[U-Boot] [PATCH 0/6] imx8: support container
This patchset is to support i.MX8 container loading from SPL, i.MX8 AHAB secure boot not support FIT image, so we need to use container image.
Currently still use a fixed offset for the 2nd container(u-boot.cnt), future patches will drop this fixed offset and use dynamaic offset according to the size of 1st container for spl. Only MMC is supported now, future patches will also support SPI/NOR/NAND following similar style as mmc part, if the mmc part is ok.
Build pass: https://travis-ci.org/MrVan/u-boot/builds/529180267
Peng Fan (6): imx: mach-imx: clean up Makefile spl: Add function to get u-boot raw sector imx8: support parsing i.MX8 Container file spl: mmc: support loading i.MX container format file imx: add container target imx8qxp_mek: switch to use container image
Makefile | 8 ++ arch/arm/include/asm/arch-imx8/image.h | 56 +++++++++++ arch/arm/mach-imx/Makefile | 26 +++-- arch/arm/mach-imx/imx8/Kconfig | 13 +++ arch/arm/mach-imx/imx8/Makefile | 4 + arch/arm/mach-imx/imx8/parse-container.c | 120 ++++++++++++++++++++++++ board/freescale/imx8qxp_mek/README | 4 +- board/freescale/imx8qxp_mek/uboot-container.cfg | 13 +++ common/spl/spl_mmc.c | 21 ++++- configs/imx8qxp_mek_defconfig | 5 +- include/spl.h | 12 +++ 11 files changed, 268 insertions(+), 14 deletions(-) create mode 100644 arch/arm/include/asm/arch-imx8/image.h create mode 100644 arch/arm/mach-imx/imx8/parse-container.c create mode 100644 board/freescale/imx8qxp_mek/uboot-container.cfg
Only eval the variables when building related target, then we will not see unrelated warning that when building spl and u-boot.
Signed-off-by: Peng Fan peng.fan@nxp.com --- arch/arm/mach-imx/Makefile | 12 ++++++------ 1 file changed, 6 insertions(+), 6 deletions(-)
diff --git a/arch/arm/mach-imx/Makefile b/arch/arm/mach-imx/Makefile index 37675d0558..0562640599 100644 --- a/arch/arm/mach-imx/Makefile +++ b/arch/arm/mach-imx/Makefile @@ -104,18 +104,15 @@ IMX_CONFIG = $(CONFIG_IMX_CONFIG:"%"=%) $(Q)mkdir -p $(dir $@) $(call if_changed_dep,cpp_cfg)
+DEPFILE_EXISTS := 0 ifeq ($(CONFIG_ARCH_IMX8), y) CNTR_DEPFILES := $(srctree)/tools/imx_cntr_image.sh IMAGE_TYPE := imx8image -SPL_DEPFILE_EXISTS := $(shell $(CPP) $(cpp_flags) -x c -o spl/u-boot-spl.cfgout $(srctree)/$(IMX_CONFIG); if [ -f spl/u-boot-spl.cfgout ]; then $(CNTR_DEPFILES) spl/u-boot-spl.cfgout; echo $$?; fi) -DEPFILE_EXISTS := $(shell $(CPP) $(cpp_flags) -x c -o u-boot-dtb.cfgout $(srctree)/$(IMX_CONFIG); if [ -f u-boot-dtb.cfgout ]; then $(CNTR_DEPFILES) u-boot-dtb.cfgout; echo $$?; fi) else ifeq ($(CONFIG_ARCH_IMX8M), y) IMAGE_TYPE := imx8mimage IMX8M_DEPFILES := $(srctree)/tools/imx8m_image.sh -DEPFILE_EXISTS := $(shell $(CPP) $(cpp_flags) -x c -o spl/u-boot-spl.cfgout $(srctree)/$(IMX_CONFIG);if [ -f spl/u-boot-spl.cfgout ]; then $(IMX8M_DEPFILES) spl/u-boot-spl.cfgout 0; echo $$?; fi) else IMAGE_TYPE := imximage -DEPFILE_EXISTS := 0 endif
MKIMAGEFLAGS_u-boot.imx = -n $(filter-out $(PLUGIN).bin $< $(PHONY),$^) \ @@ -139,30 +136,33 @@ endif
ifdef CONFIG_ARM64 ifeq ($(CONFIG_ARCH_IMX8M), y) -SPL: +SPL: spl/u-boot-spl.bin spl/u-boot-spl.cfgout FORCE
MKIMAGEFLAGS_flash.bin = -n spl/u-boot-spl.cfgout \ -T $(IMAGE_TYPE) -e $(CONFIG_SPL_TEXT_BASE) flash.bin: MKIMAGEOUTPUT = flash.log
spl/u-boot-spl-ddr.bin: spl/u-boot-spl.bin spl/u-boot-spl.cfgout FORCE + $(eval DEPFILE_EXISTS := $(shell $(CPP) $(cpp_flags) -x c -o spl/u-boot-spl.cfgout $(srctree)/$(IMX_CONFIG);if [ -f spl/u-boot-spl.cfgout ]; then $(IMX8M_DEPFILES) spl/u-boot-spl.cfgout 0; echo $$?; fi)) ifeq ($(DEPFILE_EXISTS),0) $(IMX8M_DEPFILES) spl/u-boot-spl.cfgout 1 endif
flash.bin: spl/u-boot-spl-ddr.bin u-boot.itb FORCE + $(eval DEPFILE_EXISTS := $(shell $(CPP) $(cpp_flags) -x c -o spl/u-boot-spl.cfgout $(srctree)/$(IMX_CONFIG);if [ -f spl/u-boot-spl.cfgout ]; then $(IMX8M_DEPFILES) spl/u-boot-spl.cfgout 0; echo $$?; fi)) ifeq ($(DEPFILE_EXISTS),0) $(call if_changed,mkimage) endif endif
ifeq ($(CONFIG_ARCH_IMX8), y) -SPL: +SPL: spl/u-boot-spl.bin spl/u-boot-spl.cfgout FORCE
MKIMAGEFLAGS_flash.bin = -n spl/u-boot-spl.cfgout -T $(IMAGE_TYPE) -e 0x100000 flash.bin: MKIMAGEOUTPUT = flash.log
flash.bin: spl/u-boot-spl.bin u-boot.itb FORCE + $(eval SPL_DEPFILE_EXISTS := $(shell $(CPP) $(cpp_flags) -x c -o spl/u-boot-spl.cfgout $(srctree)/$(IMX_CONFIG); if [ -f spl/u-boot-spl.cfgout ]; then $(CNTR_DEPFILES) spl/u-boot-spl.cfgout; echo $$?; fi)) ifeq ($(SPL_DEPFILE_EXISTS),0) $(call if_changed,mkimage) endif
Add a weak function spl_mmc_get_uboot_raw_sector to get u-boot raw sector. At default it returns CONFIG_SYS_MMCSD_RAW_MODE_U_BOOT_SECTOR. Users can overwrite it to return customized offset.
This is to support i.MX8 specific image type container image type.
Cc: Tien Fong Chee tien.fong.chee@intel.com Cc: Peng Fan peng.fan@nxp.com Cc: Simon Goldschmidt simon.k.r.goldschmidt@gmail.com Cc: York Sun york.sun@nxp.com Cc: Marek Vasut marex@denx.de Cc: Alex Kiernan alex.kiernan@gmail.com Signed-off-by: Peng Fan peng.fan@nxp.com --- common/spl/spl_mmc.c | 11 +++++++++-- 1 file changed, 9 insertions(+), 2 deletions(-)
diff --git a/common/spl/spl_mmc.c b/common/spl/spl_mmc.c index 324d91c884..bf53a1dadf 100644 --- a/common/spl/spl_mmc.c +++ b/common/spl/spl_mmc.c @@ -149,6 +149,13 @@ static int spl_mmc_find_device(struct mmc **mmcp, u32 boot_device) return 0; }
+#ifdef CONFIG_SYS_MMCSD_RAW_MODE_U_BOOT_USE_SECTOR +unsigned long __weak spl_mmc_get_uboot_raw_sector(struct mmc *mmc) +{ + return CONFIG_SYS_MMCSD_RAW_MODE_U_BOOT_SECTOR; +} +#endif + #ifdef CONFIG_SYS_MMCSD_RAW_MODE_U_BOOT_USE_PARTITION static int mmc_load_image_raw_partition(struct spl_image_info *spl_image, struct mmc *mmc, int partition) @@ -181,7 +188,7 @@ static int mmc_load_image_raw_partition(struct spl_image_info *spl_image,
#ifdef CONFIG_SYS_MMCSD_RAW_MODE_U_BOOT_USE_SECTOR return mmc_load_image_raw_sector(spl_image, mmc, - info.start + CONFIG_SYS_MMCSD_RAW_MODE_U_BOOT_SECTOR); + info.start + spl_mmc_get_uboot_raw_sector(mmc)); #else return mmc_load_image_raw_sector(spl_image, mmc, info.start); #endif @@ -366,7 +373,7 @@ int spl_mmc_load_image(struct spl_image_info *spl_image, #endif #ifdef CONFIG_SYS_MMCSD_RAW_MODE_U_BOOT_USE_SECTOR err = mmc_load_image_raw_sector(spl_image, mmc, - CONFIG_SYS_MMCSD_RAW_MODE_U_BOOT_SECTOR); + spl_mmc_get_uboot_raw_sector(mmc)); if (!err) return err; #endif
Add parsing i.MX8 Container file support, this is to let SPL could load images in a container file to destination address.
