[U-Boot] [PATCH 0/5] STM32: Clean unused and factorize .h files in arch-stm32
Removes unused .h files in arch/arm/include/asm/arch-stm32xx Factorize and clean some .h files to avoid to duplicate defines in separate .h files
Patrice Chotard (5): arch-stm32f4: Remove fmc.h file arch-stm32: Move gpio.h for STM32 SoCs in include/asm/ arch-stm32: Factorize stm32.h for STM32F4 and F7 arch-stm32: Remove stm32_periph.h arch-stm32: Clean arch-stm32f7/syscfg.h
arch/arm/include/asm/arch-stm32f4/fmc.h | 75 ------------ arch/arm/include/asm/arch-stm32f4/gpio.h | 146 +---------------------- arch/arm/include/asm/arch-stm32f4/stm32.h | 14 +-- arch/arm/include/asm/arch-stm32f4/stm32_periph.h | 38 ------ arch/arm/include/asm/arch-stm32f7/gpio.h | 116 +----------------- arch/arm/include/asm/arch-stm32f7/stm32.h | 45 +------ arch/arm/include/asm/arch-stm32f7/stm32_periph.h | 23 ---- arch/arm/include/asm/arch-stm32f7/syscfg.h | 9 -- arch/arm/include/asm/arch-stm32h7/gpio.h | 115 +----------------- arch/arm/include/asm/stm32_gpio.h | 115 ++++++++++++++++++ arch/arm/include/asm/stm32f.h | 22 ++++ board/st/stm32f746-disco/stm32f746-disco.c | 1 - drivers/mtd/stm32_flash.c | 2 +- 13 files changed, 144 insertions(+), 577 deletions(-) delete mode 100644 arch/arm/include/asm/arch-stm32f4/fmc.h delete mode 100644 arch/arm/include/asm/arch-stm32f4/stm32_periph.h delete mode 100644 arch/arm/include/asm/arch-stm32f7/stm32_periph.h create mode 100644 arch/arm/include/asm/stm32_gpio.h create mode 100644 arch/arm/include/asm/stm32f.h
fmc.h file is no more used, remove it. All FMC related defines are declared in drivers/ram/stm32_sdram.c which is common to all STM32 SoCs.
Signed-off-by: Patrice Chotard patrice.chotard@st.com --- arch/arm/include/asm/arch-stm32f4/fmc.h | 75 --------------------------------- 1 file changed, 75 deletions(-) delete mode 100644 arch/arm/include/asm/arch-stm32f4/fmc.h
diff --git a/arch/arm/include/asm/arch-stm32f4/fmc.h b/arch/arm/include/asm/arch-stm32f4/fmc.h deleted file mode 100644 index 7dd5077d0c34..000000000000 --- a/arch/arm/include/asm/arch-stm32f4/fmc.h +++ /dev/null @@ -1,75 +0,0 @@ -/* - * (C) Copyright 2013 - * Pavel Boldin, Emcraft Systems, paboldin@emcraft.com - * - * (C) Copyright 2015 - * Kamil Lulko, kamil.lulko@gmail.com - * - * SPDX-License-Identifier: GPL-2.0+ - */ - -#ifndef _MACH_FMC_H_ -#define _MACH_FMC_H_ - -struct stm32_fmc_regs { - u32 sdcr1; /* Control register 1 */ - u32 sdcr2; /* Control register 2 */ - u32 sdtr1; /* Timing register 1 */ - u32 sdtr2; /* Timing register 2 */ - u32 sdcmr; /* Mode register */ - u32 sdrtr; /* Refresh timing register */ - u32 sdsr; /* Status register */ -}; - -/* - * FMC registers base - */ -#define STM32_SDRAM_FMC_BASE 0xA0000140 -#define STM32_SDRAM_FMC ((struct stm32_fmc_regs *)STM32_SDRAM_FMC_BASE) - -/* Control register SDCR */ -#define FMC_SDCR_RPIPE_SHIFT 13 /* RPIPE bit shift */ -#define FMC_SDCR_RBURST_SHIFT 12 /* RBURST bit shift */ -#define FMC_SDCR_SDCLK_SHIFT 10 /* SDRAM clock divisor shift */ -#define FMC_SDCR_WP_SHIFT 9 /* Write protection shift */ -#define FMC_SDCR_CAS_SHIFT 7 /* CAS latency shift */ -#define FMC_SDCR_NB_SHIFT 6 /* Number of banks shift */ -#define FMC_SDCR_MWID_SHIFT 4 /* Memory width shift */ -#define FMC_SDCR_NR_SHIFT 2 /* Number of row address bits shift */ -#define FMC_SDCR_NC_SHIFT 0 /* Number of col address bits shift */ - -/* Timings register SDTR */ -#define FMC_SDTR_TMRD_SHIFT 0 /* Load mode register to active */ -#define FMC_SDTR_TXSR_SHIFT 4 /* Exit self-refresh time */ -#define FMC_SDTR_TRAS_SHIFT 8 /* Self-refresh time */ -#define FMC_SDTR_TRC_SHIFT 12 /* Row cycle delay */ -#define FMC_SDTR_TWR_SHIFT 16 /* Recovery delay */ -#define FMC_SDTR_TRP_SHIFT 20 /* Row precharge delay */ -#define FMC_SDTR_TRCD_SHIFT 24 /* Row-to-column delay */ - - -#define FMC_SDCMR_NRFS_SHIFT 5 - -#define FMC_SDCMR_MODE_NORMAL 0 -#define FMC_SDCMR_MODE_START_CLOCK 1 -#define FMC_SDCMR_MODE_PRECHARGE 2 -#define FMC_SDCMR_MODE_AUTOREFRESH 3 -#define FMC_SDCMR_MODE_WRITE_MODE 4 -#define FMC_SDCMR_MODE_SELFREFRESH 5 -#define FMC_SDCMR_MODE_POWERDOWN 6 - -#define FMC_SDCMR_BANK_1 (1 << 4) -#define FMC_SDCMR_BANK_2 (1 << 3) - -#define FMC_SDCMR_MODE_REGISTER_SHIFT 9 - -#define FMC_SDSR_BUSY (1 << 5) - -#define FMC_BUSY_WAIT() do { \ - __asm__ __volatile__ ("dsb" : : : "memory"); \ - while (STM32_SDRAM_FMC->sdsr & FMC_SDSR_BUSY) \ - ; \ - } while (0) - - -#endif /* _MACH_FMC_H_ */
Instead to have 3 identical gpio.h for all STM32 SoCs, migrate them in one file in include/asm.
