[U-Boot] [PATCH v3 0/4] Marvell DB-XC3-24G4XG board support
This series adds support for Marvell's Switches with integrated CPUs and the DB-XC3-24G4XG board. The CPU side is similar to the Armada range.
For now the DDR training code needs to come from the Marvell bin_hdr. It's one area where the integrated SoCs differ from the Armada range so neither the Armada-XP nor Armada-38x training code will work as-is. I'm asking Marvell about the possibility of re-licensing the code under a Proprietary/BSD/GPL as they did with Armada-38x.
I also have access to a DB-DXBC2-MM board with a different chip. I'll look at adding support for that as well at some point. It's harder to work with because it has no USB, but other than that it's similar to the DB-XC3.
Changes in v3: - use the filename binary.0 to determine if the destaddr needs to match execaddr. - Adjust path to binary.0 in kwbimage.cfg to handle external build output directories.
Changes in v2: - use CONFIG_ARMADA_MSYS instead of just CONFIG_MSYS - Disable MBUS Error proagation - new, split out from Add DB-XC3-24G4XG board with a better explanation - u-boot specific changes in u-boot.dtsi - remove unnecessary entries from board config.h - move some changes to earlier patches
Chris Packham (4): arm: mvebu: Add Marvell's integrated CPUs arm: mvebu: NAND clock support for MSYS devices tools: kwbimage: don't adjust for image_header for Armada MSYS arm: mvebu: Add DB-XC3-24G4XG board
arch/arm/dts/Makefile | 3 +- arch/arm/dts/armada-xp-98dx3236.dtsi | 343 ++++++++++++++++++ arch/arm/dts/armada-xp-98dx3336.dtsi | 39 ++ arch/arm/dts/armada-xp-98dx4251.dtsi | 54 +++ .../dts/armada-xp-db-xc3-24g4xg-u-boot.dtsi | 24 ++ arch/arm/dts/armada-xp-db-xc3-24g4xg.dts | 110 ++++++ arch/arm/mach-mvebu/Kconfig | 26 +- arch/arm/mach-mvebu/Makefile | 1 + arch/arm/mach-mvebu/cpu.c | 33 +- arch/arm/mach-mvebu/include/mach/config.h | 2 +- arch/arm/mach-mvebu/include/mach/cpu.h | 3 + arch/arm/mach-mvebu/include/mach/soc.h | 31 ++ arch/arm/mach-mvebu/mbus.c | 5 + board/Marvell/db-xc3-24g4xg/.gitignore | 1 + board/Marvell/db-xc3-24g4xg/MAINTAINERS | 7 + board/Marvell/db-xc3-24g4xg/Makefile | 14 + board/Marvell/db-xc3-24g4xg/README | 4 + board/Marvell/db-xc3-24g4xg/binary.0 | 11 + board/Marvell/db-xc3-24g4xg/db-xc3-24g4xg.c | 68 ++++ board/Marvell/db-xc3-24g4xg/kwbimage.cfg.in | 12 + configs/db-xc3-24g4xg_defconfig | 55 +++ drivers/ddr/marvell/axp/xor_regs.h | 4 + include/configs/db-xc3-24g4xg.h | 41 +++ tools/kwbimage.c | 7 + 24 files changed, 893 insertions(+), 5 deletions(-) create mode 100644 arch/arm/dts/armada-xp-98dx3236.dtsi create mode 100644 arch/arm/dts/armada-xp-98dx3336.dtsi create mode 100644 arch/arm/dts/armada-xp-98dx4251.dtsi create mode 100644 arch/arm/dts/armada-xp-db-xc3-24g4xg-u-boot.dtsi create mode 100644 arch/arm/dts/armada-xp-db-xc3-24g4xg.dts create mode 100644 board/Marvell/db-xc3-24g4xg/.gitignore create mode 100644 board/Marvell/db-xc3-24g4xg/MAINTAINERS create mode 100644 board/Marvell/db-xc3-24g4xg/Makefile create mode 100644 board/Marvell/db-xc3-24g4xg/README create mode 100644 board/Marvell/db-xc3-24g4xg/binary.0 create mode 100644 board/Marvell/db-xc3-24g4xg/db-xc3-24g4xg.c create mode 100644 board/Marvell/db-xc3-24g4xg/kwbimage.cfg.in create mode 100644 configs/db-xc3-24g4xg_defconfig create mode 100644 include/configs/db-xc3-24g4xg.h
Marvell's switch chips with integrated CPUs (collectively referred to as MSYS) share common ancestry with the Armada SoCs. Some of the IP blocks (e.g. xor) are located at different addresses and DFX server exists as a separate target on the MBUS (on Armada-38x it's just part of the core complex registers).
Signed-off-by: Chris Packham judge.packham@gmail.com ---
Changes in v3: None Changes in v2: - use CONFIG_ARMADA_MSYS instead of just CONFIG_MSYS - Disable MBUS Error proagation
arch/arm/mach-mvebu/Kconfig | 18 ++++++++++++- arch/arm/mach-mvebu/Makefile | 1 + arch/arm/mach-mvebu/cpu.c | 31 +++++++++++++++++++++-- arch/arm/mach-mvebu/include/mach/config.h | 2 +- arch/arm/mach-mvebu/include/mach/cpu.h | 3 +++ arch/arm/mach-mvebu/include/mach/soc.h | 20 +++++++++++++++ arch/arm/mach-mvebu/mbus.c | 5 ++++ drivers/ddr/marvell/axp/xor_regs.h | 4 +++ 8 files changed, 80 insertions(+), 4 deletions(-)
diff --git a/arch/arm/mach-mvebu/Kconfig b/arch/arm/mach-mvebu/Kconfig index 7dda04e0e34e..08c9972f02d7 100644 --- a/arch/arm/mach-mvebu/Kconfig +++ b/arch/arm/mach-mvebu/Kconfig @@ -46,7 +46,7 @@ config ARMADA_8K # Armada PLL frequency (used for NAND clock generation) config SYS_MVEBU_PLL_CLOCK int - default "2000000000" if ARMADA_XP || ARMADA_3700 || ARMADA_8K + default "2000000000" if ARMADA_XP || ARMADA_3700 || ARMADA_8K || ARMADA_MSYS default "1000000000" if ARMADA_38X || ARMADA_375