Signed-off-by: Peng Fan peng.fan@nxp.com --- arch/arm/include/asm/arch-imx8/image.h | 56 +++++++++++++++ arch/arm/mach-imx/imx8/Kconfig | 6 ++ arch/arm/mach-imx/imx8/Makefile | 4 ++ arch/arm/mach-imx/imx8/parse-container.c | 120 +++++++++++++++++++++++++++++++ 4 files changed, 186 insertions(+) create mode 100644 arch/arm/include/asm/arch-imx8/image.h create mode 100644 arch/arm/mach-imx/imx8/parse-container.c
diff --git a/arch/arm/include/asm/arch-imx8/image.h b/arch/arm/include/asm/arch-imx8/image.h new file mode 100644 index 0000000000..c1e5700859 --- /dev/null +++ b/arch/arm/include/asm/arch-imx8/image.h @@ -0,0 +1,56 @@ +/* SPDX-License-Identifier: GPL-2.0+ */ +/* + * Copyright 2018-2019 NXP + */ + +#ifndef __CONTAINER_HEADER_H_ +#define __CONTAINER_HEADER_H_ + +#include <linux/sizes.h> +#include <linux/types.h> + +#define IV_MAX_LEN 32 +#define HASH_MAX_LEN 64 + +#define CONTAINER_HDR_ALIGNMENT 0x400 +#define CONTAINER_HDR_EMMC_OFFSET 0 +#define CONTAINER_HDR_MMCSD_OFFSET SZ_32K +#define CONTAINER_HDR_QSPI_OFFSET SZ_4K +#define CONTAINER_HDR_NAND_OFFSET SZ_128M + +struct container_hdr { + u8 version; + u8 length_lsb; + u8 length_msb; + u8 tag; + u32 flags; + u16 sw_version; + u8 fuse_version; + u8 num_images; + u16 sig_blk_offset; + u16 reserved; +} __packed; + +struct boot_img_t { + u32 offset; + u32 size; + u64 dst; + u64 entry; + u32 hab_flags; + u32 meta; + u8 hash[HASH_MAX_LEN]; + u8 iv[IV_MAX_LEN]; +} __packed; + +struct signature_block_hdr { + u8 version; + u8 length_lsb; + u8 length_msb; + u8 tag; + u16 srk_table_offset; + u16 cert_offset; + u16 blob_offset; + u16 signature_offset; + u32 reserved; +} __packed; +#endif diff --git a/arch/arm/mach-imx/imx8/Kconfig b/arch/arm/mach-imx/imx8/Kconfig index c32f7dbb61..8e6b79eb77 100644 --- a/arch/arm/mach-imx/imx8/Kconfig +++ b/arch/arm/mach-imx/imx8/Kconfig @@ -23,6 +23,12 @@ config IMX8QXP config SYS_SOC default "imx8"
+config SPL_LOAD_IMX_CONTAINER + bool "Enable SPL loading U-Boot as a i.MX Container image" + depends on SPL + help + This is to let SPL could load i.MX8 Container image + choice prompt "i.MX8 board select" optional diff --git a/arch/arm/mach-imx/imx8/Makefile b/arch/arm/mach-imx/imx8/Makefile index 31ad169ccf..19690110a5 100644 --- a/arch/arm/mach-imx/imx8/Makefile +++ b/arch/arm/mach-imx/imx8/Makefile @@ -5,3 +5,7 @@ #
obj-y += cpu.o iomux.o + +ifdef CONFIG_SPL_BUILD +obj-$(CONFIG_SPL_LOAD_IMX_CONTAINER) += parse-container.o +endif diff --git a/arch/arm/mach-imx/imx8/parse-container.c b/arch/arm/mach-imx/imx8/parse-container.c new file mode 100644 index 0000000000..32f78bdddf --- /dev/null +++ b/arch/arm/mach-imx/imx8/parse-container.c @@ -0,0 +1,120 @@ +// SPDX-License-Identifier: GPL-2.0+ +/* + * Copyright 2018-2019 NXP + */ + +#include <common.h> +#include <errno.h> +#include <spl.h> +#include <asm/arch/image.h> + +static struct boot_img_t *read_auth_image(struct spl_image_info *spl_image, + struct spl_load_info *info, + struct container_hdr *container, + int image_index, + u32 container_sector) +{ + struct boot_img_t *images; + ulong sector; + u32 sectors; + + if (image_index > container->num_images) { + debug("Invalid image number\n"); + return NULL; + } + + images = (struct boot_img_t *)((u8 *)container + + sizeof(struct container_hdr)); + + if (images[image_index].offset % info->bl_len) { + printf("%s: image%d offset not aligned to %u\n", + __func__, image_index, info->bl_len); + return NULL; + } + + sectors = roundup(images[image_index].size, info->bl_len) / + info->bl_len; + sector = images[image_index].offset / info->bl_len + + container_sector; + + debug("%s: container: %p sector: %lu sectors: %u\n", __func__, + container, sector, sectors); + if (info->read(info, sector, sectors, + (void *)images[image_index].entry) != sectors) { + printf("%s wrong\n", __func__); + return NULL; + } + + return &images[image_index]; +} + +static int read_auth_container(struct spl_image_info *spl_image, + struct spl_load_info *info, ulong sector) +{ + struct container_hdr *container = NULL; + u16 length; + u32 sectors; + int i, size; + + size = roundup(CONTAINER_HDR_ALIGNMENT, info->bl_len); + sectors = size / info->bl_len; + + /* + * It will not override the ATF code, so safe to use it here, + * no need malloc + */ + container = (struct container_hdr *)spl_get_load_buffer(-size, size); + + debug("%s: container: %p sector: %lu sectors: %u\n", __func__, + container, sector, sectors); + if (info->read(info, sector, sectors, container) != sectors) + return -EIO; + + if (container->tag != 0x87 && container->version != 0x0) { + printf("Wrong container header"); + return -ENOENT; + } + + if (!container->num_images) { + printf("Wrong container, no image found"); + return -ENOENT; + } + + length = container->length_lsb + (container->length_msb << 8); + debug("Container length %u\n", length); + + if (length > CONTAINER_HDR_ALIGNMENT) { + size = roundup(length, info->bl_len); + sectors = size / info->bl_len; + + container = (struct container_hdr *)spl_get_load_buffer(-size, size); + + debug("%s: container: %p sector: %lu sectors: %u\n", + __func__, container, sector, sectors); + if (info->read(info, sector, sectors, container) != + sectors) + return -EIO; + } + + for (i = 0; i < container->num_images; i++) { + struct boot_img_t *image = read_auth_image(spl_image, info, + container, i, + sector); + + if (!image) + return -EINVAL; + + if (i == 0) { + spl_image->load_addr = image->dst; + spl_image->entry_point = image->entry; + } + } + + return 0; +} + +int spl_load_imx_container(struct spl_image_info *spl_image, + struct spl_load_info *info, ulong sector) +{ + return read_auth_container(spl_image, info, sector); +}
i.MX8 only support AHAB secure boot with Container format image, we could not use FIT to support secure boot, so introduce container support to let SPL could load container images.
Cc: Simon Goldschmidt simon.k.r.goldschmidt@gmail.com Cc: Tien Fong Chee tien.fong.chee@intel.com Cc: York Sun york.sun@nxp.com Cc: Marek Vasut marex@denx.de Cc: Alex Kiernan alex.kiernan@gmail.com Cc: Simon Glass sjg@chromium.org Cc: Philipp Tomsich philipp.tomsich@theobroma-systems.com Cc: Kever Yang kever.yang@rock-chips.com Cc: Heiko Schocher hs@denx.de Signed-off-by: Peng Fan peng.fan@nxp.com --- common/spl/spl_mmc.c | 10 ++++++++++ include/spl.h | 12 ++++++++++++ 2 files changed, 22 insertions(+)
diff --git a/common/spl/spl_mmc.c b/common/spl/spl_mmc.c index bf53a1dadf..6320af055b 100644 --- a/common/spl/spl_mmc.c +++ b/common/spl/spl_mmc.c @@ -79,6 +79,16 @@ int mmc_load_image_raw_sector(struct spl_image_info *spl_image, load.bl_len = mmc->read_bl_len; load.read = h_spl_load_read; ret = spl_load_simple_fit(spl_image, &load, sector, header); + } else if (IS_ENABLED(CONFIG_SPL_LOAD_IMX_CONTAINER)) { + struct spl_load_info load; + + load.dev = mmc; + load.priv = NULL; + load.filename = NULL; + load.bl_len = mmc->read_bl_len; + load.read = h_spl_load_read; + + ret = spl_load_imx_container(spl_image, &load, sector); } else { ret = mmc_load_legacy(spl_image, mmc, sector, header); } diff --git a/include/spl.h b/include/spl.h index f09909e189..b7c8a972dd 100644 --- a/include/spl.h +++ b/include/spl.h @@ -125,6 +125,18 @@ int spl_load_simple_fit(struct spl_image_info *spl_image, #define SPL_COPY_PAYLOAD_ONLY 1 #define SPL_FIT_FOUND 2
+/** + * spl_load_imx_container() - Loads a imx container image from a device. + * @spl_image: Image description to set up + * @info: Structure containing the information required to load data. + * @sector: Sector number where container image is located in the device + * + * Reads the container image @sector in the device. Loads u-boot image to + * specified load address. + */ +int spl_load_imx_container(struct spl_image_info *spl_image, + struct spl_load_info *info, ulong sector); + /* SPL common functions */ void preloader_console_init(void); u32 spl_boot_device(void);
Hi Peng,
Why not FIT?
What is a container image? Can you please point to documentation?
Hi Simon,
Subject: Re: [PATCH 4/6] spl: mmc: support loading i.MX container format file
Hi Peng,
Why not FIT?
Actually before we implement secure boot, we use FIT image, however i.MX8 only support i.MX container format image for secure boot, The chip will verify the container image when secure boot. It could not recognize FIT image. So we have to drop FIT image.
Sadly, there is no public reference manual. There is a doc that has a bit of information. https://community.nxp.com/docs/DOC-343178
Thanks, Peng.
On 5/20/19 3:30 AM, Peng Fan wrote:
Hi Simon,
Hi Peng,
Why not FIT?
Shouldn't it suffice for the SPL to be in this custom format , while the rest of the binaries can be in fitImage ?
