[U-Boot] [PATCH 0/2] arm: lpc32xx: use driver model serial console drivers
The change enables DM versions of NXP LPC32xx standard (NS16550) and high-speed UART drivers for both ordinary and SPL U-boot images.
The change increases the size of SPL images over a maximum size limit for a secondary bootloader, if it is downloaded from a small page NAND flash, but this does not concern any maintained LPC32xx boards. Anyhow this SPL_DM specific change is separated to a stand alone commit.
The change depends on high-speed UART driver switched to DM: https://patchwork.ozlabs.org/patch/556061/
Albert, I send the change to you before completion of DM HSUART review in case if you have any comments and because the change touches one board, which is maintained by you.
Vladimir Zapolskiy (2): arm: lpc32xx: switch serial console to driver model arm: lpc32xx: switch SPL builds to driver model
arch/arm/cpu/arm926ejs/lpc32xx/devices.c | 37 ++++++++++++++++++++++++++++-- arch/arm/include/asm/arch-lpc32xx/config.h | 36 ++++++++++++----------------- configs/devkit3250_defconfig | 2 ++ configs/work_92105_defconfig | 2 ++ 4 files changed, 54 insertions(+), 23 deletions(-)
On NXP LPC32xx platform for non-SPL builds the change adds standard (NS16550) and high-speed UARTs to driver model. Due to specific of DM NS16550 device description UART clock can not be got in runtime and by default it is set to 13MHz, if board PERIPH_CLK is different, this should be specified in board configuration file.
For SPL builds HSUARTs are disabled and non-DM NS16550 driver is compiled, if needed.
The change also updates default configs of devkit3250 and work_92105 boards to reflect updates in platform files.
Signed-off-by: Vladimir Zapolskiy vz@mleia.com --- arch/arm/cpu/arm926ejs/lpc32xx/devices.c | 37 ++++++++++++++++++++++++++++-- arch/arm/include/asm/arch-lpc32xx/config.h | 32 +++++++++++++++----------- configs/devkit3250_defconfig | 1 + configs/work_92105_defconfig | 1 + 4 files changed, 56 insertions(+), 15 deletions(-)
diff --git a/arch/arm/cpu/arm926ejs/lpc32xx/devices.c b/arch/arm/cpu/arm926ejs/lpc32xx/devices.c index b1c3f8f..447d0cd 100644 --- a/arch/arm/cpu/arm926ejs/lpc32xx/devices.c +++ b/arch/arm/cpu/arm926ejs/lpc32xx/devices.c @@ -5,12 +5,14 @@ */
#include <common.h> -#include <asm/arch/cpu.h> +#include <dm.h> +#include <dm/platform_data/lpc32xx_hsuart.h> +#include <ns16550.h> + #include <asm/arch/clk.h> #include <asm/arch/uart.h> #include <asm/arch/mux.h> #include <asm/io.h> -#include <dm.h>
static struct clk_pm_regs *clk = (struct clk_pm_regs *)CLK_PM_BASE; static struct uart_ctrl_regs *ctrl = (struct uart_ctrl_regs *)UART_CTRL_BASE; @@ -41,6 +43,37 @@ void lpc32xx_uart_init(unsigned int uart_id) &clk->u3clk + (uart_id - 3)); }
