[U-Boot] [ PATCH 1/2] net: fix cache misaligned issue in Broadcom SF2 driver
Fixed cache misaligned issue in the net driver. The issue shows-up when a call to flush_dcache_range is made with unaligned memory. The memory must be aligned to ARCH_DMA_MINALIGN.
Signed-off-by: Suji Velupillai suji.velupillai@broadcom.com Tested-by: Suji Velupillai suji.velupillai@broadcom.com Reviewed-by: Arun Parameswaran arun.parameswaran@broadcom.com Reviewed-by: JD Zheng jiandong.zheng@broadcom.com Reviewed-by: Shamez Kurji shamez.kurji@broadcom.com Signed-off-by: Steve Rae steve.rae@raedomain.com
Cover Letter: This series resolves issues specific to the Broadcom SF2 driver: - fix cache misaligned issue - convert to Kconfig END
drivers/net/bcm-sf2-eth-gmac.c | 113 +++++++++++++++++++++-------------------- drivers/net/bcm-sf2-eth.h | 4 +- 2 files changed, 60 insertions(+), 57 deletions(-)
diff --git a/drivers/net/bcm-sf2-eth-gmac.c b/drivers/net/bcm-sf2-eth-gmac.c index f2853cf..9ff72fa 100644 --- a/drivers/net/bcm-sf2-eth-gmac.c +++ b/drivers/net/bcm-sf2-eth-gmac.c @@ -1,5 +1,5 @@ /* - * Copyright 2014 Broadcom Corporation. + * Copyright 2014-2017 Broadcom. * * SPDX-License-Identifier: GPL-2.0+ */ @@ -28,6 +28,10 @@ } \ }
+#define RX_BUF_SIZE_ALIGNED ALIGN(RX_BUF_SIZE, ARCH_DMA_MINALIGN) +#define TX_BUF_SIZE_ALIGNED ALIGN(TX_BUF_SIZE, ARCH_DMA_MINALIGN) +#define DESCP_SIZE_ALIGNED ALIGN(sizeof(dma64dd_t), ARCH_DMA_MINALIGN) + static int gmac_disable_dma(struct eth_dma *dma, int dir); static int gmac_enable_dma(struct eth_dma *dma, int dir);
@@ -114,7 +118,7 @@ static void dma_tx_dump(struct eth_dma *dma) printf("TX Buffers:\n"); /* Initialize TX DMA descriptor table */ for (i = 0; i < TX_BUF_NUM; i++) { - bufp = (uint8_t *)(dma->tx_buf + i * TX_BUF_SIZE); + bufp = (uint8_t *)(dma->tx_buf + i * TX_BUF_SIZE_ALIGNED); printf("buf%d:0x%x; ", i, (uint32_t)bufp); } printf("\n"); @@ -145,7 +149,7 @@ static void dma_rx_dump(struct eth_dma *dma)
printf("RX Buffers:\n"); for (i = 0; i < RX_BUF_NUM; i++) { - bufp = dma->rx_buf + i * RX_BUF_SIZE; + bufp = dma->rx_buf + i * RX_BUF_SIZE_ALIGNED; printf("buf%d:0x%x; ", i, (uint32_t)bufp); } printf("\n"); @@ -163,15 +167,15 @@ static int dma_tx_init(struct eth_dma *dma)
/* clear descriptor memory */ memset((void *)(dma->tx_desc_aligned), 0, - TX_BUF_NUM * sizeof(dma64dd_t)); - memset(dma->tx_buf, 0, TX_BUF_NUM * TX_BUF_SIZE); + TX_BUF_NUM * DESCP_SIZE_ALIGNED); + memset(dma->tx_buf, 0, TX_BUF_NUM * TX_BUF_SIZE_ALIGNED);
/* Initialize TX DMA descriptor table */ for (i = 0; i < TX_BUF_NUM; i++) { descp = (dma64dd_t *)(dma->tx_desc_aligned) + i; - bufp = dma->tx_buf + i * TX_BUF_SIZE; + bufp = dma->tx_buf + i * TX_BUF_SIZE_ALIGNED; /* clear buffer memory */ - memset((void *)bufp, 0, TX_BUF_SIZE); + memset((void *)bufp, 0, TX_BUF_SIZE_ALIGNED);