Hi Marek,
Subject: Re: [U-Boot] [PATCH 4/6] spl: mmc: support loading i.MX container format file
Hi Simon,
Hi Peng,
Why not FIT?
https://eur01.safelinks.protection.outlook.com/?url=https%3A%2F%2Fcomm
unity.nxp.com%2Fdocs%2FDOC-343178&data=02%7C01%7Cpeng.fan%4 0nxp.co
m%7C8626e7a1d20c44b8715408d6dcc4d866%7C686ea1d3bc2b4c6fa92cd9 9c5c30163
5%7C0%7C0%7C636939135344595378&sdata=vmIaO78XmuL1tQJufqf7 HCGdWHTCJ
bEpmGBio15j46U%3D&reserved=0
The issue is the SoC only support i.MX container format for secure boot(AHAB boot), if we not use secure boot, FIT image do work and could work well.
We investigated using FIT for i.MX8 secure boot, but it does not make sense we did a FIT wrapper for container. Container itself is also an image format, it contains image load/entry/size and etc information.
I add a kconfig entry in SPL code, it does not hurt others if the Kconfig entry not chosen.
I do not know how other SoC vendor did FIT hardware secure boot, please share you have any information.
Thanks, Peng.
-- Best regards, Marek Vasut
On 5/20/19 3:54 AM, Peng Fan wrote:
Hi Marek,
Hi Simon,
Hi Peng,
Why not FIT?
The SPL can be in the custom format, but then can load fitImage with the next stage(s), right ?
Hi Marek,
Hi Marek,
Hi Simon,
Hi Peng,
Why not FIT?
m
0nxp.co
9c5c30163
HCGdWHTCJ
work well.
not chosen.
I am not able to follow you, could you share more details?
Thanks, Peng.
On 5/21/19 4:31 AM, Peng Fan wrote:
Hi Marek,
Hi Marek,
Hi Simon,
Hi Peng,
On Tue, 7 May 2019 at 06:52, Peng Fan peng.fan@nxp.com wrote: > > i.MX8 only support AHAB secure boot with Container format image, > we could not use FIT to support secure boot, so introduce > container
Why not FIT?
m
0nxp.co
9c5c30163
HCGdWHTCJ
work well.
not chosen.
Wrap the SPL into this custom format and then have the SPL load/authenticate fitImage with the rest (U-Boot, Linux, DTB etc). Would that work ?
Hi Marek,
Hi Marek,
Hi Marek,
Hi Simon,
> Subject: Re: [PATCH 4/6] spl: mmc: support loading i.MX container > format file > > Hi Peng, > > On Tue, 7 May 2019 at 06:52, Peng Fan peng.fan@nxp.com wrote: >> >> i.MX8 only support AHAB secure boot with Container format image, >> we could not use FIT to support secure boot, so introduce >> container > > Why not FIT?
> >> support to let SPL could load container images. > > What is a container image? Can you please point to documentation?
m
0nxp.co
9c5c30163
HCGdWHTCJ
work well.
information.
not chosen.
It not work. We already wrap SPL in i.MX container format, this patchset is to let SPL could load the 2nd container file which contains U-Boot/DTB/OP-TEE/ATF. If we let SPL load a fitimage which contains (U-Boot/DTB and etc), it could not pass secure boot authentication, because ROM not know fitimage, it only know i.MX container format.
For authentication, we always let ROM to authenticate including SPL authenticating U-Boot, so we need pass an image to ROM that ROM could recognize when SPL booting 2nd image.
Thanks, Peng.
On 5/21/19 4:55 AM, Peng Fan wrote: [...]
It's not bootrom that authenticates the next stage, it's U-Boot SPL. BootROM already authenticated and started the U-Boot SPL, so that's a trusted code. Now this trusted code can authenticate and start the next stage (U-Boot, ATF, OpTee OS, etc) ; the BootROM is already out of the picture at this point.
Shouldn't the CPU have some sort of facility, like a crypto engine, which authenticates whatever blob with the right signature against a key burned into the CPU ? If so, then you would just implement a crypto driver and pass the blob and signature to it. I suspect that's how it should work, how else would Linux be able to make use of these secure bits if it cannot call the bootrom anymore ?
Sorry for not clear. On i.MX8, SCFW (a runtime firmware )exports API for others to use, sc_seco_authenticate is the API that used for authentication. I could not share more information about this API works inside SCFW and ROM. sc_err_t sc_seco_authenticate(sc_ipc_t ipc, sc_seco_auth_cmd_t cmd, sc_faddr_t addr)
SPL will call this API, one parameter is address which needs a container image there.
sc_seco_authenticate on i.MX8 will always be available. It is exported by a runtime firmware running on a Cortex-M core inside i.MX8. The API will do authentication, its accepts container format image as input and no other format.
Thanks, Peng.
Hi Peng,
> I do not know how other SoC vendor did FIT hardware secure > boot, please share you have any information.
Please consider following scenario (I think that this is in sync with Marek's point):
1. You wrap SPL into i.MX8 "container", so the SPL would be recognised an checked by secure code in ROM.
2. Then we do have SPL "trusted". It is up to SPL to:
2.1. Use its private key to check u-boot, dtb, etc embedded into FitImage (as written here: ./doc/uImage.FIT/verified-boot.txt).
2.2. Use crypto engine (it's API) with fused keys to speed-up the process of boot (by HW support to check the binary). Such approach is in i.MX6Q.
By using above approach we do have the NXP's "container" format only seen in the SPL (which is OK, as for example Samsung does similar thing with FBL/BL1). When SPL is "trused" we may use available facilities.
Thanks, Peng.
Lukasz Majewski
DENX Software Engineering GmbH, Managing Director: Wolfgang Denk HRB 165235 Munich, Office: Kirchenstr.5, D-82194 Groebenzell, Germany Phone: (+49)-8142-66989-59 Fax: (+49)-8142-66989-80 Email: lukma@denx.de
On 5/21/19 10:32 AM, Lukasz Majewski wrote:
Hi Peng,
>> I do not know how other SoC vendor did FIT hardware secure >> boot, please share you have any information. > > The SPL can be in the custom format, but then can load fitImage > with the next stage(s), right ?
It's not in sync, see 2.1 below.
- You wrap SPL into i.MX8 "container", so the SPL would be recognised
- Then we do have SPL "trusted". It is up to SPL to:
Then you have two private keys, one which is potentially exposed by being in the SPL. You want to use the crypto engine, which has a key in it and which cannot be easily extracted.
My question is, how can Linux crypto API make use of the built-in private key in the iMX8 to authenticate payload ? There surely is a way.
Hi Marek,
Hi Peng,
>>> I do not know how other SoC vendor did FIT hardware secure >>> boot, please share you have any information. >> >> The SPL can be in the custom format, but then can load >> fitImage with the next stage(s), right ? > > I am not able to follow you, could you share more details?
There shall be s/private key/public key/g in the SPL (but then the SPL needs to be trusted).
And I fully agree that we shall use crypto engine whenever possible.
Lukasz Majewski
Hi Lukasz,
-----Original Message----- From: Lukasz Majewski [mailto:lukma@denx.de] Sent: 2019年5月21日 16:33 To: Peng Fan peng.fan@nxp.com Cc: Marek Vasut marex@denx.de; Marek Vasut marek.vasut@gmail.com; Simon Glass sjg@chromium.org; u-boot@lists.denx.de; Tien Fong Chee tien.fong.chee@intel.com; York Sun york.sun@nxp.com; dl-uboot-imx uboot-imx@nxp.com Subject: Re: [U-Boot] [PATCH 4/6] spl: mmc: support loading i.MX container format file
Hi Peng,
- You wrap SPL into i.MX8 "container", so the SPL would be recognised an
I suppose you talking HAB.
The issue to me is that sc_seco_authenticate could not take a FIT image as input.
If I switch to FIT, I need to use FIT to wrap a container image, it does not make sense to me.
Thanks, Peng.
Thanks, Peng.
Lukasz Majewski
Hi Peng,
Hi Lukasz,
Hi Peng,
Yes. As described here:
https://www.nxp.com/docs/en/application-note/AN4581.pdf
Is the sc_seco_authenticate an API accessible from SPL, U-Boot proper or Linux crypro engine driver?
Or is it just the function executed by ROM on the very beginning to load SPL?
Please correct me if I'm wrong, but isn't the container image only needed to wrap SPL?
In which other cases the container image is needed in U-Boot proper or Linux kernel?
Thanks, Peng.
Thanks, Peng.
Lukasz Majewski
Lukasz Majewski
>>>> I do not know how other SoC vendor did FIT hardware secure >>>> boot, please share you have any information. >>> >>> The SPL can be in the custom format, but then can load >>> fitImage with the next stage(s), right ? >> >> I am not able to follow you, could you share more details? > > Wrap the SPL into this custom format and then have the SPL > load/authenticate fitImage with the rest (U-Boot, Linux, DTB > etc). Would that work ?
Yes, it is an API accessible in SPL/U-Boot stage. I do not know about Linux crypto driver.
Container image will wrap SPL to make ROM could load SPL, Kick SPL and authenticate SPL.
When SPL booting U-Boot, SPL could use FIT to load and boot uboot. But when SPL need to authenticate U-Boot with AHAB on i.MX8, a container format header/image needs to be passed to sc_seco_authenticate API, the API internal implementation is it will parse the container header/image.
So in vendor tree, uboot/atf/optee are wrapped into a container format image.
When uboot authenticate kernel, we also wrap kernel image into a container format file using CST. I do not know how Linux kernel itself authenticate others.
Thanks, Peng.
Thanks, Peng.
Thanks, Peng.
Lukasz Majewski
Lukasz Majewski
Hi Peng,
>>>>> I do not know how other SoC vendor did FIT hardware >>>>> secure boot, please share you have any information. >>>> >>>> The SPL can be in the custom format, but then can load >>>> fitImage with the next stage(s), right ? >>> >>> I am not able to follow you, could you share more >>> details? >> >> Wrap the SPL into this custom format and then have the >> SPL load/authenticate fitImage with the rest (U-Boot, >> Linux, DTB etc). Would that work ? > > It not work. > We already wrap SPL in i.MX container format, this > patchset is to let SPL could load the 2nd container file > which contains U-Boot/DTB/OP-TEE/ATF. If we let SPL load > a fitimage which contains (U-Boot/DTB and etc), it could > not pass secure boot authentication, because ROM not know > fitimage, it only know i.MX container format.
