[U-Boot] [PATCH 1/2] pci: renesas: Add RCar Gen3 PCIe controller driver
Add driver for the Renesas RCar PCIe controller present on Gen3 SoCs. The PCIe on Gen3 is used both to connect external PCIe peripherals.
Signed-off-by: Marek Vasut marek.vasut+renesas@gmail.com Cc: Bin Meng bmeng.cn@gmail.com Cc: Nobuhiro Iwamatsu iwamatsu@nigauri.org --- drivers/pci/Kconfig | 8 + drivers/pci/Makefile | 1 + drivers/pci/pcie-rcar-gen3.c | 411 +++++++++++++++++++++++++++++++++++ 3 files changed, 420 insertions(+) create mode 100644 drivers/pci/pcie-rcar-gen3.c
diff --git a/drivers/pci/Kconfig b/drivers/pci/Kconfig index 1521885bde..f8f8004429 100644 --- a/drivers/pci/Kconfig +++ b/drivers/pci/Kconfig @@ -69,6 +69,14 @@ config PCI_RCAR_GEN2 Renesas RCar Gen2 SoCs. The PCIe controller on RCar Gen2 is also used to access EHCI USB controller on the SoC.
+config PCIE_RCAR_GEN3 + bool "Renesas RCar Gen3 PCIe driver" + depends on DM_PCI + depends on RCAR_GEN3 + help + Say Y here if you want to enable PCIe controller support on + Renesas RCar Gen3 SoCs. + config PCI_SANDBOX bool "Sandbox PCI support" depends on SANDBOX && DM_PCI diff --git a/drivers/pci/Makefile b/drivers/pci/Makefile index 4923641895..f6dd769bba 100644 --- a/drivers/pci/Makefile +++ b/drivers/pci/Makefile @@ -24,6 +24,7 @@ obj-$(CONFIG_PCIE_IMX) += pcie_imx.o obj-$(CONFIG_FTPCI100) += pci_ftpci100.o obj-$(CONFIG_PCI_MVEBU) += pci_mvebu.o obj-$(CONFIG_PCI_RCAR_GEN2) += pci-rcar-gen2.o +obj-$(CONFIG_PCIE_RCAR_GEN3) += pcie-rcar-gen3.o obj-$(CONFIG_SH4_PCI) += pci_sh4.o obj-$(CONFIG_SH7751_PCI) +=pci_sh7751.o obj-$(CONFIG_SH7780_PCI) +=pci_sh7780.o diff --git a/drivers/pci/pcie-rcar-gen3.c b/drivers/pci/pcie-rcar-gen3.c new file mode 100644 index 0000000000..dcf455e135 --- /dev/null +++ b/drivers/pci/pcie-rcar-gen3.c @@ -0,0 +1,411 @@ +// SPDX-License-Identifier: GPL-2.0 +/* + * Renesas RCar Gen3 PCIEC driver + * + * Copyright (C) 2018-2019 Marek Vasut marek.vasut@gmail.com + * + * Based on Linux PCIe driver for Renesas R-Car SoCs + * Copyright (C) 2014 Renesas Electronics Europe Ltd + * + * Based on: + * arch/sh/drivers/pci/pcie-sh7786.c + * arch/sh/drivers/pci/ops-sh7786.c + * Copyright (C) 2009 - 2011 Paul Mundt + * + * Author: Phil Edworthy phil.edworthy@renesas.com + */ + +#include <common.h> +#include <asm/io.h> +#include <clk.h> +#include <dm.h> +#include <errno.h> +#include <pci.h> +#include <wait_bit.h> + +#define PCIECAR 0x000010 +#define PCIECCTLR 0x000018 +#define CONFIG_SEND_ENABLE BIT(31) +#define TYPE0 (0 << 8) +#define TYPE1 BIT(8) +#define PCIECDR 0x000020 +#define PCIEMSR 0x000028 +#define PCIEINTXR 0x000400 +#define PCIEPHYSR 0x0007f0 +#define PHYRDY BIT(0) +#define PCIEMSITXR 0x000840 + +/* Transfer control */ +#define PCIETCTLR 0x02000 +#define CFINIT 1 +#define PCIETSTR 0x02004 +#define DATA_LINK_ACTIVE 1 +#define PCIEERRFR 0x02020 +#define UNSUPPORTED_REQUEST BIT(4) +#define PCIEMSIFR 0x02044 +#define PCIEMSIALR 0x02048 +#define MSIFE 1 +#define PCIEMSIAUR 0x0204c +#define PCIEMSIIER 0x02050 + +/* root port address */ +#define PCIEPRAR(x) (0x02080 + ((x) * 0x4)) + +/* local address reg & mask */ +#define PCIELAR(x) (0x02200 + ((x) * 0x20)) +#define PCIELAMR(x) (0x02208 + ((x) * 0x20)) +#define LAM_PREFETCH BIT(3) +#define LAM_64BIT BIT(2) +#define LAR_ENABLE BIT(1) + +/* PCIe address reg & mask */ +#define PCIEPALR(x) (0x03400 + ((x) * 0x20)) +#define PCIEPAUR(x) (0x03404 + ((x) * 0x20)) +#define PCIEPAMR(x) (0x03408 + ((x) * 0x20)) +#define PCIEPTCTLR(x) (0x0340c + ((x) * 0x20)) +#define PAR_ENABLE BIT(31) +#define IO_SPACE BIT(8) + +/* Configuration */ +#define PCICONF(x) (0x010000 + ((x) * 0x4)) +#define PMCAP(x) (0x010040 + ((x) * 0x4)) +#define EXPCAP(x) (0x010070 + ((x) * 0x4)) +#define VCCAP(x) (0x010100 + ((x) * 0x4)) + +/* link layer */ +#define IDSETR1 0x011004 +#define TLCTLR 0x011048 +#define MACSR 0x011054 +#define SPCHGFIN BIT(4) +#define SPCHGFAIL BIT(6) +#define SPCHGSUC BIT(7) +#define LINK_SPEED (0xf << 16) +#define LINK_SPEED_2_5GTS (1 << 16) +#define LINK_SPEED_5_0GTS (2 << 16) +#define MACCTLR 0x011058 +#define SPEED_CHANGE BIT(24) +#define SCRAMBLE_DISABLE BIT(27) +#define MACS2R 0x011078 +#define MACCGSPSETR 0x011084 +#define SPCNGRSN BIT(31) + +/* R-Car H1 PHY */ +#define H1_PCIEPHYADRR 0x04000c +#define WRITE_CMD BIT(16) +#define PHY_ACK BIT(24) +#define RATE_POS 12 +#define LANE_POS 8 +#define ADR_POS 0 +#define H1_PCIEPHYDOUTR 0x040014 + +/* R-Car Gen2 PHY */ +#define GEN2_PCIEPHYADDR 0x780 +#define GEN2_PCIEPHYDATA 0x784 +#define GEN2_PCIEPHYCTRL 0x78c + +#define INT_PCI_MSI_NR 32 + +#define RCONF(x) (PCICONF(0) + (x)) +#define RPMCAP(x) (PMCAP(0) + (x)) +#define REXPCAP(x) (EXPCAP(0) + (x)) +#define RVCCAP(x) (VCCAP(0) + (x)) + +#define PCIE_CONF_BUS(b) (((b) & 0xff) << 24) +#define PCIE_CONF_DEV(d) (((d) & 0x1f) << 19) +#define PCIE_CONF_FUNC(f) (((f) & 0x7) << 16) + +#define RCAR_PCI_MAX_RESOURCES 4 +#define MAX_NR_INBOUND_MAPS 6 + +#define PCI_EXP_FLAGS 2 /* Capabilities register */ +#define PCI_EXP_FLAGS_TYPE 0x00f0 /* Device/Port type */ +#define PCI_EXP_TYPE_ROOT_PORT 0x4 /* Root Port */ +#define PCI_EXP_LNKCAP 12 /* Link Capabilities */ +#define PCI_EXP_LNKCAP_DLLLARC 0x00100000 /* Data Link Layer Link Active Reporting Capable */ +#define PCI_EXP_SLTCAP 20 /* Slot Capabilities */ +#define PCI_EXP_SLTCAP_PSN 0xfff80000 /* Physical Slot Number */ + +enum { + RCAR_PCI_ACCESS_READ, + RCAR_PCI_ACCESS_WRITE, +}; + +struct