[PATCH 1/2] led: Implement software led blinking
From: Michael Polyntsov michael.polyntsov@iopsys.eu
If hardware (or driver) doesn't support leds blinking, it's now possible to use software implementation of blinking instead. This relies on cyclic functions.
Signed-off-by: Michael Polyntsov michael.polyntsov@iopsys.eu Signed-off-by: Mikhail Kshevetskiy mikhail.kshevetskiy@iopsys.eu --- drivers/led/Kconfig | 9 ++ drivers/led/led-uclass.c | 190 ++++++++++++++++++++++++++++++++++++++- 2 files changed, 195 insertions(+), 4 deletions(-)
diff --git a/drivers/led/Kconfig b/drivers/led/Kconfig index 9837960198d..4330f014239 100644 --- a/drivers/led/Kconfig +++ b/drivers/led/Kconfig @@ -73,6 +73,15 @@ config LED_BLINK This option enables support for this which adds slightly to the code size.
+config LED_SW_BLINK + bool "Support software LED blinking" + depends on LED_BLINK + select CYCLIC + help + Turns on led blinking implemented in the software, useful when + the hardware doesn't support led blinking. Does nothing if + driver supports blinking. + config SPL_LED bool "Enable LED support in SPL" depends on SPL_DM diff --git a/drivers/led/led-uclass.c b/drivers/led/led-uclass.c index a4be56fc258..b35964f2e99 100644 --- a/drivers/led/led-uclass.c +++ b/drivers/led/led-uclass.c @@ -15,6 +15,10 @@ #include <dm/root.h> #include <dm/uclass-internal.h>
+#ifdef CONFIG_LED_SW_BLINK +#include <malloc.h> +#endif + int led_bind_generic(struct udevice *parent, const char *driver_name) { struct udevice *dev; @@ -41,6 +45,7 @@ int led_get_by_label(const char *label, struct udevice **devp) ret = uclass_get(UCLASS_LED, &uc); if (ret) return ret; + uclass_foreach_dev(dev, uc) { struct led_uc_plat *uc_plat = dev_get_uclass_plat(dev);
@@ -52,14 +57,180 @@ int led_get_by_label(const char *label, struct udevice **devp) return -ENODEV; }
-int led_set_state(struct udevice *dev, enum led_state_t state) +#ifdef CONFIG_LED_SW_BLINK + +enum led_sw_blink_state_t { + LED_SW_BLINK_ST_OFF = 0, + LED_SW_BLINK_ST_ON = 1, + LED_SW_BLINK_ST_NONE = 2, +}; + +struct sw_blink_state { + struct udevice *dev; + enum led_sw_blink_state_t cur_blink_state; +}; + +static bool led_driver_supports_hw_blinking(const struct udevice *dev) +{ + struct led_ops *ops = led_get_ops(dev); + + /* + * We assume that if driver supports set_period, then it correctly + * handles all other requests, for example, that + * led_set_state(LEDST_BLINK) works correctly. + */ + return ops->set_period != NULL; +} + +static const char *led_sw_label_to_cyclic_func_name(const char *label) +{ +#define MAX_NAME_LEN 50 + static char cyclic_func_name[MAX_NAME_LEN] = {0}; + + snprintf(cyclic_func_name, MAX_NAME_LEN, "sw_blink_%s", label); + return cyclic_func_name; +#undef MAX_NAME_LEN +} + +static struct cyclic_info *led_sw_find_blinking_led(const char *label) +{ + struct cyclic_info *cyclic; + const char *cyclic_name; + + cyclic_name = led_sw_label_to_cyclic_func_name(label); + + hlist_for_each_entry(cyclic, cyclic_get_list(), list) { + if (strcmp(cyclic->name, cyclic_name) == 0) + return cyclic; + } + + return NULL; +} + +static bool led_sw_is_blinking(struct udevice *dev) +{ + struct led_uc_plat *uc_plat = dev_get_uclass_plat(dev); + struct cyclic_info *cyclic = led_sw_find_blinking_led(uc_plat->label); + + if (cyclic != NULL) { + struct sw_blink_state *state; + + state = (struct sw_blink_state *)cyclic->ctx; + return state->cur_blink_state != LED_SW_BLINK_ST_NONE; + } + + return false; +} + +static void led_sw_blink(void *void_state) +{ + struct