Signed-off-by: Patrice Chotard patrice.chotard@st.com --- arch/arm/include/asm/arch-stm32f4/gpio.h | 146 +------------------------------ arch/arm/include/asm/arch-stm32f7/gpio.h | 116 +----------------------- arch/arm/include/asm/arch-stm32h7/gpio.h | 115 +----------------------- arch/arm/include/asm/stm32_gpio.h | 115 ++++++++++++++++++++++++ 4 files changed, 118 insertions(+), 374 deletions(-) create mode 100644 arch/arm/include/asm/stm32_gpio.h
diff --git a/arch/arm/include/asm/arch-stm32f4/gpio.h b/arch/arm/include/asm/arch-stm32f4/gpio.h index 6173fa130000..bb4427e6f4ac 100644 --- a/arch/arm/include/asm/arch-stm32f4/gpio.h +++ b/arch/arm/include/asm/arch-stm32f4/gpio.h @@ -11,150 +11,6 @@ #ifndef _STM32_GPIO_H_ #define _STM32_GPIO_H_
-#if (CONFIG_STM32_USART == 1) -#define STM32_GPIO_PORT_X STM32_GPIO_PORT_A -#define STM32_GPIO_PIN_TX STM32_GPIO_PIN_9 -#define STM32_GPIO_PIN_RX STM32_GPIO_PIN_10 -#define STM32_GPIO_USART STM32_GPIO_AF7 - -#elif (CONFIG_STM32_USART == 2) -#define STM32_GPIO_PORT_X STM32_GPIO_PORT_D -#define STM32_GPIO_PIN_TX STM32_GPIO_PIN_5 -#define STM32_GPIO_PIN_RX STM32_GPIO_PIN_6 -#define STM32_GPIO_USART STM32_GPIO_AF7 - -#elif (CONFIG_STM32_USART == 3) -#define STM32_GPIO_PORT_X STM32_GPIO_PORT_C -#define STM32_GPIO_PIN_TX STM32_GPIO_PIN_10 -#define STM32_GPIO_PIN_RX STM32_GPIO_PIN_11 -#define STM32_GPIO_USART STM32_GPIO_AF7 - -#elif (CONFIG_STM32_USART == 6) -#define STM32_GPIO_PORT_X STM32_GPIO_PORT_G -#define STM32_GPIO_PIN_TX STM32_GPIO_PIN_14 -#define STM32_GPIO_PIN_RX STM32_GPIO_PIN_9 -#define STM32_GPIO_USART STM32_GPIO_AF8 - -#else -#define STM32_GPIO_PORT_X STM32_GPIO_PORT_A -#define STM32_GPIO_PIN_TX STM32_GPIO_PIN_9 -#define STM32_GPIO_PIN_RX STM32_GPIO_PIN_10 -#define STM32_GPIO_USART STM32_GPIO_AF7 - -#endif - -enum stm32_gpio_port { - STM32_GPIO_PORT_A = 0, - STM32_GPIO_PORT_B, - STM32_GPIO_PORT_C, - STM32_GPIO_PORT_D, - STM32_GPIO_PORT_E, - STM32_GPIO_PORT_F, - STM32_GPIO_PORT_G, - STM32_GPIO_PORT_H, - STM32_GPIO_PORT_I -}; - -enum stm32_gpio_pin { - STM32_GPIO_PIN_0 = 0, - STM32_GPIO_PIN_1, - STM32_GPIO_PIN_2, - STM32_GPIO_PIN_3, - STM32_GPIO_PIN_4, - STM32_GPIO_PIN_5, - STM32_GPIO_PIN_6, - STM32_GPIO_PIN_7, - STM32_GPIO_PIN_8, - STM32_GPIO_PIN_9, - STM32_GPIO_PIN_10, - STM32_GPIO_PIN_11, - STM32_GPIO_PIN_12, - STM32_GPIO_PIN_13, - STM32_GPIO_PIN_14, - STM32_GPIO_PIN_15 -}; - -enum stm32_gpio_mode { - STM32_GPIO_MODE_IN = 0, - STM32_GPIO_MODE_OUT, - STM32_GPIO_MODE_AF, - STM32_GPIO_MODE_AN -}; - -enum stm32_gpio_otype { - STM32_GPIO_OTYPE_PP = 0, - STM32_GPIO_OTYPE_OD -}; - -enum stm32_gpio_speed { - STM32_GPIO_SPEED_2M = 0, - STM32_GPIO_SPEED_25M, - STM32_GPIO_SPEED_50M, - STM32_GPIO_SPEED_100M -}; - -enum stm32_gpio_pupd { - STM32_GPIO_PUPD_NO = 0, - STM32_GPIO_PUPD_UP, - STM32_GPIO_PUPD_DOWN -}; - -enum stm32_gpio_af { - STM32_GPIO_AF0 = 