Maybe it would be worth to check how Linux handle this? Maybe it would shed some more light on it?
Ok. So it is needed in the ROM "part" of security.
Ok. So every time we want to use the sc_seco_authenticate API the provided image for checking needs to be wrapped into the "container" iMX8 specific format.
Ok.
Thanks, Peng.
Thanks, Peng.
> For authentication, we always let ROM to authenticate > including SPL authenticating U-Boot, so we need pass an > image to ROM that ROM could recognize when SPL booting > 2nd image.
Thanks, Peng.
Lukasz Majewski
Lukasz Majewski
Lukasz Majewski
> Subject: Re: [U-Boot] [PATCH 4/6] spl: mmc: support loading > i.MX container format file > > On 5/21/19 4:55 AM, Peng Fan wrote: > [...] > > >>>>> I do not know how other SoC vendor did FIT hardware > >>>>> secure boot, please share you have any information. > >>>> > >>>> The SPL can be in the custom format, but then can load > >>>> fitImage with the next stage(s), right ? > >>> > >>> I am not able to follow you, could you share more > >>> details? > >> > >> Wrap the SPL into this custom format and then have the > >> SPL load/authenticate fitImage with the rest (U-Boot, > >> Linux, DTB etc). Would that work ? > > > > It not work. > > We already wrap SPL in i.MX container format, this > > patchset is to let SPL could load the 2nd container file > > which contains U-Boot/DTB/OP-TEE/ATF. If we let SPL load > > a fitimage which contains (U-Boot/DTB and etc), it could > > not pass secure boot authentication, because ROM not know > > fitimage, it only know i.MX container format. > > It's not bootrom that authenticates the next stage, it's > U-Boot SPL. BootROM already authenticated and started the > U-Boot SPL, so that's a trusted code. Now this trusted code > can authenticate and start the next stage (U-Boot, ATF, > OpTee OS, etc) ; the BootROM is already out of the picture > at this point.
I am not familiar with that, so might be stupid question below. Does it really matter? i.MX6 HAB secure boot also requires CSF padding into image, we could not pass other format image to ROM when using HAB, right?
Yes. Otherwise sc_seco_authenticate will return failure. I could not think out better solution, another approach is let uboot generating a container header, and use FIT to wrap the header and other payload images, but I think directly generating a container image is simpler, because we already have SPL been wrapped into container format.
Thanks, Peng.
Ok.
Thanks, Peng.
Thanks, Peng.
> > > For authentication, we always let ROM to authenticate > > including SPL authenticating U-Boot, so we need pass an > > image to ROM that ROM could recognize when SPL booting 2nd > > image. > > Shouldn't the CPU have some sort of facility, like a crypto > engine, which authenticates whatever blob with the right > signature against a key burned into the CPU ? If so, then > you would just implement a crypto driver and pass the blob > and signature to it. I suspect that's how it should work, > how else would Linux be able to make use of these secure > bits if it cannot call the bootrom anymore ?
Thanks, Peng.
> > -- > Best regards, > Marek Vasut _______________________________________________ U-Boot mailing list U-Boot@lists.denx.de https://lists.denx.de/listinfo/u-boot
Lukasz Majewski
Wolfgang
Lukasz Majewski
Lukasz Majewski
Hi Peng,
> > Subject: Re: [U-Boot] [PATCH 4/6] spl: mmc: support > > loading i.MX container format file > > > > On 5/21/19 4:55 AM, Peng Fan wrote: > > [...] > > > > >>>>> I do not know how other SoC vendor did FIT > > >>>>> hardware secure boot, please share you have any > > >>>>> information. > > >>>> > > >>>> The SPL can be in the custom format, but then can > > >>>> load fitImage with the next stage(s), right ? > > >>> > > >>> I am not able to follow you, could you share more > > >>> details? > > >> > > >> Wrap the SPL into this custom format and then have > > >> the SPL load/authenticate fitImage with the rest > > >> (U-Boot, Linux, DTB etc). Would that work ? > > > > > > It not work. > > > We already wrap SPL in i.MX container format, this > > > patchset is to let SPL could load the 2nd container > > > file which contains U-Boot/DTB/OP-TEE/ATF. If we let > > > SPL load a fitimage which contains (U-Boot/DTB and > > > etc), it could not pass secure boot authentication, > > > because ROM not know fitimage, it only know i.MX > > > container format. > > > > It's not bootrom that authenticates the next stage, it's > > U-Boot SPL. BootROM already authenticated and started > > the U-Boot SPL, so that's a trusted code. Now this > > trusted code can authenticate and start the next stage > > (U-Boot, ATF, OpTee OS, etc) ; the BootROM is already > > out of the picture at this point. > > Sorry for not clear. On i.MX8, SCFW (a runtime firmware > )exports API for others to use, sc_seco_authenticate is > the API that used for authentication. I could not share > more information about this API works inside SCFW and > ROM. sc_err_t sc_seco_authenticate(sc_ipc_t ipc, > sc_seco_auth_cmd_t cmd, sc_faddr_t addr) > > SPL will call this API, one parameter is address which > needs a container image there.
I would check it just out of curiosity.
Yes.
I just wanted to understand the issue and help to get the simplest possible solution.
Thanks, Peng.
Ok.
Thanks, Peng.
Thanks, Peng.
> > > > > > For authentication, we always let ROM to authenticate > > > including SPL authenticating U-Boot, so we need pass > > > an image to ROM that ROM could recognize when SPL > > > booting 2nd image. > > > > Shouldn't the CPU have some sort of facility, like a > > crypto engine, which authenticates whatever blob with > > the right signature against a key burned into the CPU ? > > If so, then you would just implement a crypto driver > > and pass the blob and signature to it. I suspect that's > > how it should work, how else would Linux be able to > > make use of these secure bits if it cannot call the > > bootrom anymore ? > > sc_seco_authenticate on i.MX8 will always be available. > It is exported by a runtime firmware running on a > Cortex-M core inside i.MX8. The API will do > authentication, its accepts container format image as > input and no other format. > > Thanks, > Peng. > > > > > -- > > Best regards, > > Marek Vasut > _______________________________________________ > U-Boot mailing list > U-Boot@lists.denx.de > https://lists.denx.de/listinfo/u-boot
Lukasz Majewski
Wolfgang
Lukasz Majewski
Lukasz Majewski
Lukasz Majewski
On 5/22/19 9:34 AM, Lukasz Majewski wrote: [...]
> By using above approach we do have the NXP's "container" > format only seen in the SPL (which is OK, as for example > Samsung does similar thing with FBL/BL1). When SPL is > "trused" we may use available facilities.
Yes, it matters, because there should be such API. How would Linux authenticate e.g. userspace binaries if there wasn't one, surely not by wrapping every single object into the custom vendor-specific container ? And if there is one, you can use it to authenticate raw binaries from U-Boot SPL too, e.g. fitImage blobs with an associated signature.
Hi Marek,
On 2019/5/22 19:41, Marek Vasut wrote:
Caution: EXT Email
>> By using above approach we do have the NXP's "container" >> format only seen in the SPL (which is OK, as for example >> Samsung does similar thing with FBL/BL1). When SPL is >> "trused" we may use available facilities. > > The issue to me is that sc_seco_authenticate could not take a > FIT image as input.
iMX8 AHAB uses RSA key pair for authentication, the on-chip thing we called SRK is a array of public key hash which is dedicated for AHAB. It is not a real key. The real public key is in container. AHAB will check the public key with the on-chip SRK before using it to authenticate the image. Seco which contains the crypto engine on imx8 does not allow to use the SRK by user. No such API exported. And the fuse of SRK is locked, can't be read directly.
Actually on imx6/imx7/imx8m, the SPL and u-boot are already using ROM HAB to implement the trust chain, like SPL authenticates u-boot, u-boot authenticatse kernel. We just follow this same way on imx8, the difference is imx8 needs container format for signed image. We prefer directly loading container image than fit image. If we pack fit image into container, obviously this will cause one more copy. As a boot loader, isn't it better to have more image format supported? We don't force to use container, just set it as default. Users still can choose fit or raw image.
Hi Marek, Lukasz,
Subject: Re: [EXT] Re: [U-Boot] [PATCH 4/6] spl: mmc: support loading i.MX container format file
Hi Marek,
Caution: EXT Email
>>> By using above approach we do have the NXP's "container" >>> format only seen in the SPL (which is OK, as for example >>> Samsung does similar thing with FBL/BL1). When SPL is "trused" >>> we may use available facilities. >> >> The issue to me is that sc_seco_authenticate could not take a >> FIT image as input. > > Is the sc_seco_authenticate an API accessible from SPL, U-Boot > proper or Linux crypro engine driver?
Do you have more comment?
Thanks, Peng.
On 5/27/19 11:49 AM, Peng Fan wrote:
Hi Marek, Lukasz,
Hi Marek,
Caution: EXT Email
>>>> By using above approach we do have the NXP's "container" >>>> format only seen in the SPL (which is OK, as for example >>>> Samsung does similar thing with FBL/BL1). When SPL is "trused" >>>> we may use available facilities. >>> >>> The issue to me is that sc_seco_authenticate could not take a >>> FIT image as input. >> >> Is the sc_seco_authenticate an API accessible from SPL, U-Boot >> proper or Linux crypro engine driver? > > Yes, it is an API accessible in SPL/U-Boot stage. I do not know > about Linux crypto driver.
If the functionality of the new image format is a subset of already present image format, then no, that's called a duplication.
They can. however they cannot authenticate the fitImage because the firmware doesn't provide the necessary API for that ?
How could Linux use this iMX8 chain of trust stuff to authenticate e.g. userspace binaries ? It's the same thing as authenticating blob in a fitImage.