+#if !CONFIG_IS_ENABLED(OF_CONTROL) && !defined(CONFIG_SPL_BUILD) +static const struct ns16550_platdata lpc32xx_uart[] = { + { UART3_BASE, 2, CONFIG_SYS_NS16550_CLK }, + { UART4_BASE, 2, CONFIG_SYS_NS16550_CLK }, + { UART5_BASE, 2, CONFIG_SYS_NS16550_CLK }, + { UART6_BASE, 2, CONFIG_SYS_NS16550_CLK }, +}; + +#if defined(CONFIG_LPC32XX_HSUART) +static const struct lpc32xx_hsuart_platdata lpc32xx_hsuart[] = { + { HS_UART1_BASE, }, + { HS_UART2_BASE, }, + { HS_UART7_BASE, }, +}; +#endif + +U_BOOT_DEVICES(lpc32xx_uarts) = { +#if defined(CONFIG_LPC32XX_HSUART) + { "lpc32xx_hsuart", &lpc32xx_hsuart[0], }, + { "lpc32xx_hsuart", &lpc32xx_hsuart[1], }, +#endif + { "ns16550_serial", &lpc32xx_uart[0], }, + { "ns16550_serial", &lpc32xx_uart[1], }, + { "ns16550_serial", &lpc32xx_uart[2], }, + { "ns16550_serial", &lpc32xx_uart[3], }, +#if defined(CONFIG_LPC32XX_HSUART) + { "lpc32xx_hsuart", &lpc32xx_hsuart[2], }, +#endif +}; +#endif + void lpc32xx_dma_init(void) { /* Enable DMA interface */ diff --git a/arch/arm/include/asm/arch-lpc32xx/config.h b/arch/arm/include/asm/arch-lpc32xx/config.h index 521bff1..27e60e1 100644 --- a/arch/arm/include/asm/arch-lpc32xx/config.h +++ b/arch/arm/include/asm/arch-lpc32xx/config.h @@ -16,16 +16,21 @@ #define CONFIG_NR_DRAM_BANKS_MAX 2
/* UART configuration */ -#if (CONFIG_SYS_LPC32XX_UART >= 3) && (CONFIG_SYS_LPC32XX_UART <= 6) -#define CONFIG_SYS_NS16550_SERIAL -#define CONFIG_CONS_INDEX (CONFIG_SYS_LPC32XX_UART - 2) -#elif (CONFIG_SYS_LPC32XX_UART == 1) || (CONFIG_SYS_LPC32XX_UART == 2) || \ +#if (CONFIG_SYS_LPC32XX_UART == 1) || (CONFIG_SYS_LPC32XX_UART == 2) || \ (CONFIG_SYS_LPC32XX_UART == 7) +#if defined(CONFIG_SPL_BUILD) +/* SPL images do not support LPC32xx HSUART, UART5 is selected for SPL */ +#undef CONFIG_SYS_LPC32XX_UART +#define CONFIG_SYS_LPC32XX_UART 5 +#endif + +#if !defined(CONFIG_LPC32XX_HSUART) #define CONFIG_LPC32XX_HSUART -#else -#error "define CONFIG_SYS_LPC32XX_UART in the range from 1 to 7" +#endif #endif
+#if defined(CONFIG_SPL_BUILD) +#define CONFIG_SYS_NS16550_SERIAL #define CONFIG_SYS_NS16550_REG_SIZE -4 #define CONFIG_SYS_NS16550_CLK get_serial_clock()
@@ -33,15 +38,16 @@ #define CONFIG_SYS_NS16550_COM2 UART4_BASE #define CONFIG_SYS_NS16550_COM3 UART5_BASE #define CONFIG_SYS_NS16550_COM4 UART6_BASE +#endif
-#if defined(CONFIG_LPC32XX_HSUART) -#if CONFIG_SYS_LPC32XX_UART == 1 -#define HS_UART_BASE HS_UART1_BASE -#elif CONFIG_SYS_LPC32XX_UART == 2 -#define HS_UART_BASE HS_UART2_BASE -#else /* CONFIG_SYS_LPC32XX_UART == 7 */ -#define HS_UART_BASE HS_UART7_BASE +#if !defined(CONFIG_SYS_NS16550_CLK) +#define CONFIG_SYS_NS16550_CLK 13000000 #endif + +#if !defined(CONFIG_LPC32XX_HSUART) || defined(CONFIG_SPL_BUILD) +#define CONFIG_CONS_INDEX (CONFIG_SYS_LPC32XX_UART - 2) +#else +#define CONFIG_CONS_INDEX CONFIG_SYS_LPC32XX_UART #endif
#define CONFIG_SYS_BAUDRATE_TABLE \ diff --git a/configs/devkit3250_defconfig b/configs/devkit3250_defconfig index 64a0fb0..0abb8e0 100644 --- a/configs/devkit3250_defconfig +++ b/configs/devkit3250_defconfig @@ -1,5 +1,6 @@ CONFIG_ARM=y CONFIG_TARGET_DEVKIT3250=y +CONFIG_DM_SERIAL=y CONFIG_DM_GPIO=y CONFIG_SPL=y # CONFIG_CMD_FPGA is not set diff --git a/configs/work_92105_defconfig b/configs/work_92105_defconfig index 1cad3a2..a5a108e 100644 --- a/configs/work_92105_defconfig +++ b/configs/work_92105_defconfig @@ -1,5 +1,6 @@ CONFIG_ARM=y CONFIG_TARGET_WORK_92105=y +CONFIG_DM_SERIAL=y CONFIG_DM_GPIO=y CONFIG_SPL=y # CONFIG_CMD_IMLS is not set
Hi Vladimir,
Nits below.
nit: please put this before the dm/ include. Sub-directory include should go at the end. See:
http://www.denx.de/wiki/U-Boot/CodingStyle
#ifndef CONFIG_OF_CONTROL
should be equivalent to this.