# Armada XP/38x SoC types... @@ -63,6 +63,22 @@ config MV78460 bool select ARMADA_XP
+config ARMADA_MSYS + bool + select ARMADA_32BIT + +config 98DX4251 + bool + select ARMADA_MSYS + +config 98DX3336 + bool + select ARMADA_MSYS + +config 98DX3236 + bool + select ARMADA_MSYS + config 88F6820 bool select ARMADA_38X diff --git a/arch/arm/mach-mvebu/Makefile b/arch/arm/mach-mvebu/Makefile index ee2eca913484..2ab7b3c8417e 100644 --- a/arch/arm/mach-mvebu/Makefile +++ b/arch/arm/mach-mvebu/Makefile @@ -24,6 +24,7 @@ ifndef CONFIG_SPL_BUILD obj-$(CONFIG_ARMADA_375) += ../../../drivers/ddr/marvell/axp/xor.o obj-$(CONFIG_ARMADA_38X) += ../../../drivers/ddr/marvell/a38x/xor.o obj-$(CONFIG_ARMADA_XP) += ../../../drivers/ddr/marvell/axp/xor.o +obj-$(CONFIG_ARMADA_MSYS) += ../../../drivers/ddr/marvell/axp/xor.o obj-$(CONFIG_MVEBU_EFUSE) += efuse.o
extra-y += kwbimage.cfg diff --git a/arch/arm/mach-mvebu/cpu.c b/arch/arm/mach-mvebu/cpu.c index 919d05c88c77..61b222a21070 100644 --- a/arch/arm/mach-mvebu/cpu.c +++ b/arch/arm/mach-mvebu/cpu.c @@ -23,6 +23,11 @@ static struct mbus_win windows[] = { /* NOR */ { MBUS_BOOTROM_BASE, MBUS_BOOTROM_SIZE, CPU_TARGET_DEVICEBUS_BOOTROM_SPI, CPU_ATTR_BOOTROM }, + +#ifdef CONFIG_ARMADA_MSYS + /* DFX */ + { MBUS_DFX_BASE, MBUS_DFX_SIZE, CPU_TARGET_DFX, 0 }, +#endif };
void lowlevel_init(void) @@ -121,6 +126,14 @@ static const struct sar_freq_modes sar_freq_tab[] = { { 0x13, 0x0, 2000, 1000, 933 }, { 0xff, 0xff, 0, 0, 0 } /* 0xff marks end of array */ }; +#elif defined(CONFIG_ARMADA_MSYS) +static const struct sar_freq_modes sar_freq_tab[] = { + { 0x0, 0x0, 400, 400, 400 }, + { 0x2, 0x0, 667, 333, 667 }, + { 0x3, 0x0, 800, 400, 800 }, + { 0x5, 0x0, 800, 400, 800 }, + { 0xff, 0xff, 0, 0, 0 } /* 0xff marks end of array */ +}; #else /* SAR frequency values for Armada XP */ static const struct sar_freq_modes sar_freq_tab[] = { @@ -144,7 +157,7 @@ void get_sar_freq(struct sar_freq_modes *sar_freq) u32 freq; int i;
-#if defined(CONFIG_ARMADA_375) +#if defined(CONFIG_ARMADA_375) || defined(CONFIG_ARMADA_MSYS) val = readl(CONFIG_SAR2_REG); /* SAR - Sample At Reset */ #else val = readl(CONFIG_SAR_REG); /* SAR - Sample At Reset */ @@ -160,7 +173,7 @@ void get_sar_freq(struct sar_freq_modes *sar_freq) #endif for (i = 0; sar_freq_tab[i].val != 0xff; i++) { if (sar_freq_tab[i].val == freq) { -#if defined(CONFIG_ARMADA_375) || defined(CONFIG_ARMADA_38X) +#if defined(CONFIG_ARMADA_375) || defined(CONFIG_ARMADA_38X) || defined(CONFIG_ARMADA_MSYS) *sar_freq = sar_freq_tab[i]; return; #else @@ -270,6 +283,20 @@ int print_cpuinfo(void) } }
+ if (mvebu_soc_family() == MVEBU_SOC_MSYS) { + switch (revid) { + case 3: + puts("A0"); + break; + case 4: + puts("A1"); + break; + default: + printf("?? (%x)", revid); + break; + } + } + get_sar_freq(&sar_freq); printf(" at %d MHz\n", sar_freq.p_clk);
diff --git a/arch/arm/mach-mvebu/include/mach/config.h b/arch/arm/mach-mvebu/include/mach/config.h index 71c4f70efc9e..bbcfcfd1419b 100644 --- a/arch/arm/mach-mvebu/include/mach/config.h +++ b/arch/arm/mach-mvebu/include/mach/config.h @@ -17,7 +17,7 @@ #include <asm/arch/soc.h>
#if defined(CONFIG_ARMADA_XP) || defined(CONFIG_ARMADA_375) \ - || defined(CONFIG_ARMADA_38X) + || defined(CONFIG_ARMADA_38X) || defined(CONFIG_ARMADA_MSYS) /* * Set this for the common xor register definitions needed in dram.c * for A38x as well here. diff --git a/arch/arm/mach-mvebu/include/mach/cpu.h b/arch/arm/mach-mvebu/include/mach/cpu.h index 9e23043a4857..b9153d86c669 100644 --- a/arch/arm/mach-mvebu/include/mach/cpu.h +++ b/arch/arm/mach-mvebu/include/mach/cpu.h @@ -34,6 +34,7 @@ enum cpu_target { CPU_TARGET_PCIE02 = 0x4, CPU_TARGET_ETH01 = 0x7, CPU_TARGET_PCIE13 = 0x8, + CPU_TARGET_DFX = 0x8, CPU_TARGET_SASRAM = 0x9, CPU_TARGET_SATA01 = 0xa, /* A38X */ CPU_TARGET_NAND = 0xd, @@ -79,6 +80,8 @@ enum { #define MBUS_PCI_IO_SIZE (64 << 10) #define MBUS_SPI_BASE 0xF4000000 #define MBUS_SPI_SIZE (8 << 20) +#define MBUS_DFX_BASE 0xF6000000 +#define MBUS_DFX_SIZE (1 << 20) #define MBUS_BOOTROM_BASE 0xF8000000 #define MBUS_BOOTROM_SIZE (8 << 20)
diff --git a/arch/arm/mach-mvebu/include/mach/soc.h b/arch/arm/mach-mvebu/include/mach/soc.h index 01577f469b0e..2d88c410b88c 100644 --- a/arch/arm/mach-mvebu/include/mach/soc.h +++ b/arch/arm/mach-mvebu/include/mach/soc.h @@ -76,7 +76,11 @@ #define MVEBU_NAND_BASE (MVEBU_REGISTER(0xd0000)) #define MVEBU_SDIO_BASE (MVEBU_REGISTER(0xd8000)) #define MVEBU_LCD_BASE (MVEBU_REGISTER(0xe0000)) +#ifdef CONFIG_ARMADA_MSYS +#define MVEBU_DFX_BASE (MBUS_DFX_BASE) +#else #define MVEBU_DFX_BASE (MVEBU_REGISTER(0xe4000)) +#endif