0, - STM32_GPIO_AF1, - STM32_GPIO_AF2, - STM32_GPIO_AF3, - STM32_GPIO_AF4, - STM32_GPIO_AF5, - STM32_GPIO_AF6, - STM32_GPIO_AF7, - STM32_GPIO_AF8, - STM32_GPIO_AF9, - STM32_GPIO_AF10, - STM32_GPIO_AF11, - STM32_GPIO_AF12, - STM32_GPIO_AF13, - STM32_GPIO_AF14, - STM32_GPIO_AF15 -}; - -struct stm32_gpio_dsc { - enum stm32_gpio_port port; - enum stm32_gpio_pin pin; -}; - -struct stm32_gpio_ctl { - enum stm32_gpio_mode mode; - enum stm32_gpio_otype otype; - enum stm32_gpio_speed speed; - enum stm32_gpio_pupd pupd; - enum stm32_gpio_af af; -}; - -struct stm32_gpio_regs { - u32 moder; /* GPIO port mode */ - u32 otyper; /* GPIO port output type */ - u32 ospeedr; /* GPIO port output speed */ - u32 pupdr; /* GPIO port pull-up/pull-down */ - u32 idr; /* GPIO port input data */ - u32 odr; /* GPIO port output data */ - u32 bsrr; /* GPIO port bit set/reset */ - u32 lckr; /* GPIO port configuration lock */ - u32 afr[2]; /* GPIO alternate function */ -}; - -struct stm32_gpio_priv { - struct stm32_gpio_regs *regs; -}; - -static inline unsigned stm32_gpio_to_port(unsigned gpio) -{ - return gpio / 16; -} - -static inline unsigned stm32_gpio_to_pin(unsigned gpio) -{ - return gpio % 16; -} +#include <asm/stm32_gpio.h>
#endif /* _STM32_GPIO_H_ */ diff --git a/arch/arm/include/asm/arch-stm32f7/gpio.h b/arch/arm/include/asm/arch-stm32f7/gpio.h index 68ecdc89e6f3..c5de7981c0d0 100644 --- a/arch/arm/include/asm/arch-stm32f7/gpio.h +++ b/arch/arm/include/asm/arch-stm32f7/gpio.h @@ -7,120 +7,6 @@
#ifndef _STM32_GPIO_H_ #define _STM32_GPIO_H_ -#include <asm/gpio.h> - -enum stm32_gpio_port { - STM32_GPIO_PORT_A = 0, - STM32_GPIO_PORT_B, - STM32_GPIO_PORT_C, - STM32_GPIO_PORT_D, - STM32_GPIO_PORT_E, - STM32_GPIO_PORT_F, - STM32_GPIO_PORT_G, - STM32_GPIO_PORT_H, - STM32_GPIO_PORT_I -}; - -enum stm32_gpio_pin { - STM32_GPIO_PIN_0 = 0, - STM32_GPIO_PIN_1, - STM32_GPIO_PIN_2, - STM32_GPIO_PIN_3, - STM32_GPIO_PIN_4, - STM32_GPIO_PIN_5, - STM32_GPIO_PIN_6, - STM32_GPIO_PIN_7, - STM32_GPIO_PIN_8, - STM32_GPIO_PIN_9, - STM32_GPIO_PIN_10, - STM32_GPIO_PIN_11, - STM32_GPIO_PIN_12, - STM32_GPIO_PIN_13, - STM32_GPIO_PIN_14, - STM32_GPIO_PIN_15 -}; - -enum stm32_gpio_mode { - STM32_GPIO_MODE_IN = 0, - STM32_GPIO_MODE_OUT, - STM32_GPIO_MODE_AF, - STM32_GPIO_MODE_AN -}; - -enum stm32_gpio_otype { - STM32_GPIO_OTYPE_PP = 0, - STM32_GPIO_OTYPE_OD -}; - -enum stm32_gpio_speed { - STM32_GPIO_SPEED_2M = 0, - STM32_GPIO_SPEED_25M, - STM32_GPIO_SPEED_50M, - STM32_GPIO_SPEED_100M -}; - -enum stm32_gpio_pupd { - STM32_GPIO_PUPD_NO = 0, - STM32_GPIO_PUPD_UP, - STM32_GPIO_PUPD_DOWN -}; - -enum stm32_gpio_af { - STM32_GPIO_AF0 = 0, - STM32_GPIO_AF1, - STM32_GPIO_AF2, - STM32_GPIO_AF3, - STM32_GPIO_AF4, - STM32_GPIO_AF5, - STM32_GPIO_AF6, - STM32_GPIO_AF7, - STM32_GPIO_AF8, - STM32_GPIO_AF9, - STM32_GPIO_AF10, - STM32_GPIO_AF11, - STM32_GPIO_AF12, - STM32_GPIO_AF13, - STM32_GPIO_AF14, - STM32_GPIO_AF15 -}; - -struct stm32_gpio_dsc { - enum stm32_gpio_port port; - enum stm32_gpio_pin pin; -}; - -struct stm32_gpio_ctl { - enum stm32_gpio_mode mode; - enum stm32_gpio_otype otype; - enum