[U-Boot] Uart boot broken on AM335x-evm
Hi All, I am facing an issue with UART boot on AM335x-evm using latest U-Boot. SPL is not able to download u-boot.img completely. After a bit of debug with the help of Andrew, it is watchdog causing the timeout. If HW_WATCHDOG is disabled, SPL is able to download the image completely and u-boot successfully boots up. After this I could not progress anything.
Wondering if anyone else is facing the same issue and any pointers to debug further will be very helpful.
Thanks and regards, Lokesh
I suspect that somewhere in the Y-MODEM code we need to be calling WATCHDOG_RESET()
Agree, 2c77c0d6524e seems to be the culprit, the watchdog used to be kicked in udelay(), the commit message seems it suggest it is now up to getc(), but I can't find it getting kicked in the getc() path, I think we need to just manually add a kick in the CYGACC_COMM_IF_GETC_TIMEOUT() loop.
Andrew
Andrew F. Davis
Lokesh Vutla
