[2021.04 URGENT PATCH] Makefile: Remove idiotic ominous messages
Right before v2021.04-rc5 was dropped, several patches landed that updated the way DM warnings are printed. A side-effect of those changes is that, instead of printing warnings where appropriate, the Makefile prints the script that checks for the conditions:
if [ -n "y" ]; then if [ "y y" != "y y" ]; then echo >&2 "===================== WARNING ======================"; echo >&2 et cetera
Remedy this by appending "@" to the commands.
Fixes: 8cd1874f4c ("Makefile: Use common code for DM_ETH deprecation warning") Fixes: 78b4a564cb ("Makefile: Use common code for WDT deprecation warning") Fixes: ec384f9f12 ("Makefile: Use common code for SPI_FLASH deprecation warning") Fixes: d13aee07fd ("Makefile: Use common code for DM_VIDEO deprecation warning") Fixes: 39e526a8ec ("Makefile: Use common code for PCI deprecation warning") Fixes: 099288bf78 ("Makefile: Use common code for LIBATA deprecation warning") Fixes: a883435298 ("Makefile: Use common code for MVSATA_IDE deprecation warning") Fixes: 9e035b8ee1 ("Makefile: Use common code for USB deprecation warning") Fixes: 77dc55ea39 ("Makefile: Use common code for MMC deprecation warning") Fixes: 06467e4652 ("Makefile: Move non-DM migration messages to the top") Signed-off-by: Alexandru Gagniuc mr.nuke.me@gmail.com --- Makefile | 22 +++++++++++----------- 1 file changed, 11 insertions(+), 11 deletions(-)
diff --git a/Makefile b/Makefile index e60717f7a2..ad48cd116e 100644 --- a/Makefile +++ b/Makefile @@ -1077,25 +1077,25 @@ ifneq ($(CONFIG_DM),y) @echo >&2 "See doc/driver-model/migration.rst for more info." @echo >&2 "====================================================" endif - $(call deprecated,CONFIG_DM_MMC CONFIG_BLK,MMC,v2019.04,$(CONFIG_MMC)) - $(call deprecated,CONFIG_DM_USB CONFIG_OF_CONTROL CONFIG_BLK,\ + @$(call deprecated,CONFIG_DM_MMC CONFIG_BLK,MMC,v2019.04,$(CONFIG_MMC)) + @$(call deprecated,CONFIG_DM_USB CONFIG_OF_CONTROL CONFIG_BLK,\ USB,v2019.07,$(CONFIG_USB)) - $(call deprecated,CONFIG_AHCI,AHCI instead of CONFIG_MVSATA_IDE,v2019.07, \ + @$(call deprecated,CONFIG_AHCI,AHCI instead of CONFIG_MVSATA_IDE,v2019.07, \ $(CONFIG_MVSATA_IDE)) - $(call deprecated,CONFIG_AHCI,AHCI,v2019.07, $(CONFIG_LIBATA)) - $(call deprecated,CONFIG_DM_PCI,PCI,v2019.07,$(CONFIG_PCI)) - $(call deprecated,CONFIG_DM_VIDEO,video,v2019.07,\ + @$(call deprecated,CONFIG_AHCI,AHCI,v2019.07, $(CONFIG_LIBATA)) + @$(call deprecated,CONFIG_DM_PCI,PCI,v2019.07,$(CONFIG_PCI)) + @$(call deprecated,CONFIG_DM_VIDEO,video,v2019.07,\ $(CONFIG_LCD)$(CONFIG_VIDEO)) - $(call deprecated,CONFIG_DM_SPI_FLASH,SPI flash,v2019.07,\ + @$(call deprecated,CONFIG_DM_SPI_FLASH,SPI flash,v2019.07,\ $(CONFIG_SPI_FLASH)) - $(call deprecated,CONFIG_WDT,DM watchdog,v2019.10,\ + @$(call deprecated,CONFIG_WDT,DM watchdog,v2019.10,\ $(CONFIG_WATCHDOG)$(CONFIG_HW_WATCHDOG)) - $(call deprecated,CONFIG_DM_ETH,Ethernet drivers,v2020.07,$(CONFIG_NET)) - $(call deprecated,CONFIG_DM_I2C,I2C drivers,v2022.04,$(CONFIG_I2C)) + @$(call deprecated,CONFIG_DM_ETH,Ethernet drivers,v2020.07,$(CONFIG_NET)) + @$(call deprecated,CONFIG_DM_I2C,I2C drivers,v2022.04,$(CONFIG_I2C)) @# Check that this build does not use CONFIG options that we do not @# know about unless they are in Kconfig. All the existing CONFIG @# options are whitelisted, so new ones should not be added. - $(call cmd,cfgcheck,u-boot.cfg) + @$(call cmd,cfgcheck,u-boot.cfg)
PHONY += dtbs dtbs: dts/dt.dtb
Deferring this in favor of https://patchwork.ozlabs.org/project/uboot/patch/20210331221813.2568659-1-sj...
Alexandru Gagniuc