sw_blink_state *state = (struct sw_blink_state *)void_state; + struct udevice *dev = state->dev; + struct led_ops *ops = led_get_ops(dev); + + switch (state->cur_blink_state) { + case LED_SW_BLINK_ST_OFF: + state->cur_blink_state = LED_SW_BLINK_ST_ON; + ops->set_state(dev, LEDST_ON); + break; + case LED_SW_BLINK_ST_ON: + state->cur_blink_state = LED_SW_BLINK_ST_OFF; + ops->set_state(dev, LEDST_OFF); + break; + case LED_SW_BLINK_ST_NONE: + /* + * led_set_period has been called, but + * led_set_state(LDST_BLINK) has not yet, + * so doing nothing + */ + break; + } +} + +static void led_sw_free_cyclic(struct cyclic_info *cyclic) +{ + free(cyclic->ctx); + cyclic_unregister(cyclic); +} + +static int led_sw_set_period(struct udevice *dev, int period_ms) +{ + struct cyclic_info *cyclic; + struct sw_blink_state *state; + struct led_uc_plat *uc_plat = dev_get_uclass_plat(dev); + const char *cyclic_func_name; + + state = malloc(sizeof(struct sw_blink_state)); + if (state == NULL) { + printf("Allocating memory for sw_blink_state for %s failed\n", + uc_plat->label); + return -ENOMEM; + } + + state->cur_blink_state = LED_SW_BLINK_ST_NONE; + state->dev = dev; + + /* + * Make sure that there is no cyclic function already + * registered for this label + */ + cyclic = led_sw_find_blinking_led(uc_plat->label); + if (cyclic != NULL) + led_sw_free_cyclic(cyclic); + + cyclic_func_name = led_sw_label_to_cyclic_func_name(uc_plat->label); + + cyclic = cyclic_register(led_sw_blink, period_ms * 1000, + cyclic_func_name, (void *)state); + if (cyclic == NULL) { + printf("Registering of blinking function for %s failed\n", + uc_plat->label); + free(state); + return -ENOMEM; + } + + return 0; +} + +#endif + +int led_set_state(struct udevice *dev, enum led_state_t new_state) { struct led_ops *ops = led_get_ops(dev);
if (!ops->set_state) return -ENOSYS;
- return ops->set_state(dev, state); +#ifdef CONFIG_LED_SW_BLINK + if (!led_driver_supports_hw_blinking(dev)) { + struct cyclic_info *cyclic; + struct led_uc_plat *uc_plat = dev_get_uclass_plat(dev); + + cyclic = led_sw_find_blinking_led(uc_plat->label); + + if (cyclic != NULL) { + if (new_state == LEDST_BLINK) { + struct sw_blink_state *cur_st; + + cur_st = (struct sw_blink_state *)cyclic->ctx; + + /* + * Next call to led_sw_blink will start blinking + */ + cur_st->cur_blink_state = LED_SW_BLINK_ST_OFF; + return 0; + } + + /* + * Changing current blinking state to + * something else + */ + led_sw_free_cyclic(cyclic); + } + } +#endif + + return ops->set_state(dev, new_state); }
enum led_state_t led_get_state(struct udevice *dev) @@ -69,19 +240,31 @@ enum led_state_t led_get_state(struct udevice *dev) if (!ops->get_state) return -ENOSYS;
+#ifdef CONFIG_LED_SW_BLINK + if (!led_driver_supports_hw_blinking(dev) && led_sw_is_blinking(dev)) + return LEDST_BLINK; +#endif + return ops->get_state(dev); }
#ifdef CONFIG_LED_BLINK + int led_set_period(struct udevice *dev, int period_ms) { struct led_ops *ops = led_get_ops(dev);
- if (!ops->set_period) + if (!ops->set_period) { +#ifdef CONFIG_LED_SW_BLINK + return led_sw_set_period(dev, period_ms); +#else return -ENOSYS; +#endif + }
return ops->set_period(dev, period_ms); } + #endif
static int led_post_bind(struct udevice *dev) @@ -113,7 +296,6 @@ static int led_post_bind(struct udevice *dev) * probe() to configure its default state during startup. */ dev_or_flags(dev, DM_FLAG_PROBE_AFTER_BIND); - return 0; }
The standard property
linux,default-trigger = "pattern";
used to get an effect. No blinking parameters can be set yet.