stm32_gpio_speed speed; - enum stm32_gpio_pupd pupd; - enum stm32_gpio_af af; -}; - -struct stm32_gpio_regs { - u32 moder; /* GPIO port mode */ - u32 otyper; /* GPIO port output type */ - u32 ospeedr; /* GPIO port output speed */ - u32 pupdr; /* GPIO port pull-up/pull-down */ - u32 idr; /* GPIO port input data */ - u32 odr; /* GPIO port output data */ - u32 bsrr; /* GPIO port bit set/reset */ - u32 lckr; /* GPIO port configuration lock */ - u32 afr[2]; /* GPIO alternate function */ -}; - -struct stm32_gpio_priv { - struct stm32_gpio_regs *regs; -}; - -static inline unsigned stm32_gpio_to_port(unsigned gpio) -{ - return gpio / 16; -} - -static inline unsigned stm32_gpio_to_pin(unsigned gpio) -{ - return gpio % 16; -} +#include <asm/stm32_gpio.h>
#endif /* _STM32_GPIO_H_ */ diff --git a/arch/arm/include/asm/arch-stm32h7/gpio.h b/arch/arm/include/asm/arch-stm32h7/gpio.h index 092bf3aaaca4..7846ff444006 100644 --- a/arch/arm/include/asm/arch-stm32h7/gpio.h +++ b/arch/arm/include/asm/arch-stm32h7/gpio.h @@ -7,120 +7,7 @@
#endif /* _STM32_GPIO_H_ */ diff --git a/arch/arm/include/asm/stm32_gpio.h b/arch/arm/include/asm/stm32_gpio.h new file mode 100644 index 000000000000..d24e8096acfe --- /dev/null +++ b/arch/arm/include/asm/stm32_gpio.h @@ -0,0 +1,115 @@ +/* + * Copyright (C) 2016, STMicroelectronics - All Rights Reserved + * Author(s): Vikas Manocha, vikas.manocha@st.com for STMicroelectronics. + * + * SPDX-License-Identifier: GPL-2.0+ + */ + +#ifndef _GPIO_H_ +#define _GPIO_H_ + +enum stm32_gpio_port { + STM32_GPIO_PORT_A = 0, + STM32_GPIO_PORT_B, + STM32_GPIO_PORT_C, + STM32_GPIO_PORT_D, + STM32_GPIO_PORT_E, + STM32_GPIO_PORT_F, + STM32_GPIO_PORT_G, + STM32_GPIO_PORT_H, + STM32_GPIO_PORT_I +}; + +enum stm32_gpio_pin { + STM32_GPIO_PIN_0 = 0, + STM32_GPIO_PIN_1, + STM32_GPIO_PIN_2, + STM32_GPIO_PIN_3, + STM32_GPIO_PIN_4, + STM32_GPIO_PIN_5, + STM32_GPIO_PIN_6, + STM32_GPIO_PIN_7, + STM32_GPIO_PIN_8, + STM32_GPIO_PIN_9, + STM32_GPIO_PIN_10, + STM32_GPIO_PIN_11, + STM32_GPIO_PIN_12, + STM32_GPIO_PIN_13, + STM32_GPIO_PIN_14, + STM32_GPIO_PIN_15 +}; + +enum stm32_gpio_mode { + STM32_GPIO_MODE_IN = 0, + STM32_GPIO_MODE_OUT, + STM32_GPIO_MODE_AF, + STM32_GPIO_MODE_AN +}; + +enum stm32_gpio_otype { + STM32_GPIO_OTYPE_PP = 0, + STM32_GPIO_OTYPE_OD +}; + +enum stm32_gpio_speed { + STM32_GPIO_SPEED_2M = 0, + STM32_GPIO_SPEED_25M, + STM32_GPIO_SPEED_50M, + STM32_GPIO_SPEED_100M +}; + +enum stm32_gpio_pupd { + STM32_GPIO_PUPD_NO = 0, + STM32_GPIO_PUPD_UP, + STM32_GPIO_PUPD_DOWN +}; + +enum stm32_gpio_af { + STM32_GPIO_AF0 = 0, + STM32_GPIO_AF1, + STM32_GPIO_AF2, + STM32_GPIO_AF3, + STM32_GPIO_AF4, + STM32_GPIO_AF5, + STM32_GPIO_AF6, + STM32_GPIO_AF7, + STM32_GPIO_AF8, + STM32_GPIO_AF9, + STM32_GPIO_AF10, + STM32_GPIO_AF11, + STM32_GPIO_AF12, + STM32_GPIO_AF13, + STM32_GPIO_AF14, + STM32_GPIO_AF15 +}; + +struct stm32_gpio_dsc { + enum stm32_gpio_port port; + enum stm32_gpio_pin pin; +}; + +struct stm32_gpio_ctl { + enum