[PATCH v2] RFC: gitlab: x86: Add a coreboot test
Coreboot supports U-Boot as a payload and this recently got a bit of a facelist. Add a test for this.
For now this uses a binary build of coreboot (v4.15). Future work could potentially build it from source, but we need to figure out the toolchain problems first, since coreboot uses its own toolchain.
This needs some changes to the hooks scripts as well. An example build is at https://source.denx.de/u-boot/custodians/u-boot-dm/-/jobs/359687
Changes in v2: - Drop the local CI changes; we need the real ones applied first anyway
.gitlab-ci.yml | 26 ++++++++++++++++++++++++++ 1 file changed, 26 insertions(+)
diff --git a/.gitlab-ci.yml b/.gitlab-ci.yml index 4c89daeadcf..065d8d6158e 100644 --- a/.gitlab-ci.yml +++ b/.gitlab-ci.yml @@ -52,6 +52,16 @@ stages: genimage --inputpath . --config board/sifive/unleashed/genimage_spi-nor.cfg; cp images/spi-nor.img ${UBOOT_TRAVIS_BUILD_DIR}/; fi + - if [[ "${TEST_PY_BD}" == "coreboot" ]]; then + wget -O - + "https://drive.google.com/uc?id=1x6nrtWIyIRPLS2cQBwYTnT2TbOI8UjmM&export=..." | + xz -dc >${UBOOT_TRAVIS_BUILD_DIR}/coreboot.rom; + wget -O - + "https://drive.google.com/uc?id=149Cz-5SZXHNKpi9xg6R_5XITWohu348y&export=..." > + cbfstool; + chmod a+x cbfstool; + ./cbfstool ${UBOOT_TRAVIS_BUILD_DIR}/coreboot.rom add-flat-binary -f ${UBOOT_TRAVIS_BUILD_DIR}/u-boot.bin -n fallback/payload -c LZMA -l 0x1110000 -e 0x1110000; + fi - virtualenv -p /usr/bin/python3 /tmp/venv - . /tmp/venv/bin/activate - pip install -r test/py/requirements.txt @@ -61,6 +71,10 @@ stages: ./test/py/test.py -ra --bd ${TEST_PY_BD} ${TEST_PY_ID} ${TEST_PY_TEST_SPEC:+"-k ${TEST_PY_TEST_SPEC}"} --build-dir "$UBOOT_TRAVIS_BUILD_DIR" + # It seems that the files in /tmp go away, so copy out what we need + - if [[ "${TEST_PY_BD}" == "coreboot" ]]; then + cp -v /tmp/coreboot/*.{html,css} .; + fi
build all 32bit ARM platforms: stage: world build @@ -366,3 +380,15 @@ xtfpga test.py: TEST_PY_TEST_SPEC: "not sleep" TEST_PY_ID: "--id qemu" <<: *buildman_and_testpy_dfn + +coreboot test.py: + variables: + TEST_PY_BD: "coreboot" + TEST_PY_TEST_SPEC: "not sleep" + TEST_PY_ID: "--id qemu" + artifacts: + paths: + - "*.html" + - "*.css" + expire_in: 1 week + <<: *buildman_and_testpy_dfn
We should build coreboot in the Dockerfile like we do grub and so forth, then not have to worry about the toolchain things since it's just a one-time cost to me (or anyone else doing docker build).
Hi Tom,
OK...it does take an age though, since it builds various toolchains before it will even build coreboot. I'm going to talk to them about why they can't use 'normal' toolchains. Anyway, I'll add it in and see how it looks.
Do you want me to try the DockerFile thing first, or is having a download OK for now? What do you think about doing a docker thing for nikia_rx51 ?
On Fri, Dec 03, 2021 at 08:47:55AM -0700, Simon Glass wrote:
Hi Tom,
For coreboot, lets see what the feedback you get is, and we can deal with adding the test soon like this I suppose.
For nokia_rx51, I assume you mean building qemu and I'm not sure we can without making the test more fragile for non-CI? It doesn't tend to be much of a bottleneck so I'd rather not tweak it further.
Hi Tom,
Hi Tom,
OK, it might take some weeks to figure it out but am having a chat next week.
Ah OK I hadn't thought of that side. It fails for me a fair bit which is why I think of it.
