[U-Boot] [PATCH] armv8: ls1012afrwy: update of env board variables
ls1012afrwy and ls1012afrdm both boards are variant of ls1012a based SoC, by default board and board_name uboot env variables are set as ls1012afrdm. whenever board is detected as ls1012afrwy, uboot env variables are updated to ls1012afrwy if it set as other than ls1012afrwy
Signed-off-by: Pramod Kumar pramod.kumar_1@nxp.com --- Changes in v2: - fix subject and commit message
board/freescale/ls1012afrdm/ls1012afrdm.c | 9 +++++++++ 1 file changed, 9 insertions(+)
diff --git a/board/freescale/ls1012afrdm/ls1012afrdm.c b/board/freescale/ls1012afrdm/ls1012afrdm.c index 5db1027717..d149d489d5 100644 --- a/board/freescale/ls1012afrdm/ls1012afrdm.c +++ b/board/freescale/ls1012afrdm/ls1012afrdm.c @@ -42,6 +42,7 @@ int checkboard(void) puts("Board: LS1012AFRDM "); #else int rev; + const char *b_name, *board;
rev = get_board_version();
@@ -60,6 +61,14 @@ int checkboard(void) puts(": unknown"); break; } + + board = env_get("board"); + if (strncmp(board, "ls1012afrwy", strlen("ls1012afrwy")) != 0) + env_set("board", "ls1012afrwy"); + + b_name = env_get("board_name"); + if (strncmp(b_name, "ls1012afrwy", strlen("ls1012afrwy")) != 0) + env_set("board_name", "ls1012afrwy"); #endif
Changes in v2:
- board = env_get("board");
- if (strncmp(board, "ls1012afrwy", strlen("ls1012afrwy")) != 0)
- b_name = env_get("board_name");
- if (strncmp(b_name, "ls1012afrwy", strlen("ls1012afrwy")) != 0)
#endif
I don't see how you detect the board. You only check if the variables were set. By the way, where do you use "board_name"?
York
Pramod Kumar
York Sun