rcar_gen3_pcie_priv { + fdt_addr_t regs; +}; + +static void rcar_rmw32(struct udevice *dev, int where, u32 mask, u32 data) +{ + struct rcar_gen3_pcie_priv *priv = dev_get_priv(dev); + int shift = 8 * (where & 3); + + clrsetbits_le32(priv->regs + (where & ~3), + mask << shift, data << shift); +} + +static u32 rcar_read_conf(struct udevice *dev, int where) +{ + struct rcar_gen3_pcie_priv *priv = dev_get_priv(dev); + int shift = 8 * (where & 3); + + return readl(priv->regs + (where & ~3)) >> shift; +} + +static int rcar_pcie_config_access(struct udevice *udev, + unsigned char access_type, + pci_dev_t bdf, int where, ulong *data) +{ + struct rcar_gen3_pcie_priv *priv = dev_get_priv(udev); + u32 reg = where & ~3; + + /* Clear errors */ + clrbits_le32(priv->regs + PCIEERRFR, 0); + + /* Set the PIO address */ + writel((bdf << 8) | reg, priv->regs + PCIECAR); + + /* Enable the configuration access */ + if (!PCI_BUS(bdf)) + writel(CONFIG_SEND_ENABLE | TYPE0, priv->regs + PCIECCTLR); + else + writel(CONFIG_SEND_ENABLE | TYPE1, priv->regs + PCIECCTLR); + + /* Check for errors */ + if (readl(priv->regs + PCIEERRFR) & UNSUPPORTED_REQUEST) + return -ENODEV; + + /* Check for master and target aborts */ + if (rcar_read_conf(udev, RCONF(PCI_STATUS)) & + (PCI_STATUS_REC_MASTER_ABORT | PCI_STATUS_REC_TARGET_ABORT)) + return -ENODEV; + + if (access_type == RCAR_PCI_ACCESS_READ) + *data = readl(priv->regs + PCIECDR); + else + writel(*data, priv->regs + PCIECDR); + + /* Disable the configuration access */ + writel(0, priv->regs + PCIECCTLR); + + return 0; +} + +static int rcar_gen3_pcie_addr_valid(pci_dev_t d, uint where) +{ + u32 slot; + + if (PCI_FUNC(d)) + return -EINVAL; + + slot = PCI_DEV(d); + if (slot != 1) + return -EINVAL; + + return 0; +} + +static int rcar_gen3_pcie_read_config(struct udevice *dev, pci_dev_t bdf, + uint where, ulong *val, + enum pci_size_t size) +{ + ulong reg; + int ret; + + ret = rcar_gen3_pcie_addr_valid(bdf, where); + if (ret) { + *val = pci_get_ff(size); + return 0; + } + + ret = rcar_pcie_config_access(dev, RCAR_PCI_ACCESS_READ, + bdf, where, ®); + if (ret != 0) + reg = 0xffffffffUL; + + *val = pci_conv_32_to_size(reg, where, size); + + return ret; +} + +static int rcar_gen3_pcie_write_config(struct udevice *dev, pci_dev_t bdf, + uint where, ulong val, + enum pci_size_t size) +{ + ulong data; + int ret; + + ret = rcar_gen3_pcie_addr_valid(bdf, where); + if (ret) + return ret; + + data = pci_conv_32_to_size(val, where, size); + + ret = rcar_pcie_config_access(dev, RCAR_PCI_ACCESS_WRITE, + bdf, where, &data); + + return ret; +} + +static int rcar_gen3_pcie_wait_for_phyrdy(struct udevice *dev) +{ + struct