Signed-off-by: Michael Polyntsov michael.polyntsov@iopsys.eu Signed-off-by: Mikhail Kshevetskiy mikhail.kshevetskiy@iopsys.eu --- drivers/led/led-uclass.c | 34 ++++++++++++++++++++++++++++++---- 1 file changed, 30 insertions(+), 4 deletions(-)
diff --git a/drivers/led/led-uclass.c b/drivers/led/led-uclass.c index b35964f2e99..645d0069efe 100644 --- a/drivers/led/led-uclass.c +++ b/drivers/led/led-uclass.c @@ -271,6 +271,9 @@ static int led_post_bind(struct udevice *dev) { struct led_uc_plat *uc_plat = dev_get_uclass_plat(dev); const char *default_state; +#ifdef CONFIG_LED_BLINK + const char *trigger; +#endif
if (!uc_plat->label) uc_plat->label = dev_read_string(dev, "label"); @@ -291,6 +294,13 @@ static int led_post_bind(struct udevice *dev) else return 0;
+#ifdef CONFIG_LED_BLINK + trigger = dev_read_string(dev, "linux,default-trigger"); + if (trigger && !strncmp(trigger, "pattern", 7)) { + uc_plat->default_state = LEDST_BLINK; + } +#endif + /* * In case the LED has default-state DT property, trigger * probe() to configure its default state during startup. @@ -302,12 +312,28 @@ static int led_post_bind(struct udevice *dev) static int led_post_probe(struct udevice *dev) { struct led_uc_plat *uc_plat = dev_get_uclass_plat(dev); + int rc = 0;
- if (uc_plat->default_state == LEDST_ON || - uc_plat->default_state == LEDST_OFF) - led_set_state(dev, uc_plat->default_state); + switch (uc_plat->default_state) { + case LEDST_ON: + case LEDST_OFF: + rc = led_set_state(dev, uc_plat->default_state); + break; +#ifdef CONFIG_LED_BLINK + case LEDST_BLINK: { + const int default_period_ms = 1000;
- return 0; + rc = led_set_period(dev, default_period_ms); + if (rc == 0) + rc = led_set_state(dev, uc_plat->default_state); + break; + } +#endif + default: + break; + } + + return rc; }
UCLASS_DRIVER(led) = {
Hi Mikhail,
On Thu, 27 Jun 2024 at 12:31, Mikhail Kshevetskiy mikhail.kshevetskiy@iopsys.eu wrote:
select CYCLIC
help
Can you talk about the blinking p[eriod / API?
You should not need to #ifdef include files
return cyclic;
return NULL;
if (cyclic) {
return false;
You should not need that cast
break;
break;
* so doing nothing
break;
free(cyclic->ctx);
uc_plat->label);
return -ENOMEM;
I think it would be better to put struct sw_blink_state fields inside uc_plat. After all, it is pretty tiny. We try not to malloc() data for devices.
state->dev = dev;
if (cyclic != NULL)
if (cyclic)
please fix globally
uc_plat->label);
log_err()
free(state);
return -ENOMEM;
if (IS_ENABLED(CONFIG_LED_SW_BLINK))
* something else
return LEDST_BLINK;
This is a bit strange...you are in effect creating a default implementation?
#endif
Unrelated change (we use a blank line before the final return in each function)
-- 2.43.0
On 27.06.2024 22:05, Simon Glass wrote:
Hi Mikhail,
select CYCLIC
help
Could you clarify what do you mean?
will fix
return cyclic;
return NULL;
if (cyclic) {
will fix
return false;
will fix
break;
break;
* so doing nothing
break;
free(cyclic->ctx);
uc_plat->label);
return -ENOMEM;
state->dev = dev;
if (cyclic != NULL)
if (cyclic)
please fix globally
uc_plat->label);
log_err()
free(state);
return -ENOMEM;
* something else
return LEDST_BLINK;
#endif
-- 2.43.0
Hi Mikhail,
On Tue, 2 Jul 2024 at 12:54, Mikhail Kshevetskiy mikhail.kshevetskiy@genexis.eu wrote:
Hi Mikhail,
select CYCLIC
help
I mean can you explain in this help
Hi Simon and all,
This patch series implements: * software led blinking (via cyclic functions) * add support of dts property to specify blinking of the led
v2 changes: * Drop sw_blink_state structure, move its necessary fields to led_uc_plat structure. * Add cyclic_info pointer to led_uc_plat structure. This simplify code a lot. * Remove cyclic function search logic. Not needed anymore. * Fix blinking period. It was twice large. * Other cleanups.
