[U-Boot] [v3] arm: Fixed the offset for the no relocation.
When the u-boot address of destination equal to __start, no relocation. relocation offset(r9) = 0.
Signed-off-by: Zhong Hongbo bocui107@gmail.com --- Change for V3: - Drop the change of arm720t, It has already merge the change. Change for V2: - Clean a line for arm1176. --- arch/arm/cpu/arm1136/start.S | 1 + arch/arm/cpu/arm1176/start.S | 1 + arch/arm/cpu/arm920t/start.S | 1 + arch/arm/cpu/arm925t/start.S | 1 + arch/arm/cpu/arm926ejs/start.S | 1 + arch/arm/cpu/arm946es/start.S | 1 + arch/arm/cpu/arm_intcm/start.S | 1 + arch/arm/cpu/ixp/start.S | 1 + arch/arm/cpu/lh7a40x/start.S | 1 + arch/arm/cpu/pxa/start.S | 1 + arch/arm/cpu/s3c44b0/start.S | 1 + arch/arm/cpu/sa1100/start.S | 1 + 12 files changed, 12 insertions(+)
diff --git a/arch/arm/cpu/arm1136/start.S b/arch/arm/cpu/arm1136/start.S index 2483c63..3752af9 100644 --- a/arch/arm/cpu/arm1136/start.S +++ b/arch/arm/cpu/arm1136/start.S @@ -190,6 +190,7 @@ stack_setup:
adr r0, _start cmp r0, r6 + moveq r9, #0 /* no relocation. relocation offset(r9) = 0 */ beq clear_bss /* skip relocation */ mov r1, r6 /* r1 <- scratch for copy_loop */ ldr r3, _bss_start_ofs diff --git a/arch/arm/cpu/arm1176/start.S b/arch/arm/cpu/arm1176/start.S index d613641..667a0e0 100644 --- a/arch/arm/cpu/arm1176/start.S +++ b/arch/arm/cpu/arm1176/start.S @@ -252,6 +252,7 @@ stack_setup:
adr r0, _start cmp r0, r6 + moveq r9, #0 /* no relocation. relocation offset(r9) = 0 */ beq clear_bss /* skip relocation */ mov r1, r6 /* r1 <- scratch for copy_loop */ ldr r3, _bss_start_ofs diff --git a/arch/arm/cpu/arm920t/start.S b/arch/arm/cpu/arm920t/start.S index 9b8604e..14c9156 100644 --- a/arch/arm/cpu/arm920t/start.S +++ b/arch/arm/cpu/arm920t/start.S @@ -210,6 +210,7 @@ stack_setup:
adr r0, _start cmp r0, r6 + moveq r9, #0 /* no relocation. relocation offset(r9) = 0 */ beq clear_bss /* skip relocation */ mov r1, r6 /* r1 <- scratch for copy_loop */ ldr r3, _bss_start_ofs diff --git a/arch/arm/cpu/arm925t/start.S b/arch/arm/cpu/arm925t/start.S index 1a54416..3a483f6 100644 --- a/arch/arm/cpu/arm925t/start.S +++ b/arch/arm/cpu/arm925t/start.S @@ -204,6 +204,7 @@ stack_setup:
adr r0, _start cmp r0, r6 + moveq r9, #0 /* no relocation. relocation offset(r9) = 0 */ beq clear_bss /* skip relocation */ mov r1, r6 /* r1 <- scratch for copy_loop */ ldr r3, _bss_start_ofs diff --git a/arch/arm/cpu/arm926ejs/start.S b/arch/arm/cpu/arm926ejs/start.S index 6f05f1a..1b530dc 100644 --- a/arch/arm/cpu/arm926ejs/start.S +++ b/arch/arm/cpu/arm926ejs/start.S @@ -235,6 +235,7 @@ stack_setup: adr r0, _start sub r9, r6, r0 /* r9 <- relocation offset */ cmp r0, r6 + moveq r9, #0 /* no relocation. relocation offset(r9) = 0 */ beq clear_bss /* skip relocation */ mov r1, r6 /* r1 <- scratch for copy loop */ ldr r3, _bss_start_ofs diff --git a/arch/arm/cpu/arm946es/start.S b/arch/arm/cpu/arm946es/start.S index b4d1d2d..30e2183 100644 --- a/arch/arm/cpu/arm946es/start.S +++ b/arch/arm/cpu/arm946es/start.S @@ -175,6 +175,7 @@ stack_setup:
adr r0, _start cmp r0, r6 + moveq r9, #0 /* no relocation. relocation offset(r9) = 0 */ beq clear_bss /* skip relocation */ mov r1, r6 /* r1 <- scratch for copy_loop */ ldr r3, _bss_start_ofs diff --git a/arch/arm/cpu/arm_intcm/start.S b/arch/arm/cpu/arm_intcm/start.S index b85e7d4..a133d19 100644 --- a/arch/arm/cpu/arm_intcm/start.S +++ b/arch/arm/cpu/arm_intcm/start.S @@ -171,6 +171,7 @@ stack_setup:
adr r0, _start cmp r0, r6 + moveq r9, #0 /* no relocation. relocation offset(r9) = 0 */ beq clear_bss /* skip relocation */ mov r1, r6 /* r1 <- scratch for copy_loop */ ldr r3, _bss_start_ofs diff --git a/arch/arm/cpu/ixp/start.S b/arch/arm/cpu/ixp/start.S index 59c359a..c12f1a7 100644 --- a/arch/arm/cpu/ixp/start.S +++ b/arch/arm/cpu/ixp/start.S @@ -273,6 +273,7 @@ stack_setup:
