[U-Boot] [PATCH u-boot 0/3] amlogic: clean up board files
this series simplifies Amlogic board files by factorizing common code and removing unneeded parts. Also, it fixes printing the serial number read from efuse.
Beniamino Galvani (3): boards: amlogic: remove ethernet gpio reset code from boards boards: amlogic: use common function for environment initialization arm: meson: null-terminate the serial number
arch/arm/include/asm/arch-meson/sm.h | 1 + arch/arm/mach-meson/sm.c | 29 +++++++++++++++++++++ board/amlogic/khadas-vim/khadas-vim.c | 25 +----------------- board/amlogic/libretech-cc/libretech-cc.c | 25 +----------------- board/amlogic/nanopi-k2/nanopi-k2.c | 31 +---------------------- board/amlogic/odroid-c2/odroid-c2.c | 31 +---------------------- board/amlogic/p212/p212.c | 25 +----------------- 7 files changed, 35 insertions(+), 132 deletions(-)
The reset is already handled by the designware driver using information from device tree.
Signed-off-by: Beniamino Galvani b.galvani@gmail.com --- board/amlogic/nanopi-k2/nanopi-k2.c | 6 ------ board/amlogic/odroid-c2/odroid-c2.c | 6 ------ 2 files changed, 12 deletions(-)
diff --git a/board/amlogic/nanopi-k2/nanopi-k2.c b/board/amlogic/nanopi-k2/nanopi-k2.c index 339dbb81db..ae29dd6fa4 100644 --- a/board/amlogic/nanopi-k2/nanopi-k2.c +++ b/board/amlogic/nanopi-k2/nanopi-k2.c @@ -30,12 +30,6 @@ int misc_init_r(void)
meson_gx_eth_init(PHY_INTERFACE_MODE_RGMII, 0);
- /* Reset PHY on GPIOZ_14 */ - clrbits_le32(GX_GPIO_EN(3), BIT(14)); - clrbits_le32(GX_GPIO_OUT(3), BIT(14)); - mdelay(10); - setbits_le32(GX_GPIO_OUT(3), BIT(14)); - if (!eth_env_get_enetaddr("ethaddr", mac_addr)) { len = meson_sm_read_efuse(EFUSE_MAC_OFFSET, mac_addr, EFUSE_MAC_SIZE); diff --git a/board/amlogic/odroid-c2/odroid-c2.c b/board/amlogic/odroid-c2/odroid-c2.c index c47b9ce9cb..2a2755c387 100644 --- a/board/amlogic/odroid-c2/odroid-c2.c +++ b/board/amlogic/odroid-c2/odroid-c2.c @@ -30,12 +30,6 @@ int misc_init_r(void)
- mdelay(10);
- mdelay(10);
Acked-by: Neil Armstrong narmstrong@baylibre.com
Signed-off-by: Beniamino Galvani b.galvani@gmail.com Acked-by: Neil Armstrong narmstrong@baylibre.com
Clean up board files by moving the duplicate environment initialization to arch code.
Signed-off-by: Beniamino Galvani b.galvani@gmail.com --- arch/arm/include/asm/arch-meson/sm.h | 1 + arch/arm/mach-meson/sm.c | 27 +++++++++++++++++++++++ board/amlogic/khadas-vim/khadas-vim.c | 25 +-------------------- board/amlogic/libretech-cc/libretech-cc.c | 25 +-------------------- board/amlogic/nanopi-k2/nanopi-k2.c | 25 +-------------------- board/amlogic/odroid-c2/odroid-c2.c | 25 +-------------------- board/amlogic/p212/p212.c | 25 +-------------------- 7 files changed, 33 insertions(+), 120 deletions(-)
diff --git a/arch/arm/include/asm/arch-meson/sm.h b/arch/arm/include/asm/arch-meson/sm.h index 83d6441803..db2be38fc5 100644 --- a/arch/arm/include/asm/arch-meson/sm.h +++ b/arch/arm/include/asm/arch-meson/sm.h @@ -7,5 +7,6 @@ #define __MESON_SM_H__
ssize_t meson_sm_read_efuse(uintptr_t offset, void *buffer, size_t size); +void meson_init_env_from_efuse(void);
#endif /* __MESON_SM_H__ */ diff --git a/arch/arm/mach-meson/sm.c b/arch/arm/mach-meson/sm.c index 0bba5e4a07..2628591fe6 100644 --- a/arch/arm/mach-meson/sm.c +++ b/arch/arm/mach-meson/sm.c @@ -6,6 +6,7 @@ */
#include <common.h> +#include <environment.h> #include <asm/arch/gx.h> #include <linux/kernel.h>