#define SOC_COHERENCY_FABRIC_CTRL_REG (MVEBU_REGISTER(0x20200)) #define MBUS_ERR_PROP_EN (1 << 8) @@ -149,6 +153,22 @@ #define BOOT_FROM_SPI 0x32 #define BOOT_FROM_MMC 0x30 #define BOOT_FROM_MMC_ALT 0x31 +#elif defined(CONFIG_ARMADA_MSYS) +/* SAR values for MSYS */ +#define CONFIG_SAR_REG (MBUS_DFX_BASE + 0xf8200) +#define CONFIG_SAR2_REG (MBUS_DFX_BASE + 0xf8204) + +#define SAR_CPU_FREQ_OFFS 18 +#define SAR_CPU_FREQ_MASK (0x7 << SAR_CPU_FREQ_OFFS) +#define SAR_BOOT_DEVICE_OFFS 11 +#define SAR_BOOT_DEVICE_MASK (0x7 << SAR_BOOT_DEVICE_OFFS) + +#define BOOT_DEV_SEL_OFFS 11 +#define BOOT_DEV_SEL_MASK (0x7 << BOOT_DEV_SEL_OFFS) + +#define BOOT_FROM_NAND 0x1 +#define BOOT_FROM_UART 0x2 +#define BOOT_FROM_SPI 0x3 #else /* SAR values for Armada XP */ #define CONFIG_SAR_REG (MVEBU_REGISTER(0x18230)) diff --git a/arch/arm/mach-mvebu/mbus.c b/arch/arm/mach-mvebu/mbus.c index df4c5cb2d718..3a869e09d3ba 100644 --- a/arch/arm/mach-mvebu/mbus.c +++ b/arch/arm/mach-mvebu/mbus.c @@ -344,6 +344,11 @@ static void mvebu_mbus_default_setup_cpu_target(struct mvebu_mbus_state *mbus) } } mbus_dram_info.num_cs = cs; + +#if defined(CONFIG_ARMADA_MSYS) + /* Disable MBUS Err Prop - in order to avoid data aborts */ + clrbits_le32(mbus->mbuswins_base + 0x200, BIT(8)); +#endif }
static const struct mvebu_mbus_soc_data diff --git a/drivers/ddr/marvell/axp/xor_regs.h b/drivers/ddr/marvell/axp/xor_regs.h index db5c41967393..d779e564189a 100644 --- a/drivers/ddr/marvell/axp/xor_regs.h +++ b/drivers/ddr/marvell/axp/xor_regs.h @@ -13,7 +13,11 @@ #define XOR_UNIT(chan) ((chan) >> 1) #define XOR_CHAN(chan) ((chan) & 1)
+#ifdef CONFIG_ARMADA_MSYS +#define MV_XOR_REGS_OFFSET(unit) (0xF0800) +#else #define MV_XOR_REGS_OFFSET(unit) (0x60900) +#endif #define MV_XOR_REGS_BASE(unit) (MV_XOR_REGS_OFFSET(unit))
/* XOR Engine Control Register Map */
Thanks, Stefan
Applied to u-boot-marvell/master.
Thanks, Stefan
One difference with the integrated CPUs is that they use a different clock control block to the Armada devices. Update mvebu_get_nand_clock() accordingly.
Signed-off-by: Chris Packham judge.packham@gmail.com --- This could probably be squashed into the previous change. I was trying to separate things to aid review but it's hard to do so and keep bisectability.
arch/arm/mach-mvebu/cpu.c | 2 ++ arch/arm/mach-mvebu/include/mach/soc.h | 11 +++++++++++ 2 files changed, 13 insertions(+)
diff --git a/arch/arm/mach-mvebu/cpu.c b/arch/arm/mach-mvebu/cpu.c index 61b222a21070..5609ee2f9a3b 100644 --- a/arch/arm/mach-mvebu/cpu.c +++ b/arch/arm/mach-mvebu/cpu.c @@ -499,6 +499,8 @@ u32 mvebu_get_nand_clock(void)
if (mvebu_soc_family() == MVEBU_SOC_A38X) reg = MVEBU_DFX_DIV_CLK_CTRL(1); + else if (mvebu_soc_family() == MVEBU_SOC_MSYS) + reg = MVEBU_DFX_DIV_CLK_CTRL(8); else reg = MVEBU_CORE_DIV_CLK_CTRL(1);
diff --git a/arch/arm/mach-mvebu/include/mach/soc.h b/arch/arm/mach-mvebu/include/mach/soc.h index 2d88c410b88c..f666ee24243b 100644 --- a/arch/arm/mach-mvebu/include/mach/soc.h +++ b/arch/arm/mach-mvebu/include/mach/soc.h @@ -100,9 +100,20 @@ #define SPI_PUP_EN BIT(5)
#define MVEBU_CORE_DIV_CLK_CTRL(i) (MVEBU_CLOCK_BASE + ((i) * 0x8)) +#ifdef CONFIG_ARMADA_MSYS +#define MVEBU_DFX_DIV_CLK_CTRL(i) (MVEBU_DFX_BASE + 0xf8000 + 0x250 + ((i) * 0x4)) +#define NAND_ECC_DIVCKL_RATIO_OFFS 6 +#define NAND_ECC_DIVCKL_RATIO_MASK (0xF << NAND_ECC_DIVCKL_RATIO_OFFS) +#else #define MVEBU_DFX_DIV_CLK_CTRL(i) (MVEBU_DFX_BASE + 0x250 + ((i) * 0x4)) +#endif +#ifdef CONFIG_ARMADA_MSYS +#define NAND_ECC_DIVCKL_RATIO_OFFS 6 +#define NAND_ECC_DIVCKL_RATIO_MASK (0xF << NAND_ECC_DIVCKL_RATIO_OFFS) +#else #define NAND_ECC_DIVCKL_RATIO_OFFS 8 #define NAND_ECC_DIVCKL_RATIO_MASK (0x3F << NAND_ECC_DIVCKL_RATIO_OFFS) +#endif
#define SDRAM_MAX_CS 4 #define SDRAM_ADDR_MASK 0xFF000000
Thanks, Stefan
Thanks, Stefan
For the time being the Armada MSYS SoCs need to use the bin_hdr from the Marvell U-Boot. Because of this the binary.0 does not contain the image header that a proper u-boot SPL would so the adjustment introduced by commit 94084eea3bd3 ("tools: kwbimage: Fix dest addr") does not apply.
Changes in v2: - new, split out from Add DB-XC3-24G4XG board with a better explanation
tools/kwbimage.c | 7 +++++++ 1 file changed, 7 insertions(+)
diff --git a/tools/kwbimage.c b/tools/kwbimage.c index a88a3830c0c8..dffaf9043a04 100644 --- a/tools/kwbimage.c +++ b/tools/kwbimage.c @@ -1273,6 +1273,13 @@ static void *image_create_v1(size_t *imagesz, struct image_tool_params *params, e = image_find_option(IMAGE_CFG_DEBUG); if (e) main_hdr->flags = e->debug ? 0x1 : 0; + e = image_find_option(IMAGE_CFG_BINARY); + if (e) { + char *s = strrchr(e->binary.file, '/'); + + if (strcmp(s, "/binary.0") == 0) + main_hdr->destaddr = cpu_to_le32(params->addr); + }
#if defined(CONFIG_KWB_SECURE) if (image_get_csk_index() >= 0) {
Changes in v3:
Changes in v2:
Thanks, Stefan
Changes in v3:
Changes in v2:
Thanks, Stefan
From: Chris Packham chris.packham@alliedtelesis.co.nz
The DB-XC3-24G4XG is a switch development board from Marvell. It can either use and external CPU card such as the db-88f6820-amc or the internal CPU that is integrated into the switch.
Add support for running U-Boot on the internal CPU and enable the USB, SPI and NAND peripherals. For now this needs the bin_hdr from the Marvell U-Boot for this board.
