[U-Boot] [PATCH] armv8: ls1046aqds: Fix NAND offset for Fman ucode and env
Fix a bug of 'commit 8104deb2d6b7 ("armv8: layerscape: Adjust memory mapping for Flash/SD card on LS1046A")' as NAND block size is 256KB on LS1046AQDS.
Signed-off-by: Gong Qianyu Qianyu.Gong@nxp.com --- include/configs/ls1046a_common.h | 2 +- include/configs/ls1046aqds.h | 2 +- 2 files changed, 2 insertions(+), 2 deletions(-)
diff --git a/include/configs/ls1046a_common.h b/include/configs/ls1046a_common.h index dfc8e9237d..6d501b9c54 100644 --- a/include/configs/ls1046a_common.h +++ b/include/configs/ls1046a_common.h @@ -183,7 +183,7 @@ #define CONFIG_ENV_SPI_MODE 0x03 #elif defined(CONFIG_NAND_BOOT) #define CONFIG_SYS_QE_FMAN_FW_IN_NAND -#define CONFIG_SYS_FMAN_FW_ADDR (72 * CONFIG_SYS_NAND_BLOCK_SIZE) +#define CONFIG_SYS_FMAN_FW_ADDR (36 * CONFIG_SYS_NAND_BLOCK_SIZE) #else #define CONFIG_SYS_QE_FMAN_FW_IN_NOR #define CONFIG_SYS_FMAN_FW_ADDR 0x60900000 diff --git a/include/configs/ls1046aqds.h b/include/configs/ls1046aqds.h index 9231cca9e9..39bd1c38a8 100644 --- a/include/configs/ls1046aqds.h +++ b/include/configs/ls1046aqds.h @@ -435,7 +435,7 @@ unsigned long get_board_ddr_clk(void);
#ifdef CONFIG_NAND_BOOT #define CONFIG_ENV_SIZE 0x2000 -#define CONFIG_ENV_OFFSET (24 * CONFIG_SYS_NAND_BLOCK_SIZE) +#define CONFIG_ENV_OFFSET (12 * CONFIG_SYS_NAND_BLOCK_SIZE) #elif defined(CONFIG_SD_BOOT) #define CONFIG_ENV_OFFSET (3 * 1024 * 1024) #define CONFIG_SYS_MMC_ENV_DEV 0
Applied to fsl-qoriq master. Thanks.
York
Gong Qianyu
York Sun