@@ -14,6 +15,11 @@ #define FN_EFUSE_READ 0x82000030 #define FN_EFUSE_WRITE 0x82000031
+#define EFUSE_SN_OFFSET 20 +#define EFUSE_SN_SIZE 16 +#define EFUSE_MAC_OFFSET 52 +#define EFUSE_MAC_SIZE 6 + static void *shmem_input; static void *shmem_output;
@@ -54,3 +60,24 @@ ssize_t meson_sm_read_efuse(uintptr_t offset, void *buffer, size_t size)
return regs.regs[0]; } + +void meson_init_env_from_efuse(void) +{ + static u8 mac[EFUSE_MAC_SIZE]; + char serial[EFUSE_SN_SIZE]; + ssize_t len; + + if (!eth_env_get_enetaddr("ethaddr", mac)) { + len = meson_sm_read_efuse(EFUSE_MAC_OFFSET, + mac, EFUSE_MAC_SIZE); + if (len == EFUSE_MAC_SIZE && is_valid_ethaddr(mac)) + eth_env_set_enetaddr("ethaddr", mac); + } + + if (!env_get("serial#")) { + len = meson_sm_read_efuse(EFUSE_SN_OFFSET, serial, + EFUSE_SN_SIZE); + if (len == EFUSE_SN_SIZE) + env_set("serial#", serial); + } +} diff --git a/board/amlogic/khadas-vim/khadas-vim.c b/board/amlogic/khadas-vim/khadas-vim.c index 692bf2add3..4483a96761 100644 --- a/board/amlogic/khadas-vim/khadas-vim.c +++ b/board/amlogic/khadas-vim/khadas-vim.c @@ -6,18 +6,12 @@
#include <common.h> #include <dm.h> -#include <environment.h> #include <asm/io.h> #include <asm/arch/gx.h> #include <asm/arch/mem.h> #include <asm/arch/sm.h> #include <asm/arch/eth.h>
-#define EFUSE_SN_OFFSET 20 -#define EFUSE_SN_SIZE 16 -#define EFUSE_MAC_OFFSET 52 -#define EFUSE_MAC_SIZE 6 - int board_init(void) { return 0; @@ -25,26 +19,9 @@ int board_init(void)
int misc_init_r(void) { - u8 mac_addr[EFUSE_MAC_SIZE]; - char serial[EFUSE_SN_SIZE]; - ssize_t len; - meson_gx_eth_init(PHY_INTERFACE_MODE_RMII, MESON_GXL_USE_INTERNAL_RMII_PHY); - - if (!eth_env_get_enetaddr("ethaddr", mac_addr)) { - len = meson_sm_read_efuse(EFUSE_MAC_OFFSET, - mac_addr, EFUSE_MAC_SIZE); - if (len == EFUSE_MAC_SIZE && is_valid_ethaddr(mac_addr)) - eth_env_set_enetaddr("ethaddr", mac_addr); - } - - if (!env_get("serial#")) { - len = meson_sm_read_efuse(EFUSE_SN_OFFSET, serial, - EFUSE_SN_SIZE); - if (len == EFUSE_SN_SIZE) - env_set("serial#", serial); - } + meson_init_env_from_efuse();
return 0; } diff --git a/board/amlogic/libretech-cc/libretech-cc.c b/board/amlogic/libretech-cc/libretech-cc.c index ccab1272c5..86b1d213ff 100644 --- a/board/amlogic/libretech-cc/libretech-cc.c +++ b/board/amlogic/libretech-cc/libretech-cc.c @@ -6,18 +6,12 @@
#include <common.h> #include <dm.h> -#include <environment.h> #include <asm/io.h> #include <asm/arch/gx.h> #include <asm/arch/sm.h> #include <asm/arch/eth.h> #include <asm/arch/mem.h>
return 0; } diff --git a/board/amlogic/nanopi-k2/nanopi-k2.c b/board/amlogic/nanopi-k2/nanopi-k2.c index ae29dd6fa4..e61c23f8c6 100644 --- a/board/amlogic/nanopi-k2/nanopi-k2.c +++ b/board/amlogic/nanopi-k2/nanopi-k2.c @@ -5,18 +5,12 @@
-#define EFUSE_SN_OFFSET 20 -#define EFUSE_SN_SIZE 16 -#define EFUSE_MAC_OFFSET 52 -#define EFUSE_MAC_SIZE 6 - int board_init(void) { return 0; @@ -24,25 +18,8 @@ int board_init(void)
int misc_init_r(void) { - u8 mac_addr[EFUSE_MAC_SIZE]; - char serial[EFUSE_SN_SIZE]; - ssize_t len; - meson_gx_eth_init(PHY_INTERFACE_MODE_RGMII, 0); - - if (!eth_env_get_enetaddr("ethaddr", mac_addr)) { - len = meson_sm_read_efuse(EFUSE_MAC_OFFSET, - mac_addr, EFUSE_MAC_SIZE); - if (len == EFUSE_MAC_SIZE && is_valid_ethaddr(mac_addr)) - eth_env_set_enetaddr("ethaddr", mac_addr); - } - - if (!env_get("serial#")) { - len = meson_sm_read_efuse(EFUSE_SN_OFFSET, serial, - EFUSE_SN_SIZE); - if (len == EFUSE_SN_SIZE) - env_set("serial#", serial); - } + meson_init_env_from_efuse();