Thanks, Mikhail Kshevetskiy
Signed-off-by: Michael Polyntsov michael.polyntsov@iopsys.eu Signed-off-by: Mikhail Kshevetskiy mikhail.kshevetskiy@iopsys.eu --- drivers/led/Kconfig | 14 ++++++ drivers/led/led-uclass.c | 102 +++++++++++++++++++++++++++++++++++++++ include/led.h | 12 +++++ 3 files changed, 128 insertions(+)
diff --git a/drivers/led/Kconfig b/drivers/led/Kconfig index 9837960198d..1afb081df11 100644 --- a/drivers/led/Kconfig +++ b/drivers/led/Kconfig @@ -73,6 +73,20 @@ config LED_BLINK This option enables support for this which adds slightly to the code size.
+config LED_SW_BLINK + bool "Support software LED blinking" + depends on LED_BLINK + select CYCLIC + help + Turns on led blinking implemented in the software, useful when + the hardware doesn't support led blinking. Half of the period + led will be ON and the rest time it will be OFF. Standard + led commands can be used to configure blinking. Does nothing + if driver supports blinking. + WARNING: Blinking may be inaccurate during execution of time + consuming commands (ex. flash reading). Also it will completely + stops during OS booting. + config SPL_LED bool "Enable LED support in SPL" depends on SPL_DM diff --git a/drivers/led/led-uclass.c b/drivers/led/led-uclass.c index a4be56fc258..d021c3bbf20 100644 --- a/drivers/led/led-uclass.c +++ b/drivers/led/led-uclass.c @@ -52,6 +52,94 @@ int led_get_by_label(const char *label, struct udevice **devp) return -ENODEV; }
+#ifdef CONFIG_LED_SW_BLINK +static void led_sw_blink(void *data) +{ + struct udevice *dev = data; + struct led_uc_plat *uc_plat = dev_get_uclass_plat(dev); + struct led_ops *ops = led_get_ops(dev); + + switch (uc_plat->sw_blink_state) { + case LED_SW_BLINK_ST_OFF: + uc_plat->sw_blink_state = LED_SW_BLINK_ST_ON; + ops->set_state(dev, LEDST_ON); + break; + case LED_SW_BLINK_ST_ON: + uc_plat->sw_blink_state = LED_SW_BLINK_ST_OFF; + ops->set_state(dev, LEDST_OFF); + break; + case LED_SW_BLINK_ST_NONE: + /* + * led_set_period has been called, but + * led_set_state(LDST_BLINK) has not yet, + * so doing nothing + */ + break; + } +} + +static int led_sw_set_period(struct udevice *dev, int period_ms) +{ + struct led_uc_plat *uc_plat = dev_get_uclass_plat(dev); + struct cyclic_info *cyclic = uc_plat->cyclic; + struct led_ops *ops = led_get_ops(dev); + char cyclic_name[64]; + int half_period_us; + + uc_plat->sw_blink_state = LED_SW_BLINK_ST_NONE; + ops->set_state(dev, LEDST_OFF); + + half_period_us = period_ms * 1000 / 2; + + if (cyclic) { + cyclic->delay_us = half_period_us; + cyclic->start_time_us = timer_get_us(); + } else { + snprintf(cyclic_name, sizeof(cyclic_name), + "led_sw_blink_%s", uc_plat->label); + + cyclic = cyclic_register(led_sw_blink, half_period_us, + cyclic_name, dev); + if (!cyclic) { + log_err("Registering of blinking function for %s failed\n", + uc_plat->label); + return -ENOMEM; + } + + uc_plat->cyclic = cyclic; + } + + return 0; +} + +static bool led_sw_is_blinking(struct udevice *dev) +{ + struct led_uc_plat *uc_plat = dev_get_uclass_plat(dev); + + return (uc_plat->sw_blink_state != LED_SW_BLINK_ST_NONE); +} + +static bool led_sw_on_state_change(struct udevice *dev, enum led_state_t state) +{ + struct led_uc_plat *uc_plat = dev_get_uclass_plat(dev); + + if (uc_plat->cyclic) { + if (state == LEDST_BLINK) { + /* start blinking on next led_sw_blink() call */ + uc_plat->sw_blink_state = LED_SW_BLINK_ST_OFF; + return true; + } + + /* stop blinking */ + cyclic_unregister(uc_plat->cyclic); + uc_plat->cyclic = NULL; + uc_plat->sw_blink_state = LED_SW_BLINK_ST_NONE; + } + + return false; +} +#endif /* CONFIG_LED_SW_BLINK */ + int led_set_state(struct udevice *dev, enum led_state_t state) { struct led_ops *ops = led_get_ops(dev); @@ -59,6 +147,11 @@ int led_set_state(struct udevice *dev, enum led_state_t state) if (!ops->set_state) return -ENOSYS;
+#ifdef CONFIG_LED_SW_BLINK + if (led_sw_on_state_change(dev, state)) + return 0; +#endif + return ops->set_state(dev, state); }
@@ -69,6 +162,11 @@ enum led_state_t led_get_state(struct udevice *dev) if (!ops->get_state) return -ENOSYS;
+#ifdef CONFIG_LED_SW_BLINK + if (led_sw_is_blinking(dev)) + return LEDST_BLINK; +#endif + return ops->get_state(dev); }
@@ -78,7 +176,11 @@ int led_set_period(struct udevice *dev, int period_ms) struct led_ops *ops = led_get_ops(dev);
if (!ops->set_period) +#ifdef CONFIG_LED_SW_BLINK + return led_sw_set_period(dev, period_ms); +#else return -ENOSYS; +#endif
return ops->set_period(dev, period_ms); } diff --git a/include/led.h b/include/led.h index a6353166289..bd50fdf33ef 100644 --- a/include/led.h +++ b/include/led.h @@ -20,6 +20,14 @@ enum led_state_t { LEDST_COUNT, };
+#ifdef CONFIG_LED_SW_BLINK +enum led_sw_blink_state_t { + LED_SW_BLINK_ST_NONE = 0, + LED_SW_BLINK_ST_OFF = 1, + LED_SW_BLINK_ST_ON = 2, +}; +#endif + /** * struct led_uc_plat - Platform data the uclass stores about each device * @@ -29,6 +37,10 @@ enum led_state_t { struct led_uc_plat { const char *label; enum led_state_t default_state; +#ifdef CONFIG_LED_SW_BLINK + enum led_sw_blink_state_t sw_blink_state; + struct cyclic_info *cyclic; +#endif };
Hi Mikhail,
On Wed, 3 Jul 2024 at 02:02, Mikhail Kshevetskiy mikhail.kshevetskiy@iopsys.eu wrote:
v2 changes:
- Drop sw_blink_state structure, move its necessary fields to led_uc_plat structure.
- Add cyclic_info pointer to led_uc_plat structure. This simplify code a lot.
- Remove cyclic function search logic. Not needed anymore.
- Fix blinking period. It was twice large.
- Other cleanups.
LGTM except for the #ifdefs...I've put an idea below.
select CYCLIC
help
Drop the word 'will'
You can put this block into a separate file, like led_blink.c and export the functions, since it accesses members which are behind an #ifdef
obj-$(CONFIG_LED_SW_BLINK) += led_blink.o
break;
break;
* so doing nothing
break;
int half_period_us;
if (cyclic) {
} else {
cyclic_name, dev);
if (!cyclic) {
uc_plat->label);
return -ENOMEM;
return true;
/* stop blinking */
return false;
Then these #ifdefs should be able to change to
if (IS_ENABLED(CONFIG_LED_SW_BLINK) && led_sw_on_state_change(dev, state)) ...
I suppose static inlines are another way if you prefer, but as there is only one caller it probably isn't worth it.
return LEDST_BLINK;
can drop this #ifdef
+}; +#endif
- struct led_uc_plat - Platform data the uclass stores about each device
+#endif };
Need to add function prototypes here for flashing API.