stm32_gpio_mode mode; + enum stm32_gpio_otype otype; + enum stm32_gpio_speed speed; + enum stm32_gpio_pupd pupd; + enum stm32_gpio_af af; +}; + +struct stm32_gpio_regs { + u32 moder; /* GPIO port mode */ + u32 otyper; /* GPIO port output type */ + u32 ospeedr; /* GPIO port output speed */ + u32 pupdr; /* GPIO port pull-up/pull-down */ + u32 idr; /* GPIO port input data */ + u32 odr; /* GPIO port output data */ + u32 bsrr; /* GPIO port bit set/reset */ + u32 lckr; /* GPIO port configuration lock */ + u32 afr[2]; /* GPIO alternate function */ +}; + +struct stm32_gpio_priv { + struct stm32_gpio_regs *regs; +}; + +#endif /* _GPIO_H_ */
Hi Patrice,
good move to consolidate these headers. One comment below.
-#endif
- STM32_GPIO_PORT_I
- STM32_GPIO_PIN_1,
- STM32_GPIO_PIN_2,
- STM32_GPIO_PIN_3,
- STM32_GPIO_PIN_4,
- STM32_GPIO_PIN_5,
- STM32_GPIO_PIN_6,
- STM32_GPIO_PIN_7,
- STM32_GPIO_PIN_8,
- STM32_GPIO_PIN_9,
- STM32_GPIO_PIN_15
- STM32_GPIO_AF1,
- STM32_GPIO_AF2,
- STM32_GPIO_AF3,
- STM32_GPIO_AF4,
- STM32_GPIO_AF5,
- STM32_GPIO_AF6,
- STM32_GPIO_AF7,
- STM32_GPIO_AF8,
- STM32_GPIO_AF9,
- STM32_GPIO_AF10,
- STM32_GPIO_AF11,
- STM32_GPIO_AF12,
- STM32_GPIO_AF13,
- STM32_GPIO_AF14,
- STM32_GPIO_AF15
- return gpio / 16;
- return gpio % 16;
Hmm.. this header seems like dummy header(in all architectures f4/f7/h7) only to include gpio header here. Also arch/arm/include/asm/ does not seems like good place for soc specific header files.
how about creating one level like arch/arm/include/asm/arch-stm32/ to include common gpio.h here. It would fix both of above points. The same location can be used to move other commonalities in future.
Cheers, Vikas
- Copyright (C) 2016, STMicroelectronics - All Rights Reserved
- Author(s): Vikas Manocha, vikas.manocha@st.com for STMicroelectronics.
- STM32_GPIO_PORT_I
- STM32_GPIO_PIN_1,
- STM32_GPIO_PIN_2,
- STM32_GPIO_PIN_3,
- STM32_GPIO_PIN_4,
- STM32_GPIO_PIN_5,
- STM32_GPIO_PIN_6,
- STM32_GPIO_PIN_7,
- STM32_GPIO_PIN_8,
- STM32_GPIO_PIN_9,
- STM32_GPIO_PIN_15
- STM32_GPIO_AF1,
- STM32_GPIO_AF2,
- STM32_GPIO_AF3,
- STM32_GPIO_AF4,
- STM32_GPIO_AF5,
- STM32_GPIO_AF6,
- STM32_GPIO_AF7,
- STM32_GPIO_AF8,
- STM32_GPIO_AF9,
- STM32_GPIO_AF10,
- STM32_GPIO_AF11,
- STM32_GPIO_AF12,
- STM32_GPIO_AF13,
- STM32_GPIO_AF14,
- STM32_GPIO_AF15
Hi Vikas
On 02/07/2018 08:28 PM, Vikas Manocha wrote:
Hi Patrice,
- return gpio % 16;
Agree, but omap have put several omap_xxxx.h files too.
It's possible to create an additionnal level arch/arm/include/asm/arch-stm32/ and put specificities to each SoCs into :
arch/arm/include/asm/arch-stm32/stm32f4 arch/arm/include/asm/arch-stm32/stm32f7 arch/arm/include/asm/arch-stm32/stm32h7
If we focus on stm32f7, this implies to modify the content of CONFIG_SYS_SOC from "stm32f7" to "stm32/stm32f7" in board/st/stm32f746-disco/Kconfig but:
1) In any case, we can't include directly files located in arch/arm/include/asm/arch-stm32 because SYS_SOC is used to build include path.