ctrl = 0; /* if last descr set endOfTable */ @@ -187,10 +191,11 @@ static int dma_tx_init(struct eth_dma *dma) descp = dma->tx_desc_aligned; bufp = dma->tx_buf; flush_dcache_range((unsigned long)descp, - (unsigned long)(descp + - sizeof(dma64dd_t) * TX_BUF_NUM)); - flush_dcache_range((unsigned long)(bufp), - (unsigned long)(bufp + TX_BUF_SIZE * TX_BUF_NUM)); + (unsigned long)descp + + DESCP_SIZE_ALIGNED * TX_BUF_NUM); + flush_dcache_range((unsigned long)bufp, + (unsigned long)bufp + + TX_BUF_SIZE_ALIGNED * TX_BUF_NUM);
/* initialize the DMA channel */ writel((uint32_t)(dma->tx_desc_aligned), GMAC0_DMA_TX_ADDR_LOW_ADDR); @@ -215,20 +220,20 @@ static int dma_rx_init(struct eth_dma *dma)
/* clear descriptor memory */ memset((void *)(dma->rx_desc_aligned), 0, - RX_BUF_NUM * sizeof(dma64dd_t)); + RX_BUF_NUM * DESCP_SIZE_ALIGNED); /* clear buffer memory */ - memset(dma->rx_buf, 0, RX_BUF_NUM * RX_BUF_SIZE); + memset(dma->rx_buf, 0, RX_BUF_NUM * RX_BUF_SIZE_ALIGNED);
/* Initialize RX DMA descriptor table */ for (i = 0; i < RX_BUF_NUM; i++) { descp = (dma64dd_t *)(dma->rx_desc_aligned) + i; - bufp = dma->rx_buf + i * RX_BUF_SIZE; + bufp = dma->rx_buf + i * RX_BUF_SIZE_ALIGNED; ctrl = 0; /* if last descr set endOfTable */ if (i == (RX_BUF_NUM - 1)) ctrl = D64_CTRL1_EOT; descp->ctrl1 = ctrl; - descp->ctrl2 = RX_BUF_SIZE; + descp->ctrl2 = RX_BUF_SIZE_ALIGNED; descp->addrlow = (uint32_t)bufp; descp->addrhigh = 0;
@@ -240,10 +245,11 @@ static int dma_rx_init(struct eth_dma *dma) bufp = dma->rx_buf; /* flush descriptor and buffer */ flush_dcache_range((unsigned long)descp, - (unsigned long)(descp + - sizeof(dma64dd_t) * RX_BUF_NUM)); + (unsigned long)descp + + DESCP_SIZE_ALIGNED * RX_BUF_NUM); flush_dcache_range((unsigned long)(bufp), - (unsigned long)(bufp + RX_BUF_SIZE * RX_BUF_NUM)); + (unsigned long)bufp + + RX_BUF_SIZE_ALIGNED * RX_BUF_NUM);
/* initailize the DMA channel */ writel((uint32_t)descp, GMAC0_DMA_RX_ADDR_LOW_ADDR); @@ -292,14 +298,12 @@ static int dma_deinit(struct eth_dma *dma)
free(dma->tx_buf); dma->tx_buf = NULL; - free(dma->tx_desc); - dma->tx_desc = NULL; + free(dma->tx_desc_aligned); dma->tx_desc_aligned = NULL;
free(dma->rx_buf); dma->rx_buf = NULL; - free(dma->rx_desc); - dma->rx_desc = NULL; + free(dma->rx_desc_aligned); dma->rx_desc_aligned = NULL;
return 0; @@ -307,7 +311,7 @@ static int dma_deinit(struct eth_dma *dma)
int gmac_tx_packet(struct eth_dma *dma, void *packet, int length) { - uint8_t *bufp = dma->tx_buf + dma->cur_tx_index * TX_BUF_SIZE; + uint8_t *bufp = dma->tx_buf + dma->cur_tx_index * TX_BUF_SIZE_ALIGNED;