On 2019/5/27 19:31, Marek Vasut wrote:
Caution: EXT Email
Hi Marek, Lukasz,
Hi Marek,
Caution: EXT Email
>>>>> By using above approach we do have the NXP's "container" >>>>> format only seen in the SPL (which is OK, as for example >>>>> Samsung does similar thing with FBL/BL1). When SPL is "trused" >>>>> we may use available facilities. >>>> >>>> The issue to me is that sc_seco_authenticate could not take a >>>> FIT image as input. >>> >>> Is the sc_seco_authenticate an API accessible from SPL, U-Boot >>> proper or Linux crypro engine driver? >> >> Yes, it is an API accessible in SPL/U-Boot stage. I do not know >> about Linux crypto driver. > > Maybe it would be worth to check how Linux handle this? Maybe it > would shed some more light on it?
Userspace binaries don't use the same key pair. They are signed by software vendors' key. The private key for chip secure boot is only hold by device manufacturer. For example, android needs to authenticate a signed APK. Its public key (Key A) is in system FS. iMX trust chain only reaches to kernel + ramdisk. Then the chain hands over to android. In ramdisk, android puts another public Key (Key B) used by dm-verify for system FS. So once system FS is verified ok, then the public key A becomes trusted. Finally we can use public key A for APK authentication.
Best regards, Ye Li
Caution: EXT Email
Hi Marek, Lukasz,
Hi Marek,
Caution: EXT Email
>>>>>> By using above approach we do have the NXP's "container" >>>>>> format only seen in the SPL (which is OK, as for example >>>>>> Samsung does similar thing with FBL/BL1). When SPL is "trused" >>>>>> we may use available facilities. >>>>> >>>>> The issue to me is that sc_seco_authenticate could not take a >>>>> FIT image as input. >>>> >>>> Is the sc_seco_authenticate an API accessible from SPL, U-Boot >>>> proper or Linux crypro engine driver? >>> >>> Yes, it is an API accessible in SPL/U-Boot stage. I do not know >>> about Linux crypto driver. >> >> Maybe it would be worth to check how Linux handle this? Maybe it >> would shed some more light on it? > > I am not familiar with that, so might be stupid question below. > Does it really matter?
So can we put a public key into the SPL and use it to verify a fitImage ?
Caution: EXT Email
Hi Marek, Lukasz,
Hi Marek,
Caution: EXT Email
On 5/22/19 9:34 AM, Lukasz Majewski wrote: [...] >>>>>>> By using above approach we do have the NXP's "container" >>>>>>> format only seen in the SPL (which is OK, as for example >>>>>>> Samsung does similar thing with FBL/BL1). When SPL is
"trused"
>>>>>>> we may use available facilities. >>>>>> >>>>>> The issue to me is that sc_seco_authenticate could not take >>>>>> a FIT image as input. >>>>> >>>>> Is the sc_seco_authenticate an API accessible from SPL, >>>>> U-Boot proper or Linux crypro engine driver? >>>> >>>> Yes, it is an API accessible in SPL/U-Boot stage. I do not >>>> know about Linux crypto driver. >>> >>> Maybe it would be worth to check how Linux handle this? Maybe >>> it would shed some more light on it? >> >> I am not familiar with that, so might be stupid question below. >> Does it really matter? > > I would check it just out of curiosity.
container ?
copy.
A) is in system FS.
to android.
Technically doable. But compared with the current approach that reuse ROM public API, Using crypto driver in SPL will be complicated and code size larger without calling ROM API.
I do not understand the problem the SPL loading NXP i.MX8 container format. SPL should only support raw and fit format? vendor format is not allowed and not accepted?
Stefano, Simon, Tom
Any comments?
Thanks, Peng.
Caution: EXT Email
Hi Marek, Lukasz,
Hi Marek,
On 2019/5/22 19:41, Marek Vasut wrote: > Caution: EXT Email > > On 5/22/19 9:34 AM, Lukasz Majewski wrote: > [...] >>>>>>>> By using above approach we do have the NXP's "container" >>>>>>>> format only seen in the SPL (which is OK, as for example >>>>>>>> Samsung does similar thing with FBL/BL1). When SPL is
"trused"
>>>>>>>> we may use available facilities. >>>>>>> >>>>>>> The issue to me is that sc_seco_authenticate could not take >>>>>>> a FIT image as input. >>>>>> >>>>>> Is the sc_seco_authenticate an API accessible from SPL, >>>>>> U-Boot proper or Linux crypro engine driver? >>>>> >>>>> Yes, it is an API accessible in SPL/U-Boot stage. I do not >>>>> know about Linux crypto driver. >>>> >>>> Maybe it would be worth to check how Linux handle this? Maybe >>>> it would shed some more light on it? >>> >>> I am not familiar with that, so might be stupid question below. >>> Does it really matter? >> >> I would check it just out of curiosity. > > Yes, it matters, because there should be such API. How would Linux > authenticate e.g. userspace binaries if there wasn't one, surely > not by wrapping every single object into the custom vendor-specific
container ?
> And if there is one, you can use it to authenticate raw binaries > from U-Boot SPL too, e.g. fitImage blobs with an associated signature. >
copy.
A) is in system FS.
to android.
The problem I have is with the duplication of functionality -- the iMX8 custom format does exactly the same as fitImage, except differently and with smaller user base, thus with less users and reviewers and thus with less potential bugfixes, which I think in crypto code is important.
Caution: EXT Email
Hi Marek, Lukasz,
> Subject: Re: [EXT] Re: [U-Boot] [PATCH 4/6] spl: mmc: support > loading i.MX container format file > > Hi Marek, > > On 2019/5/22 19:41, Marek Vasut wrote: >> Caution: EXT Email >> >> On 5/22/19 9:34 AM, Lukasz Majewski wrote: >> [...] >>>>>>>>> By using above approach we do have the NXP's "container" >>>>>>>>> format only seen in the SPL (which is OK, as for example >>>>>>>>> Samsung does similar thing with FBL/BL1). When SPL is
"trused"
>>>>>>>>> we may use available facilities. >>>>>>>> >>>>>>>> The issue to me is that sc_seco_authenticate could not >>>>>>>> take a FIT image as input. >>>>>>> >>>>>>> Is the sc_seco_authenticate an API accessible from SPL, >>>>>>> U-Boot proper or Linux crypro engine driver? >>>>>> >>>>>> Yes, it is an API accessible in SPL/U-Boot stage. I do not >>>>>> know about Linux crypto driver. >>>>> >>>>> Maybe it would be worth to check how Linux handle this? Maybe >>>>> it would shed some more light on it? >>>> >>>> I am not familiar with that, so might be stupid question below. >>>> Does it really matter? >>> >>> I would check it just out of curiosity. >> >> Yes, it matters, because there should be such API. How would >> Linux authenticate e.g. userspace binaries if there wasn't one, >> surely not by wrapping every single object into the custom >> vendor-specific
container ?
>> And if there is one, you can use it to authenticate raw binaries >> from U-Boot SPL too, e.g. fitImage blobs with an associated
signature.
>> > > iMX8 AHAB uses RSA key pair for authentication, the on-chip thing > we called SRK is a array of public key hash which is dedicated > for AHAB. It is not a real key. The real public key is in container. > AHAB will check the public key with the on-chip SRK before using > it to authenticate the image. > Seco which contains the crypto engine on imx8 does not allow to > use the SRK by user. No such API exported. > And the fuse of SRK is locked, can't be read directly. > > Actually on imx6/imx7/imx8m, the SPL and u-boot are already using > ROM HAB to implement the trust chain, like SPL authenticates > u-boot, u-boot authenticatse kernel. We just follow this same way > on imx8, the difference is > imx8 needs container format for signed image. We prefer directly > loading container image than fit image. > If we pack fit image into container, obviously this will cause > one more
copy.
> We > don't force to use container, just set it as default. Users still > can choose fit or raw image.
A) is in system FS.
to android.
authentication.
format.
The change to spl mmc common code is as below: diff --git a/common/spl/spl_mmc.c b/common/spl/spl_mmc.c index bf53a1dadf..6320af055b 100644 --- a/common/spl/spl_mmc.c +++ b/common/spl/spl_mmc.c @@ -79,6 +79,16 @@ int mmc_load_image_raw_sector(struct spl_image_info *spl_image, load.bl_len = mmc->read_bl_len; load.read = h_spl_load_read; ret = spl_load_simple_fit(spl_image, &load, sector, header); + } else if (IS_ENABLED(CONFIG_SPL_LOAD_IMX_CONTAINER)) { + struct spl_load_info load; + + load.dev = mmc; + load.priv = NULL; + load.filename = NULL; + load.bl_len = mmc->read_bl_len; + load.read = h_spl_load_read; + + ret = spl_load_imx_container(spl_image, &load, sector); } else {
If IMX_CONTAINER is not preferred, I'll change it to CONFIG_SPL_LOAD_VENDOR_FORMAT. In this way, only i.MX users need to take care container format, non i.MX users no need to care about that.
It is not duplication of FIT. Container support the similar function of FIT image, but it is not only that.
Thanks, Peng.
Caution: EXT Email
On 5/27/19 11:49 AM, Peng Fan wrote: > Hi Marek, Lukasz, > >> Subject: Re: [EXT] Re: [U-Boot] [PATCH 4/6] spl: mmc: support >> loading i.MX container format file >> >> Hi Marek, >> >> On 2019/5/22 19:41, Marek Vasut wrote: >>> Caution: EXT Email >>> >>> On 5/22/19 9:34 AM, Lukasz Majewski wrote: >>> [...] >>>>>>>>>> By using above approach we do have the NXP's "container" >>>>>>>>>> format only seen in the SPL (which is OK, as for example >>>>>>>>>> Samsung does similar thing with FBL/BL1). When SPL is
"trused"
>>>>>>>>>> we may use available facilities. >>>>>>>>> >>>>>>>>> The issue to me is that sc_seco_authenticate could not >>>>>>>>> take a FIT image as input. >>>>>>>> >>>>>>>> Is the sc_seco_authenticate an API accessible from SPL, >>>>>>>> U-Boot proper or Linux crypro engine driver? >>>>>>> >>>>>>> Yes, it is an API accessible in SPL/U-Boot stage. I do not >>>>>>> know about Linux crypto driver. >>>>>> >>>>>> Maybe it would be worth to check how Linux handle this? Maybe >>>>>> it would shed some more light on it? >>>>> >>>>> I am not familiar with that, so might be stupid question below. >>>>> Does it really matter? >>>> >>>> I would check it just out of curiosity. >>> >>> Yes, it matters, because there should be such API. How would >>> Linux authenticate e.g. userspace binaries if there wasn't one, >>> surely not by wrapping every single object into the custom >>> vendor-specific
container ?