For example in drivers/gpio/gpio-uclass.c, #include <asm/gpio.h> is in fact #include <asm/<SYS_SOC>/gpio.h
so equal to #include <asm/arch-stm32/stm32f7/gpio.h
2) Other effect, now in "soc" environment variable, we will obtain "stm32/stm32f7" instead of "stm32f7". This is not a big deal, but we must add some code to extract the soc name from "soc" environment variable.
Both solution are not perfect.
Thanks
Patrice
Cheers, Vikas
Hi Patrice,
On 02/08/2018 05:35 AM, Patrice CHOTARD wrote:
Hi Vikas
Hi Patrice,
- return gpio % 16;
I see omap files, they might be first ones to use this structure, i am not sure. But in any case, it does not look clean today. How about creating asm/arch-stm32 to put common stuff like this gpio header.
-#include <asm/stm32_gpio.h> +#include <asm/arch-stm32/stm32_gpio.h>
It can be done with no modification required in SYS_SOC, the point you mentioned below. It does not remove the arch-stm32f7/f7/h7/ gpio headers but avoids include/asm cluttering with SOC files.
Cheers, Vikas
- In any case, we can't include directly files located in
- Other effect, now in "soc" environment variable, we will obtain
Thanks
Patrice
Cheers, Vikas
Hi Vikas
On 02/08/2018 11:19 PM, Vikas Manocha wrote:
Hi Patrice,
Hi Vikas
Hi Patrice,
- return gpio % 16;
Yes agree, i will send a v2 with this update
Thanks Vikas ;-)
Patrice
Cheers, Vikas
Thanks
Patrice
Cheers, Vikas
For STM32F4 and F7 SoCx family, a specific stm32.h file exists. Some common defines are duplicated or even unused in each of these stm32.h.
Factorize all common definition in arch/arm/include/asm/stm32f.h and keep specific definitions in each arch/arm/include/asm/arch-stm32fx/stm32.h.
Signed-off-by: Patrice Chotard patrice.chotard@st.com --- arch/arm/include/asm/arch-stm32f4/stm32.h | 14 ++-------- arch/arm/include/asm/arch-stm32f7/stm32.h | 45 +------------------------------ arch/arm/include/asm/stm32f.h | 22 +++++++++++++++ drivers/mtd/stm32_flash.c | 2 +- 4 files changed, 26 insertions(+), 57 deletions(-) create mode 100644 arch/arm/include/asm/stm32f.h
diff --git a/arch/arm/include/asm/arch-stm32f4/stm32.h b/arch/arm/include/asm/arch-stm32f4/stm32.h index 763b18cb5412..86cca059075d 100644 --- a/arch/arm/include/asm/arch-stm32f4/stm32.h +++ b/arch/arm/include/asm/arch-stm32f4/stm32.h @@ -11,17 +11,12 @@ #ifndef _MACH_STM32_H_ #define _MACH_STM32_H_
+#include <asm/stm32f.h> + /* * Peripheral memory map */ #define STM32_SYSMEM_BASE 0x1FFF0000 -#define STM32_PERIPH_BASE 0x40000000 -#define STM32_APB1PERIPH_BASE (STM32_PERIPH_BASE + 0x00000000) -#define STM32_APB2PERIPH_BASE (STM32_PERIPH_BASE + 0x00010000) -#define STM32_AHB1PERIPH_BASE (STM32_PERIPH_BASE + 0x00020000) -#define STM32_AHB2PERIPH_BASE (STM32_PERIPH_BASE + 0x10000000) - -#define STM32_BUS_MASK 0xFFFF0000
/* * Register maps @@ -37,15 +32,10 @@ struct stm32_u_id_regs { */ #define STM32_U_ID_BASE (STM32_SYSMEM_BASE + 0x7A10) #define STM32_U_ID ((struct stm32_u_id_regs *)STM32_U_ID_BASE) - -#define FLASH_CNTL_BASE (STM32_AHB1PERIPH_BASE + 0x3C00) - static const u32 sect_sz_kb[CONFIG_SYS_MAX_FLASH_SECT] = { [0 ... 3] = 16 * 1024, [4] = 64 * 1024, [5 ... 11] = 128 * 1024 };
-void stm32_flash_latency_cfg(int latency); - #endif /* _MACH_STM32_H_ */ diff --git a/arch/arm/include/asm/arch-stm32f7/stm32.h b/arch/arm/include/asm/arch-stm32f7/stm32.h index 40df89142608..3f097548d374 100644 --- a/arch/arm/include/asm/arch-stm32f7/stm32.h +++ b/arch/arm/include/asm/arch-stm32f7/stm32.h @@ -8,46 +8,7 @@ #ifndef _ASM_ARCH_HARDWARE_H #define _ASM_ARCH_HARDWARE_H