{ HS_UART1_BASE, },
{ HS_UART2_BASE, },
{ HS_UART7_BASE, },
+}; +#endif
+#endif +}; +#endif
2.1.4
BTW you should be able to adjust it to work in SPL also.
Hi Simon,
On 19.12.2015 22:30, Simon Glass wrote:
Hi Vladimir,
Nits below.
Ok, thanks for the hint, I relied only on coding style description from README.
Here I want to emphasize that the change is non-SPL specific.
If this patch is applied, then SPL image still contains legacy NS16550 driver, and U-boot image is switched to its DM driver.
!defined(CONFIG_SPL_BUILD) is removed in the second change.
{ HS_UART1_BASE, },
{ HS_UART2_BASE, },
{ HS_UART7_BASE, },
+}; +#endif
+#endif +}; +#endif
2.1.4
That is done in the second patch.
Do you think it makes sense to squash them?
With best wishes, Vladimir
For NXP LPC32xx boards the change enables SPL_DM option, this allows to use any driver model UART driver in SPL images, hence a restriction on HSUART in SPL image is removed and well as definitions for non-DM NS16550 driver, its DM version is used instead.
Note, CONFIG_SPL_DM option noticeably increases SPL image, if just NAND SLC and DM version of NS16650 are included to the image, the size of SPL image is increased almost in two times from 10672 bytes to 19704 bytes. If SPL image is downloaded from a small page NAND device, then this can cause a problem, according to the LPC32xx User's Manual the maximum size of a secondary bootloader stored on small page NAND flash should not exceed 15.5KB (maximum size of a secondary bootloader on a large page NAND is 54KB).
Because SPL_DM requires malloc(), enable CONFIG_SYS_MALLOC_SIMPLE for all LPC32xx boards in shared config.h file.
Signed-off-by: Vladimir Zapolskiy vz@mleia.com --- arch/arm/cpu/arm926ejs/lpc32xx/devices.c | 2 +- arch/arm/include/asm/arch-lpc32xx/config.h | 24 ++++++------------------ configs/devkit3250_defconfig | 1 + configs/work_92105_defconfig | 1 + 4 files changed, 9 insertions(+), 19 deletions(-)
diff --git a/arch/arm/cpu/arm926ejs/lpc32xx/devices.c b/arch/arm/cpu/arm926ejs/lpc32xx/devices.c index 447d0cd..1fab875 100644 --- a/arch/arm/cpu/arm926ejs/lpc32xx/devices.c +++ b/arch/arm/cpu/arm926ejs/lpc32xx/devices.c @@ -43,7 +43,7 @@ void lpc32xx_uart_init(unsigned int uart_id) &clk->u3clk + (uart_id - 3)); }
-#if !CONFIG_IS_ENABLED(OF_CONTROL) && !defined(CONFIG_SPL_BUILD) +#if !CONFIG_IS_ENABLED(OF_CONTROL) static const struct ns16550_platdata lpc32xx_uart[] = { { UART3_BASE, 2, CONFIG_SYS_NS16550_CLK }, { UART4_BASE, 2, CONFIG_SYS_NS16550_CLK }, diff --git a/arch/arm/include/asm/arch-lpc32xx/config.h b/arch/arm/include/asm/arch-lpc32xx/config.h index 27e60e1..a9f057e 100644 --- a/arch/arm/include/asm/arch-lpc32xx/config.h +++ b/arch/arm/include/asm/arch-lpc32xx/config.h @@ -15,36 +15,24 @@
-/* UART configuration */ -#if (CONFIG_SYS_LPC32XX_UART == 1) || (CONFIG_SYS_LPC32XX_UART == 2) || \ - (CONFIG_SYS_LPC32XX_UART == 7) +/* SPL build configuration */ #if defined(CONFIG_SPL_BUILD) -/* SPL images do not support LPC32xx HSUART, UART5 is selected for SPL */ -#undef CONFIG_SYS_LPC32XX_UART -#define CONFIG_SYS_LPC32XX_UART 5 +#define CONFIG_SYS_MALLOC_SIMPLE #endif