adr r0, _start cmp r0, r6 + moveq r9, #0 /* no relocation. relocation offset(r9) = 0 */ beq clear_bss /* skip relocation */ mov r1, r6 /* r1 <- scratch for copy_loop */ ldr r3, _bss_start_ofs diff --git a/arch/arm/cpu/lh7a40x/start.S b/arch/arm/cpu/lh7a40x/start.S index bd68cd4..33b9269 100644 --- a/arch/arm/cpu/lh7a40x/start.S +++ b/arch/arm/cpu/lh7a40x/start.S @@ -184,6 +184,7 @@ stack_setup:
adr r0, _start cmp r0, r6 + moveq r9, #0 /* no relocation. relocation offset(r9) = 0 */ beq clear_bss /* skip relocation */ mov r1, r6 /* r1 <- scratch for copy_loop */ ldr r3, _bss_start_ofs diff --git a/arch/arm/cpu/pxa/start.S b/arch/arm/cpu/pxa/start.S index 33c73f6..536cf5c 100644 --- a/arch/arm/cpu/pxa/start.S +++ b/arch/arm/cpu/pxa/start.S @@ -197,6 +197,7 @@ stack_setup:
adr r0, _start cmp r0, r6 + moveq r9, #0 /* no relocation. relocation offset(r9) = 0 */ beq clear_bss /* skip relocation */ mov r1, r6 /* r1 <- scratch for copy_loop */ ldr r3, _bss_start_ofs diff --git a/arch/arm/cpu/s3c44b0/start.S b/arch/arm/cpu/s3c44b0/start.S index 8daf26c..323b923 100644 --- a/arch/arm/cpu/s3c44b0/start.S +++ b/arch/arm/cpu/s3c44b0/start.S @@ -156,6 +156,7 @@ stack_setup:
adr r0, _start cmp r0, r6 + moveq r9, #0 /* no relocation. relocation offset(r9) = 0 */ beq clear_bss /* skip relocation */ mov r1, r6 /* r1 <- scratch for copy_loop */ ldr r3, _bss_start_ofs diff --git a/arch/arm/cpu/sa1100/start.S b/arch/arm/cpu/sa1100/start.S index bcea2a8..1ea92d1 100644 --- a/arch/arm/cpu/sa1100/start.S +++ b/arch/arm/cpu/sa1100/start.S @@ -160,6 +160,7 @@ stack_setup:
Sorry, Add Albert to the thread.
Change for V3:
Change for V2:
- moveq r9, #0 /* no relocation. relocation offset(r9) = 0 */ beq clear_bss /* skip relocation */ mov r1, r6 /* r1 <- scratch for copy_loop */ ldr r3, _bss_start_ofs
- moveq r9, #0 /* no relocation. relocation offset(r9) = 0 */ beq clear_bss /* skip relocation */ mov r1, r6 /* r1 <- scratch for copy loop */ ldr r3, _bss_start_ofs
Dear Zhong Hongbo,
Good, now what kind of issue does this patch fix?
Change for V3:
Change for V2:
Best regards, Marek Vasut
On 03/09/12 08:14, Marek Vasut wrote:
Dear Zhong Hongbo,
Hi Marek
When you adopt CONFIG_SPL_BUILD framework, no CONFIG_NAND_SPL, if the addr of destination is equal to _start, we should skip u-boot relocation.
In the last, u-boot will count the dest addr, see the below:
adr r1, _start add lr, r0, r1 add lr, lr, r9
Here, lr = lr + r9, r9 is the offset of u-boot, So when it do not neet to reolocat, we need to set the zero value for r9 register.
/* setup parameters for board_init_r */ mov r0, r5 /* gd_t */ mov r1, r6 /* dest_addr */ /* jump to it ... */ mov pc, lr
Thanks, hongbo
Change for V3:
Change for V2:
Dear Zhong Hongbo,
Hi Marek
I can confirm this issue - I see this when I ported SPL to a MX35 board. However, clearing r9 was not enough. I had to fix also _rel_dyn_* to make SPL working, and I did changing the start.S in the same way start.S for arv7 is built.
Do you not have these issues ?
Regards, Stefano
Dear Zhong Hongbo,
Hi Marek
Hi Stefano,
That is enough for my smdk6400 board.
Thanks, hongbo
Regards, Stefano
Dear Zhong Hongbo,
Hi Marek
Hi Stefano,
Ok, thanks. Then I will post a patch on top of yours, but here my:
Tested-by: Stefano Babic sbabic@denx.de
Tested on a i.MX35 board (ARM1136) with SPL.
Regards, Stefano
Dear Zhong Hongbo,
Hi Marek
Hi Stefano,
Hi Stefano,
Ok, Thanks,
BR, hongbo
Regards, Stefano
Stefano Babic
Zhong Hongbo