return 0; } diff --git a/board/amlogic/odroid-c2/odroid-c2.c b/board/amlogic/odroid-c2/odroid-c2.c index 2a2755c387..fffd225485 100644 --- a/board/amlogic/odroid-c2/odroid-c2.c +++ b/board/amlogic/odroid-c2/odroid-c2.c @@ -5,18 +5,12 @@
return 0; } diff --git a/board/amlogic/p212/p212.c b/board/amlogic/p212/p212.c index 06c2eaee47..57f776f404 100644 --- a/board/amlogic/p212/p212.c +++ b/board/amlogic/p212/p212.c @@ -6,18 +6,12 @@
-#define EFUSE_SN_OFFSET 20 -#define EFUSE_SN_SIZE 16 -#define EFUSE_MAC_OFFSET 52 -#define EFUSE_MAC_SIZE 6 - int board_init(void) { return 0; @@ -25,25 +19,8 @@ int board_init(void)
int misc_init_r(void) { - u8 mac_addr[EFUSE_MAC_SIZE]; - char serial[EFUSE_SN_SIZE]; - ssize_t len; - meson_gx_eth_init(PHY_INTERFACE_MODE_RMII, 0); - - if (!eth_env_get_enetaddr("ethaddr", mac_addr)) { - len = meson_sm_read_efuse(EFUSE_MAC_OFFSET, - mac_addr, EFUSE_MAC_SIZE); - if (len == EFUSE_MAC_SIZE && is_valid_ethaddr(mac_addr)) - eth_env_set_enetaddr("ethaddr", mac_addr); - } - - if (!env_get("serial#")) { - len = meson_sm_read_efuse(EFUSE_SN_OFFSET, serial, - EFUSE_SN_SIZE); - if (len == EFUSE_SN_SIZE) - env_set("serial#", serial); - } + meson_init_env_from_efuse();
return 0; }
Hi Beniamino,
- static u8 mac[EFUSE_MAC_SIZE];
- ssize_t len;
- if (!eth_env_get_enetaddr("ethaddr", mac)) {
EFUSE_SN_SIZE);
- ssize_t len;
EFUSE_SN_SIZE);
- ssize_t len;
EFUSE_SN_SIZE);
- ssize_t len;
EFUSE_SN_SIZE);
- ssize_t len;
EFUSE_SN_SIZE);
- ssize_t len;
EFUSE_SN_SIZE);
In fact, only the "Odroid-C2" board uses these EFUSE offsets for MAC and Serial, so this was a task on my infinite TODO list to fix the MAC readout on the other boards and use the Serial number from ATF and drop reading it from the Efuses.
For the story, it seems that the early GXBB does not implement the Secure Monitor ChipID call, but the later and GXL/GXM does. User can still store a serial number at offset : 18 with size 16
For MAC Address, for most products, they derive an unique mac address from the ChipID and allmost never store it on the Efuse... And another weird stuff, Hardkernel uses a weird Efuse offset, because amlogic uses a smaller offset : 0 and size 6
At least you could refactor by passing the offsets to the meson_init_env_from_efuse() call.
Neil
Terminate the serial number variable with null to avoid printing trailing garbage.
Signed-off-by: Beniamino Galvani b.galvani@gmail.com --- arch/arm/mach-meson/sm.c | 6 ++++-- 1 file changed, 4 insertions(+), 2 deletions(-)
diff --git a/arch/arm/mach-meson/sm.c b/arch/arm/mach-meson/sm.c index 2628591fe6..23eafe87b4 100644 --- a/arch/arm/mach-meson/sm.c +++ b/arch/arm/mach-meson/sm.c @@ -64,7 +64,7 @@ ssize_t meson_sm_read_efuse(uintptr_t offset, void *buffer, size_t size) void meson_init_env_from_efuse(void) { static u8 mac[EFUSE_MAC_SIZE]; - char serial[EFUSE_SN_SIZE]; + char serial[EFUSE_SN_SIZE + 1]; ssize_t len;
if (!eth_env_get_enetaddr("ethaddr", mac)) { @@ -77,7 +77,9 @@ void meson_init_env_from_efuse(void) if (!env_get("serial#")) { len = meson_sm_read_efuse(EFUSE_SN_OFFSET, serial, EFUSE_SN_SIZE); - if (len == EFUSE_SN_SIZE) + if (len == EFUSE_SN_SIZE) { + serial[EFUSE_SN_SIZE] = '\0'; env_set("serial#", serial); + } } }
Beniamino Galvani
Neil Armstrong
