[U-Boot] Pull request: u-boot-arm/master
Hi Wolfgang,
The following changes since commit 9cbfee6dc200cc746394c7efc10253a24f3ce108:
fw_env.h: fix comment (2012-02-11 22:18:38 +0100)
are available in the git repository at: git://git.denx.de/u-boot-arm.git master
Albert ARIBAUD (5): edminiv2: add hush parser, cmdline editing and long help Rename ehci-kirkwood as ehci-marvell Remove kirkwood-specifics from marvell EHCI driver orion5x: add USB host ehci-marvell support edminiv2: add USB host support
Amit Virdi (1): ARM: Convert spear3xx and spear6xx boards to boards.cfg
Aneesh V (1): OMAP4460: Reduce MPU clock speed from 920 to 700
Ben Gardiner (1): arm, davinci: add PLL0 prediv to da850 lowlevel setup
Chander Kashyap (8): Exynos: PWM: Add TCMPB3 field in pwm structure Exynos: Fix ARM Clock frequency calculation Origen: Select SCLKMPLL as FIMD0 parent clock Exynos: Clock.c: Use CONFIG_SYS_CLK_FREQ macro ARM: EXYNOS: Add support for Exynos5 based SoCs EXYNOS: Add SMDK5250 board support EXYNOS: SMDK5250: Add MMC SPL support SMDK5250: Add ethernet support
Christian Riesch (5): arm, davinci: Add lowlevel_init for SoCs other than DM644X arm, arm926ejs: Do cpu critical inits only for boards that require it arm, arm926ejs: Add option CONFIG_SYS_EXCEPTION_VECTORS_HIGH arm, arm926ejs: Enable icache only if CONFIG_SYS_ICACHE_OFF is not defined arm, davinci: Add support for the Calimain board from OMICRON electronics
David Müller (ELSOFT AG) (1): ARM: activate DISPLAY_CPUINFO for VCMA9 + SMDK2410 board
Dechesne, Nicolas (1): OMAP SPL: Fix missing timer_init() call in OMAP4 s_init()
Dirk Behme (4): imximage: Add MX53 to the documentation imximage: Add support for i.MX6 imximage: Sort bootops alphabetically i.mx6q: configs: Add fdt_high and initrd_high variables
Fabio Estevam (3): sdhc_boot: Introduce CONFIG_FSL_FIXED_MMC_LOCATION option configs: Remove CONFIG_NET_MULTI from board files mx28: Show CPU frequency
Govindraj.R (6): usb: ulpi: Extend the existing ulpi framework. usb: ulpi: Add omap-ulpi-view port support ehci-omap: Clean up added ehci-omap.c OMAP3+: Clock: Adding ehci clock enabling OMAP4: clock-common: Move the usb dppl configuration to new func OMAP4: ehci-omap: enable ehci-omap for panda boards
Hadli, Manjunath (2): davinci: remove macro CONFIG_DISPLAY_CPUINFO davinci: add support for printing clock frequency
Heiko Schocher (7): arm, davinci: add workaround for not resetting DMA bus and VPSS modules arm, davinci: add timer defines for tcr field common: add possibility for readline_into_buffer timeout common, menu: add statusline support common, menu: show menu on startup if CONFIG_MENU_SHOW is defined common, menu: do not trigger timeout again, if a line is read arm, davinci: cam_enc_4xx board updates
Helmut Raiger (3): mmc: access mxcmmc from mx31 boards mc13783.h: create and add regulator mode 0 and 1 tt01: add MMC support
HeungJun, Kim (3): ARMV7: Exynos4: Add watchdog.h for Exynos4 ARMV7: Exynos4: Add supoort power for Exynos4 ARMV7: Exynos4: Add support for TRATS board
Holger Brunck (2): arm/km: speed up i2c access for keymile boards arm/km: checkpatch cleanup
Ian Campbell (1): kirkwood_spi: correct access to irq_mask register
Ilya Yanok (2): ehci-omap: driver for EHCI host on OMAP3 mcx: support for HTKW mcx board
Jason Liu (2): i.mx6q: mx6qsabrelite: Add the ethernet function support i.mx: i.mx5: update imx_get_mac_from_fuse function