rcar_gen3_pcie_priv *priv = dev_get_priv(dev); + + return wait_for_bit_le32((void *)priv->regs + PCIEPHYSR, PHYRDY, + true, 50, false); +} + +static int rcar_gen3_pcie_wait_for_dl(struct udevice *dev) +{ + struct rcar_gen3_pcie_priv *priv = dev_get_priv(dev); + + return wait_for_bit_le32((void *)priv->regs + PCIETSTR, + DATA_LINK_ACTIVE, true, 50, false); +} + +static int rcar_gen3_pcie_hw_init(struct udevice *dev) +{ + struct rcar_gen3_pcie_priv *priv = dev_get_priv(dev); + int ret; + + /* Begin initialization */ + writel(0, priv->regs + PCIETCTLR); + + /* Set mode */ + writel(1, priv->regs + PCIEMSR); + + ret = rcar_gen3_pcie_wait_for_phyrdy(dev); + if (ret) + return ret; + + /* + * Initial header for port config space is type 1, set the device + * class to match. Hardware takes care of propagating the IDSETR + * settings, so there is no need to bother with a quirk. + */ + writel(PCI_CLASS_BRIDGE_PCI << 16, priv->regs + IDSETR1); + + /* + * Setup Secondary Bus Number & Subordinate Bus Number, even though + * they aren't used, to avoid bridge being detected as broken. + */ + rcar_rmw32(dev, RCONF(PCI_SECONDARY_BUS), 0xff, 1); + rcar_rmw32(dev, RCONF(PCI_SUBORDINATE_BUS), 0xff, 1); + + /* Initialize default capabilities. */ + rcar_rmw32(dev, REXPCAP(0), 0xff, PCI_CAP_ID_EXP); + rcar_rmw32(dev, REXPCAP(PCI_EXP_FLAGS), + PCI_EXP_FLAGS_TYPE, PCI_EXP_TYPE_ROOT_PORT << 4); + rcar_rmw32(dev, RCONF(PCI_HEADER_TYPE), 0x7f, + PCI_HEADER_TYPE_BRIDGE); + + /* Enable data link layer active state reporting */ + rcar_rmw32(dev, REXPCAP(PCI_EXP_LNKCAP), + PCI_EXP_LNKCAP_DLLLARC, PCI_EXP_LNKCAP_DLLLARC); + + /* Write out the physical slot number = 0 */ + rcar_rmw32(dev, REXPCAP(PCI_EXP_SLTCAP), + PCI_EXP_SLTCAP_PSN, 0); + + /* Set the completion timer timeout to the maximum 50ms. */ + rcar_rmw32(dev, TLCTLR + 1, 0x3f, 50); + + /* Terminate list of capabilities (Next Capability Offset=0) */ + rcar_rmw32(dev, RVCCAP(0), 0xfff00000, 0); + + /* Finish initialization - establish a PCI Express link */ + writel(CFINIT, priv->regs + PCIETCTLR); + + return rcar_gen3_pcie_wait_for_dl(dev); +} + +static int rcar_gen3_pcie_probe(struct udevice *dev) +{ + struct rcar_gen3_pcie_priv *priv = dev_get_priv(dev); + struct pci_controller *hose = dev_get_uclass_priv(dev); + struct clk pci_clk; + u32 mask; + int i, cnt, ret; + + ret = clk_get_by_index(dev, 0, &pci_clk); + if (ret) + return ret; + + ret = clk_enable(&pci_clk); + if (ret) + return ret; + + for (i = 0; i < hose->region_count; i++) { + if (hose->regions[i].flags != PCI_REGION_SYS_MEMORY) + continue; + + if (hose->regions[i].phys_start == 0) + continue; + + mask = (hose->regions[i].size - 1) & ~0xf; + mask |= LAR_ENABLE; + writel(hose->regions[i].phys_start, priv->regs + PCIEPRAR(0)); + writel(hose->regions[i].phys_start, priv->regs + PCIELAR(0)); + writel(mask, priv->regs + PCIELAMR(0)); + break; + } + + writel(0, priv->regs + PCIEPRAR(4)); + writel(0, priv->regs + PCIELAR(4)); + writel(0, priv->regs + PCIELAMR(4)); + + ret = rcar_gen3_pcie_hw_init(dev); + if (ret) + return ret; + + for (i = 0, cnt = 0; i < hose->region_count; i++) { + if (hose->regions[i].flags == PCI_REGION_SYS_MEMORY) + continue; + + writel(0, priv->regs + PCIEPTCTLR(cnt)); + writel((hose->regions[i].size - 1) & ~0x7f, + priv->regs + PCIEPAMR(cnt)); + writel(upper_32_bits(hose->regions[i].phys_start), + priv->regs + PCIEPAUR(cnt)); + writel(lower_32_bits(hose->regions[i].phys_start), + priv->regs + PCIEPALR(cnt)); + mask = PAR_ENABLE; + if (hose->regions[i].flags == PCI_REGION_IO) + mask |= IO_SPACE; + writel(mask, priv->regs + PCIEPTCTLR(cnt)); + + cnt++; + } + + return 0; +} + +static int rcar_gen3_pcie_ofdata_to_platdata(struct udevice *dev) +{ + struct rcar_gen3_pcie_priv *priv = dev_get_priv(dev); + + priv->regs = devfdt_get_addr_index(dev, 0); + if (!priv->regs) + return -EINVAL; + + return 0; +} + +static const struct dm_pci_ops rcar_gen3_pcie_ops = { + .read_config = rcar_gen3_pcie_read_config, + .write_config = rcar_gen3_pcie_write_config, +}; + +static const struct udevice_id rcar_gen3_pcie_ids[] = { + { .compatible = "renesas,pcie-rcar-gen3" }, + { } +}; + +U_BOOT_DRIVER(rcar_gen3_pcie) = { + .name = "rcar_gen3_pcie", + .id = UCLASS_PCI, + .of_match = rcar_gen3_pcie_ids, + .ops = &rcar_gen3_pcie_ops, + .probe = rcar_gen3_pcie_probe, + .ofdata_to_platdata = rcar_gen3_pcie_ofdata_to_platdata, + .priv_auto_alloc_size = sizeof(struct rcar_gen3_pcie_priv), +};
Enable PCIe driver on R-Car Gen3 Salvator-X boards.
Signed-off-by: Marek Vasut marek.vasut+renesas@gmail.com Cc: Nobuhiro Iwamatsu iwamatsu@nigauri.org --- configs/r8a7795_salvator-x_defconfig | 4 ++++ configs/r8a77965_salvator-x_defconfig | 4 ++++ configs/r8a7796_salvator-x_defconfig | 4 ++++ 3 files changed, 12 insertions(+)
diff --git a/configs/r8a7795_salvator-x_defconfig b/configs/r8a7795_salvator-x_defconfig index 8c5c9ed0c4..2990130a44 100644 --- a/configs/r8a7795_salvator-x_defconfig +++ b/configs/r8a7795_salvator-x_defconfig @@ -16,6 +16,7 @@ CONFIG_CMD_BOOTZ=y CONFIG_CMD_GPIO=y CONFIG_CMD_I2C=y CONFIG_CMD_MMC=y +CONFIG_CMD_PCI=y CONFIG_CMD_USB=y CONFIG_CMD_DHCP=y CONFIG_CMD_MII=y @@ -51,6 +52,9 @@ CONFIG_RENESAS_RAVB=y CONFIG_PINCTRL=y CONFIG_PINCONF=y CONFIG_PINCTRL_PFC=y +CONFIG_PCI=y +CONFIG_DM_PCI=y +CONFIG_PCIE_RCAR_GEN3=y CONFIG_DM_REGULATOR=y CONFIG_DM_REGULATOR_FIXED=y CONFIG_DM_REGULATOR_GPIO=y diff --git