[U-Boot] [PATCH] mvgbe: fix network device indices
Don't assume that the MAC address of egiga0 rsp. egiga1 is ethaddr rsp. eth1addr. If there is only a egiga1 device, u-boot will enumerate it as device 0 and therefore the MAC address is set with the environmen varibale ethaddr.
Signed-off-by: Michael Walle michael@walle.cc --- drivers/net/mvgbe.c | 13 +++++++------ include/net.h | 12 ++++++++++++ net/eth.c | 8 ++++++++ 3 files changed, 27 insertions(+), 6 deletions(-)
diff --git a/drivers/net/mvgbe.c b/drivers/net/mvgbe.c index c701f43..738e8d3 100644 --- a/drivers/net/mvgbe.c +++ b/drivers/net/mvgbe.c @@ -645,7 +645,7 @@ int mvgbe_initialize(bd_t *bis) struct mvgbe_device *dmvgbe; struct eth_device *dev; int devnum; - char *s; + int eth_idx = 0; u8 used_ports[MAX_MVGBE_DEVS] = CONFIG_MVGBE_PORTS;
for (devnum = 0; devnum < MAX_MVGBE_DEVS; devnum++) { @@ -700,16 +700,13 @@ error1: /* must be less than NAMESIZE (16) */ sprintf(dev->name, "egiga%d", devnum);
- /* Extract the MAC address from the environment */ switch (devnum) { case 0: dmvgbe->regs = (void *)MVGBE0_BASE; - s = "ethaddr"; break; #if defined(MVGBE1_BASE) case 1: dmvgbe->regs = (void *)MVGBE1_BASE; - s = "eth1addr"; break; #endif default: /* this should never happen */ @@ -718,7 +715,9 @@ error1: return -1; }
- while (!eth_getenv_enetaddr(s, dev->enetaddr)) { + /* Extract the MAC address from the environment */ + while (!eth_getenv_enetaddr_by_index("eth", eth_idx, + dev->enetaddr)) { /* Generate Private MAC addr if not set */ dev->enetaddr[0] = 0x02; dev->enetaddr[1] = 0x50; @@ -734,7 +733,7 @@ error1: dev->enetaddr[4] = get_random_hex(); dev->enetaddr[5] = get_random_hex(); #endif - eth_setenv_enetaddr(s, dev->enetaddr); + eth_setenv_enetaddr_by_index("eth", eth_idx, dev->enetaddr); }
dev->init = (void *)mvgbe_init; @@ -745,6 +744,8 @@ error1:
eth_register(dev);
+ eth_idx++; + #if defined(CONFIG_MII) || defined(CONFIG_CMD_MII) miiphy_register(dev->name, smi_reg_read, smi_reg_write); /* Set phy address of the port */ diff --git a/include/net.h b/include/net.h index d5d37b6..d378cd2 100644 --- a/include/net.h +++ b/include/net.h @@ -103,6 +103,18 @@ extern int eth_setenv_enetaddr(char *name, const uchar *enetaddr); extern int eth_getenv_enetaddr_by_index(const char *base_name, int index, uchar *enetaddr);
+/* + * Set the hardware address for an ethernet interface. + * Args: + * base_name - base name for device (normally "eth") + * index - device index number (0 for first) + * enetaddr - returns 6 byte hardware address + * Returns: + * Return true if the environment varibable was set successfully. + */ +extern int eth_setenv_enetaddr_by_index(const char *base_name, int index, + const uchar *enetaddr); + extern int usb_eth_initialize(bd_t *bi); extern int eth_init(bd_t *bis); /* Initialize the device */ extern int eth_send(volatile void *packet, int length); /* Send a packet */ diff --git a/net/eth.c b/net/eth.c index 4280d6d..a8f68fc 100644 --- a/net/eth.c +++ b/net/eth.c @@ -62,6 +62,14 @@ int eth_getenv_enetaddr_by_index(const char *base_name, int index, return eth_getenv_enetaddr(enetvar, enetaddr); }
+int eth_setenv_enetaddr_by_index(const char *base_name, int index, + const uchar *enetaddr) +{ + char enetvar[32]; + sprintf(enetvar, index ? "%s%daddr" : "%saddr", base_name, index); + return eth_setenv_enetaddr(enetvar, enetaddr); +} + static int eth_mac_skip(int index) { char enetvar[15];
-----Original Message----- From: u-boot-bounces@lists.denx.de [mailto:u-boot-bounces@lists.denx.de] On Behalf Of Michael Walle Sent: Friday, October 07, 2011 3:53 AM To: u-boot@lists.denx.de Subject: [U-Boot] [PATCH] mvgbe: fix network device indices
So if there is only one eth port available, the associated environment variable should be ethaddr, this is understood. Is there any issue with this?