/* kick off the dma */ size_t len = length; @@ -348,10 +352,11 @@ int gmac_tx_packet(struct eth_dma *dma, void *packet, int length) descp->ctrl2 = ctrl;
/* flush descriptor and buffer */ - flush_dcache_range((unsigned long)descp, - (unsigned long)(descp + sizeof(dma64dd_t))); + flush_dcache_range((unsigned long)dma->tx_desc_aligned, + (unsigned long)dma->tx_desc_aligned + + DESCP_SIZE_ALIGNED * TX_BUF_NUM); flush_dcache_range((unsigned long)bufp, - (unsigned long)(bufp + TX_BUF_SIZE)); + (unsigned long)bufp + TX_BUF_SIZE_ALIGNED);
/* now update the dma last descriptor */ writel(last_desc, GMAC0_DMA_TX_PTR_ADDR); @@ -426,14 +431,15 @@ int gmac_check_rx_done(struct eth_dma *dma, uint8_t *buf) ;
/* get the packet pointer that corresponds to the rx descriptor */ - bufp = dma->rx_buf + index * RX_BUF_SIZE; + bufp = dma->rx_buf + index * RX_BUF_SIZE_ALIGNED;
descp = (dma64dd_t *)(dma->rx_desc_aligned) + index; /* flush descriptor and buffer */ - flush_dcache_range((unsigned long)descp, - (unsigned long)(descp + sizeof(dma64dd_t))); + flush_dcache_range((unsigned long)dma->rx_desc_aligned, + (unsigned long)dma->rx_desc_aligned + + DESCP_SIZE_ALIGNED * RX_BUF_NUM); flush_dcache_range((unsigned long)bufp, - (unsigned long)(bufp + RX_BUF_SIZE)); + (unsigned long)bufp + RX_BUF_SIZE_ALIGNED);
buflen = (descp->ctrl2 & D64_CTRL2_BC_MASK);
@@ -457,12 +463,13 @@ int gmac_check_rx_done(struct eth_dma *dma, uint8_t *buf) memcpy(buf, datap, rcvlen);
/* update descriptor that is being added back on ring */ - descp->ctrl2 = RX_BUF_SIZE; + descp->ctrl2 = RX_BUF_SIZE_ALIGNED; descp->addrlow = (uint32_t)bufp; descp->addrhigh = 0; /* flush descriptor */ - flush_dcache_range((unsigned long)descp, - (unsigned long)(descp + sizeof(dma64dd_t))); + flush_dcache_range((unsigned long)dma->rx_desc_aligned, + (unsigned long)dma->rx_desc_aligned + + DESCP_SIZE_ALIGNED * RX_BUF_NUM);
/* set the lastdscr for the rx ring */ writel(((uint32_t)descp) & D64_XP_LD_MASK, GMAC0_DMA_RX_PTR_ADDR); @@ -573,7 +580,7 @@ static int gmac_enable_dma(struct eth_dma *dma, int dir) * set the lastdscr for the rx ring */ writel(((uint32_t)(dma->rx_desc_aligned) + - (RX_BUF_NUM - 1) * RX_BUF_SIZE) & + (RX_BUF_NUM - 1) * RX_BUF_SIZE_ALIGNED) & D64_XP_LD_MASK, GMAC0_DMA_RX_PTR_ADDR); }
@@ -893,54 +900,52 @@ int gmac_add(struct eth_device *dev) void *tmp;
/* - * Desc has to be 16-byte aligned ? - * If it is 8-byte aligned by malloc, fail Tx + * Desc has to be 16-byte aligned. But for dcache flush it must be + * aligned to ARCH_DMA_MINALIGN. */ - tmp = malloc(sizeof(dma64dd_t) * TX_BUF_NUM + 8); + tmp = memalign(ARCH_DMA_MINALIGN, DESCP_SIZE_ALIGNED * TX_BUF_NUM); if (tmp == NULL) { printf("%s: Failed to allocate TX desc Buffer\n", __func__); return -1; }