+/* UART configuration */ +#if (CONFIG_SYS_LPC32XX_UART == 1) || (CONFIG_SYS_LPC32XX_UART == 2) || \ + (CONFIG_SYS_LPC32XX_UART == 7) #if !defined(CONFIG_LPC32XX_HSUART) #define CONFIG_LPC32XX_HSUART #endif #endif
-#if defined(CONFIG_SPL_BUILD) -#define CONFIG_SYS_NS16550_SERIAL -#define CONFIG_SYS_NS16550_REG_SIZE -4 -#define CONFIG_SYS_NS16550_CLK get_serial_clock() - -#define CONFIG_SYS_NS16550_COM1 UART3_BASE -#define CONFIG_SYS_NS16550_COM2 UART4_BASE -#define CONFIG_SYS_NS16550_COM3 UART5_BASE -#define CONFIG_SYS_NS16550_COM4 UART6_BASE -#endif - #if !defined(CONFIG_SYS_NS16550_CLK) #define CONFIG_SYS_NS16550_CLK 13000000 #endif
-#if !defined(CONFIG_LPC32XX_HSUART) || defined(CONFIG_SPL_BUILD) +#if !defined(CONFIG_LPC32XX_HSUART) #define CONFIG_CONS_INDEX (CONFIG_SYS_LPC32XX_UART - 2) #else #define CONFIG_CONS_INDEX CONFIG_SYS_LPC32XX_UART diff --git a/configs/devkit3250_defconfig b/configs/devkit3250_defconfig index 0abb8e0..87c137d 100644 --- a/configs/devkit3250_defconfig +++ b/configs/devkit3250_defconfig @@ -1,5 +1,6 @@ CONFIG_ARM=y CONFIG_TARGET_DEVKIT3250=y +CONFIG_SPL_DM=y CONFIG_DM_SERIAL=y CONFIG_DM_GPIO=y CONFIG_SPL=y diff --git a/configs/work_92105_defconfig b/configs/work_92105_defconfig index a5a108e..db69345 100644 --- a/configs/work_92105_defconfig +++ b/configs/work_92105_defconfig @@ -1,5 +1,6 @@ CONFIG_ARM=y CONFIG_TARGET_WORK_92105=y +CONFIG_SPL_DM=y CONFIG_DM_SERIAL=y CONFIG_DM_GPIO=y CONFIG_SPL=y
Hi Vladimir,
You are bringing in the full malloc(). Try adding:
CONFIG_SPL_SYS_MALLOC_SIMPLE=y
to your defconfig. The should cut the size increment to just under 5KB. That is still a lot. Are you able to use Thumb on your board?
Hi Simon,
On 15.12.2015 20:57, Simon Glass wrote:
Hi Vladimir,
thank you for the hint, I was not aware of this option.
The size of SPL image dropped from 19704 down to 15608 bytes for devkit3250, and I verified that the new image works.
I checked the difference with objdump (10672 -> 15608):
* +3236 bytes of alloc/DM/uclass functions, * +320 bytes of static data, * +360 bytes of difference in non-DM/DM NS16550 drivers * +160 bytes memcpy(), strcmp(), * +144 bytes reset_cpu(), do_reset(), reset_misc() * etc, nothing outstanding.
I think that the total size of DM/uclass functions about 3KB is pretty tight, let it remain.
Yes, ARM core of LPC32xx has ARMv5TE architecture.
My board has a large page NAND device (Albert's board also has some large page NAND device I believe), so generally it is not a problem for me, if new SPL image is a bit larger, however I want to emphasize this in a commit message.
Albert, what do you think about the change? Do be you prefer to add CONFIG_SPL_SYS_MALLOC_SIMPLE=y to defconfigs?
I think it is better to do it in v2, plus I have to remove
diff --git a/arch/arm/include/asm/arch-lpc32xx/config.h b/arch/arm/include/asm/arch-lpc32xx/config.h index a9f057e..3b7f6bd 100644 --- a/arch/arm/include/asm/arch-lpc32xx/config.h +++ b/arch/arm/include/asm/arch-lpc32xx/config.h @@ -15,11 +15,6 @@
-/* SPL build configuration */ -#if defined(CONFIG_SPL_BUILD) -#define CONFIG_SYS_MALLOC_SIMPLE -#endif - /* UART configuration */ #if (CONFIG_SYS_LPC32XX_UART == 1) || (CONFIG_SYS_LPC32XX_UART == 2) || \ (CONFIG_SYS_LPC32XX_UART == 7)
-- With best wishes, Vladimir
Vladimir Zapolskiy
