("Create cmobase-v1.0.pdf") of >> + riscv-CMOs. >> + >> + - const: zicboz >> + description: >> + The standard Zicboz extension for cache-block zeroing as ratified >> + in commit 3dd606f ("Create cmobase-v1.0.pdf") of riscv-CMOs. >> + >> + - const: zicntr >> + description: >> + The standard Zicntr extension for base counters and timers, as >> + ratified in the 20191213 version of the unprivileged ISA >> + specification. >> + >> + - const: zicsr >> + description: >> + The standard Zicsr extension for control and status register >> + instructions, as ratified in the 20191213 version of the >> + unprivileged ISA specification. >> + >> + - const: zifencei >> + description: >> + The standard Zifencei extension for instruction-fetch fence, as >> + ratified in the 20191213 version of the unprivileged ISA >> + specification. >> + >> + - const: zihintpause >> + description: >> + The standard Zihintpause extension for pause hints, as ratified in >> + commit d8ab5c7 ("Zihintpause is ratified") of the riscv-isa-manual. >> + >> + - const: zihpm >> + description: >> + The standard Zihpm extension for hardware performance counters, as >> + ratified in the 20191213 version of the unprivileged ISA >> + specification. >> + >> + - const: ztso >> + description: >> + The standard Ztso extension for total store ordering, as ratified >> + in commit 2e5236 ("Ztso is now ratified.") of the >> + riscv-isa-manual. >> + >> +additionalProperties: true >> +... >> -- >> 2.40.1 >>
Anup Patel
Palmer Dabbelt
