[U-Boot] Verified boot production uses question
Hi all, question, is anyone using the U-Boot verified-boot in production?
I am using configuration verification for several OpenCompute/OpenBMC boards. After a deep-dive review I found some edge cases that in rare circumstances could lead to a signature check bypass. I think this is low-risk at best since the scenario requires special hardware behavior to exist. Our board were susceptible in the general sense, but we had implemented some additional sanity checks on the FIT structures that prevented this.
There are some proposed changes that attempt to mitigate this [1], [2], [3]. Any one of these changes mitigates the bypass scenario. If you don't mind reaching out to me I can share the exact situation/details.
[1] https://lists.denx.de/pipermail/u-boot/2018-June/330454.html [2] https://lists.denx.de/pipermail/u-boot/2018-June/330487.html [3] https://lists.denx.de/pipermail/u-boot/2018-June/330599.html
Thanks, -Teddy
Teddy,
I have been digging into this lately as well, and actually noticed a few other things on top of what you are seeing, mentioned below. I don't want to derail this email thread too much, but there is another patch working on signature-key fallback sequencing as well (which claims to be supported).
Slightly related: if you use two fit images to boot it seems that the second will never be verified. Once the first is deemed OK it just lets the boot happen.
Thanks, -Teddy
Thanks,
Sam
On Thu, Jun 7, 2018 at 3:45 PM, Sam Voss sam.voss@rockwellcollins.com wrote:
Teddy,
No worries, any/all attention on the verified-boot implementation is great!
Good find, this sounds like a limitation of the signature checking. But this can be dangerous if you expected the secondary FIT to be checked. I hope no one is using this scenario for production boards.
Curious if your planned patch is also addressing this limitation?
Thanks, -Teddy
Thanks,
Sam
Thanks, -Teddy
Teddy, All,
I agree, its a pretty handy feature.
The patch I have out right now only focuses on the fallback mechanism mentioned earlier, I wasn't able to go into the details on this one as it may have fallen out of our scope. I will likely drop an RFC at some point to try to get the conversation moving, however.
Thanks,
Sam
Sam Voss
Teddy Reed