Then I have anther question in my mind- Why not we name eth0addr for environment variable associated with egiga0 to maintain consistency with naming and used ports?
Regards.. Prafulla . .
Am Fr, 7.10.2011, 10:26 schrieb Prafulla Wadaskar:
Are you asking me or the list? (if the question was for me, remember that there might be _only_ the egiga1 device.)
If i get it right, there is another problem with setting the environment variable from the driver itself.
eth_register() and eth_init() using an own index to enumerate the devices. Eg. if an e1000 is registered before the the associated environment variable would be eth1addr for the first mvgbe device and eth2addr for the second.
This patch only fixes the case where no other network device is registered. (The current behaviour just works with egiga0 being the only or the first and egiga1 being the second device).
Am Freitag 07 Oktober 2011, 12:48:40 schrieb Michael Walle:
ping :)
- char enetvar[32];
- sprintf(enetvar, index ? "%s%daddr" : "%saddr", base_name, index);
- return eth_setenv_enetaddr(enetvar, enetaddr);
please unify the duplicate logic coming from eth_getenv_enetaddr_by_index in a new local static function -mike
Don't assume that the MAC address of egiga0 rsp. egiga1 is ethaddr rsp. eth1addr. If there is only a egiga1 device, u-boot will enumerate it as device 0 and therefore the MAC address is set with the environment varibale ethaddr.
Hi
If I understood it correctly, In current implementation, if only egiga1 device is enabled on the board, then it will assign MAC address associated with environment variable "ethaddr".
This patch will make environment variable "egiga1" available in such case. Right?
If so, then this is not the case with only mvgbe, it is applicable for all network drivers.
I think this is okay, are there any issues following this standard structure at your end?
Regards.. Prafulla . . .
Am Freitag 21 Oktober 2011, 10:09:15 schrieben Sie:
Hi
yes but the current mvgbe driver will check eth1addr and set it to a random value if not set.
mh? This patch will use the same enumeration as the net/eth.c code in eth_initialize(). At least if there is no other ethernet driver than mvgbe. So ethaddr is set to a random value instead of eth1addr, which eth_initialize() then use the set the mac address.
yeah other drivers also set eth(N)addr sometimes, which suffers from the same problem. maybe a driver could provide some callback to initialize a macaddress or eth_register returns the device index which in turn could be used to get the proper ethNaddr environment variable.
-----Original Message----- From: Michael Walle [mailto:michael@walle.cc] Sent: Wednesday, October 26, 2011 2:41 AM To: Prafulla Wadaskar Cc: u-boot@lists.denx.de; Mike Frysinger Subject: Re: [U-Boot] [PATCH] mvgbe: fix network device indices
ethaddr rsp.
enumerate it as
environment
varibale ethaddr.
Hi
on the board,
variable
"ethaddr".
Yes, but this may be avoided by defining CONFIG_SKIP_LOCAL_MAC_RANDOMIZATION as done for edminiv2 board.
in such case.
Right?
applicable for all
network drivers.
I think right place to provide solution for this problem is net/eth.c. The suggested change is logical but doing this will affect all u-boot users. May be some more opinion on this will be helpful.
-- Michael
Am Do, 27.10.2011, 11:12 schrieb Prafulla Wadaskar:
on the board,
variable
"ethaddr".
Ok, but that is not my problem ;) And even if this macro is set, the wrong environment variable will still be set (in this case not a randomized mac address, but :00:00:<devnum> suffix).
in such case.
Right?
applicable for all
network drivers.
ok, so the second option still applies, that is eth_register() returns a device index. the current eth_register always returns zero, in fact all drivers in the uboot source don't check the return code. so here we could return the device index.
@wolfgang: any opinion on that? or any other idea how to pass the ethernet device number to a network driver?
