[U-Boot] [PATCH 0/2] env: Make environment loading log more clear
This patch series intended to make boot log better. Basically here we just remove unwanted error messages, relying on the message from most deep API to be printed (like mmc subsystem). At the moment this looks like most clean solution to cluttered log problem, as any other solution will be hackish.
With this patch set applied we will see something like this:
Loading Environment from FAT... MMC: no card present Loading Environment from MMC... OK
instead of:
Loading Environment from FAT... MMC: no card present ** Bad device mmc 0 ** Failed (-5) Loading Environment from MMC... OK
Sam Protsenko (2): env: Don't print "Failed" error message disk: part: Remove redundant error message
disk/part.c | 2 +- env/env.c | 4 +--- 2 files changed, 2 insertions(+), 4 deletions(-)
"Failed" error message from env_load() only clutters the log with unnecessary details, as we already have all needed warnings by that time. Example:
Remove this "Failed" message to keep log short and clear.
Signed-off-by: Sam Protsenko semen.protsenko@linaro.org --- env/env.c | 4 +--- 1 file changed, 1 insertion(+), 3 deletions(-)
diff --git a/env/env.c b/env/env.c index 5c0842ac07..3ab4ec4237 100644 --- a/env/env.c +++ b/env/env.c @@ -196,9 +196,7 @@ int env_load(void)
printf("Loading Environment from %s... ", drv->name); ret = drv->load(); - if (ret) - printf("Failed (%d)\n", ret); - else + if (!ret) printf("OK\n");
if (!ret)
Dear Sam,
if (!ret)
Now we have two "if (!ret)" in sequence. Make this one block, please.
On Fri, Jul 20, 2018 at 4:29 PM, Wolfgang Denk wd@denx.de wrote:
Dear Sam,
if (!ret) printf("OK\n"); if (!ret)
Good point. Will do in v2, thanks.
-- DENX Software Engineering GmbH, Managing Director: Wolfgang Denk HRB 165235 Munich, Office: Kirchenstr.5, D-82194 Groebenzell, Germany Phone: (+49)-8142-66989-10 Fax: (+49)-8142-66989-80 Email: wd@denx.de Commitment, n.: Commitment can be illustrated by a breakfast of ham and eggs. The chicken was involved, the pig was committed.
Underlying API should already print some meaningful error message, so this one is just brings more noise. E.g. we can see log like this:
Obviously, second error message is unwanted. Let's only print it in case when DEBUG is defined to keep log short and clear.
Signed-off-by: Sam Protsenko semen.protsenko@linaro.org --- disk/part.c | 2 +- 1 file changed, 1 insertion(+), 1 deletion(-)
diff --git a/disk/part.c b/disk/part.c index 9266a09ec3..9e457a6e72 100644 --- a/disk/part.c +++ b/disk/part.c @@ -400,7 +400,7 @@ int blk_get_device_by_str(const char *ifname, const char *dev_hwpart_str,
*dev_desc = get_dev_hwpart(ifname, dev, hwpart); if (!(*dev_desc) || ((*dev_desc)->type == DEV_TYPE_UNKNOWN)) { - printf("** Bad device %s %s **\n", ifname, dev_hwpart_str); + debug("** Bad device %s %s **\n", ifname, dev_hwpart_str); dev = -ENOENT; goto cleanup; }
Sam Protsenko
