[U-Boot] [PATCH] sh: delete an unused source file
Signed-off-by: Masahiro Yamada yamada.m@jp.panasonic.com Cc: Nobuhiro Iwamatsu nobuhiro.iwamatsu.yj@renesas.com --- arch/sh/cpu/sh2/cache.c | 96 ------------------------------------------------- 1 file changed, 96 deletions(-) delete mode 100644 arch/sh/cpu/sh2/cache.c
diff --git a/arch/sh/cpu/sh2/cache.c b/arch/sh/cpu/sh2/cache.c deleted file mode 100644 index 8093e98..0000000 --- a/arch/sh/cpu/sh2/cache.c +++ /dev/null @@ -1,96 +0,0 @@ -/* - * (C) Copyright 2007 - * Yoshihiro Shimoda shimoda.yoshihiro@renesas.com - * - * Copyright (C) 2007, 2008 Nobobuhiro Iwamatsu iwamatsu@nigauri.org - * Copyright (C) 2008 Renesas Solutions Corp. - * - * SPDX-License-Identifier: GPL-2.0+ - */ - -#include <common.h> -#include <command.h> -#include <asm/processor.h> -#include <asm/io.h> - -/* - * Jump to P2 area. - * When handling TLB or caches, we need to do it from P2 area. - */ -#define jump_to_P2() \ -do { \ - unsigned long __dummy; \ - __asm__ __volatile__( \ - "mov.l 1f, %0\n\t" \ - "or %1, %0\n\t" \ - "jmp @%0\n\t" \ - " nop\n\t" \ - ".balign 4\n" \ - "1: .long 2f\n" \ - "2:" \ - : "=&r" (__dummy) \ - : "r" (0x20000000)); \ -} while (0) - -/* - * Back to P1 area. - */ -#define back_to_P1() \ -do { \ - unsigned long __dummy; \ - __asm__ __volatile__( \ - "nop;nop;nop;nop;nop;nop;nop\n\t" \ - "mov.l 1f, %0\n\t" \ - "jmp @%0\n\t" \ - " nop\n\t" \ - ".balign 4\n" \ - "1: .long 2f\n" \ - "2:" \ - : "=&r" (__dummy)); \ -} while (0) - -#define CACHE_VALID 1 -#define CACHE_UPDATED 2 - -static inline void cache_wback_all(void) -{ - unsigned long addr, data, i, j; - - jump_to_P2(); - for (i = 0; i < CACHE_OC_NUM_ENTRIES; i++) { - for (j = 0; j < CACHE_OC_NUM_WAYS; j++) { - addr = CACHE_OC_ADDRESS_ARRAY - | (j << CACHE_OC_WAY_SHIFT) - | (i << CACHE_OC_ENTRY_SHIFT); - data = inl(addr); - if (data & CACHE_UPDATED) { - data &= ~CACHE_UPDATED; - outl(data, addr); - } - } - } - back_to_P1(); -} - - -#define CACHE_ENABLE 0 -#define CACHE_DISABLE 1 - -int cache_control(unsigned int cmd) -{ - unsigned long ccr; - - jump_to_P2(); - ccr = inl(CCR); - - if (ccr & CCR_CACHE_ENABLE) - cache_wback_all(); - - if (cmd == CACHE_DISABLE) - outl(CCR_CACHE_STOP, CCR); - else - outl(CCR_CACHE_INIT, CCR); - back_to_P1(); - - return 0; -}
2014-03-31 13:09 GMT+09:00 Masahiro Yamada yamada.m@jp.panasonic.com:
Acked-by: Nobuhiro Iwamatsu iwamatsu@nigauri.org
- (C) Copyright 2007
- Yoshihiro Shimoda shimoda.yoshihiro@renesas.com
- Copyright (C) 2007, 2008 Nobobuhiro Iwamatsu iwamatsu@nigauri.org
- Copyright (C) 2008 Renesas Solutions Corp.
- Jump to P2 area.
- When handling TLB or caches, we need to do it from P2 area.
"or %1, %0\n\t" \
"jmp @%0\n\t" \
" nop\n\t" \
".balign 4\n" \
"1: .long 2f\n" \
"2:" \
: "=&r" (__dummy) \
-} while (0)
- Back to P1 area.
"jmp @%0\n\t" \
" nop\n\t" \
".balign 4\n" \
"1: .long 2f\n" \
"2:" \
-} while (0)
jump_to_P2();
data = inl(addr);
outl(data, addr);
back_to_P1();
unsigned long ccr;
jump_to_P2();
ccr = inl(CCR);
cache_wback_all();
else
back_to_P1();
1.8.3.2
Applied to u-boot-sh.git. Thanks!
Nobuhiro
2014-03-31 14:46 GMT+09:00 Nobuhiro Iwamatsu nobuhiro.iwamatsu.yj@renesas.com:
- Jump to P2 area.
"or %1, %0\n\t" \
"jmp @%0\n\t" \
" nop\n\t" \
".balign 4\n" \
"1: .long 2f\n" \
"2:" \
: "=&r" (__dummy) \
-} while (0)
- Back to P1 area.
"jmp @%0\n\t" \
" nop\n\t" \
".balign 4\n" \
"1: .long 2f\n" \
"2:" \
-} while (0)
jump_to_P2();
data = inl(addr);
outl(data, addr);
back_to_P1();
unsigned long ccr;
jump_to_P2();
ccr = inl(CCR);
cache_wback_all();
else
back_to_P1();
1.8.3.2
-- Nobuhiro Iwamatsu
Hi Nobuhiro,
On Mon, 31 Mar 2014 15:02:24 +0900 Nobuhiro Iwamatsu nobuhiro.iwamatsu.yj@renesas.com wrote:
Nobuhiro
This patch went to u-boot-sh/next but it has not been synced with the mainline.
Could you send a pull-request of u-boot-sh/next ?
Best Regards Masahiro Yamada
Sorry, reply was late. This was already applied into u-boot/master.
Thanks!
Nobuhiro
2014-04-28 17:00 GMT+09:00 Masahiro Yamada yamada.m@jp.panasonic.com:
Hi Nobuhiro,
Nobuhiro
Masahiro Yamada
Nobuhiro Iwamatsu
