[U-Boot] [PATCH] SPL: sunxi: don't force .BSS into DRAM
Probably due to some (ill-founded) fear of a large BSS all sunxi boards forced their SPL BSS section into DRAM. This only works if there is no usage of a .BSS variable before the DRAM is initialised. The recent inclusion of tiny-printf breaks this assumption (it has two variables in .BSS), so any early printf (printing a number) hangs a board. This in particular breaks the (WIP) Pine64 SPL, which at the moment links Allwinner's libdram library, trying to print debug information: DRAM:DRAM driver version: V1.0 DRAM Type = <hangs>
As it turns out the normal BSS size for sunxi is about 256 Bytes, so we can happily remove the symbols and the linker script part that was forcing the section into DRAM and let the linker naturally put it into SRAM. Tested on BananaPi M1 and Pine64(-SPL), also buildman sunxi was happy.
Thanks to Siarhei for providing helpful hints!
Signed-off-by: Andre Przywara andre.przywara@arm.com ---
(and now with the list in CC: as well) ...
arch/arm/cpu/armv7/sunxi/u-boot-spl.lds | 4 +--- include/configs/sunxi-common.h | 4 ---- 2 files changed, 1 insertion(+), 7 deletions(-)
diff --git a/arch/arm/cpu/armv7/sunxi/u-boot-spl.lds b/arch/arm/cpu/armv7/sunxi/u-boot-spl.lds index 53f0cbd..a90404f 100644 --- a/arch/arm/cpu/armv7/sunxi/u-boot-spl.lds +++ b/arch/arm/cpu/armv7/sunxi/u-boot-spl.lds @@ -16,8 +16,6 @@ */ MEMORY { .sram : ORIGIN = CONFIG_SPL_TEXT_BASE,\ LENGTH = CONFIG_SPL_MAX_SIZE } -MEMORY { .sdram : ORIGIN = CONFIG_SPL_BSS_START_ADDR, \ - LENGTH = CONFIG_SPL_BSS_MAX_SIZE }
OUTPUT_FORMAT("elf32-littlearm", "elf32-littlearm", "elf32-littlearm") OUTPUT_ARCH(arm) @@ -54,5 +52,5 @@ SECTIONS *(.bss*) . = ALIGN(4); __bss_end = .; - } > .sdram + } > .sram } diff --git a/include/configs/sunxi-common.h b/include/configs/sunxi-common.h index 94275a7..e3fe965 100644 --- a/include/configs/sunxi-common.h +++ b/include/configs/sunxi-common.h @@ -75,7 +75,6 @@ * since it needs to fit in with the other values. By also #defining it * we get warnings if the Kconfig value mismatches. */ #define CONFIG_SPL_STACK_R_ADDR 0x2fe00000 -#define CONFIG_SPL_BSS_START_ADDR 0x2ff80000 #else #define SDRAM_OFFSET(x) 0x4##x #define CONFIG_SYS_SDRAM_BASE 0x40000000 @@ -86,11 +85,8 @@ * since it needs to fit in with the other values. By also #defining it * we get warnings if the Kconfig value mismatches. */ #define CONFIG_SPL_STACK_R_ADDR 0x4fe00000 -#define CONFIG_SPL_BSS_START_ADDR 0x4ff80000 #endif
-#define CONFIG_SPL_BSS_MAX_SIZE 0x00080000 /* 512 KiB */ - #if defined(CONFIG_MACH_SUN9I) || defined(CONFIG_MACH_SUN50I) /* * The A80's A1 sram starts at 0x00010000 rather then at 0x00000000 and is
I believe you should fix tiny-printf instead, try this patch:
diff --git a/lib/tiny-printf.c b/lib/tiny-printf.c index 451f4f7..5b9b0dc 100644 --- a/lib/tiny-printf.c +++ b/lib/tiny-printf.c @@ -17,7 +17,7 @@ static char *bf; static char zs;
/* Current position in sprintf() output string */ -static char *outstr; +static char *outstr __section(".data");
static void out(char c) {
Except SRAM is limited, which is why bss was in DRAM.
- } > .sdram
- } > .sram
- since it needs to fit in with the other values. By also #defining it
- we get warnings if the Kconfig value mismatches. */
- The A80's A1 sram starts at 0x00010000 rather then at 0x00000000 and is
Hi Marek,
Mmmh, that looks like a hack to paper over another hack for me. I don't think we should start to annotate seemingly random variables (at least in the code) just to cover up for some linker hack. And frankly, having bss in initially inaccessible memory without documenting this or enforcing sanity checks to catch those cases like tiny-printf seems quite hacky to me. Also if I am not mistaken we don't actually clear BSS for the SPL?
I could live with some compiler switch or linker script snippet to avoid using BSS variables for the SPL (or parts of it, at least).
Or we provide a per SoC BSS offset to utilise other SRAM locations and use that for BSS.
To prove my debugging theory I initialised _both_ those variables to 1, that also worked. But definitely you need to cover "zs" as well.
Except that DRAM is not available initially ;-)
Cheers, Andre.
- } > .sdram
- } > .sram
Andre Przywara
