[U-Boot] [PATCH] ARM: AM43xx: Fix mmcboot command in EXTRA_ENV_SETTINGS
loadbootenv expects devtype variable to be set. This is missing in mmcboot command. With this the following error comes: U-Boot# run mmcboot mmc0 is current device SD/MMC found on device 0 ** Bad device usb 0 ** ** Bad device usb 0 ** Fixing this by setting devtype as mmc.
Reported-by: Tony Lindgren tony@atomide.com Signed-off-by: Lokesh Vutla lokeshvutla@ti.com --- include/configs/am43xx_evm.h | 1 + 1 file changed, 1 insertion(+)
diff --git a/include/configs/am43xx_evm.h b/include/configs/am43xx_evm.h index d5e6c4b..b2028ec 100644 --- a/include/configs/am43xx_evm.h +++ b/include/configs/am43xx_evm.h @@ -145,6 +145,7 @@ "loadfdt=load ${devtype} ${bootpart} ${fdtaddr} ${bootdir}/${fdtfile}\0" \ "mmcboot=mmc dev ${mmcdev}; " \ "setenv devnum ${mmcdev}; " \ + "setenv devtype mmc; " \ "if mmc rescan; then " \ "echo SD/MMC found on device ${devnum};" \ "if run loadbootenv; then " \
Applied to u-boot-ti/master, thanks!
Lokesh Vutla