2.39.2
Mikhail Kshevetskiy mikhail.kshevetskiy@iopsys.eu writes:
- struct led_uc_plat *uc_plat = dev_get_uclass_plat(dev);
- struct cyclic_info *cyclic = uc_plat->cyclic;
- struct led_ops *ops = led_get_ops(dev);
- char cyclic_name[64];
- int half_period_us;
- uc_plat->sw_blink_state = LED_SW_BLINK_ST_NONE;
- ops->set_state(dev, LEDST_OFF);
- half_period_us = period_ms * 1000 / 2;
- if (cyclic) {
- } else {
cyclic_name, dev);
if (!cyclic) {
uc_plat->label);
return -ENOMEM;
You need to be aware of the API change that is by now in master, see https://lore.kernel.org/u-boot/20240521084652.1726460-1-rasmus.villemoes@pre... and in particular commits 3a11eada38e and 008c4b3c3115. The latter you'll find soon enough because this won't build.
The former is a bit more subtle and would silently break here (as passing an auto array is no longer allowed) - consider whether you really need the led_sw_blink_ to be part of the name, or if uc_plat->label itself isn't descriptive enough.
Rasmus
diff --git a/drivers/led/led-uclass.c b/drivers/led/led-uclass.c index d021c3bbf20..78d1a3d152b 100644 --- a/drivers/led/led-uclass.c +++ b/drivers/led/led-uclass.c @@ -190,6 +190,9 @@ static int led_post_bind(struct udevice *dev) { struct led_uc_plat *uc_plat = dev_get_uclass_plat(dev); const char *default_state; +#ifdef CONFIG_LED_BLINK + const char *trigger; +#endif
if (!uc_plat->label) uc_plat->label = dev_read_string(dev, "label"); @@ -210,6 +213,13 @@ static int led_post_bind(struct udevice *dev) else return 0;
+#ifdef CONFIG_LED_BLINK + trigger = dev_read_string(dev, "linux,default-trigger"); + if (trigger && !strncmp(trigger, "pattern", 7)) { + uc_plat->default_state = LEDST_BLINK; + } +#endif + /* * In case the LED has default-state DT property, trigger * probe() to configure its default state during startup. @@ -222,12 +232,28 @@ static int led_post_bind(struct udevice *dev) static int led_post_probe(struct udevice *dev) { struct led_uc_plat *uc_plat = dev_get_uclass_plat(dev); + int rc = 0;
Hi Mikhail,
It looks like this is not used, so you can drop it and use a local variable here?
if (IS_ENABLED(CONFIG_LED_BLINK)
No {} around single lines. You can use patman to send patches and it will check this for you (I hope!).
int rc = 0;
case LEDST_ON:
case LEDST_OFF:
break;
case LEDST_BLINK: {
Here again you can use if IS_ENABLED(CONFIG_LED_BLINK) inside the case which should produce very similar code size, hopefully the same.
if (rc == 0)
break;
default:
break;
return rc;
2.39.2
On 7/3/24 12:08, Simon Glass wrote:
Hi Mikhail,
Unfortunately no, see below.
This is not so easy. The definition of LEDST_BLINK depends on CONFIG_LED_BLINK, thus this code will not compile if CONFIG_LED_BLINK is not defined. We can define LEDST_BLINK unconditionally, but it will cause an issue in the cmd/led.c.
int rc = 0;
case LEDST_ON:
case LEDST_OFF:
break;
case LEDST_BLINK: {
Do you suggest an if inside the handling of "default:" case? Also see above notes about dependency of LEDST_BLINK on CONFIG_LED_BLINK.
if (rc == 0)
break;
default:
break;
return rc;
2.39.2
As one of those "well, hunh" kind of moment, I'm cc'ing Christian Marangi who also just posted patches foor this kind of functionality.
Eh... Well this implementation is better. I had the idea of adding support on the uclass level but I preferred to limit it only to GPIO.
Think this would match how it's done in upstream linux kernel so I think mine should be ignored and this taken (for sw blink).
Should not change a thing for the series since all the bits were using generic LED functions.
participants (6)
Christian Marangi
Mikhail Kshevetskiy
Mikhail Kshevetskiy
Rasmus Villemoes