- dma->tx_desc = (void *)tmp; - dma->tx_desc_aligned = (void *)(((uint32_t)tmp) & (~0xf)); + dma->tx_desc_aligned = (void *)tmp; debug("TX Descriptor Buffer: %p; length: 0x%x\n", - dma->tx_desc_aligned, sizeof(dma64dd_t) * TX_BUF_NUM); + dma->tx_desc_aligned, DESCP_SIZE_ALIGNED * TX_BUF_NUM);
- tmp = malloc(TX_BUF_SIZE * TX_BUF_NUM); + tmp = memalign(ARCH_DMA_MINALIGN, TX_BUF_SIZE_ALIGNED * TX_BUF_NUM); if (tmp == NULL) { printf("%s: Failed to allocate TX Data Buffer\n", __func__); - free(dma->tx_desc); + free(dma->tx_desc_aligned); return -1; } dma->tx_buf = (uint8_t *)tmp; debug("TX Data Buffer: %p; length: 0x%x\n", - dma->tx_buf, TX_BUF_SIZE * TX_BUF_NUM); + dma->tx_buf, TX_BUF_SIZE_ALIGNED * TX_BUF_NUM);
- /* Desc has to be 16-byte aligned ? */ - tmp = malloc(sizeof(dma64dd_t) * RX_BUF_NUM + 8); + /* Desc has to be 16-byte aligned */ + tmp = memalign(ARCH_DMA_MINALIGN, DESCP_SIZE_ALIGNED * RX_BUF_NUM); if (tmp == NULL) { printf("%s: Failed to allocate RX Descriptor\n", __func__); - free(dma->tx_desc); + free(dma->tx_desc_aligned); free(dma->tx_buf); return -1; } - dma->rx_desc = tmp; - dma->rx_desc_aligned = (void *)(((uint32_t)tmp) & (~0xf)); + dma->rx_desc_aligned = (void *)tmp; debug("RX Descriptor Buffer: %p, length: 0x%x\n", - dma->rx_desc_aligned, sizeof(dma64dd_t) * RX_BUF_NUM); + dma->rx_desc_aligned, DESCP_SIZE_ALIGNED * RX_BUF_NUM);
- tmp = malloc(RX_BUF_SIZE * RX_BUF_NUM); + tmp = memalign(ARCH_DMA_MINALIGN, RX_BUF_SIZE_ALIGNED * RX_BUF_NUM); if (tmp == NULL) { printf("%s: Failed to allocate RX Data Buffer\n", __func__); - free(dma->tx_desc); + free(dma->tx_desc_aligned); free(dma->tx_buf); - free(dma->rx_desc); + free(dma->rx_desc_aligned); return -1; } - dma->rx_buf = tmp; + dma->rx_buf = (uint8_t *)tmp; debug("RX Data Buffer: %p; length: 0x%x\n", - dma->rx_buf, RX_BUF_SIZE * RX_BUF_NUM); + dma->rx_buf, RX_BUF_SIZE_ALIGNED * RX_BUF_NUM);
g_dmactrlflags = 0;
diff --git a/drivers/net/bcm-sf2-eth.h b/drivers/net/bcm-sf2-eth.h index 6104aff..c4e2e01 100644 --- a/drivers/net/bcm-sf2-eth.h +++ b/drivers/net/bcm-sf2-eth.h @@ -1,5 +1,5 @@ /* - * Copyright 2014 Broadcom Corporation. + * Copyright 2014-2017 Broadcom. * * SPDX-License-Identifier: GPL-2.0+ */ @@ -30,8 +30,6 @@ enum { struct eth_dma { void *tx_desc_aligned; void *rx_desc_aligned; - void *tx_desc; - void *rx_desc;
uint8_t *tx_buf; uint8_t *rx_buf;
move to Kconfig: CONFIG_BCM_SF2_ETH CONFIG_BCM_SF2_ETH_GMAC
Also modified defconfigs of all platforms that use these configs.