-/* STM32F746 */ -#define ITCM_FLASH_BASE 0x00200000UL -#define AXIM_FLASH_BASE 0x08000000UL - -#define ITCM_SRAM_BASE 0x00000000UL -#define DTCM_SRAM_BASE 0x20000000UL -#define SRAM1_BASE 0x20010000UL -#define SRAM2_BASE 0x2004C000UL - -#define PERIPH_BASE 0x40000000UL - -#define APB1_PERIPH_BASE (PERIPH_BASE + 0x00000000) -#define APB2_PERIPH_BASE (PERIPH_BASE + 0x00010000) -#define AHB1_PERIPH_BASE (PERIPH_BASE + 0x00020000) -#define AHB2_PERIPH_BASE (PERIPH_BASE + 0x10000000) -#define AHB3_PERIPH_BASE (PERIPH_BASE + 0x20000000) - -#define USART2_BASE (APB1_PERIPH_BASE + 0x4400) -#define USART3_BASE (APB1_PERIPH_BASE + 0x4800) -#define PWR_BASE (APB1_PERIPH_BASE + 0x7000) - -#define USART1_BASE (APB2_PERIPH_BASE + 0x1000) -#define USART6_BASE (APB2_PERIPH_BASE + 0x1400) -#define STM32_SYSCFG_BASE (APB2_PERIPH_BASE + 0x3800) - -#define STM32_GPIOA_BASE (AHB1_PERIPH_BASE + 0x0000) -#define STM32_GPIOB_BASE (AHB1_PERIPH_BASE + 0x0400) -#define STM32_GPIOC_BASE (AHB1_PERIPH_BASE + 0x0800) -#define STM32_GPIOD_BASE (AHB1_PERIPH_BASE + 0x0C00) -#define STM32_GPIOE_BASE (AHB1_PERIPH_BASE + 0x1000) -#define STM32_GPIOF_BASE (AHB1_PERIPH_BASE + 0x1400) -#define STM32_GPIOG_BASE (AHB1_PERIPH_BASE + 0x1800) -#define STM32_GPIOH_BASE (AHB1_PERIPH_BASE + 0x1C00) -#define STM32_GPIOI_BASE (AHB1_PERIPH_BASE + 0x2000) -#define STM32_GPIOJ_BASE (AHB1_PERIPH_BASE + 0x2400) -#define STM32_GPIOK_BASE (AHB1_PERIPH_BASE + 0x2800) -#define FLASH_CNTL_BASE (AHB1_PERIPH_BASE + 0x3C00) - - -#define SDRAM_FMC_BASE (AHB3_PERIPH_BASE + 0x40000140) +#include <asm/stm32f.h>
static const u32 sect_sz_kb[CONFIG_SYS_MAX_FLASH_SECT] = { [0 ... 3] = 32 * 1024, @@ -55,8 +16,4 @@ static const u32 sect_sz_kb[CONFIG_SYS_MAX_FLASH_SECT] = { [5 ... 7] = 256 * 1024 };
-#define STM32_BUS_MASK GENMASK(31, 16) - -void stm32_flash_latency_cfg(int latency); - #endif /* _ASM_ARCH_HARDWARE_H */ diff --git a/arch/arm/include/asm/stm32f.h b/arch/arm/include/asm/stm32f.h new file mode 100644 index 000000000000..7bea20b4d06a --- /dev/null +++ b/arch/arm/include/asm/stm32f.h @@ -0,0 +1,22 @@ +/* + * Copyright (C) 2018, STMicroelectronics - All Rights Reserved + * Author(s): Patrice Chotard, patrice.chotard@st.com for STMicroelectronics. + * + * SPDX-License-Identifier: GPL-2.0+ + */ + +#ifndef _ASM_ARCH_STM32F_H +#define _ASM_ARCH_STM32F_H + +#define STM32_PERIPH_BASE 0x40000000UL + +#define STM32_APB2_PERIPH_BASE (STM32_PERIPH_BASE + 0x00010000) +#define STM32_AHB1_PERIPH_BASE (STM32_PERIPH_BASE + 0x00020000) + +#define STM32_SYSCFG_BASE (STM32_APB2_PERIPH_BASE + 0x3800) +#define STM32_FLASH_CNTL_BASE (STM32_AHB1_PERIPH_BASE + 0x3C00) + +void stm32_flash_latency_cfg(int latency); + +#endif /* _ASM_ARCH_STM32F_H */ + diff --git a/drivers/mtd/stm32_flash.c b/drivers/mtd/stm32_flash.c index 472499d83c3b..a82814272e21 100644 --- a/drivers/mtd/stm32_flash.c +++ b/drivers/mtd/stm32_flash.c @@ -12,7 +12,7 @@
flash_info_t flash_info[CONFIG_SYS_MAX_FLASH_BANKS];
-#define STM32_FLASH ((struct stm32_flash_regs *)FLASH_CNTL_BASE) +#define STM32_FLASH ((struct stm32_flash_regs *)STM32_FLASH_CNTL_BASE)
void stm32_flash_latency_cfg(int latency) {
- Peripheral memory map
- Register maps
same comment, location of this header should be ....arch-stm32/stm32f.h
Cheers, Vikas
- Copyright (C) 2018, STMicroelectronics - All Rights Reserved
- Author(s): Patrice Chotard, patrice.chotard@st.com for STMicroelectronics.
Remove arch/arm/include/asm/arch-stm32fx/stm32_periph.h as all defines or enums are no more used.