>>> And if there is one, you can use it to authenticate raw binaries >>> from U-Boot SPL too, e.g. fitImage blobs with an associated
signature.
>>> >> >> iMX8 AHAB uses RSA key pair for authentication, the on-chip thing >> we called SRK is a array of public key hash which is dedicated >> for AHAB. It is not a real key. The real public key is in container. >> AHAB will check the public key with the on-chip SRK before using >> it to authenticate the image. >> Seco which contains the crypto engine on imx8 does not allow to >> use the SRK by user. No such API exported. >> And the fuse of SRK is locked, can't be read directly. >> >> Actually on imx6/imx7/imx8m, the SPL and u-boot are already using >> ROM HAB to implement the trust chain, like SPL authenticates >> u-boot, u-boot authenticatse kernel. We just follow this same way >> on imx8, the difference is >> imx8 needs container format for signed image. We prefer directly >> loading container image than fit image. >> If we pack fit image into container, obviously this will cause >> one more
copy.
>> We >> don't force to use container, just set it as default. Users still >> can choose fit or raw image.
A) is in system FS.
to android.
authentication.
format.
load.dev = mmc;
load.priv = NULL;
I never implied that.
That would make it even worse, since if we follow this course of development, I suspect iMX9 will have another different container format and the list will grow on.
So what is it ?
I don't think I get it. Why would I, as an iMX8 user, want to pick custom new vendor-specific format over years-proven generic fitImage? What is the selling point here ?
On 2019/5/27 19:31, Marek Vasut wrote: > Caution: EXT Email > > On 5/27/19 11:49 AM, Peng Fan wrote: >> Hi Marek, Lukasz, >> >>> Subject: Re: [EXT] Re: [U-Boot] [PATCH 4/6] spl: mmc: support >>> loading i.MX container format file >>> >>> Hi Marek, >>> >>> On 2019/5/22 19:41, Marek Vasut wrote: >>>> Caution: EXT Email >>>> >>>> On 5/22/19 9:34 AM, Lukasz Majewski wrote: >>>> [...] >>>>>>>>>>> By using above approach we do have the NXP's
"container"
>>>>>>>>>>> format only seen in the SPL (which is OK, as for >>>>>>>>>>> example Samsung does similar thing with FBL/BL1).
When
>>>>>>>>>>> SPL is
"trused"
>>>>>>>>>>> we may use available facilities. >>>>>>>>>> >>>>>>>>>> The issue to me is that sc_seco_authenticate could not >>>>>>>>>> take a FIT image as input. >>>>>>>>> >>>>>>>>> Is the sc_seco_authenticate an API accessible from SPL, >>>>>>>>> U-Boot proper or Linux crypro engine driver? >>>>>>>> >>>>>>>> Yes, it is an API accessible in SPL/U-Boot stage. I do not >>>>>>>> know about Linux crypto driver. >>>>>>> >>>>>>> Maybe it would be worth to check how Linux handle this? >>>>>>> Maybe it would shed some more light on it? >>>>>> >>>>>> I am not familiar with that, so might be stupid question below. >>>>>> Does it really matter? >>>>> >>>>> I would check it just out of curiosity. >>>> >>>> Yes, it matters, because there should be such API. How would >>>> Linux authenticate e.g. userspace binaries if there wasn't >>>> one, surely not by wrapping every single object into the >>>> custom vendor-specific
container ?
>>>> And if there is one, you can use it to authenticate raw >>>> binaries from U-Boot SPL too, e.g. fitImage blobs with an >>>> associated
signature.
>>>> >>> >>> iMX8 AHAB uses RSA key pair for authentication, the on-chip >>> thing we called SRK is a array of public key hash which is >>> dedicated for AHAB. It is not a real key. The real public key is in
container.
>>> AHAB will check the public key with the on-chip SRK before >>> using it to authenticate the image. >>> Seco which contains the crypto engine on imx8 does not allow to >>> use the SRK by user. No such API exported. >>> And the fuse of SRK is locked, can't be read directly. >>> >>> Actually on imx6/imx7/imx8m, the SPL and u-boot are already >>> using ROM HAB to implement the trust chain, like SPL >>> authenticates u-boot, u-boot authenticatse kernel. We just >>> follow this same way on imx8, the difference is >>> imx8 needs container format for signed image. We prefer >>> directly loading container image than fit image. >>> If we pack fit image into container, obviously this will cause >>> one more
copy.
supported?
> > If the functionality of the new image format is a subset of > already present image format, then no, that's called a duplication. > >>> We >>> don't force to use container, just set it as default. Users >>> still can choose fit or raw image. > > They can. however they cannot authenticate the fitImage because > the firmware doesn't provide the necessary API for that ? > >> >> Do you have more comment? > > How could Linux use this iMX8 chain of trust stuff to authenticate e.g. > userspace binaries ? It's the same thing as authenticating blob > in a fitImage. >
A) is in system FS.
to android.
authentication.
format.
code is important.
header);
load.dev = mmc;
load.priv = NULL;
- sector); } else {
Let me summary the previous SoC that NXP is actively maintaining i.MX6/7/7ULP/8M use IVT i.MX8/8X use container
I could not disclose information about future i.MX SoC.
So what is it ?
https://www.nxp.com/docs/en/reference-manual/IMX8DQXPRM.pdf Chapter 5 has information about container set and container.
We not against FIT, we already use FIT on i.MX8M, to let spl to authenticate FIT image using ROM HAB, not using crypto driver.
We would not introduce cypto driver in SPL stage, that means HAB FIT and AHAB container needs to be dropped when SPL loading other images. ROM already provides API for bootloader to authenticate images, introducing complex crypto driver in SPL could enlarge code size and make things complicated.
Thanks, Peng.
On 5/30/19 9:06 AM, Ye Li wrote: > On 2019/5/27 19:31, Marek Vasut wrote: >> Caution: EXT Email >> >> On 5/27/19 11:49 AM, Peng Fan wrote: >>> Hi Marek, Lukasz, >>> >>>> Subject: Re: [EXT] Re: [U-Boot] [PATCH 4/6] spl: mmc: support >>>> loading i.MX container format file >>>> >>>> Hi Marek, >>>> >>>> On 2019/5/22 19:41, Marek Vasut wrote: >>>>> Caution: EXT Email >>>>> >>>>> On 5/22/19 9:34 AM, Lukasz Majewski wrote: >>>>> [...] >>>>>>>>>>>> By using above approach we do have the NXP's
"container"
>>>>>>>>>>>> format only seen in the SPL (which is OK, as for >>>>>>>>>>>> example Samsung does similar thing with FBL/BL1).
When
>>>>>>>>>>>> SPL is "trused" >>>>>>>>>>>> we may use available facilities. >>>>>>>>>>> >>>>>>>>>>> The issue to me is that sc_seco_authenticate could not >>>>>>>>>>> take a FIT image as input. >>>>>>>>>> >>>>>>>>>> Is the sc_seco_authenticate an API accessible from SPL, >>>>>>>>>> U-Boot proper or Linux crypro engine driver? >>>>>>>>> >>>>>>>>> Yes, it is an API accessible in SPL/U-Boot stage. I do not >>>>>>>>> know about Linux crypto driver. >>>>>>>> >>>>>>>> Maybe it would be worth to check how Linux handle this? >>>>>>>> Maybe it would shed some more light on it? >>>>>>> >>>>>>> I am not familiar with that, so might be stupid question below. >>>>>>> Does it really matter? >>>>>> >>>>>> I would check it just out of curiosity. >>>>> >>>>> Yes, it matters, because there should be such API. How would >>>>> Linux authenticate e.g. userspace binaries if there wasn't >>>>> one, surely not by wrapping every single object into the >>>>> custom vendor-specific container ? >>>>> And if there is one, you can use it to authenticate raw >>>>> binaries from U-Boot SPL too, e.g. fitImage blobs with an >>>>> associated
signature.
>>>>> >>>> >>>> iMX8 AHAB uses RSA key pair for authentication, the on-chip >>>> thing we called SRK is a array of public key hash which is >>>> dedicated for AHAB. It is not a real key. The real public key is in
container.
>>>> AHAB will check the public key with the on-chip SRK before >>>> using it to authenticate the image. >>>> Seco which contains the crypto engine on imx8 does not allow to >>>> use the SRK by user. No such API exported. >>>> And the fuse of SRK is locked, can't be read directly. >>>> >>>> Actually on imx6/imx7/imx8m, the SPL and u-boot are already >>>> using ROM HAB to implement the trust chain, like SPL >>>> authenticates u-boot, u-boot authenticatse kernel. We just >>>> follow this same way on imx8, the difference is >>>> imx8 needs container format for signed image. We prefer >>>> directly loading container image than fit image. >>>> If we pack fit image into container, obviously this will cause >>>> one more copy. >>>> As a boot loader, isn't it better to have more image format
supported?