a/configs/r8a77965_salvator-x_defconfig b/configs/r8a77965_salvator-x_defconfig index 228d848c23..a18f5dd173 100644 --- a/configs/r8a77965_salvator-x_defconfig +++ b/configs/r8a77965_salvator-x_defconfig @@ -17,6 +17,7 @@ CONFIG_CMD_BOOTZ=y CONFIG_CMD_GPIO=y CONFIG_CMD_I2C=y CONFIG_CMD_MMC=y +CONFIG_CMD_PCI=y CONFIG_CMD_USB=y CONFIG_CMD_DHCP=y CONFIG_CMD_MII=y @@ -52,6 +53,9 @@ CONFIG_RENESAS_RAVB=y CONFIG_PINCTRL=y CONFIG_PINCONF=y CONFIG_PINCTRL_PFC=y +CONFIG_PCI=y +CONFIG_DM_PCI=y +CONFIG_PCIE_RCAR_GEN3=y CONFIG_DM_REGULATOR=y CONFIG_DM_REGULATOR_FIXED=y CONFIG_DM_REGULATOR_GPIO=y diff --git a/configs/r8a7796_salvator-x_defconfig b/configs/r8a7796_salvator-x_defconfig index 67d3b517f4..314978afb5 100644 --- a/configs/r8a7796_salvator-x_defconfig +++ b/configs/r8a7796_salvator-x_defconfig @@ -17,6 +17,7 @@ CONFIG_CMD_BOOTZ=y CONFIG_CMD_GPIO=y CONFIG_CMD_I2C=y CONFIG_CMD_MMC=y +CONFIG_CMD_PCI=y CONFIG_CMD_USB=y CONFIG_CMD_DHCP=y CONFIG_CMD_MII=y @@ -52,6 +53,9 @@ CONFIG_RENESAS_RAVB=y CONFIG_PINCTRL=y CONFIG_PINCONF=y CONFIG_PINCTRL_PFC=y +CONFIG_PCI=y +CONFIG_DM_PCI=y +CONFIG_PCIE_RCAR_GEN3=y CONFIG_DM_REGULATOR=y CONFIG_DM_REGULATOR_FIXED=y CONFIG_DM_REGULATOR_GPIO=y
nits: should this be PCI_RCAR_GEN3 to be consistent with PCI_RCAR_GEN2? or maybe we should rename previous PCI_RCAR_GEN2 to PCIE_RCAR_GEN2? I have no problem with PCI vs PCIe, but better to be consistent.
depends on DM_PCI
help
- Renesas RCar Gen3 PCIEC driver
- Copyright (C) 2018-2019 Marek Vasut marek.vasut@gmail.com
- Based on Linux PCIe driver for Renesas R-Car SoCs
- Copyright (C) 2014 Renesas Electronics Europe Ltd
- Based on:
- arch/sh/drivers/pci/pcie-sh7786.c
- arch/sh/drivers/pci/ops-sh7786.c
- Copyright (C) 2009 - 2011 Paul Mundt
- Author: Phil Edworthy phil.edworthy@renesas.com
+enum {
fdt_addr_t regs;
/* Clear errors */
if (!PCI_BUS(bdf))
else
return -ENODEV;
return -ENODEV;
else
u32 slot;
if (PCI_FUNC(d))
return -EINVAL;
slot = PCI_DEV(d);
if (slot != 1)
return -EINVAL;
ulong reg;
int ret;
if (ret) {
bdf, where, ®);
if (ret != 0)
reg = 0xffffffffUL;
return ret;
ulong data;
int ret;
if (ret)
return ret;
bdf, where, &data);
return ret;
true, 50, false);
int ret;
/* Set mode */
if (ret)
return ret;
struct clk pci_clk;
u32 mask;
int i, cnt, ret;
if (ret)
return ret;
if (ret)
return ret;
continue;
continue;
mask |= LAR_ENABLE;
break;
if (ret)
return ret;
continue;
mask = PAR_ENABLE;
mask |= IO_SPACE;
cnt++;
nits: since this is the ofdata_to_platdata() call, generally it should save device tree info to dev->platdata, not dev->priv.
if (!priv->regs)
return -EINVAL;
.id = UCLASS_PCI,
Other than above nits, overall looks very good. Reviewed-by: Bin Meng bmeng.cn@gmail.com
Regards, Bin
Bin Meng