Signed-off-by: Patrice Chotard patrice.chotard@st.com --- arch/arm/include/asm/arch-stm32f4/stm32_periph.h | 38 ------------------------ arch/arm/include/asm/arch-stm32f7/stm32_periph.h | 23 -------------- board/st/stm32f746-disco/stm32f746-disco.c | 1 - 3 files changed, 62 deletions(-) delete mode 100644 arch/arm/include/asm/arch-stm32f4/stm32_periph.h delete mode 100644 arch/arm/include/asm/arch-stm32f7/stm32_periph.h
diff --git a/arch/arm/include/asm/arch-stm32f4/stm32_periph.h b/arch/arm/include/asm/arch-stm32f4/stm32_periph.h deleted file mode 100644 index fa45a5c0f1cb..000000000000 --- a/arch/arm/include/asm/arch-stm32f4/stm32_periph.h +++ /dev/null @@ -1,38 +0,0 @@ -/* - * Copyright (C) 2016, STMicroelectronics - All Rights Reserved - * Author(s): Vikas Manocha, vikas.manocha@st.com for STMicroelectronics. - * - * SPDX-License-Identifier: GPL-2.0+ - */ - -#ifndef __ASM_ARM_ARCH_PERIPH_H -#define __ASM_ARM_ARCH_PERIPH_H - -/* - * Peripherals required for pinmux configuration. List will - * grow with support for more devices getting added. - * Numbering based on interrupt table. - * - */ -enum periph_id { - UART1_GPIOA_9_10 = 0, - UART2_GPIOD_5_6, -}; - -enum periph_clock { - USART1_CLOCK_CFG = 0, - USART2_CLOCK_CFG, - GPIO_A_CLOCK_CFG, - GPIO_B_CLOCK_CFG, - GPIO_C_CLOCK_CFG, - GPIO_D_CLOCK_CFG, - GPIO_E_CLOCK_CFG, - GPIO_F_CLOCK_CFG, - GPIO_G_CLOCK_CFG, - GPIO_H_CLOCK_CFG, - GPIO_I_CLOCK_CFG, - GPIO_J_CLOCK_CFG, - GPIO_K_CLOCK_CFG, -}; - -#endif /* __ASM_ARM_ARCH_PERIPH_H */ diff --git a/arch/arm/include/asm/arch-stm32f7/stm32_periph.h b/arch/arm/include/asm/arch-stm32f7/stm32_periph.h deleted file mode 100644 index 38d4ade13d2f..000000000000 --- a/arch/arm/include/asm/arch-stm32f7/stm32_periph.h +++ /dev/null @@ -1,23 +0,0 @@ -/* - * Copyright (C) 2016, STMicroelectronics - All Rights Reserved - * Author(s): Vikas Manocha, vikas.manocha@st.com for STMicroelectronics. - * - * SPDX-License-Identifier: GPL-2.0+ - */ - -#ifndef __ASM_ARM_ARCH_PERIPH_H -#define __ASM_ARM_ARCH_PERIPH_H - -/* - * Peripherals required for pinmux configuration. List will - * grow with support for more devices getting added. - * Numbering based on interrupt table. - * - */ -enum periph_id { - PERIPH_ID_USART1 = 37, - - PERIPH_ID_QUADSPI = 92, -}; - -#endif /* __ASM_ARM_ARCH_PERIPH_H */ diff --git a/board/st/stm32f746-disco/stm32f746-disco.c b/board/st/stm32f746-disco/stm32f746-disco.c index ec39468fb8a2..05b316fe90a4 100644 --- a/board/st/stm32f746-disco/stm32f746-disco.c +++ b/board/st/stm32f746-disco/stm32f746-disco.c @@ -13,7 +13,6 @@ #include <asm/armv7m.h> #include <asm/arch/stm32.h> #include <asm/arch/gpio.h> -#include <asm/arch/stm32_periph.h> #include <asm/arch/syscfg.h> #include <asm/gpio.h>
Remove all unused defines
Signed-off-by: Patrice Chotard patrice.chotard@st.com --- arch/arm/include/asm/arch-stm32f7/syscfg.h | 9 --------- 1 file changed, 9 deletions(-)
diff --git a/arch/arm/include/asm/arch-stm32f7/syscfg.h b/arch/arm/include/asm/arch-stm32f7/syscfg.h index 49e78f203dcd..310eec584f20 100644 --- a/arch/arm/include/asm/arch-stm32f7/syscfg.h +++ b/arch/arm/include/asm/arch-stm32f7/syscfg.h @@ -23,16 +23,7 @@ struct stm32_syscfg_regs { */ #define STM32_SYSCFG ((struct stm32_syscfg_regs *)STM32_SYSCFG_BASE)
-/* SYSCFG memory remap register */ -#define SYSCFG_MEMRMP_MEM_BOOT BIT(0) -#define SYSCFG_MEMRMP_SWP_FMC BIT(10) - /* SYSCFG peripheral mode configuration register */ -#define SYSCFG_PMC_ADCXDC2 BIT(16) #define SYSCFG_PMC_MII_RMII_SEL BIT(23)
-/* Compensation cell control register */ -#define SYSCFG_CMPCR_CMP_PD BIT(0) -#define SYSCFG_CMPCR_READY BIT(8) - #endif
Patrice CHOTARD
Vikas Manocha