This patchset introduces a new element "index" within the eth_device structure, which is populated by eth_register(). The second patch uses this element to get the right name of the environment variable for the ethernet hardware address.
Instead of counting the device index everytime a functions needs it, store it in the eth_device struct. eth_register() keeps track of the indices and updates the device's index number. This simplifies some functions in net/eth.c.
Additionally, a network driver can now query its index, eg. to get the correct environment ethaddr name.
Signed-off-by: Michael Walle michael@walle.cc Cc: Prafulla Wadaskar prafulla@marvell.com Cc: Mike Frysinger vapier@gentoo.com Cc: Wolfgang Denk wd@denx.de --- include/net.h | 1 + net/eth.c | 41 ++++++++++++----------------------------- 2 files changed, 13 insertions(+), 29 deletions(-)
diff --git a/include/net.h b/include/net.h index b408dea..7f9b1d1 100644 --- a/include/net.h +++ b/include/net.h @@ -89,6 +89,7 @@ struct eth_device { #endif int (*write_hwaddr) (struct eth_device*); struct eth_device *next; + int index; void *priv; };
diff --git a/net/eth.c b/net/eth.c index 4280d6d..b4b9b43 100644 --- a/net/eth.c +++ b/net/eth.c @@ -127,7 +127,6 @@ struct eth_device *eth_get_dev_by_name(const char *devname) struct eth_device *eth_get_dev_by_index(int index) { struct eth_device *dev, *target_dev; - int idx = 0;
if (!eth_devices) return NULL; @@ -135,12 +134,11 @@ struct eth_device *eth_get_dev_by_index(int index) dev = eth_devices; target_dev = NULL; do { - if (idx == index) { + if (dev->index == index) { target_dev = dev; break; } dev = dev->next; - idx++; } while (dev != eth_devices);
return target_dev; @@ -148,24 +146,11 @@ struct eth_device *eth_get_dev_by_index(int index)
int eth_get_dev_index (void) { - struct eth_device *dev; - int num = 0; - - if (!eth_devices) { - return (-1); - } - - for (dev = eth_devices; dev; dev = dev->next) { - if (dev == eth_current) - break; - ++num; - } - - if (dev) { - return (num); + if (!eth_current) { + return -1; }
- return (0); + return eth_current->index; }
static void eth_current_changed(void) @@ -219,6 +204,7 @@ int eth_write_hwaddr(struct eth_device *dev, const char *base_name, int eth_register(struct eth_device *dev) { struct eth_device *d; + static int index = 0;
assert(strlen(dev->name) < NAMESIZE);
@@ -233,14 +219,14 @@ int eth_register(struct eth_device *dev)
dev->state = ETH_STATE_INIT; dev->next = eth_devices; + dev->index = index++;
return 0; }
int eth_initialize(bd_t *bis) { - int eth_number = 0; - + int num_devices = 0; eth_devices = NULL; eth_current = NULL;
@@ -281,7 +267,7 @@ int eth_initialize(bd_t *bis)
show_boot_progress (65); do { - if (eth_number) + if (dev->index) puts (", ");
printf("%s", dev->name); @@ -294,18 +280,18 @@ int eth_initialize(bd_t *bis) if (strchr(dev->name, ' ')) puts("\nWarning: eth device name has a space!\n");
- if (eth_write_hwaddr(dev, "eth", eth_number)) + if (eth_write_hwaddr(dev, "eth", dev->index)) puts("\nWarning: failed to set MAC address\n");
- eth_number++; dev = dev->next; + num_devices++; } while(dev != eth_devices);
eth_current_changed(); putc ('\n'); }
- return eth_number; + return num_devices; }
#ifdef CONFIG_MCAST_TFTP @@ -356,7 +342,6 @@ u32 ether_crc (size_t len, unsigned char const *p)
int eth_init(bd_t *bis) { - int eth_number; struct eth_device *old_current, *dev;
if (!eth_current) { @@ -365,16 +350,14 @@ int eth_init(bd_t *bis) }
/* Sync environment with network devices */ - eth_number = 0; dev = eth_devices; do { uchar env_enetaddr[6];
- if (eth_getenv_enetaddr_by_index("eth", eth_number, + if (eth_getenv_enetaddr_by_index("eth", dev->index, env_enetaddr)) memcpy(dev->enetaddr, env_enetaddr, 6);
- ++eth_number; dev = dev->next; } while (dev != eth_devices);
Am Donnerstag 27 Oktober 2011, 23:31:35 schrieb Michael Walle:
sorry mike, i'll fix this for v2 ;)
Am Do, 27.10.2011, 22:31 schrieb Michael Walle:
Ping, anyone?
