[U-Boot] [PATCH] cmd_yaffs: Clean up command usage messages
Remove duplicate command names in usage messages to fix issues such as: => help yls yls - yaffs ls
Usage: yls yls [-l] dirname
Signed-off-by: Peter Tyser ptyser@xes-inc.com --- common/cmd_yaffs2.c | 26 +++++++++++++------------- 1 file changed, 13 insertions(+), 13 deletions(-)
diff --git a/common/cmd_yaffs2.c b/common/cmd_yaffs2.c index d43a9d4..9244606 100644 --- a/common/cmd_yaffs2.c +++ b/common/cmd_yaffs2.c @@ -281,46 +281,46 @@ int do_ymv(cmd_tbl_t *cmdtp, int flag, int argc, char *const argv[])
U_BOOT_CMD(ytrace, 2, 0, do_ytrace, "show/set yaffs trace mask", - "ytrace [new_mask] show/set yaffs trace mask"); + "[new_mask] show/set yaffs trace mask");
U_BOOT_CMD(ydevls, 1, 0, do_ydevls, "list yaffs mount points", "list yaffs mount points");
U_BOOT_CMD(ydevconfig, 5, 0, do_ydevconfig, "configure yaffs mount point", - "ydevconfig mtpoint mtd_id start_block end_block configures a yaffs2 mount point"); + "mtpoint mtd_id start_block end_block configures a yaffs2 mount point");
U_BOOT_CMD(ymount, 2, 0, do_ymount, - "mount yaffs", "ymount mtpoint mounts a yaffs2 mount point"); + "mount yaffs", "mtpoint mounts a yaffs2 mount point");
U_BOOT_CMD(yumount, 2, 0, do_yumount, - "unmount yaffs", "yunmount mtpoint unmounts a yaffs2 mount point"); + "unmount yaffs", "mtpoint unmounts a yaffs2 mount point");
-U_BOOT_CMD(yls, 3, 0, do_yls, "yaffs ls", "yls [-l] dirname"); +U_BOOT_CMD(yls, 3, 0, do_yls, "yaffs ls", "[-l] dirname");
U_BOOT_CMD(yrd, 2, 0, do_yrd, - "read file from yaffs", "yrd path read file from yaffs"); + "read file from yaffs", "path read file from yaffs");
U_BOOT_CMD(ywr, 4, 0, do_ywr, "write file to yaffs", - "ywr filename value num_vlues write values to yaffs file"); + "filename value num_vlues write values to yaffs file");
U_BOOT_CMD(yrdm, 3, 0, do_yrdm, "read file to memory from yaffs", - "yrdm filename offset reads yaffs file into memory"); + "filename offset reads yaffs file into memory");
U_BOOT_CMD(ywrm, 4, 0, do_ywrm, "write file from memory to yaffs", - "ywrm filename offset size writes memory to yaffs file"); + "filename offset size writes memory to yaffs file");
U_BOOT_CMD(ymkdir, 2, 0, do_ymkdir, - "YAFFS mkdir", "ymkdir dir create a yaffs directory"); + "YAFFS mkdir", "dir create a yaffs directory");
U_BOOT_CMD(yrmdir, 2, 0, do_yrmdir, - "YAFFS rmdir", "yrmdir dirname removes a yaffs directory"); + "YAFFS rmdir", "dirname removes a yaffs directory");
-U_BOOT_CMD(yrm, 2, 0, do_yrm, "YAFFS rm", "yrm path removes a yaffs file"); +U_BOOT_CMD(yrm, 2, 0, do_yrm, "YAFFS rm", "path removes a yaffs file");
U_BOOT_CMD(ymv, 4, 0, do_ymv, "YAFFS mv", - "ymv old_path new_path moves/rename files within a yaffs mount point"); + "old_path new_path moves/rename files within a yaffs mount point");
Peter Tyser
