[PATCH] net: pfe_eth: fix crash with secure boot on LS1012A
Fix crash with secure boot as follows, Net: SF: Detected s25fs512s with page size 256 Bytes, erase size 256 KiB, total 64 MiB "Synchronous Abort" handler, esr 0x96000210 elr: 000000008206db44 lr : 0000000082004ea0 (reloc) elr: 00000000b7ba6b44 lr : 00000000b7b3dea0 x0 : 00000000b79407e8 x1 : 0000000040640000 x2 : 0000000000000050 x3 : 0000000000000000 x4 : 000000000000000a x5 : 0000000000000050 x6 : 0000000000000366 x7 : 00000000b7942308 x8 : 00000000b76407c0 x9 : 0000000000000008 x10: 0000000000000044 x11: 00000000b7634d1c x12: 000000000000004f x13: 0000000000000044 x14: 00000000b7634d98 x15: 00000000b76407c0 x16: 0000000000000000 x17: 0000000000000000 x18: 00000000b7636dd8 x19: 0000000000000000 x20: 00000000b79407d0 x21: 00000000b79407e8 x22: 0000000040640000 x23: 00000000b7634e58 x24: 0000000000000000 x25: 0000000003800000 x26: 00000000b7bdd000 x27: 0000000000000000 x28: 0000000000000000 x29: 00000000b7634d10
Code: d2800003 eb03005f 54000101 d65f03c0 (f8636826) Resetting CPU ...
Signed-off-by: Biwen Li biwen.li@nxp.com --- board/freescale/ls1012afrdm/Kconfig | 11 +++++ board/freescale/ls1012aqds/Kconfig | 14 +++++-- board/freescale/ls1012ardb/Kconfig | 18 +++++++-- drivers/net/pfe_eth/pfe_firmware.c | 62 +++++++++++++++++++++++++---- 4 files changed, 92 insertions(+), 13 deletions(-)
diff --git a/board/freescale/ls1012afrdm/Kconfig b/board/freescale/ls1012afrdm/Kconfig index 55b414e168..4ac69d7117 100644 --- a/board/freescale/ls1012afrdm/Kconfig +++ b/board/freescale/ls1012afrdm/Kconfig @@ -16,6 +16,10 @@ config SYS_LS_PFE_FW_ADDR hex "Flash address of PFE firmware" default 0x40a00000
+config SYS_LS_PFE_FW_LENGTH + hex "length of PFE firmware" + default 0x40000 + config SYS_LS_PPA_FW_ADDR hex "PPA Firmware Addr" default 0x40400000 @@ -65,6 +69,10 @@ config SYS_LS_PFE_FW_ADDR hex "Flash address of PFE firmware" default 0x40020000
+config SYS_LS_PFE_FW_LENGTH + hex "length of PFE firmware" + default 0x40000 + config SYS_LS_PPA_FW_ADDR hex "PPA Firmware Addr" default 0x40060000 @@ -77,6 +85,9 @@ config SYS_LS_PFE_ESBC_ADDR hex "PFE Firmware HDR Addr" default 0x401f8000
+config SYS_LS_PFE_ESBC_LENGTH + hex "length of PFE Firmware HDR" + default 0xc00 endif
if TARGET_LS1012AFRDM || TARGET_LS1012AFRWY diff --git a/board/freescale/ls1012aqds/Kconfig b/board/freescale/ls1012aqds/Kconfig index 8844557aae..59b1a87665 100644 --- a/board/freescale/ls1012aqds/Kconfig +++ b/board/freescale/ls1012aqds/Kconfig @@ -20,6 +20,14 @@ if CHAIN_OF_TRUST config SYS_LS_PPA_ESBC_ADDR hex "PPA Firmware HDR Addr" default 0x40680000 + +config SYS_LS_PFE_ESBC_ADDR + hex "PFE Firmware HDR Addr" + default 0x40700000 + +config SYS_LS_PFE_ESBC_LENGTH + hex "length of PFE Firmware HDR" + default 0xc00 endif
if FSL_PFE @@ -39,9 +47,9 @@ config SYS_LS_PFE_FW_ADDR hex "Flash address of PFE firmware" default 0x40a00000
-config SYS_LS_PFE_ESBC_ADDR - hex "PFE Firmware HDR Addr" - default 0x40700000 +config SYS_LS_PFE_FW_LENGTH + hex "length of PFE firmware" + default 0x300000