- int index; void *priv;
int idx = 0;
if (idx == index) {
} dev = dev->next;if (dev->index == index) { target_dev = dev; break;
idx++;
return target_dev;
- int num = 0;
return (-1);
break;
++num;
- if (dev) {
return (num);
- if (!eth_current) {
}return -1;
- return (0);
- return eth_current->index;
- int num_devices = 0; eth_devices = NULL; eth_current = NULL;
if (eth_number)
if (dev->index) puts (", "); printf("%s", dev->name);
num_devices++;
- return num_devices;
if (!eth_current) {
dev = dev->next; } while (dev != eth_devices);++eth_number;
-- 1.7.2.5
-----Original Message----- From: Michael Walle [mailto:michael@walle.cc] Sent: Thursday, November 03, 2011 4:54 PM To: Michael Walle Cc: u-boot@lists.denx.de; Prafulla Wadaskar; Mike Frysinger; Wolfgang Denk; Michael Walle Subject: Re: [PATCH 1/2] net: introduce per device index
needs it, store
the indices and
functions in
net/eth.c.
to get the
Ping, anyone?
These patches are for u-boot-net.git. Copying Ben on this.
Dear Prafulla Wadaskar,
In message F766E4F80769BD478052FB6533FA745D1A14DD9299@SC-VEXCH4.marvell.com you wrote:
Ben has resigned long ago. We're currently without Net custodian (any volunteers out there??) so I will have to pick that up - when time comes.
The patch was submitted after close of trhe merge window, so it is low priority for now.
Acked-by: Mike Frysinger vapier@gentoo.org -mike
Don't assume that the MAC address of egiga0 rsp. egiga1 is ethaddr rsp. eth1addr. If there is only a egiga1 device, u-boot will enumerate it as device 0. Instead use the correct index number stored within the eth_device structure.
Signed-off-by: Michael Walle michael@walle.cc Cc: Prafulla Wadaskar prafulla@marvell.com --- drivers/net/mvgbe.c | 27 +++++++++++++-------------- include/net.h | 12 ++++++++++++ net/eth.c | 17 ++++++++++++++++- 3 files changed, 41 insertions(+), 15 deletions(-)
diff --git a/drivers/net/mvgbe.c b/drivers/net/mvgbe.c index c701f43..80314ec 100644 --- a/drivers/net/mvgbe.c +++ b/drivers/net/mvgbe.c @@ -645,7 +645,6 @@ int mvgbe_initialize(bd_t *bis) struct mvgbe_device *dmvgbe; struct eth_device *dev; int devnum; - char *s; u8 used_ports[MAX_MVGBE_DEVS] = CONFIG_MVGBE_PORTS;
for (devnum = 0; devnum < MAX_MVGBE_DEVS; devnum++) { @@ -700,16 +699,13 @@ error1: /* must be less than NAMESIZE (16) */ sprintf(dev->name, "egiga%d", devnum);
- /* Extract the MAC address from the environment */ switch (devnum) { case 0: dmvgbe->regs = (void *)MVGBE0_BASE; - s = "ethaddr"; break; #if defined(MVGBE1_BASE) case 1: dmvgbe->regs = (void *)MVGBE1_BASE; - s = "eth1addr"; break; #endif default: /* this should never happen */ @@ -718,7 +714,17 @@ error1: return -1; }
- while (!eth_getenv_enetaddr(s, dev->enetaddr)) { + dev->init = (void *)mvgbe_init; + dev->halt = (void *)mvgbe_halt; + dev->send = (void *)mvgbe_send; + dev->recv = (void *)mvgbe_recv; + dev->write_hwaddr = (void *)mvgbe_write_hwaddr; + + eth_register(dev); + + /* Extract the MAC address from the environment */ + while (!eth_getenv_enetaddr_by_index("eth", dev->index, + dev->enetaddr)) { /* Generate Private MAC addr if not set */ dev->enetaddr[0] = 0x02; dev->enetaddr[1] = 0x50; @@ -734,17 +740,10 @@ error1: dev->enetaddr[4] = get_random_hex(); dev->enetaddr[5] = get_random_hex(); #endif - eth_setenv_enetaddr(s, dev->enetaddr); + eth_setenv_enetaddr_by_index("eth", dev->index, + dev->enetaddr); }