Changes in v3: - Adjust path to binary.0 in kwbimage.cfg to handle external build output directories.
Changes in v2: - u-boot specific changes in u-boot.dtsi - remove unnecessary entries from board config.h - move some changes to earlier patches
arch/arm/dts/Makefile | 3 +- arch/arm/dts/armada-xp-98dx3236.dtsi | 343 ++++++++++++++++++ arch/arm/dts/armada-xp-98dx3336.dtsi | 39 ++ arch/arm/dts/armada-xp-98dx4251.dtsi | 54 +++ .../dts/armada-xp-db-xc3-24g4xg-u-boot.dtsi | 24 ++ arch/arm/dts/armada-xp-db-xc3-24g4xg.dts | 110 ++++++ arch/arm/mach-mvebu/Kconfig | 8 + board/Marvell/db-xc3-24g4xg/.gitignore | 1 + board/Marvell/db-xc3-24g4xg/MAINTAINERS | 7 + board/Marvell/db-xc3-24g4xg/Makefile | 14 + board/Marvell/db-xc3-24g4xg/README | 4 + board/Marvell/db-xc3-24g4xg/binary.0 | 11 + board/Marvell/db-xc3-24g4xg/db-xc3-24g4xg.c | 68 ++++ board/Marvell/db-xc3-24g4xg/kwbimage.cfg.in | 12 + configs/db-xc3-24g4xg_defconfig | 55 +++ include/configs/db-xc3-24g4xg.h | 41 +++ 16 files changed, 793 insertions(+), 1 deletion(-) create mode 100644 arch/arm/dts/armada-xp-98dx3236.dtsi create mode 100644 arch/arm/dts/armada-xp-98dx3336.dtsi create mode 100644 arch/arm/dts/armada-xp-98dx4251.dtsi create mode 100644 arch/arm/dts/armada-xp-db-xc3-24g4xg-u-boot.dtsi create mode 100644 arch/arm/dts/armada-xp-db-xc3-24g4xg.dts create mode 100644 board/Marvell/db-xc3-24g4xg/.gitignore create mode 100644 board/Marvell/db-xc3-24g4xg/MAINTAINERS create mode 100644 board/Marvell/db-xc3-24g4xg/Makefile create mode 100644 board/Marvell/db-xc3-24g4xg/README create mode 100644 board/Marvell/db-xc3-24g4xg/binary.0 create mode 100644 board/Marvell/db-xc3-24g4xg/db-xc3-24g4xg.c create mode 100644 board/Marvell/db-xc3-24g4xg/kwbimage.cfg.in create mode 100644 configs/db-xc3-24g4xg_defconfig create mode 100644 include/configs/db-xc3-24g4xg.h
diff --git a/arch/arm/dts/Makefile b/arch/arm/dts/Makefile index 930b7e03db04..1429672a8b6c 100644 --- a/arch/arm/dts/Makefile +++ b/arch/arm/dts/Makefile @@ -151,7 +151,8 @@ dtb-$(CONFIG_ARCH_MVEBU) += \ armada-xp-theadorable.dtb \ armada-38x-controlcenterdc.dtb \ armada-385-atl-x530.dtb \ - armada-385-atl-x530DP.dtb + armada-385-atl-x530DP.dtb \ + armada-xp-db-xc3-24g4xg.dtb
dtb-$(CONFIG_ARCH_UNIPHIER_LD11) += \ uniphier-ld11-global.dtb \ diff --git a/arch/arm/dts/armada-xp-98dx3236.dtsi b/arch/arm/dts/armada-xp-98dx3236.dtsi new file mode 100644 index 000000000000..5df1d1848dbc --- /dev/null +++ b/arch/arm/dts/armada-xp-98dx3236.dtsi @@ -0,0 +1,343 @@ +// SPDX-License-Identifier: (GPL-2.0+ OR MIT) +/* + * Device Tree Include file for Marvell 98dx3236 family SoC + * + * Copyright (C) 2016 Allied Telesis Labs + * + * Contains definitions specific to the 98dx3236 SoC that are not + * common to all Armada XP SoCs. + */ + +#include "armada-370-xp.dtsi" + +/ { + #address-cells = <2>; + #size-cells = <2>; + + model = "Marvell 98DX3236 SoC"; + compatible = "marvell,armadaxp-98dx3236", "marvell,armada-370-xp"; + + aliases { + gpio0 = &gpio0; + gpio1 = &gpio1; + gpio2 = &gpio2; + }; + + cpus { + #address-cells = <1>; + #size-cells = <0>; + enable-method = "marvell,98dx3236-smp"; + + cpu@0 { + device_type = "cpu"; + compatible = "marvell,sheeva-v7"; + reg = <0>; + clocks = <&cpuclk 0>; + clock-latency = <1000000>; + }; + }; + + soc { + compatible = "marvell,armadaxp-mbus", "simple-bus"; + + ranges = <MBUS_ID(0xf0, 0x01) 0 0 0xf1000000 0x100000 + MBUS_ID(0x01, 0x1d) 0 0 0xfff00000 0x100000 + MBUS_ID(0x01, 0x2f) 0 0 0xf0000000 0x1000000 + MBUS_ID(0x03, 0x00) 0 0 0xa8000000 0x4000000 + MBUS_ID(0x08, 0x00) 0 0 0xac000000 0x100000>; + + bootrom { + compatible = "marvell,bootrom"; + reg = <MBUS_ID(0x01, 0x1d) 0 0x100000>; + }; + + /* + * 98DX3236 has 1 x1 PCIe unit Gen2.0 + */ + pciec: pcie@82000000 { + compatible = "marvell,armada-xp-pcie"; + status = "disabled"; + device_type = "pci"; + + #address-cells = <3>; + #size-cells = <2>; + + msi-parent = <&mpic>; + bus-range = <0x00 0xff>; + + ranges = + <0x82000000 0 0x40000 MBUS_ID(0xf0, 0x01) 0x40000 0 0x00002000 /* Port 0.0 registers */ + 0x82000000 0x1 0 MBUS_ID(0x04, 0xe8) 0 1 0 /* Port 0.0 MEM */ + 0x81000000 0x1 0 MBUS_ID(0x04, 0xe0) 0 1 0 /* Port 0.0 IO */>; + + pcie1: pcie@1,0 { + device_type = "pci"; + assigned-addresses = <0x82000800 0 0x40000 0 0x2000>; + reg = <0x0800 0 0 0 0>; + #address-cells = <3>; + #size-cells = <2>; + #interrupt-cells = <1>; + ranges = <0x82000000 0 0 0x82000000 0x1 0 1 0 + 0x81000000 0 0 0x81000000 0x1 0 1 0>; + bus-range = <0x00 0xff>; + interrupt-map-mask = <0 0 0 0>; + interrupt-map = <0 0 0 0 &mpic 58>; + marvell,pcie-port = <0>; + marvell,pcie-lane = <0>; + clocks = <&gateclk 5>; + status = "disabled"; + }; + }; + + internal-regs { + sdramc: sdramc@1400 { + compatible = "marvell,armada-xp-sdram-controller"; + reg = <0x1400 0x500>; + }; + + L2: l2-cache@8000 { + compatible = "marvell,aurora-system-cache"; + reg = <0x08000 0x1000>; + cache-id-part = <0x100>; + cache-level = <2>; + cache-unified; + wt-override; + }; + + gpio0: gpio@18100 { + compatible = "marvell,orion-gpio"; + reg = <0x18100 0x40>; + ngpios = <32>; + gpio-controller; + #gpio-cells = <2>; + interrupt-controller; + #interrupt-cells = <2>; + interrupts = <82>, <83>, <84>, <85>; + }; + + /* does not exist */ + gpio1: gpio@18140 { + compatible = "marvell,orion-gpio"; + reg = <0x18140 0x40>; + status = "disabled"; + }; + + gpio2: gpio@18180 { /* rework some properties */ + compatible = "marvell,orion-gpio"; + reg = <0x18180 0x40>; + ngpios = <1>; /* only gpio #32 */ + gpio-controller; + #gpio-cells = <2>; + interrupt-controller; + #interrupt-cells = <2>; + interrupts = <87>; + }; + + systemc: system-controller@18200 { + compatible = "marvell,armada-370-xp-system-controller"; + reg = <0x18200 0x500>; + }; + + gateclk: clock-gating-control@18220 { + compatible = "marvell,mv98dx3236-gating-clock"; + reg = <0x18220 0x4>; + clocks = <&coreclk 0>; + #clock-cells = <1>; + }; + + cpuclk: clock-complex@18700 { + #clock-cells = <1>; + compatible = "marvell,mv98dx3236-cpu-clock"; + reg = <0x18700 0x24>, <0x1c054 0x10>; + clocks = <&coreclk 1>; + }; + + corediv-clock@18740 { + status = "disabled"; + }; + + cpu-config@21000 { + compatible = "marvell,armada-xp-cpu-config"; + reg = <0x21000 0x8>; + }; + + ethernet@70000 { + compatible = "marvell,armada-xp-neta"; + }; + + ethernet@74000 { + compatible = "marvell,armada-xp-neta"; + }; + + xor1: xor@f0800 { + compatible = "marvell,orion-xor"; + reg = <0xf0800 0x100 + 0xf0a00 0x100>; + clocks = <&gateclk 22>; + status = "okay"; + + xor10 { + interrupts = <51>; + dmacap,memcpy; + dmacap,xor; + }; + xor11 { + interrupts = <52>; + dmacap,memcpy; + dmacap,xor; + dmacap,memset; + }; + }; + + nand_controller: nand@d0000 { + clocks = <&dfx_coredivclk 0>; + }; + + xor0: xor@f0900 { + compatible = "marvell,orion-xor"; + reg = <0xF0900 0x100 + 0xF0B00 0x100>; + clocks = <&gateclk 28>; + status = "okay"; + + xor00 { + interrupts = <94>; + dmacap,memcpy; + dmacap,xor; + }; + xor01 { + interrupts = <95>; + dmacap,memcpy; + dmacap,xor; + dmacap,memset; + }; + }; + }; + + dfx: dfx-server@ac000000 { + compatible = "marvell,dfx-server", "simple-bus"; + #address-cells = <1>; + #size-cells = <1>; + ranges = <0 MBUS_ID(0x08, 0x00) 0 0x100000>; + reg = <MBUS_ID(0x08, 0x00) 0 0x100000>; + + thermal: thermal@f8078 { + compatible = "marvell,armada380-thermal"; + reg = <0xf8078 0x4>, <0xf8074 0x4>; + status = "okay"; + }; + + coreclk: mvebu-sar@f8204 { + compatible = "marvell,mv98dx3236-core-clock"; + reg = <0xf8204 0x4>; + #clock-cells = <1>; + }; + + dfx_coredivclk: corediv-clock@f8268 { + compatible = "marvell,mv98dx3236-corediv-clock"; + reg = <0xf8268 0xc>; + #clock-cells = <1>; + clocks = <&mainpll>; + clock-output-names = "nand"; + }; + }; + + switch: switch@a8000000 { + compatible = "simple-bus"; + #address-cells = <1>; + #size-cells = <1>; + ranges = <0 MBUS_ID(0x03, 0x00) 0 0x100000>; + + pp0: packet-processor@0 { + compatible = "marvell,prestera-98dx3236", "marvell,prestera"; + reg = <0 0x4000000>; + interrupts = <33>, <34>, <35>; + dfx = <&dfx>; + }; + }; + }; + + clocks { + /* 25 MHz reference crystal */ + refclk: oscillator { + compatible = "fixed-clock"; + #clock-cells = <0>; + clock-frequency = <25000000>; + }; + }; +}; + +&i2c0 { + compatible = "marvell,mv78230-i2c", "marvell,mv64xxx-i2c"; + reg = <0x11000 0x100>; +}; + +&i2c1 { + compatible = "marvell,mv78230-i2c", "marvell,mv64xxx-i2c"; + reg = <0x11100 0x100>; +}; + +&mpic { + reg = <0x20a00 0x2d0>, <0x21070 0x58>; +}; + +&rtc { + status = "disabled"; +}; + +&timer { + compatible = "marvell,armada-xp-timer"; + clocks = <&coreclk 2>, <&refclk>; + clock-names = "nbclk", "fixed"; +}; + +&watchdog { + compatible = "marvell,armada-xp-wdt"; + clocks = <&coreclk 2>, <&refclk>; + clock-names = "nbclk", "fixed"; +}; + +&cpurst { + reg = <0x20800 0x20>; +}; + +&usb0 { + clocks = <&gateclk 18>; +}; + +&usb1 { + clocks = <&gateclk 19>; +}; + +&pinctrl { + compatible = "marvell,98dx3236-pinctrl"; + + nand_pins: nand-pins { + marvell,pins = "mpp20", "mpp21", "mpp22", + "mpp23", "mpp24", "mpp25", + "mpp26", "mpp27", "mpp28", + "mpp29", "mpp30"; + marvell,function = "dev"; + }; + + nand_rb: nand-rb { + marvell,pins = "mpp19"; + marvell,function = "nand"; + }; + + spi0_pins: spi0-pins { + marvell,pins = "mpp0", "mpp1", + "mpp2", "mpp3"; + marvell,function = "spi0"; + }; +}; + +&spi0 { + compatible = "marvell,armada-xp-spi", "marvell,orion-spi"; + pinctrl-0 = <&spi0_pins>; + pinctrl-names = "default"; +}; + +&sdio { + status = "disabled"; +}; diff --git a/arch/arm/dts/armada-xp-98dx3336.dtsi b/arch/arm/dts/armada-xp-98dx3336.dtsi new file mode 100644 index 000000000000..1d9d8a8ea60c --- /dev/null +++ b/arch/arm/dts/armada-xp-98dx3336.dtsi @@ -0,0 +1,39 @@ +// SPDX-License-Identifier: (GPL-2.0+ OR MIT) +/* + * Device Tree Include file for Marvell 98dx3336 family SoC + * + * Copyright (C) 2016 Allied Telesis Labs + * + * Contains definitions specific to the 98dx3236 SoC that are not + * common to all Armada XP SoCs. + */ + +#include "armada-xp-98dx3236.dtsi" + +/ { + model = "Marvell 98DX3336 SoC"; + compatible = "marvell,armadaxp-98dx3336", "marvell,armadaxp-98dx3236", "marvell,armada-370-xp"; + + cpus { + cpu@1 { + device_type = "cpu"; + compatible = "marvell,sheeva-v7"; + reg = <1>; + clocks = <&cpuclk 1>; + clock-latency = <1000000>; + }; + }; + + soc { + internal-regs { + resume@20980 { + compatible = "marvell,98dx3336-resume-ctrl"; + reg = <0x20980 0x10>; + }; + }; + }; +}; + +&pp0 { + compatible = "marvell,prestera-98dx3336", "marvell,prestera"; +}; diff --git a/arch/arm/dts/armada-xp-98dx4251.dtsi b/arch/arm/dts/armada-xp-98dx4251.dtsi new file mode 100644 index 000000000000..48ffdc72bfc7 --- /dev/null +++ b/arch/arm/dts/armada-xp-98dx4251.dtsi @@ -0,0 +1,54 @@ +// SPDX-License-Identifier: (GPL-2.0+ OR MIT) +/* + * Device Tree Include file for Marvell 98dx4521 family SoC + * + * Copyright (C) 2016 Allied Telesis Labs + * + * Contains definitions specific to the 98dx4521 SoC that are not + * common to all Armada XP SoCs. + */ + +#include "armada-xp-98dx3236.dtsi" + +/ { + model = "Marvell 98DX4251 SoC"; + compatible = "marvell,armadaxp-98dx4251", "marvell,armadaxp-98dx3236", "marvell,armada-370-xp"; + + cpus { + cpu@1 { + device_type = "cpu"; + compatible = "marvell,sheeva-v7"; + reg = <1>; + clocks = <&cpuclk 1>; + clock-latency = <1000000>; + }; + }; + + soc { + internal-regs { + resume@20980 { + compatible = "marvell,98dx3336-resume-ctrl"; + reg = <0x20980 0x10>; + }; + }; + }; +}; + +&sdio { + status = "okay"; +}; + +&pinctrl { + compatible = "marvell,98dx4251-pinctrl"; + + sdio_pins: sdio-pins { + marvell,pins = "mpp5", "mpp6", "mpp7", + "mpp8", "mpp9", "mpp10"; + marvell,function = "sd0"; + }; +}; + +&pp0 { + compatible = "marvell,prestera-98dx4251", "marvell,prestera"; + interrupts = <33>, <34>, <35>, <36>; +}; diff --git a/arch/arm/dts/armada-xp-db-xc3-24g4xg-u-boot.dtsi b/arch/arm/dts/armada-xp-db-xc3-24g4xg-u-boot.dtsi new file mode 100644 index 000000000000..90cad85506d0 --- /dev/null +++ b/arch/arm/dts/armada-xp-db-xc3-24g4xg-u-boot.dtsi @@ -0,0 +1,24 @@ +// SPDX-License-Identifier: (GPL-2.0+ OR MIT) + +&uart0 { + u-boot,dm-pre-reloc; +}; + +&nand_controller { + compatible="marvell,mvebu-pxa3xx-nand"; + status = "okay"; + label = "pxa3xx_nand-0"; + nand-rb = <0>; + marvell,nand-keep-config; + nand-on-flash-bbt; + nand-ecc-strength = <4>; + nand-ecc-step-size = <512>; +}; + +&spi0 { + u-boot,dm-pre-reloc; + + spi-flash@0 { + u-boot,dm-pre-reloc; + }; +}; diff --git a/arch/arm/dts/armada-xp-db-xc3-24g4xg.dts b/arch/arm/dts/armada-xp-db-xc3-24g4xg.dts new file mode 100644 index 000000000000..d4b52881e6f0 --- /dev/null +++ b/arch/arm/dts/armada-xp-db-xc3-24g4xg.dts @@ -0,0 +1,110 @@ +// SPDX-License-Identifier: (GPL-2.0+ OR MIT) +/* + * Device Tree file for DB-XC3-24G4XG board + * + * Copyright (C) 2016 Allied Telesis Labs + * + * Based on armada-xp-db.dts + * + * Note: this Device Tree assumes that the bootloader has remapped the + * internal registers to 0xf1000000 (instead of the default + * 0xd0000000). The 0xf1000000 is the default used by the recent, + * DT-capable, U-Boot bootloaders provided by Marvell. Some earlier + * boards were delivered with an older version of the bootloader that + * left internal registers mapped at 0xd0000000. If you are in this + * situation, you should either update your bootloader (preferred + * solution) or the below Device Tree should be adjusted. + */ + +/dts-v1/; +#include "armada-xp-98dx3336.dtsi" +#include "armada-xp-db-xc3-24g4xg-u-boot.dtsi" + +/ { + model = "DB-XC3-24G4XG"; + compatible = "marvell,armadaxp-98dx3336", "marvell,armadaxp-mv78260", "marvell,armadaxp", "marvell,armada-370-xp"; + + chosen { + stdout-path = "serial0:115200n8"; + bootargs = "console=ttyS0,115200 earlyprintk"; + }; + + aliases { + spi0 = &spi0; + }; + + memory { + device_type = "memory"; + reg = <0 0x00000000 0 0x40000000>; /* 1 GB */ + }; +}; + +&L2 { + arm,parity-enable; + marvell,ecc-enable; +}; + +&devbus_bootcs { + status = "okay"; + + /* Device Bus parameters are required */ + + /* Read parameters */ + devbus,bus-width = <16>; + devbus,turn-off-ps = <60000>; + devbus,badr-skew-ps = <0>; + devbus,acc-first-ps = <124000>; + devbus,acc-next-ps = <248000>; + devbus,rd-setup-ps = <0>; + devbus,rd-hold-ps = <0>; + + /* Write parameters */ + devbus,sync-enable = <0>; + devbus,wr-high-ps = <60000>; + devbus,wr-low-ps = <60000>; + devbus,ale-wr-ps = <60000>; +}; + +&uart0 { + status = "okay"; +}; + +&uart1 { + status = "okay"; +}; + +&i2c0 { + clock-frequency = <100000>; + status = "okay"; +}; + +&usb0 { + status = "okay"; +}; + +&spi0 { + status = "okay"; + + spi-flash@0 { + #address-cells = <1>; + #size-cells = <1>; + compatible = "spi-flash", "jedec,spi-nor"; + reg = <0>; /* Chip select 0 */ + spi-max-frequency = <108000000>; + m25p,fast-read; + + partition@u-boot { + reg = <0x00000000 0x00100000>; + label = "u-boot"; + }; + partition@u-boot-env { + reg = <0x00100000 0x00040000>; + label = "u-boot-env"; + }; + partition@unused { + reg = <0x00140000 0x00ec0000>; + label = "unused"; + }; + + }; +}; diff --git a/arch/arm/mach-mvebu/Kconfig b/arch/arm/mach-mvebu/Kconfig index 08c9972f02d7..cfb464def8a7 100644 --- a/arch/arm/mach-mvebu/Kconfig +++ b/arch/arm/mach-mvebu/Kconfig @@ -152,6 +152,10 @@ config TARGET_X530 bool "Support Allied Telesis x530" select 88F6820
+config TARGET_DB_XC3_24G4XG + bool "Support DB-XC3-24G4XG" + select 98DX3336 + endchoice
config SYS_BOARD @@ -170,6 +174,7 @@ config SYS_BOARD default "theadorable" if TARGET_THEADORABLE default "a38x" if TARGET_CONTROLCENTERDC default "x530" if TARGET_X530 + default "db-xc3-24g4xg" if TARGET_DB_XC3_24G4XG
config SYS_CONFIG_NAME default "clearfog" if TARGET_CLEARFOG @@ -187,6 +192,7 @@ config SYS_CONFIG_NAME default "turris_mox" if TARGET_TURRIS_MOX default "controlcenterdc" if TARGET_CONTROLCENTERDC default "x530" if TARGET_X530 + default "db-xc3-24g4xg" if TARGET_DB_XC3_24G4XG
config SYS_VENDOR default "Marvell" if TARGET_DB_MV784MP_GP @@ -195,6 +201,8 @@ config SYS_VENDOR default "Marvell" if TARGET_DB_88F6820_GP default "Marvell" if TARGET_DB_88F6820_AMC default "Marvell" if TARGET_MVEBU_ARMADA_8K + default "Marvell" if TARGET_DB_XC3_24G4XG + default "Marvell" if TARGET_MVEBU_DB_88F7040 default "solidrun" if TARGET_CLEARFOG default "kobol" if TARGET_HELIOS4 default "Synology" if TARGET_DS414 diff --git a/board/Marvell/db-xc3-24g4xg/.gitignore b/board/Marvell/db-xc3-24g4xg/.gitignore new file mode 100644 index 000000000000..775b9346b859 --- /dev/null +++ b/board/Marvell/db-xc3-24g4xg/.gitignore @@ -0,0 +1 @@ +kwbimage.cfg diff --git a/board/Marvell/db-xc3-24g4xg/MAINTAINERS b/board/Marvell/db-xc3-24g4xg/MAINTAINERS new file mode 100644 index 000000000000..94d4a901783b --- /dev/null +++ b/board/Marvell/db-xc3-24g4xg/MAINTAINERS @@ -0,0 +1,7 @@ +DB-XC3-24G4XG BOARD +M: Chris Packham chris.packham@alliedtelesis.co.nz +S: Maintained +F: board/Marvell/db-xc3-24g4xg/ +F: include/configs/db-xc3-24g4xg.h +F: configs/db-xc3-24g4xg-amc_defconfig +F: arch/arm/dts/armada-xp-db-xc3-24g4xg.dts diff --git a/board/Marvell/db-xc3-24g4xg/Makefile b/board/Marvell/db-xc3-24g4xg/Makefile new file mode 100644 index 000000000000..4dd57902d474 --- /dev/null +++ b/board/Marvell/db-xc3-24g4xg/Makefile @@ -0,0 +1,14 @@ +# SPDX-License-Identifier: GPL-2.0+ +# +# Copyright (C) 2015 Stefan Roese sr@denx.de + +obj-y := db-xc3-24g4xg.o +extra-y := kwbimage.cfg + +quiet_cmd_sed = SED $@ + cmd_sed = sed $(SEDFLAGS_$(@F)) $< >$(dir $<)$(@F) + +SEDFLAGS_kwbimage.cfg =-e "s|^BINARY.*|BINARY $(srctree)/$(@D)/binary.0 0000005b 00000068|" +$(src)/kwbimage.cfg: $(src)/kwbimage.cfg.in include/autoconf.mk \ + include/config/auto.conf + $(call if_changed,sed) diff --git a/board/Marvell/db-xc3-24g4xg/README b/board/Marvell/db-xc3-24g4xg/README new file mode 100644 index 000000000000..5e479b433e4d --- /dev/null +++ b/board/Marvell/db-xc3-24g4xg/README @@ -0,0 +1,4 @@ +To generate binary.0 from Marvell's bin_hdr.elf use the following command + + arm-softfloat-linux-gnueabi-objcopy -S -O binary bin_hdr.elf \ + board/Marvell/db-xc3-24g4xg/binary.0 diff --git a/board/Marvell/db-xc3-24g4xg/binary.0 b/board/Marvell/db-xc3-24g4xg/binary.0 new file mode 100644 index 000000000000..8dd687286a00 --- /dev/null +++ b/board/Marvell/db-xc3-24g4xg/binary.0 @@ -0,0 +1,11 @@ +-------- +WARNING: +-------- +This file should contain the bin_hdr generated by the original Marvell +U-Boot implementation. As this is currently not included in this +U-Boot version, we have added this placeholder, so that the U-Boot +image can be generated without errors. + +If you have a known to be working bin_hdr for your board, then you +just need to replace this text file here with the binary header +and recompile U-Boot. diff --git a/board/Marvell/db-xc3-24g4xg/db-xc3-24g4xg.c b/board/Marvell/db-xc3-24g4xg/db-xc3-24g4xg.c new file mode 100644 index 000000000000..cae428ffd06c --- /dev/null +++ b/board/Marvell/db-xc3-24g4xg/db-xc3-24g4xg.c @@ -0,0 +1,68 @@ +// SPDX-License-Identifier: GPL-2.0+ +/* + * Copyright (C) 2015 Stefan Roese sr@denx.de + */ + +#include <common.h> +#include <i2c.h> +#include <asm/gpio.h> +#include <linux/mbus.h> +#include <linux/io.h> +#include <asm/arch/cpu.h> +#include <asm/arch/soc.h> + +DECLARE_GLOBAL_DATA_PTR; + +/* + * These values and defines are taken from the Marvell U-Boot version + * "u-boot-2013.01-2016_T1.0.eng_drop_v6" + */ +#define DB_DX_AC3_GPP_OUT_ENA_LOW (~(BIT(0) | BIT(2) | BIT(3) | BIT(4) | BIT(6) | BIT(12) \ + | BIT(13) | BIT(16) | BIT(17) | BIT(20) | BIT(29) | BIT(30))) +#define DB_DX_AC3_GPP_OUT_ENA_MID (~(0)) +#define DB_DX_AC3_GPP_OUT_VAL_LOW (BIT(0) | BIT(2) | BIT(3) | BIT(4) | BIT(6) | BIT(12) \ + | BIT(13) | BIT(16) | BIT(17) | BIT(20) | BIT(29) | BIT(30)) +#define DB_DX_AC3_GPP_OUT_VAL_MID 0x0 +#define DB_DX_AC3_GPP_POL_LOW 0x0 +#define DB_DX_AC3_GPP_POL_MID 0x0 + +int board_early_init_f(void) +{ + /* Configure MPP */ + writel(0x00142222, MVEBU_MPP_BASE + 0x00); + writel(0x11122000, MVEBU_MPP_BASE + 0x04); + writel(0x44444004, MVEBU_MPP_BASE + 0x08); + writel(0x14444444, MVEBU_MPP_BASE + 0x0c); + writel(0x00000001, MVEBU_MPP_BASE + 0x10); + + /* Set GPP Out value */ + writel(DB_DX_AC3_GPP_OUT_VAL_LOW, MVEBU_GPIO0_BASE + 0x00); + writel(DB_DX_AC3_GPP_OUT_VAL_MID, MVEBU_GPIO1_BASE + 0x00); + + /* Set GPP Polarity */ + writel(DB_DX_AC3_GPP_POL_LOW, MVEBU_GPIO0_BASE + 0x0c); + writel(DB_DX_AC3_GPP_POL_MID, MVEBU_GPIO1_BASE + 0x0c); + + /* Set GPP Out Enable */ + writel(DB_DX_AC3_GPP_OUT_ENA_LOW, MVEBU_GPIO0_BASE + 0x04); + writel(DB_DX_AC3_GPP_OUT_ENA_MID, MVEBU_GPIO1_BASE + 0x04); + + return 0; +} + +int board_init(void) +{ + /* address of boot parameters */ + gd->bd->bi_boot_params = mvebu_sdram_bar(0) + 0x100; + + return 0; +} + +#ifdef CONFIG_DISPLAY_BOARDINFO +int checkboard(void) +{ + puts("Board: " CONFIG_SYS_BOARD "\n"); + + return 0; +} +#endif diff --git a/board/Marvell/db-xc3-24g4xg/kwbimage.cfg.in b/board/Marvell/db-xc3-24g4xg/kwbimage.cfg.in new file mode 100644 index 000000000000..b8bb7a6eb75b --- /dev/null +++ b/board/Marvell/db-xc3-24g4xg/kwbimage.cfg.in @@ -0,0 +1,12 @@ +# +# Copyright (C) 2014 Stefan Roese sr@denx.de +# + +# Armada XP uses version 1 image format +VERSION 1 + +# Boot Media configurations +BOOT_FROM spi + +# Binary Header (bin_hdr) with DDR3 training code +BINARY board/Marvell/db-xc3-24g4xg/binary.0 0000005b 00000068 diff --git a/configs/db-xc3-24g4xg_defconfig b/configs/db-xc3-24g4xg_defconfig new file mode 100644 index 000000000000..0285ccaa365c --- /dev/null +++ b/configs/db-xc3-24g4xg_defconfig @@ -0,0 +1,55 @@ +CONFIG_ARM=y +CONFIG_ARCH_MVEBU=y +CONFIG_SYS_TEXT_BASE=0x00800000 +CONFIG_SYS_MALLOC_F_LEN=0x2000 +CONFIG_TARGET_DB_XC3_24G4XG=y +CONFIG_BUILD_TARGET="u-boot.kwb" +CONFIG_SYS_CONSOLE_INFO_QUIET=y +CONFIG_CMD_MEMTEST=y +CONFIG_SYS_ALT_MEMTEST=y +# CONFIG_CMD_FLASH is not set +CONFIG_CMD_I2C=y +CONFIG_CMD_SF=y +CONFIG_CMD_SPI=y +CONFIG_CMD_USB=y +# CONFIG_CMD_SETEXPR is not set +CONFIG_CMD_DHCP=y +CONFIG_CMD_TFTPPUT=y +CONFIG_CMD_MII=y +CONFIG_CMD_PING=y +CONFIG_CMD_CACHE=y +CONFIG_CMD_TIME=y +CONFIG_CMD_EXT2=y +CONFIG_CMD_EXT4=y +CONFIG_CMD_FAT=y +CONFIG_CMD_FS_GENERIC=y +CONFIG_CMD_UBI=y +CONFIG_DEFAULT_DEVICE_TREE="armada-xp-db-xc3-24g4xg" +CONFIG_ENV_IS_IN_SPI_FLASH=y +CONFIG_SPL_OF_TRANSLATE=y +CONFIG_BLK=y +CONFIG_DM_I2C=y +CONFIG_SYS_I2C_MVTWSI=y +# CONFIG_MMC is not set +CONFIG_MTD=y +CONFIG_MTD_DEVICE=y +CONFIG_NAND=y +CONFIG_NAND_PXA3XX=y +CONFIG_SPI_FLASH=y +CONFIG_SPI_FLASH_SFDP_SUPPORT=y +CONFIG_SPI_FLASH_MACRONIX=y +CONFIG_SPI_FLASH_STMICRO=y +CONFIG_SPI_FLASH_SST=y +# CONFIG_SPI_FLASH_USE_4K_SECTORS is not set +CONFIG_PCI=y +CONFIG_PCI_MVEBU=y +CONFIG_SYS_NS16550=y +CONFIG_KIRKWOOD_SPI=y +CONFIG_USB=y +CONFIG_DM_USB=y +CONFIG_USB_EHCI_HCD=y +CONFIG_USB_STORAGE=y +CONFIG_USB_HOST_ETHER=y +CONFIG_USB_ETHER_ASIX=y +CONFIG_USB_ETHER_RTL8152=y +CONFIG_USB_ETHER_SMSC95XX=y diff --git a/include/configs/db-xc3-24g4xg.h b/include/configs/db-xc3-24g4xg.h new file mode 100644 index 000000000000..0f75ad71859e --- /dev/null +++ b/include/configs/db-xc3-24g4xg.h @@ -0,0 +1,41 @@ +/* SPDX-License-Identifier: GPL-2.0+ */ +/* + * Copyright (C) 2014 Stefan Roese sr@denx.de + */ + +#ifndef _CONFIG_DB_XC3_24G4G_H +#define _CONFIG_DB_XC3_24G4G_H + +/* + * High Level Configuration Options (easy to change) + */ + +#define CONFIG_SYS_KWD_CONFIG $(CONFIG_BOARDDIR)/kwbimage.cfg +#define CONFIG_SYS_TCLK 200000000 /* 200MHz */ + +/* USB/EHCI configuration */ +#define CONFIG_EHCI_IS_TDI + +/* Environment in SPI NOR flash */ +#define CONFIG_ENV_OFFSET (1 << 20) /* 1MiB in */ +#define CONFIG_ENV_SIZE (64 << 10) /* 64KiB */ +#define CONFIG_ENV_SECT_SIZE (256 << 10) /* 256KiB sectors */ + +/* NAND */ +#define CONFIG_SYS_NAND_USE_FLASH_BBT +#define CONFIG_SYS_NAND_ONFI_DETECTION + +/* Keep device tree and initrd in lower memory so the kernel can access them */ +#define CONFIG_EXTRA_ENV_SETTINGS \ + "fdt_high=0x10000000\0" \ + "initrd_high=0x10000000\0" + +/* + * mv-common.h should be defined after CMD configs since it used them + * to enable certain macros + */ +#include "mv-common.h" +#undef CONFIG_SYS_MAXARGS +#define CONFIG_SYS_MAXARGS 96 + +#endif /* _CONFIG_DB_XC3_24G4G_H */
Changes in v3:
Changes in v2:
Thanks, Stefan
Changes in v3:
Changes in v2:
Thanks, Stefan
Chris Packham
Stefan Roese