Signed-off-by: Suji Velupillai suji.velupillai@broadcom.com Tested-by: Suji Velupillai suji.velupillai@broadcom.com Reviewed-by: JD Zheng jiandong.zheng@broadcom.com Reviewed-by: Scott Branden scott.branden@broadcom.com Signed-off-by: Steve Rae steve.rae@raedomain.com ---
arch/arm/include/asm/arch-bcmcygnus/configs.h | 6 +----- configs/bcm28155_w1d_defconfig | 5 +++-- configs/bcm911360_entphn-ns_defconfig | 3 +++ configs/bcm911360_entphn_defconfig | 3 +++ configs/bcm911360k_defconfig | 3 +++ configs/bcm958300k-ns_defconfig | 3 +++ configs/bcm958300k_defconfig | 3 +++ configs/bcm958305k_defconfig | 3 +++ drivers/net/Kconfig | 15 +++++++++++++++ scripts/config_whitelist.txt | 2 -- 10 files changed, 37 insertions(+), 9 deletions(-)
diff --git a/arch/arm/include/asm/arch-bcmcygnus/configs.h b/arch/arm/include/asm/arch-bcmcygnus/configs.h index af7f3bf..92b1c5e 100644 --- a/arch/arm/include/asm/arch-bcmcygnus/configs.h +++ b/arch/arm/include/asm/arch-bcmcygnus/configs.h @@ -1,5 +1,5 @@ /* - * Copyright 2014 Broadcom Corporation. + * Copyright 2014-2017 Broadcom. * * SPDX-License-Identifier: GPL-2.0+ */ @@ -23,10 +23,6 @@ #define CONFIG_SYS_NS16550_COM3 0x18023000
/* Ethernet */ -#define CONFIG_BCM_SF2_ETH -#define CONFIG_BCM_SF2_ETH_GMAC - -#define CONFIG_PHYLIB #define CONFIG_PHY_BROADCOM #define CONFIG_PHY_RESET_DELAY 10000 /* PHY reset delay in us*/
diff --git a/configs/bcm28155_w1d_defconfig b/configs/bcm28155_w1d_defconfig index aa5216e..4adbce6 100644 --- a/configs/bcm28155_w1d_defconfig +++ b/configs/bcm28155_w1d_defconfig @@ -1,7 +1,6 @@ CONFIG_ARM=y CONFIG_ENABLE_ARM_SOC_BOOT0_HOOK=y CONFIG_TARGET_BCM28155_AP=y -CONFIG_SYS_EXTRA_OPTIONS="BCM_SF2_ETH,BCM_SF2_ETH_GMAC" CONFIG_VERSION_VARIABLE=y # CONFIG_DISPLAY_CPUINFO is not set # CONFIG_DISPLAY_BOARDINFO is not set @@ -15,7 +14,6 @@ CONFIG_CMD_MMC=y CONFIG_CMD_I2C=y CONFIG_CMD_GPIO=y # CONFIG_CMD_SETEXPR is not set -# CONFIG_CMD_NET is not set # CONFIG_CMD_NFS is not set CONFIG_CMD_CACHE=y CONFIG_CMD_FAT=y @@ -33,3 +31,6 @@ CONFIG_USB_GADGET_DOWNLOAD=y CONFIG_G_DNL_MANUFACTURER="Broadcom Corporation" CONFIG_G_DNL_VENDOR_NUM=0x18d1 CONFIG_G_DNL_PRODUCT_NUM=0x0d02 +CONFIG_NETDEVICES=y +CONFIG_BCM_SF2_ETH=y +CONFIG_BCM_SF2_ETH_GMAC=y diff --git a/configs/bcm911360_entphn-ns_defconfig b/configs/bcm911360_entphn-ns_defconfig index adcc152..f1df78a 100644 --- a/configs/bcm911360_entphn-ns_defconfig +++ b/configs/bcm911360_entphn-ns_defconfig @@ -19,3 +19,6 @@ CONFIG_CMD_TIME=y CONFIG_CMD_FAT=y CONFIG_SYS_NS16550=y CONFIG_OF_LIBFDT=y +CONFIG_NETDEVICES=y +CONFIG_BCM_SF2_ETH=y +CONFIG_BCM_SF2_ETH_GMAC=y diff --git a/configs/bcm911360_entphn_defconfig b/configs/bcm911360_entphn_defconfig index e49071d..22da69e 100644 --- a/configs/bcm911360_entphn_defconfig +++ b/configs/bcm911360_entphn_defconfig @@ -19,3 +19,6 @@ CONFIG_CMD_TIME=y CONFIG_CMD_FAT=y CONFIG_SYS_NS16550=y CONFIG_OF_LIBFDT=y +CONFIG_NETDEVICES=y +CONFIG_BCM_SF2_ETH=y +CONFIG_BCM_SF2_ETH_GMAC=y diff --git a/configs/bcm911360k_defconfig b/configs/bcm911360k_defconfig index 8077c4a..0281fc8 100644 --- a/configs/bcm911360k_defconfig +++ b/configs/bcm911360k_defconfig @@ -19,3 +19,6 @@ CONFIG_CMD_TIME=y CONFIG_CMD_FAT=y CONFIG_SYS_NS16550=y CONFIG_OF_LIBFDT=y +CONFIG_NETDEVICES=y +CONFIG_BCM_SF2_ETH=y +CONFIG_BCM_SF2_ETH_GMAC=y diff --git a/configs/bcm958300k-ns_defconfig b/configs/bcm958300k-ns_defconfig index 26d0b0b..c837721 100644 --- a/configs/bcm958300k-ns_defconfig +++ b/configs/bcm958300k-ns_defconfig @@ -19,3 +19,6 @@ CONFIG_CMD_TIME=y CONFIG_CMD_FAT=y CONFIG_SYS_NS16550=y CONFIG_OF_LIBFDT=y +CONFIG_NETDEVICES=y +CONFIG_BCM_SF2_ETH=y +CONFIG_BCM_SF2_ETH_GMAC=y diff --git a/configs/bcm958300k_defconfig b/configs/bcm958300k_defconfig index 8077c4a..0281fc8 100644 --- a/configs/bcm958300k_defconfig +++ b/configs/bcm958300k_defconfig @@ -19,3 +19,6 @@ CONFIG_CMD_TIME=y CONFIG_CMD_FAT=y CONFIG_SYS_NS16550=y CONFIG_OF_LIBFDT=y +CONFIG_NETDEVICES=y +CONFIG_BCM_SF2_ETH=y +CONFIG_BCM_SF2_ETH_GMAC=y diff --git a/configs/bcm958305k_defconfig b/configs/bcm958305k_defconfig index 8077c4a..0281fc8 100644 --- a/configs/bcm958305k_defconfig +++ b/configs/bcm958305k_defconfig @@ -19,3 +19,6 @@ CONFIG_CMD_TIME=y CONFIG_CMD_FAT=y CONFIG_SYS_NS16550=y CONFIG_OF_LIBFDT=y +CONFIG_NETDEVICES=y +CONFIG_BCM_SF2_ETH=y +CONFIG_BCM_SF2_ETH_GMAC=y diff --git a/drivers/net/Kconfig b/drivers/net/Kconfig index 70e3661..34c4f23 100644 --- a/drivers/net/Kconfig +++ b/drivers/net/Kconfig @@ -40,6 +40,21 @@ config ALTERA_TSE Please find details on the "Triple-Speed Ethernet MegaCore Function Resource Center" of Altera.
+config BCM_SF2_ETH + bool "Broadcom SF2 (Starfighter2) Ethernet support" + select PHYLIB + help + This driver provides a MAC and DMA abstraction framework to + support multiple Broadcom SoCs. + +config BCM_SF2_ETH_GMAC + bool "Broadcom SF2 (Starfighter2) GMAC Ethernet support" + depends on BCM_SF2_ETH + help + This driver provides support to ethernet for bcmcygnus specific + based platforms only and it is based on the framework provided + by the Starfighter2 driver. + config DWC_ETH_QOS bool "Synopsys DWC Ethernet QOS device support" depends on DM_ETH diff --git a/scripts/config_whitelist.txt b/scripts/config_whitelist.txt index f6c9101..21ece38 100644 --- a/scripts/config_whitelist.txt +++ b/scripts/config_whitelist.txt @@ -250,9 +250,7 @@ CONFIG_BCH_CONST_PARAMS CONFIG_BCH_CONST_T CONFIG_BCM2835_GPIO CONFIG_BCM283X_MU_SERIAL -CONFIG_BCM_SF2_ETH CONFIG_BCM_SF2_ETH_DEFAULT_PORT -CONFIG_BCM_SF2_ETH_GMAC CONFIG_BD_NUM_CPUS CONFIG_BF506_UART0_PORTF CONFIG_BF506_UART1_PORTG
- Copyright 2014 Broadcom Corporation.
- Copyright 2014-2017 Broadcom.
+config BCM_SF2_ETH
select PHYLIB
help
help
Odd that the config doesn't include "cygnus" in it if that's what it applies to.
Any reason not to move this along with the driver enable?
