[U-Boot] How to handle binary data file in u-boot
Hi Experts,
We have implemented an display utilty in u-boot and this utlity needs a waveform file.
We are planning to release this display utility, but we don't know how to do with the waveform file. The file is as large as 800KB.
Now we just put the waveform file on mmc and read it out in boot.
Is there any better way to deliver this binary waveform file as part of the bootloader? How is this case typically handled?
Thanks in advance.
Yours Terry
Lv Terry-R65388 wrote:
Hi Experts,
Files that large are usually not embedded within the u-boot image.
It depends where your u-boot image is. If its in NOR flash, for example, one would add a partition of suitable size to put the data in. If the external location can be flexibly defined (filename for SD/MMC or location for others) it is great.
of the bootloader?
As part of the bootloader (image) you'd need to convert the bytestream into a lengthy initialized array and link it into the image. I'm not sure the toolchain can handle that and I am sure that method is not welcome in the repository (800kb binary --> several MB c-source)...
Have a look at the code to handle FPGA images, you can probably even reuse or share code with there.
Reinhard
Hi Reinhard,
Thank you very much.
Yours Terry
-----Original Message----- From: Reinhard Meyer [mailto:reinhard.meyer@emk-elektronik.de] Sent: 2010年7月29日 15:45 To: Lv Terry-R65388 Cc: u-boot@lists.denx.de Subject: Re: [U-Boot] How to handle binary data file in u-boot
Hi Experts,
don't know
out in boot.
Reinhard
Hi Experts,
Now we just put the waveform file on mmc and read it out in boot. Is there any better way to deliver this binary waveform file as part
Because the file is raw data, it is normally not linked to u-boot code. I mean, you can convert the data in a C-array and link it to the bootloader, but is it worth ?
The same issue is for images used as splashscreen in u-boot, in some case quite huge (but not so big as yours). They are often saved in different areas (or after the bootloader), but not linked together.
You could easier concatenate u-boot and your waveform data in a single file using "cat", padding bytes if you need to reserve some areas, and probably you reach easier the same goal, if you want only to deliver a single file containing both bootloader and data.
Best regards, Stefano Babic
Lv Terry-R65388
Reinhard Meyer
Stefano Babic