- dev->init = (void *)mvgbe_init; - dev->halt = (void *)mvgbe_halt; - dev->send = (void *)mvgbe_send; - dev->recv = (void *)mvgbe_recv; - dev->write_hwaddr = (void *)mvgbe_write_hwaddr; - - eth_register(dev); - #if defined(CONFIG_MII) || defined(CONFIG_CMD_MII) miiphy_register(dev->name, smi_reg_read, smi_reg_write); /* Set phy address of the port */ diff --git a/include/net.h b/include/net.h index 7f9b1d1..b841f85 100644 --- a/include/net.h +++ b/include/net.h @@ -117,6 +117,18 @@ extern int eth_setenv_enetaddr(char *name, const uchar *enetaddr); extern int eth_getenv_enetaddr_by_index(const char *base_name, int index, uchar *enetaddr);
+/* + * Set the hardware address for an ethernet interface. + * Args: + * base_name - base name for device (normally "eth") + * index - device index number (0 for first) + * enetaddr - returns 6 byte hardware address + * Returns: + * Return true if the environment varibable was set successfully. + */ +extern int eth_setenv_enetaddr_by_index(const char *base_name, int index, + const uchar *enetaddr); + extern int usb_eth_initialize(bd_t *bi); extern int eth_init(bd_t *bis); /* Initialize the device */ extern int eth_send(volatile void *packet, int length); /* Send a packet */ diff --git a/net/eth.c b/net/eth.c index b4b9b43..baa6ded 100644 --- a/net/eth.c +++ b/net/eth.c @@ -54,14 +54,29 @@ int eth_setenv_enetaddr(char *name, const uchar *enetaddr) return setenv(name, buf); }
+static void eth_get_enetaddr_env_name(char *buf, const char *base_name, + int index) +{ + sprintf(buf, index ? "%s%daddr" : "%saddr", base_name, index); + return buf; +} + int eth_getenv_enetaddr_by_index(const char *base_name, int index, uchar *enetaddr) { char enetvar[32]; - sprintf(enetvar, index ? "%s%daddr" : "%saddr", base_name, index); + eth_get_enetaddr_env_name(enetvar, base_name, index); return eth_getenv_enetaddr(enetvar, enetaddr); }
+int eth_setenv_enetaddr_by_index(const char *base_name, int index, + const uchar *enetaddr) +{ + char enetvar[32]; + eth_get_enetaddr_env_name(enetvar, base_name, index); + return eth_setenv_enetaddr(enetvar, enetaddr); +} + static int eth_mac_skip(int index) { char enetvar[15];
this is wrong. net drivers should not be touching the env at all. please fix your driver to not do that first. -mike
Am Donnerstag 03 November 2011, 19:10:57 schrieb Mike Frysinger:
i guess this whole mac randomization/generation code belongs to board specific files.
correct -mike
-----Original Message----- From: Mike Frysinger [mailto:vapier@gentoo.org] Sent: Friday, November 04, 2011 4:42 AM To: Michael Walle Cc: u-boot@lists.denx.de; Prafulla Wadaskar; Wolfgang Denk Subject: Re: [PATCH 2/2] mvgbe: fix network device indices
Frysinger:
index,
at all.
to board
specific files.
correct
We can move mac randomization code to the board specific files, but it will be needed for each board and there will be code duplication.
How about supporting standalone mac randomization feature?
On Friday 04 November 2011 02:29:24 Prafulla Wadaskar wrote:
Mike Frysinger:
while (!eth_getenv_enetaddr_by_index("eth", dev-index,
correct
there's two issues here. (1) no net driver should touch the env. this is why we have the dev->enetaddr field in the first place. (2) drivers should be seeding dev->enetaddr with values from storage directly related to it. so for parts that have dedicated EEPROM interfaces, reading the MAC out of that storage makes sense. if no storage like that exists, then it is up to the board to figure out where to find the address.
that means this could should be moved to the boards file.
i think Wolfgang would be opposed to that. mac randomization should not be the first line of defense. your board is supposed to be managing this sanely. from the mvgbe code, it seems that this is not the case and these boards are a bit insane. -mike
Mike Frysinger:
correct
Granted, MAC randomization as a feature -- i.e., choosing to use a random MAC *instead* of any other way -- would be Bad(tm).
