[U-Boot] [PATCH] Fix mxc_hab documenation for DEK blob generation
From: Ulises Cardenas Ulises.Cardenas@freescale.com
Include/fsl_sec.h defines sec_in and sec_out, according to the platform's endianess. Therefore, CONFIG_SYS_FSL_LE needs to be declared in the configuration file of the target, in order to use enable the DEK blob generation command. This requirement is not explicit in the README.mxc_hab.
Signed-off-by: Ulises Cardenas Ulises.Cardenas@freescale.com ---
doc/README.mxc_hab | 1 + 1 file changed, 1 insertion(+)
diff --git a/doc/README.mxc_hab b/doc/README.mxc_hab index e9340dd..a1b1d34 100644 --- a/doc/README.mxc_hab +++ b/doc/README.mxc_hab @@ -69,6 +69,7 @@ CONFIG_SECURE_BOOT CONFIG_SYS_FSL_SEC_COMPAT 4 /* HAB version */ CONFIG_FSL_CAAM CONFIG_CMD_DEKBLOB +CONFIG_SYS_FSL_LE
Note: The encrypted boot feature is only supported by HABv4 or greater.
Applied to u-boot-imx master, thanks !
Best regards, Stefano Babic
Stefano Babic