>> >> If the functionality of the new image format is a subset of >> already present image format, then no, that's called a duplication. >> >>>> We >>>> don't force to use container, just set it as default. Users >>>> still can choose fit or raw image. >> >> They can. however they cannot authenticate the fitImage because >> the firmware doesn't provide the necessary API for that ? >> >>> >>> Do you have more comment? >> >> How could Linux use this iMX8 chain of trust stuff to authenticate e.g. >> userspace binaries ? It's the same thing as authenticating blob >> in a fitImage. >> > > Userspace binaries don't use the same key pair. They are signed by > software vendors' key. The private key for chip secure boot is > only hold by device manufacturer. > For example, android needs to authenticate a signed APK. Its > public key (Key A) is in system FS. > iMX trust chain only reaches to kernel + ramdisk. Then the chain > hands over to android. > In ramdisk, android puts another public Key (Key B) used by > dm-verify for system FS. So once system FS is verified ok, then > the public key A becomes trusted. Finally we can use public key A > for APK
authentication.
format.
code is important.
header);
load.dev = mmc;
load.priv = NULL;
- sector); } else {
My assumption is that the future iMX SoC will use yet another different container format.
So what is it ?
Thanks, any specific part of those 80 pages ?
Great
Ah I see, so it's all making the whole crypto simpler by offloading the hard parts into the firmware, which just magically handles everything , without having much extra code in the SPL ?
> Subject: Re: [EXT] Re: [U-Boot] [PATCH 4/6] spl: mmc: support > loading i.MX container format file > > On 5/30/19 9:06 AM, Ye Li wrote: >> On 2019/5/27 19:31, Marek Vasut wrote: >>> Caution: EXT Email >>> >>> On 5/27/19 11:49 AM, Peng Fan wrote: >>>> Hi Marek, Lukasz, >>>> >>>>> Subject: Re: [EXT] Re: [U-Boot] [PATCH 4/6] spl: mmc: support >>>>> loading i.MX container format file >>>>> >>>>> Hi Marek, >>>>> >>>>> On 2019/5/22 19:41, Marek Vasut wrote: >>>>>> Caution: EXT Email >>>>>> >>>>>> On 5/22/19 9:34 AM, Lukasz Majewski wrote: >>>>>> [...] >>>>>>>>>>>>> By using above approach we do have the NXP's
"container"
>>>>>>>>>>>>> format only seen in the SPL (which is OK, as for >>>>>>>>>>>>> example Samsung does similar thing with FBL/BL1).
When
>>>>>>>>>>>>> SPL is > "trused" >>>>>>>>>>>>> we may use available facilities. >>>>>>>>>>>> >>>>>>>>>>>> The issue to me is that sc_seco_authenticate could not >>>>>>>>>>>> take a FIT image as input. >>>>>>>>>>> >>>>>>>>>>> Is the sc_seco_authenticate an API accessible from SPL, >>>>>>>>>>> U-Boot proper or Linux crypro engine driver? >>>>>>>>>> >>>>>>>>>> Yes, it is an API accessible in SPL/U-Boot stage. I do >>>>>>>>>> not know about Linux crypto driver. >>>>>>>>> >>>>>>>>> Maybe it would be worth to check how Linux handle this? >>>>>>>>> Maybe it would shed some more light on it? >>>>>>>> >>>>>>>> I am not familiar with that, so might be stupid question
below.
>>>>>>>> Does it really matter? >>>>>>> >>>>>>> I would check it just out of curiosity. >>>>>> >>>>>> Yes, it matters, because there should be such API. How would >>>>>> Linux authenticate e.g. userspace binaries if there wasn't >>>>>> one, surely not by wrapping every single object into the >>>>>> custom vendor-specific > container ? >>>>>> And if there is one, you can use it to authenticate raw >>>>>> binaries from U-Boot SPL too, e.g. fitImage blobs with an >>>>>> associated
signature.
>>>>>> >>>>> >>>>> iMX8 AHAB uses RSA key pair for authentication, the on-chip >>>>> thing we called SRK is a array of public key hash which is >>>>> dedicated for AHAB. It is not a real key. The real public key >>>>> is in
container.
>>>>> AHAB will check the public key with the on-chip SRK before >>>>> using it to authenticate the image. >>>>> Seco which contains the crypto engine on imx8 does not allow >>>>> to use the SRK by user. No such API exported. >>>>> And the fuse of SRK is locked, can't be read directly. >>>>> >>>>> Actually on imx6/imx7/imx8m, the SPL and u-boot are already >>>>> using ROM HAB to implement the trust chain, like SPL >>>>> authenticates u-boot, u-boot authenticatse kernel. We just >>>>> follow this same way on imx8, the difference is >>>>> imx8 needs container format for signed image. We prefer >>>>> directly loading container image than fit image. >>>>> If we pack fit image into container, obviously this will >>>>> cause one more > copy. >>>>> As a boot loader, isn't it better to have more image format
supported?
>>> >>> If the functionality of the new image format is a subset of >>> already present image format, then no, that's called a duplication. >>> >>>>> We >>>>> don't force to use container, just set it as default. Users >>>>> still can choose fit or raw image. >>> >>> They can. however they cannot authenticate the fitImage because >>> the firmware doesn't provide the necessary API for that ? >>> >>>> >>>> Do you have more comment? >>> >>> How could Linux use this iMX8 chain of trust stuff to authenticate
e.g.
>>> userspace binaries ? It's the same thing as authenticating blob >>> in a fitImage. >>> >> >> Userspace binaries don't use the same key pair. They are signed >> by software vendors' key. The private key for chip secure boot >> is only hold by > device manufacturer. >> For example, android needs to authenticate a signed APK. Its >> public key (Key > A) is in system FS. >> iMX trust chain only reaches to kernel + ramdisk. Then the chain >> hands over > to android. >> In ramdisk, android puts another public Key (Key B) used by >> dm-verify for system FS. So once system FS is verified ok, then >> the public key A becomes trusted. Finally we can use public key >> A for APK
authentication.
fitImage ?
format.
code is important.
header);
load.dev = mmc;
load.priv = NULL;
- sector); } else {
So what is it ?
https://eur01.safelinks.protection.outlook.com/?url=https%3A%2F%2Fwww.
nxp.com%2Fdocs%2Fen%2Freference-manual%2FIMX8DQXPRM.pdf&da ta=02%7C
01%7Cpeng.fan%40nxp.com%7C72216052f4234a93ad1f08d6e95ed782%7C6 86ea1d3b
c2b4c6fa92cd99c5c301635%7C0%7C1%7C636952990895125305&sdat a=KO%2B0e
E3v%2FkHuJ%2BhR7mBgc4NWXxbMUupfubXXu%2BueIWo%3D&reserv ed=0
Figure 5-24. Container Format has a picture about a single container. i.MX8 container also support container sets, support encrypt blob, certificates, SRK management. Support signature to the whole container, no need single image inside container.
Great
Yes. Use what ROM provides will make things easier for U-Boot.
Thanks, Peng.
On 6/5/19 5:03 AM, Peng Fan wrote: [...]
So what is it ?
Isn't that all supported in fitImage too ?
Great
Is it possible to perform a security audit on the ROM as easily as on U-Boot ? I mean, U-Boot is free software, the source is available, so security researchers can easily scrutinize it. Is the ROM ?
So what is it ?
This is neither the first nor last time functionality has been essentially duplicated, sadly, for reasons.
Great
So, here's my two cents (and it may or may not seem contradictory with my opinions in the secure boot thread going on currently on the Linaro Boot Architecture list). Yes, it would and IMHO is better when we use free and open software to solve our problems (and an aside to the RISC-V folks as this is yet another area they can make the world a better place in). But I am a believe in dealing with the world as it stands at times too. The question isn't "can we get NXP to re-spin i.MX8 to use the FIT image format?" as that's obviously going to be "No.". The question is, "can we support this format in a clean manner?" and the answer is obviously "Yes.". So please lets keep that in mind with reviewing the code as at the end of the day it is more beneficial for this to be supported in mainline U-Boot than only supported in the vendor tree. Thanks!
> It is not duplication of FIT. Container support the similar function > of FIT image, but it is not only that.
So what is it ?
Great
I agree with this. I would still like to have an open alternative available though.
> It is not duplication of FIT. Container support the similar > function of FIT image, but it is not only that.
So what is it ?
ta=02%7C
86ea1d3b
a=KO%2B0e
ed=0
I'll share the fit things to our ROM stakeholders, but they take decision on new SoC design.
fitImage?
Great
images.
Thanks. So I think you agree the current approach. Could I get any A-b or R-b tags from the list?
Thanks, Peng.
Thanks!
-- Tom
>> It is not duplication of FIT. Container support the similar >> function of FIT image, but it is not only that. > > So what is it ?
ta=02%7C
86ea1d3b
a=KO%2B0e
ed=0
> I don't think I get it. Why would I, as an iMX8 user, want to > pick custom new vendor-specific format over years-proven > generic
fitImage?
Great
images.
Just to add my 2 cents...
Please if possible provide a good (and as much verbose as possible) entry to ./doc/README.imx_image (or something) regarding the i.MX8 format.
Thanks in advance,
Thanks, Peng.
Thanks!
-- Tom
Lukasz Majewski
>>> It is not duplication of FIT. Container support the similar >>> function of FIT image, but it is not only that. >> >> So what is it ? > >
ta=02%7C >
86ea1d3b >
a=KO%2B0e >
ed=0 > Chapter 5 has information about container set and container.
>> I don't think I get it. Why would I, as an iMX8 user, want to >> pick custom new vendor-specific format over years-proven >> generic
fitImage?
> > We not against FIT, we already use FIT on i.MX8M, to let spl > to authenticate FIT image using ROM HAB, not using crypto > driver.
Great
>> What is the selling point here ? > > We would not introduce cypto driver in SPL stage, that means > HAB FIT and AHAB container needs to be dropped when SPL > loading other
images.
> ROM already provides API for bootloader to authenticate > images, introducing complex crypto driver in SPL could enlarge > code size and make things complicated.
ok. I'll post out a separate patch for that.
Regards, Peng.
Thanks in advance,
Thanks, Peng.
Thanks!