But what about MAC randomization as a function provided by the SoC level to board MAC init code that wants to use it? For instance, a weak MAC setup function provided by the SoC level, and the board level would use it or provide its own.
-mike
Amicalement,
Dear Albert ARIBAUD,
What would be the result? A bord that comes up with a new MAC address each time you reset it?
Hi Wolfgang,
No -- the goal of the randomization code was, is, and will be to allow the board to use the network when no correct MAC address can be found anywhere (env vars, EEPROM, e-fuses, whatever). When a correct address is available, that address will be used. Typically, this happens when the board has not been provisioned yet, at a point where the MAC address it uses is not relevant yet.
Notes:
1. This code would only be available to kirkwood-based boards anyway.
2. Although the code incorrectly describes it as "private", the random address is actually a locally administered address (bit 1 of first octet is set), which eliminates the risk of clashing against any 'normal' (universally administered) address; and its last three octets are randomized in order to limit the risk of clashing against other locally administered addresses if we're unlucky enough to have any on the network segment.
Amicalement,
And if this is the case, then the board will come up with a new MAC address each time you reset it, right?
I've done provisioning stuff a couple of times before, and I'm just doing is again. Random MAC addresses are a broken concept, and anybody who considers using it should reassess his concepts.
Where is the real MAC address coming from, and how does it get assigned to this specific board? And how do you make sure not to make mistakes when all you see is some board with a random MAC address?
[The systems I know usually either have the MAC address pre-programmed in some storage device on the board, or printed on a barcode label, so you can use ca barcode reader in combination with "askenv" and very little U-Boot scripting as part of your production test / initialization procedures.]
- This code would only be available to kirkwood-based boards anyway.
That doe snot make things any better.
- Although the code incorrectly describes it as "private", the random
I consider the whole approach broken and object against it.
-----Original Message----- From: Albert ARIBAUD [mailto:albert.u.boot@aribaud.net] Sent: Saturday, November 05, 2011 3:24 PM To: Mike Frysinger Cc: Prafulla Wadaskar; u-boot@lists.denx.de Subject: Re: [U-Boot] [PATCH 2/2] mvgbe: fix network device indices
Mike Frysinger:
Frysinger:
On Thursday 27 October 2011 17:31:36 Michael Walle wrote: > --- a/drivers/net/mvgbe.c > +++ b/drivers/net/mvgbe.c > > + /* Extract the MAC address from the environment
index,
> + dev->enetaddr)) { > > /* Generate Private MAC addr if not set */ > dev->enetaddr[0] = 0x02; > dev->enetaddr[1] = 0x50;
env
belongs to board
specific files.
correct
files, but it will
env. this is why
drivers should be
out of that
is up to the
should not be
these boards are a
bit insane.
I ack for this method
-----Original Message----- From: Mike Frysinger [mailto:vapier@gentoo.org] Sent: Saturday, November 05, 2011 4:37 AM To: Prafulla Wadaskar Cc: Michael Walle; u-boot@lists.denx.de; Wolfgang Denk Subject: Re: [PATCH 2/2] mvgbe: fix network device indices
Mike Frysinger:
Frysinger:
index,
env
belongs to board
specific files.
correct
files, but it will
Hi Mike
I had posted feedback for your patch first and seen this email latter.
On some boards, using mvbge random mac generation is needed since there is no eeprom to hold this. Further practically it is not possible to hardcode mac address and recompile, nor it is suggested to have any mac/ip/server address definition in board config files.
Random mac address helps to resolve dhcp issues with more similar boards in the same network in such cases and will be applicable for any board.
Your patch is clean to abstract out mac randomization, on the other hand you should not remove the support for other boards which are already using it.
May be some more patches on the top to move support in board/arch specific files are needed. (if framework can not be entertained)
i'm not the one to convince. i think Wolfgang addressed these already and still said no. -mike
participants (5)
Albert ARIBAUD
Michael Walle
Mike Frysinger
Prafulla Wadaskar