Matthias Fuchs (1): mx28: fix i.MX28 spi driver
Michael Walle (1): arm, arm-kirkwood: disable l2c before linux boot
Minkyu Kang (4): ORIGEN: remove duplicated MACH_TYPE define S5P: support generic watchdog timer TRATS: use the generic watchdog timer TRATS: set gpio of UART correctly
Pali Rohár (1): arm: omap3: Define save_boot_params in lowlevel_init.S for SPL only
Peter Barada (2): omap3logic: Add missing GPMC pinmux for LAN92xx access ARMV7: Fix duplicate use of "b" parameter in ACTIM_CTRLA definition
Peter Meerwald (3): beagle: fix typos omap3: fix comment typos doc: fix typos
Prafulla Wadaskar (1): bugfix: all Marvell specific build fails due to undefined reference to `get_ticks'
Schuyler Patton (1): AM3517: Changed default clock rate for AM3517
Simon Glass (9): tegra: Adjust funcmux config test to permit expansion tegra: Add enum to select from available funcmux configs tegra: Add I2C support to funcmux tegra: Add SDMMC support to funcmux tegra: Use funcmux for MMC on tamonten tegra: Use funcmux for MMC on harmony tegra: Use funcmux for MMC on seaboard tegra: mmc: Support operation with dcache enabled tegra2: Enable data cache
Stefan (1): kirkwood: add support for D-Link DNS-325
Stefano Babic (3): imx6: mx6qarm2: updated board_mmc_getcd() to the new prototype OMAP3: TAM3517: update ehci interface ARM: omap3: Added Teejet mt_ventoux
Stephen Warren (3): tegra2: Fix conflicting pinmux for UARTA tegra2: Fix default RAM size selection in odmdata tegra2: Add support for Compal Paz00 (Toshiba AC100)
Sughosh Ganu (2): arm, arm926ejs: Flush the data cache before disabling it Changes to move hawkboard to the new spl infrastructure
Thomas Weber (1): OMAP3: Add Corscience Tricorder board
Tom Rini (1): OMAP3: Correct get_sdr_cs_offset mask
Troy Kisky (2): i.mx6: mx6x_pins: Fix uart txd definitions i.mx6q: mx6qsabrelite: Setup uart1 pinmux
Yegor Yefremov (1): am3517evm: remove rootfstype kernel parameter for MMC boot device
robertcnelson@gmail.com (1): Beagleboard: Correct memory size on rev C4
MAINTAINERS | 21 + Makefile | 9 +- README | 6 + arch/arm/cpu/arm1136/mx31/generic.c | 1 + arch/arm/cpu/arm926ejs/armada100/timer.c | 18 + arch/arm/cpu/arm926ejs/cache.c | 9 + arch/arm/cpu/arm926ejs/cpu.c | 2 + arch/arm/cpu/arm926ejs/davinci/cpu.c | 76 +-- arch/arm/cpu/arm926ejs/davinci/da850_lowlevel.c | 31 +- arch/arm/cpu/arm926ejs/davinci/dm365_lowlevel.c | 52 ++- arch/arm/cpu/arm926ejs/davinci/lowlevel_init.S | 4 + arch/arm/cpu/arm926ejs/davinci/spl.c | 4 +- arch/arm/cpu/arm926ejs/kirkwood/Makefile | 1 + arch/arm/cpu/arm926ejs/kirkwood/cache.c | 34 + arch/arm/cpu/arm926ejs/kirkwood/timer.c | 18 + arch/arm/cpu/arm926ejs/mx27/generic.c | 35 +- arch/arm/cpu/arm926ejs/mx28/mx28.c | 3 +- arch/arm/cpu/arm926ejs/orion5x/timer.c | 18 + arch/arm/cpu/arm926ejs/pantheon/timer.c | 18 + arch/arm/cpu/arm926ejs/start.S | 28 +- arch/arm/cpu/armv7/exynos/clock.c | 229 +++++++- arch/arm/cpu/armv7/mx5/soc.c | 2 +- arch/arm/cpu/armv7/omap-common/clocks-common.c | 54 +- arch/arm/cpu/armv7/omap-common/hwinit-common.c | 2 + arch/arm/cpu/armv7/omap3/board.c | 8 +- arch/arm/cpu/armv7/omap3/clock.c | 20 + arch/arm/cpu/armv7/omap3/lowlevel_init.S | 4 +- arch/arm/cpu/armv7/omap3/sdrc.c | 2 +- arch/arm/cpu/armv7/omap4/clocks.c | 27 +- arch/arm/cpu/armv7/s5p-common/Makefile | 1 + arch/arm/cpu/armv7/s5p-common/wdt.c | 59 ++ arch/arm/cpu/armv7/tegra2/board.c | 12 +- arch/arm/cpu/armv7/tegra2/funcmux.c | 152 ++++- arch/arm/include/asm/arch-davinci/da850_lowlevel.h | 9 + arch/arm/include/asm/arch-davinci/dm365_lowlevel.h | 1 - arch/arm/include/asm/arch-davinci/hardware.h | 9 + arch/arm/include/asm/arch-davinci/pll_defs.h | 3 +- arch/arm/include/asm/arch-davinci/timer_defs.h | 16 + arch/arm/include/asm/arch-exynos/clock.h | 326 ++++++++++ arch/arm/include/asm/arch-exynos/cpu.h | 36 +- arch/arm/include/asm/arch-exynos/dmc.h | 146 +++++ arch/arm/include/asm/arch-exynos/gpio.h | 99 +++- arch/arm/include/asm/arch-exynos/power.h | 230 +++++++ arch/arm/include/asm/arch-exynos/pwm.h | 2 +- arch/arm/include/asm/arch-exynos/tzpc.h | 52 ++ arch/arm/include/asm/arch-exynos/watchdog.h | 57 ++ arch/arm/include/asm/arch-kirkwood/config.h | 2 +- arch/arm/include/asm/arch-kirkwood/kirkwood.h | 12 + arch/arm/include/asm/arch-mx27/clock.h | 22 +- arch/arm/include/asm/arch-mx31/clock.h | 3 +- arch/arm/include/asm/arch-mx31/imx-regs.h | 11 + arch/arm/include/asm/arch-mx31/sys_proto.h | 2 +- arch/arm/include/asm/arch-mx6/mx6x_pins.h | 36 +- arch/arm/include/asm/arch-omap3/clocks_omap3.h | 2 +- .../asm/arch-omap3/{ehci_omap3.h => ehci.h} | 45 +- arch/arm/include/asm/arch-omap3/mem.h | 57 +- arch/arm/include/asm/arch-omap3/sys_proto.h | 1 + arch/arm/include/asm/arch-omap4/ehci.h | 49 ++ arch/arm/include/asm/arch-orion5x/orion5x.h | 12 + arch/arm/include/asm/arch-s5pc1xx/cpu.h | 1 + arch/arm/include/asm/arch-s5pc1xx/watchdog.h | 58 ++ arch/arm/include/asm/arch-tegra2/funcmux.h | 30 +- arch/arm/include/asm/ehci-omap.h | 142 +++++ arch/arm/include/asm/u-boot.h | 3 + arch/arm/lib/board.c | 10 +- board/ait/cam_enc_4xx/cam_enc_4xx.c | 667 +++++++++++++++++++- board/ait/cam_enc_4xx/ublimage.cfg | 3 +- board/avionic-design/common/tamonten.c | 10 +- board/compal/paz00/Makefile | 41 ++ board/compal/paz00/paz00.c | 81 +++ board/corscience/tricorder/Makefile | 46 ++ board/corscience/tricorder/tricorder.c | 105 +++ board/corscience/tricorder/tricorder.h | 375 +++++++++++ board/d-link/dns325/Makefile | 49 ++ board/d-link/dns325/dns325.c | 148 +++++ board/d-link/dns325/dns325.h | 48 ++ board/d-link/dns325/kwbimage.cfg | 208 ++++++ board/davinci/da8xxevm/da850evm.c | 4 +- board/davinci/da8xxevm/hawkboard.c | 23 + board/davinci/da8xxevm/hawkboard_nand_spl.c | 115 ---- .../{u-boot-spl.lds => u-boot-spl-da850evm.lds} | 0 .../davinci/da8xxevm/u-boot-spl-hawk.lds | 22 +- board/efikamx/efikamx-usb.c | 24 +- board/enbw/enbw_cmc/enbw_cmc.c | 13 +- board/freescale/common/Makefile | 2 +- board/freescale/mx6qarm2/mx6qarm2.c | 9 +- board/freescale/mx6qsabrelite/mx6qsabrelite.c | 114 ++++ board/hale/tt01/tt01.c | 34 +- board/htkw/mcx/Makefile | 38 ++ board/htkw/mcx/mcx.c | 112 ++++ board/htkw/mcx/mcx.h | 408 ++++++++++++ board/keymile/km_arm/km_arm.c | 23 +- board/logicpd/omap3som/omap3logic.c | 15 + board/nvidia/harmony/harmony.c | 19 +- board/nvidia/seaboard/seaboard.c | 21 +- board/omicron/calimain/Makefile | 45 ++ board/omicron/calimain/calimain.c | 188 ++++++ board/samsung/origen/lowlevel_init.S | 5 + board/samsung/origen/origen_setup.h | 12 + board/samsung/smdk5250/Makefile | 58 ++ board/samsung/smdk5250/clock_init.c | 202 ++++++ board/samsung/smdk5250/dmc_init.c | 462 ++++++++++++++ board/samsung/smdk5250/lowlevel_init.S | 96 +++ board/samsung/smdk5250/mmc_boot.c | 58 ++ board/samsung/smdk5250/setup.h | 451 +++++++++++++ board/samsung/smdk5250/smdk5250.c | 240 +++++++ board/samsung/smdk5250/tzpc_init.c | 48 ++ board/samsung/trats/Makefile | 43 ++ board/samsung/trats/setup.h | 637 +++++++++++++++++++ board/samsung/trats/trats.c | 366 +++++++++++ board/technexion/twister/twister.c | 22 + board/teejet/mt_ventoux/Makefile | 38 ++ board/teejet/mt_ventoux/mt_ventoux.c | 233 +++++++ board/teejet/mt_ventoux/mt_ventoux.h | 429 +++++++++++++ board/ti/beagle/beagle.c | 116 +--- board/ti/beagle/beagle.h | 4 +- board/ti/panda/panda.c | 38 ++ board/ti/panda/panda_mux_data.h | 16 +- boards.cfg | 13 +- common/cmd_bdinfo.c | 9 + common/cmd_nvedit.c | 2 +- common/main.c | 24 +- common/menu.c | 15 +- doc/README.SPL | 4 +- doc/README.hawkboard | 43 +- doc/README.imximage | 13 +- doc/README.menu | 10 + doc/README.omap-ulpi-viewport | 27 + drivers/mmc/mxcmmc.c | 8 +- drivers/mmc/tegra2_mmc.c | 16 + drivers/spi/kirkwood_spi.c | 2 +- drivers/spi/mxs_spi.c | 12 +- drivers/usb/host/Makefile | 3 +- .../usb/host/{ehci-kirkwood.c => ehci-marvell.c} | 36 +- drivers/usb/host/ehci-omap.c | 255 ++++++++ drivers/usb/ulpi/Makefile | 1 + drivers/usb/ulpi/omap-ulpi-viewport.c | 105 +++ drivers/usb/ulpi/ulpi-viewport.c | 32 +- drivers/usb/ulpi/ulpi.c | 54 +- include/common.h | 4 +- include/configs/MPC8536DS.h | 1 + include/configs/P1010RDB.h | 5 +- include/configs/P1_P2_RDB.h | 1 + include/configs/P2020COME.h | 1 + include/configs/P2020DS.h | 1 + include/configs/P2041RDB.h | 1 + include/configs/PM826.h | 2 - include/configs/PM828.h | 2 - include/configs/VCMA9.h | 3 +- include/configs/am3517_evm.h | 3 +- include/configs/calimain.h | 363 +++++++++++ include/configs/cam_enc_4xx.h | 143 ++++- include/configs/coreboot.h | 6 - include/configs/corenet_ds.h | 1 + include/configs/da830evm.h | 4 + include/configs/da850evm.h | 11 +- include/configs/davinci_dm355evm.h | 5 +- include/configs/davinci_dm355leopard.h | 5 +- include/configs/davinci_dm365evm.h | 4 + include/configs/davinci_dm6467Tevm.h | 5 +- include/configs/davinci_dm6467evm.h | 5 +- include/configs/davinci_dvevm.h | 6 +- include/configs/davinci_schmoogie.h | 5 +- include/configs/davinci_sffsdr.h | 5 +- include/configs/davinci_sonata.h | 5 +- include/configs/dns325.h | 188 ++++++ include/configs/ea20.h | 4 + include/configs/ecovec.h | 1 - include/configs/edminiv2.h | 24 + include/configs/efikamx.h | 1 - include/configs/enbw_cmc.h | 12 +- include/configs/ethernut5.h | 1 - include/configs/flea3.h | 1 - include/configs/hawkboard.h | 28 +- include/configs/km/km_arm.h | 2 +- include/configs/m28evk.h | 1 - include/configs/mcx.h | 378 +++++++++++ include/configs/mt_ventoux.h | 58 ++ include/configs/mx6qarm2.h | 2 + include/configs/mx6qsabrelite.h | 15 +- include/configs/omap3_beagle.h | 8 + include/configs/omap3_evm_common.h | 1 - include/configs/omap3_mvblx.h | 1 - include/configs/omap4_panda.h | 26 +- include/configs/origen.h | 2 - include/configs/p1_p2_rdb_pc.h | 7 +- include/configs/paz00.h | 51 ++ include/configs/s5pc210_universal.h | 1 + include/configs/smdk2410.h | 3 +- include/configs/smdk5250.h | 204 ++++++ include/configs/tam3517-common.h | 7 +- include/configs/trats.h | 217 +++++++ include/configs/tricorder.h | 320 ++++++++++ include/configs/tt01.h | 12 + include/mc13783.h | 80 +++ include/menu.h | 4 + include/usb/ulpi.h | 36 +- nand_spl/board/davinci/da8xxevm/Makefile | 155 ----- tools/Makefile | 6 + tools/imximage.c | 8 +- tools/imximage.h | 2 + tools/mkexynosspl.c | 122 ++++ 202 files changed, 11361 insertions(+), 937 deletions(-) create mode 100644 arch/arm/cpu/arm926ejs/kirkwood/cache.c create mode 100644 arch/arm/cpu/armv7/s5p-common/wdt.c create mode 100644 arch/arm/include/asm/arch-exynos/dmc.h create mode 100644 arch/arm/include/asm/arch-exynos/power.h create mode 100644 arch/arm/include/asm/arch-exynos/tzpc.h create mode 100644 arch/arm/include/asm/arch-exynos/watchdog.h rename arch/arm/include/asm/arch-omap3/{ehci_omap3.h => ehci.h} (51%) create mode 100644 arch/arm/include/asm/arch-omap4/ehci.h create mode 100644 arch/arm/include/asm/arch-s5pc1xx/watchdog.h create mode 100644 arch/arm/include/asm/ehci-omap.h create mode 100644 board/compal/paz00/Makefile create mode 100644 board/compal/paz00/paz00.c create mode 100644 board/corscience/tricorder/Makefile create mode 100644 board/corscience/tricorder/tricorder.c create mode 100644 board/corscience/tricorder/tricorder.h create mode 100644 board/d-link/dns325/Makefile create mode 100644 board/d-link/dns325/dns325.c create mode 100644 board/d-link/dns325/dns325.h create mode 100644 board/d-link/dns325/kwbimage.cfg delete mode 100644 board/davinci/da8xxevm/hawkboard_nand_spl.c rename board/davinci/da8xxevm/{u-boot-spl.lds => u-boot-spl-da850evm.lds} (100%) rename nand_spl/board/davinci/da8xxevm/u-boot.lds => board/davinci/da8xxevm/u-boot-spl-hawk.lds (86%) create mode 100644 board/htkw/mcx/Makefile create mode 100644 board/htkw/mcx/mcx.c create mode 100644 board/htkw/mcx/mcx.h create mode 100644 board/omicron/calimain/Makefile create mode 100644 board/omicron/calimain/calimain.c create mode 100644 board/samsung/smdk5250/Makefile create mode 100644 board/samsung/smdk5250/clock_init.c create mode 100644 board/samsung/smdk5250/dmc_init.c create mode 100644 board/samsung/smdk5250/lowlevel_init.S create mode 100644 board/samsung/smdk5250/mmc_boot.c create mode 100644 board/samsung/smdk5250/setup.h create mode 100644 board/samsung/smdk5250/smdk5250.c create mode 100644 board/samsung/smdk5250/tzpc_init.c create mode 100644 board/samsung/trats/Makefile create mode 100644 board/samsung/trats/setup.h create mode 100644 board/samsung/trats/trats.c create mode 100644 board/teejet/mt_ventoux/Makefile create mode 100644 board/teejet/mt_ventoux/mt_ventoux.c create mode 100644 board/teejet/mt_ventoux/mt_ventoux.h create mode 100644 doc/README.omap-ulpi-viewport rename drivers/usb/host/{ehci-kirkwood.c => ehci-marvell.c} (73%) create mode 100644 drivers/usb/host/ehci-omap.c create mode 100644 drivers/usb/ulpi/omap-ulpi-viewport.c create mode 100644 include/configs/calimain.h create mode 100644 include/configs/dns325.h create mode 100644 include/configs/mcx.h create mode 100644 include/configs/mt_ventoux.h create mode 100644 include/configs/paz00.h create mode 100644 include/configs/smdk5250.h create mode 100644 include/configs/trats.h create mode 100644 include/configs/tricorder.h create mode 100644 include/mc13783.h delete mode 100644 nand_spl/board/davinci/da8xxevm/Makefile create mode 100644 tools/mkexynosspl.c
Amicalement,
Dear Albert ARIBAUD,
In message 4F37835D.7020705@aribaud.net you wrote:
Hi Wolfgang,
David M�ller (ELSOFT AG) (1): ARM: activate DISPLAY_CPUINFO for VCMA9 + SMDK2410 board
Pali Roh�r (1): arm: omap3: Define save_boot_params in lowlevel_init.S for SPL only
Applied, thanks.
Albert ARIBAUD