-- Tom
Lukasz Majewski
ta=02%7C
86ea1d3b
a=KO%2B0e
ed=0
> I don't think I get it. Why would I, as an iMX8 user, want to > pick custom new vendor-specific format over years-proven generic
fitImage?
Great
images.
I would still like an answer to my question about the security auditing above.
ta=02%7C >
86ea1d3b >
a=KO%2B0e >
>> I don't think I get it. Why would I, as an iMX8 user, want to >> pick custom new vendor-specific format over years-proven generic
fitImage?
> > We not against FIT, we already use FIT on i.MX8M, to let spl to > authenticate FIT image using ROM HAB, not using crypto driver.
Great
>> What is the selling point here ? > > We would not introduce cypto driver in SPL stage, that means HAB > FIT and AHAB container needs to be dropped when SPL loading other
images.
> ROM already provides API for bootloader to authenticate images, > introducing complex crypto driver in SPL could enlarge code size > and make things complicated.
Sorry. Missed your thread. I not work on ROM stuff, but I think answer is no to public.
Thanks, Peng.
On 6/6/19 9:54 AM, Peng Fan wrote:
>> We would not introduce cypto driver in SPL stage, that means HAB >> FIT and AHAB container needs to be dropped when SPL loading other
images.
>> ROM already provides API for bootloader to authenticate images, >> introducing complex crypto driver in SPL could enlarge code size >> and make things complicated. > > Ah I see, so it's all making the whole crypto simpler by > offloading the hard parts into the firmware, which just magically > handles everything , without having much extra code in the SPL ?
I see.
Simon,
Subject: RE: [PATCH 4/6] spl: mmc: support loading i.MX container format file
Hi Simon,
Hi Peng,
Why not FIT?
https://www.nxp.com/docs/en/reference-manual/IMX8DQXPRM.pdf Chapter 5.9.4 High Level Container Format
Thanks, Peng.
Thanks, Peng.
To support SPL loading container file, add a new Makefile target, and introduce a new Kconfig file to source the cfg file which will be parsed by mkimage.
Signed-off-by: Peng Fan peng.fan@nxp.com --- Makefile | 8 ++++++++ arch/arm/mach-imx/Makefile | 14 ++++++++++++++ arch/arm/mach-imx/imx8/Kconfig | 7 +++++++ 3 files changed, 29 insertions(+)
diff --git a/Makefile b/Makefile index d6a6ef19ab..2912cebaf6 100644 --- a/Makefile +++ b/Makefile @@ -1300,9 +1300,17 @@ SPL: spl/u-boot-spl.bin FORCE $(Q)$(MAKE) $(build)=arch/arm/mach-imx $@
ifeq ($(CONFIG_ARCH_IMX8M)$(CONFIG_ARCH_IMX8), y) +ifeq ($(CONFIG_SPL_LOAD_IMX_CONTAINER), y) +u-boot.cnt: u-boot.bin FORCE + $(Q)$(MAKE) $(build)=arch/arm/mach-imx $@ + +flash.bin: spl/u-boot-spl.bin u-boot.cnt FORCE + $(Q)$(MAKE) $(build)=arch/arm/mach-imx $@ +else flash.bin: spl/u-boot-spl.bin u-boot.itb FORCE $(Q)$(MAKE) $(build)=arch/arm/mach-imx $@ endif +endif
u-boot-with-spl.imx u-boot-with-nand-spl.imx: SPL u-boot.bin FORCE $(Q)$(MAKE) $(build)=arch/arm/mach-imx $@ diff --git a/arch/arm/mach-imx/Makefile b/arch/arm/mach-imx/Makefile index 0562640599..494eee8e5a 100644 --- a/arch/arm/mach-imx/Makefile +++ b/arch/arm/mach-imx/Makefile @@ -104,6 +104,11 @@ IMX_CONFIG = $(CONFIG_IMX_CONFIG:"%"=%) $(Q)mkdir -p $(dir $@) $(call if_changed_dep,cpp_cfg)
+IMX_CONTAINER_CFG = $(CONFIG_IMX_CONTAINER_CFG:"%"=%) +container.cfg: $(IMX_CONTAINER_CFG) FORCE + $(Q)mkdir -p $(dir $@) + $(call if_changed_dep,cpp_cfg) + DEPFILE_EXISTS := 0 ifeq ($(CONFIG_ARCH_IMX8), y) CNTR_DEPFILES := $(srctree)/tools/imx_cntr_image.sh @@ -161,7 +166,16 @@ SPL: spl/u-boot-spl.bin spl/u-boot-spl.cfgout FORCE MKIMAGEFLAGS_flash.bin = -n spl/u-boot-spl.cfgout -T $(IMAGE_TYPE) -e 0x100000 flash.bin: MKIMAGEOUTPUT = flash.log
+MKIMAGEFLAGS_u-boot.cnt = -n container.cfg -T $(IMAGE_TYPE) -e 0x100000 +u-boot.cnt: MKIMAGEOUTPUT = u-boot.cnt.log + +ifeq ($(CONFIG_SPL_LOAD_IMX_CONTAINER), y) +u-boot.cnt: u-boot.bin container.cfg FORCE + $(call if_changed,mkimage) +flash.bin: spl/u-boot-spl.bin u-boot.cnt FORCE +else flash.bin: spl/u-boot-spl.bin u-boot.itb FORCE +endif $(eval SPL_DEPFILE_EXISTS := $(shell $(CPP) $(cpp_flags) -x c -o spl/u-boot-spl.cfgout $(srctree)/$(IMX_CONFIG); if [ -f spl/u-boot-spl.cfgout ]; then $(CNTR_DEPFILES) spl/u-boot-spl.cfgout; echo $$?; fi)) ifeq ($(SPL_DEPFILE_EXISTS),0) $(call if_changed,mkimage) diff --git a/arch/arm/mach-imx/imx8/Kconfig b/arch/arm/mach-imx/imx8/Kconfig index 8e6b79eb77..8128ec16b4 100644 --- a/arch/arm/mach-imx/imx8/Kconfig +++ b/arch/arm/mach-imx/imx8/Kconfig @@ -29,6 +29,13 @@ config SPL_LOAD_IMX_CONTAINER help This is to let SPL could load i.MX8 Container image
+config IMX_CONTAINER_CFG + string "i.MX Container config file" + depends on SPL + help + This is to specific the cfg file for generating container + image which will be loaded by SPL. + choice prompt "i.MX8 board select" optional
Because FIT could not be used for AHAB secure boot on i.MX8, so switch to use container image that could let SPL verify ATF and U-Boot with AHAB.
Note: The AHAB related code has not been added.
Signed-off-by: Peng Fan peng.fan@nxp.com --- board/freescale/imx8qxp_mek/README | 4 +--- board/freescale/imx8qxp_mek/uboot-container.cfg | 13 +++++++++++++ configs/imx8qxp_mek_defconfig | 5 ++--- 3 files changed, 16 insertions(+), 6 deletions(-) create mode 100644 board/freescale/imx8qxp_mek/uboot-container.cfg
diff --git a/board/freescale/imx8qxp_mek/README b/board/freescale/imx8qxp_mek/README index f32290e3a2..6dc151b166 100644 --- a/board/freescale/imx8qxp_mek/README +++ b/board/freescale/imx8qxp_mek/README @@ -39,11 +39,9 @@ $ cp imx-sc-firmware-0.7/mx8qx-mek-scfw-tcm.bin .
Build U-Boot ============ -$ export ATF_LOAD_ADDR=0x80000000 -$ export BL33_LOAD_ADDR=0x80020000 $ make imx8qxp_mek_defconfig $ make flash.bin -$ dd if=u-boot.itb of=flash.bin bs=512 seek=528 +$ dd if=u-boot.cnt of=flash.bin bs=512 seek=528
Flash the binary into the SD card ================================= diff --git a/board/freescale/imx8qxp_mek/uboot-container.cfg b/board/freescale/imx8qxp_mek/uboot-container.cfg new file mode 100644 index 0000000000..8165811818 --- /dev/null +++ b/board/freescale/imx8qxp_mek/uboot-container.cfg @@ -0,0 +1,13 @@ +/* SPDX-License-Identifier: GPL-2.0+ */ +/* + * Copyright 2019 NXP + */ + +#define __ASSEMBLY__ + +/* This file is to create a container image could be loaded by SPL */ +BOOT_FROM SD 0x400 +SOC_TYPE IMX8QX +CONTAINER +IMAGE A35 bl31.bin 0x80000000 +IMAGE A35 u-boot.bin CONFIG_SYS_TEXT_BASE diff --git a/configs/imx8qxp_mek_defconfig b/configs/imx8qxp_mek_defconfig index 6101f62087..8fafb3cf1a 100644 --- a/configs/imx8qxp_mek_defconfig +++ b/configs/imx8qxp_mek_defconfig @@ -5,15 +5,14 @@ CONFIG_SPL_GPIO_SUPPORT=y CONFIG_SPL_LIBCOMMON_SUPPORT=y CONFIG_SPL_LIBGENERIC_SUPPORT=y CONFIG_SYS_MALLOC_F_LEN=0x4000 +CONFIG_SPL_LOAD_IMX_CONTAINER=y +CONFIG_IMX_CONTAINER_CFG="board/freescale/imx8qxp_mek/uboot-container.cfg" CONFIG_TARGET_IMX8QXP_MEK=y CONFIG_SPL_MMC_SUPPORT=y CONFIG_SPL_SERIAL_SUPPORT=y CONFIG_SPL_DRIVERS_MISC_SUPPORT=y CONFIG_NR_DRAM_BANKS=3 CONFIG_SPL=y -CONFIG_FIT=y -CONFIG_SPL_LOAD_FIT=y -CONFIG_SPL_FIT_GENERATOR="arch/arm/mach-imx/mkimage_fit_atf.sh" CONFIG_SYS_EXTRA_OPTIONS="IMX_CONFIG=board/freescale/imx8qxp_mek/imximage.cfg" CONFIG_BOOTDELAY=3 CONFIG_LOG=y
participants (7)
Lukasz Majewski
Peng Fan
Ye Li
