[U-Boot] [PATCH] test_avb: Add pymark.buildconfigspec information for the AVB tests
Signed-off-by: Tom Rini trini@konsulko.com --- test/py/tests/test_avb.py | 5 +++++ 1 file changed, 5 insertions(+)
diff --git a/test/py/tests/test_avb.py b/test/py/tests/test_avb.py index 770bdde4ad0c..7996e4845db3 100644 --- a/test/py/tests/test_avb.py +++ b/test/py/tests/test_avb.py @@ -23,6 +23,7 @@ mmc_dev = 1 temp_addr = 0x90000000 temp_addr2 = 0x90002000
+@pytest.mark.buildconfigspec('cmd_avb') def test_avb_verify(u_boot_console): """Run AVB 2.0 boot verification chain with avb subset of commands """ @@ -35,6 +36,7 @@ def test_avb_verify(u_boot_console): assert response.find(success_str)
+@pytest.mark.buildconfigspec('cmd_avb') def test_avb_mmc_uuid(u_boot_console): """Check if 'avb get_uuid' works, compare results with 'part list mmc 1' output @@ -67,6 +69,7 @@ def test_avb_mmc_uuid(u_boot_console): assert guid == avb_guid_resp.split("UUID: ")[1]
+@pytest.mark.buildconfigspec('cmd_avb') def test_avb_read_rb(u_boot_console): """Test reading rollback indexes """ @@ -77,6 +80,7 @@ def test_avb_read_rb(u_boot_console): response = u_boot_console.run_command('avb read_rb 1')
+@pytest.mark.buildconfigspec('cmd_avb') def test_avb_is_unlocked(u_boot_console): """Test if device is in the unlocked state """ @@ -87,6 +91,7 @@ def test_avb_is_unlocked(u_boot_console): response = u_boot_console.run_command('avb is_unlocked')
+@pytest.mark.buildconfigspec('cmd_avb') def test_avb_mmc_read(u_boot_console): """Test mmc read operation """