config DDR_PFE_PHYS_BASEADDR hex "PFE DDR physical base address" diff --git a/board/freescale/ls1012ardb/Kconfig b/board/freescale/ls1012ardb/Kconfig index 5a2fa91f6b..c4acea3ae2 100644 --- a/board/freescale/ls1012ardb/Kconfig +++ b/board/freescale/ls1012ardb/Kconfig @@ -20,6 +20,14 @@ if CHAIN_OF_TRUST config SYS_LS_PPA_ESBC_ADDR hex "PPA Firmware HDR Addr" default 0x40680000 + +config SYS_LS_PFE_ESBC_ADDR + hex "PFE Firmware HDR Addr" + default 0x40640000 + +config SYS_LS_PFE_ESBC_LENGTH + hex "length of PFE Firmware HDR" + default 0xc00 endif
if FSL_PFE @@ -33,9 +41,9 @@ config SYS_LS_PFE_FW_ADDR hex "Flash address of PFE firmware" default 0x40a00000
-config SYS_LS_PFE_ESBC_ADDR - hex "PFE Firmware HDR Addr" - default 0x40640000 +config SYS_LS_PFE_FW_LENGTH + hex "length of PFE firmware" + default 0x300000
config DDR_PFE_PHYS_BASEADDR hex "PFE DDR physical base address" @@ -89,6 +97,10 @@ config SYS_LS_PFE_FW_ADDR hex "Flash address of PFE firmware" default 0x40a00000
+config SYS_LS_PFE_FW_LENGTH + hex "length of PFE firmware" + default 0x300000 + config DDR_PFE_PHYS_BASEADDR hex "PFE DDR physical base address" default 0x03800000 diff --git a/drivers/net/pfe_eth/pfe_firmware.c b/drivers/net/pfe_eth/pfe_firmware.c index d414c750d4..d6718822b2 100644 --- a/drivers/net/pfe_eth/pfe_firmware.c +++ b/drivers/net/pfe_eth/pfe_firmware.c @@ -24,6 +24,9 @@ #define PFE_FIRMWARE_FIT_CNF_NAME "config@1"
static const void *pfe_fit_addr; +#ifdef CONFIG_CHAIN_OF_TRUST +static const void *pfe_esbc_hdr_addr; +#endif
/* * PFE elf firmware loader. @@ -166,10 +169,10 @@ static int pfe_fit_check(void)
int pfe_spi_flash_init(void) { - struct spi_flash *pfe_flash; + struct spi_flash *pfe_flash = NULL; struct udevice *new; int ret = 0; - void *addr = malloc(CONFIG_SYS_QE_FMAN_FW_LENGTH); + void *addr = malloc(CONFIG_SYS_LS_PFE_FW_LENGTH);
if (!addr) return -ENOMEM; @@ -179,24 +182,69 @@ int pfe_spi_flash_init(void) CONFIG_ENV_SPI_MAX_HZ, CONFIG_ENV_SPI_MODE, &new); + if (ret) { + printf("SF: failed to probe spi\n"); + goto exit1; + } +
pfe_flash = dev_get_uclass_priv(new); if (!pfe_flash) { printf("SF: probe for pfe failed\n"); - free(addr); - return -ENODEV; + ret = -ENODEV; + goto exit1; }
ret = spi_flash_read(pfe_flash, CONFIG_SYS_LS_PFE_FW_ADDR, - CONFIG_SYS_QE_FMAN_FW_LENGTH, + CONFIG_SYS_LS_PFE_FW_LENGTH, addr); - if (ret) + if (ret) { printf("SF: read for pfe failed\n"); + goto exit1; + } + +#ifdef CONFIG_CHAIN_OF_TRUST + void *hdr_addr = malloc(CONFIG_SYS_LS_PFE_ESBC_LENGTH); + + if (!hdr_addr) { + ret = -ENOMEM; + goto exit1; + }
+ ret = spi_flash_read(pfe_flash, + CONFIG_SYS_LS_PFE_ESBC_ADDR, + CONFIG_SYS_LS_PFE_ESBC_LENGTH, + hdr_addr); + if (ret) { + printf("SF: failed to read pfe esbc header\n"); + goto exit2; + } + + pfe_esbc_hdr_addr = hdr_addr; +#endif pfe_fit_addr = addr; spi_flash_free(pfe_flash);
+ goto exit; +#ifdef CONFIG_CHAIN_OF_TRUST +exit2: + if (hdr_addr) { + free(hdr_addr); + hdr_addr = NULL; + } +#endif +exit1: + if (addr) { + free(addr); + addr = NULL; + } +exit: + if (pfe_flash) { + spi_flash_free(pfe_flash); + pfe_flash = NULL; + } + return ret; }
@@ -233,7 +281,7 @@ int pfe_firmware_init(void) goto err;
#ifdef CONFIG_CHAIN_OF_TRUST - pfe_esbc_hdr = CONFIG_SYS_LS_PFE_ESBC_ADDR; + pfe_esbc_hdr = (uintptr_t)pfe_esbc_hdr_addr; pfe_img_addr = (uintptr_t)pfe_fit_addr; if (fsl_check_boot_mode_secure() != 0) { /*
Biwen Li
