[U-Boot] AT91SAM9260 and Micrel KSZ8041
Hello,
I am working with a custom board based on the AT91SAM9260 with a Micrel KSZ8041 physical layer. The ethernet appears to work fine in u-boot, but neither of the lights on the jack are working, however I can tftp files through the ethernet port. My bigger problem is that in Linux I cannot connect to my network, all of the RX packets show are listed as errors. I am trying to rule-out a hardware issue so I wanted to check to see if anyone is working with the Micrel KSZ8041, and whether the lights should be working, and if they had gotten it working under Linux. Also, if anyone knows of a difference between the u-boot ethernet and linux kernel ethernet that may be causing the problem I would appreciate any insight. I have tried the 2.6.24, 2.6.25, and 2.6.27 kernels.
Thanks, Kevin
............ I wanted to check to see if anyone is working with the Micrel KSZ8041, and whether the lights should be working, and if they had gotten it working under Linux.
Yes, we're currently and succesfully using KSZ8041 together with AT91SAM9260. We have tested it with both u-boot and linux (we're using 2.6.21 kernel) and without big patches.
I suggest you to double check your hardware platform (since the KSZ8041 comes in QFN package with termal pad on bottom side). You probably have some unsoldered pin.
Regards
Gianfranco
Ing.G.Morandi (Portatile)
Kevin Greer