-CONFIG_BCM_SF2_ETH_GMAC CONFIG_BD_NUM_CPUS CONFIG_BF506_UART0_PORTF CONFIG_BF506_UART1_PORTG -- 2.7.4
U-Boot mailing list U-Boot@lists.denx.de http://lists.denx.de/listinfo/u-boot
Thank you Joe for your time and feedback, Please see the answers inline. Suji
On Tue, Mar 21, 2017 at 11:53 AM, Joe Hershberger <joe.hershberger@gmail.com
defconfig
defconfig
Function
+config BCM_SF2_ETH
select PHYLIB
help
help
It is because the driver is common to multiple SOC, cygnus is one of them. (cc'ed Jiandong Zheng in this reply, the original committer of the driver)
Yes we can move this with the driver enable. Can we make this as separate commit?
On Thu, Mar 23, 2017 at 12:32 PM, Suji Velupillai suji.velupillai@broadcom.com wrote:
On Tue, Mar 21, 2017 at 11:53 AM, Joe Hershberger joe.hershberger@gmail.com wrote:
+config BCM_SF2_ETH
select PHYLIB
help
help
specific
My biggest concern here is there is no information that would allow a user to determine what the difference is between this option and the one above (without "_GMAC"). More details are needed above as well. Such as which other SoCs use that framework.
That's no problem.
END
Needs to be "Cover-letter:"
- I'll update this in V2
diff --git a/drivers/net/bcm-sf2-eth-gmac.c b/drivers/net/bcm-sf2-eth- gmac.c index f2853cf..9ff72fa 100644 --- a/drivers/net/bcm-sf2-eth-gmac.c +++ b/drivers/net/bcm-sf2-eth-gmac.c @@ -1,5 +1,5 @@ /*
memset(dma->tx_buf, 0, TX_BUF_NUM * TX_BUF_SIZE_ALIGNED); /* Initialize TX DMA descriptor table */ for (i = 0; i < TX_BUF_NUM; i++) { descp = (dma64dd_t *)(dma->tx_desc_aligned) + i;
memset((void *)bufp, 0, TX_BUF_SIZE_ALIGNED); ctrl = 0; /* if last descr set endOfTable */
sizeof(dma64dd_t) *
TX_BUF_NUM));
TX_BUF_NUM));
TX_BUF_SIZE_ALIGNED * TX_BUF_NUM); /* initialize the DMA channel */ writel((uint32_t)(dma->tx_desc_aligned),
memset(dma->rx_buf, 0, RX_BUF_NUM * RX_BUF_SIZE_ALIGNED); /* Initialize RX DMA descriptor table */ for (i = 0; i < RX_BUF_NUM; i++) { descp = (dma64dd_t *)(dma->rx_desc_aligned) + i;
sizeof(dma64dd_t) *
RX_BUF_NUM));
RX_BUF_NUM));
RX_BUF_SIZE_ALIGNED * RX_BUF_NUM); /* initailize the DMA channel */ writel((uint32_t)descp, GMAC0_DMA_RX_ADDR_LOW_ADDR);
free(dma->tx_desc);
free(dma->tx_desc_aligned); dma->tx_desc_aligned = NULL; free(dma->rx_buf); dma->rx_buf = NULL;
free(dma->rx_desc);
free(dma->rx_desc_aligned); dma->rx_desc_aligned = NULL; return 0;
(unsigned long)bufp + TX_BUF_SIZE_ALIGNED); /* now update the dma last descriptor */ writel(last_desc, GMAC0_DMA_TX_PTR_ADDR);
bufp = dma->rx_buf + index * RX_BUF_SIZE_ALIGNED; descp = (dma64dd_t *)(dma->rx_desc_aligned) + index; /* flush descriptor and buffer */
(unsigned long)bufp + RX_BUF_SIZE_ALIGNED); buflen = (descp->ctrl2 & D64_CTRL2_BC_MASK);
DESCP_SIZE_ALIGNED * RX_BUF_NUM); /* set the lastdscr for the rx ring */ writel(((uint32_t)descp) & D64_XP_LD_MASK, GMAC0_DMA_RX_PTR_ADDR);
free(dma->tx_desc);
free(dma->tx_desc);
dma->rx_desc = tmp;
free(dma->tx_desc);
free(dma->rx_desc);
dma->rx_buf = tmp;
dma->rx_buf, RX_BUF_SIZE_ALIGNED * RX_BUF_NUM); g_dmactrlflags = 0;
void *tx_desc;
void *rx_desc; uint8_t *tx_buf; uint8_t *rx_buf;
-- 2.7.4
Joe Hershberger
Joe Hershberger
Steve Rae
Suji Velupillai
