[PATCH] crypto/fsl: fsl_hash: Fix dcache issue in caam_hash_finish
HW accelerated hash operations are giving incorrect hash output. so add flush and invalidate for input/output hash buffers.
Fixes: 94e3c8c4fd (crypto/fsl - Add progressive hashing support using hardware acceleration.) Signed-off-by: Gaurav Jain gaurav.jain@nxp.com --- drivers/crypto/fsl/fsl_hash.c | 8 ++++++++ 1 file changed, 8 insertions(+)
diff --git a/drivers/crypto/fsl/fsl_hash.c b/drivers/crypto/fsl/fsl_hash.c index a52c4ac957..9e6829b7ad 100644 --- a/drivers/crypto/fsl/fsl_hash.c +++ b/drivers/crypto/fsl/fsl_hash.c @@ -149,12 +149,20 @@ static int caam_hash_finish(void *hash_ctx, void *dest_buf, driver_hash[caam_algo].digestsize, 1);
+ flush_dcache_range((ulong)ctx->sg_tbl, (ulong)(ctx->sg_tbl) + len); + flush_dcache_range((ulong)ctx->sha_desc, + (ulong)(ctx->sha_desc) + (sizeof(uint32_t) * MAX_CAAM_DESCSIZE)); + flush_dcache_range((ulong)ctx->hash, + (ulong)(ctx->hash) + driver_hash[caam_algo].digestsize); + ret = run_descriptor_jr(ctx->sha_desc);
if (ret) { debug("Error %x\n", ret); return ret; } else { + invalidate_dcache_range((ulong)ctx->hash, + (ulong)(ctx->hash) + driver_hash[caam_algo].digestsize); memcpy(dest_buf, ctx->hash, sizeof(ctx->hash)); } free(ctx);
AFAICT, it takes somewhat more to fix that commit; the progressive hashing is entirely broken.
It doesn't actually do anything progressive, it just stashes the address/length pairs it is given, but doesn't feed the contents of those buffers to the hardware, folding it into the hash state. So the caller must not touch the buffers it passes until the finalization. I.e. I think this won't work:
char buf[SOMETHING];
update_buffer(buf); hash_update(buf, len); update_buffer_again(buf); hash_update(buf, len);
And this pattern can be found in e.g. drivers/dfu/dfu.c which seems to repeatedly pass the same address (dfu->i_buf_start) to ->hash_update.
Am I reading the code wrong?
Rasmus
Correct.
Indeed, this won't work.
At first glance, dfu asks for crc32 algorithm, so it won't use this backend. But the concept is correct: user is not forced to keep a buffer unmodified (or even allocated) after .hash_update returns.
Thanks, Horia
HW accelerated hash operations are giving incorrect hash output. so add flush and invalidate for input/output hash buffers. Fixes: 94e3c8c4fd (crypto/fsl - Add progressive hashing support using hardware acceleration.) Signed-off-by: Gaurav Jain gaurav.jain@nxp.com
Best regards, Stefano Babic
Gaurav Jain
Horia Geantă
Rasmus Villemoes
sbabic@denx.de
