[U-Boot] [PATCH v3 0/3] Allwinner DE2 HDMI SimpleFB support
This patchset is for Allwinner DE2 HDMI SimpleFB support.
The framebuffer initialized by the Allwinner DE2 driver can be passed by to the kernel as simplefb, and this can enable the kernel to display graphics without having full DE2 driver.
Add the suppot of simplefb in DE2 code.
The code to find a simplefb with sunxi extension and a suitable pipeline is extracted to a new source file in video/sunxi/.
An option is added for device tree simplefb, and furtherly the DE1 simplefb support should also be converted to it.
Icenowy Zheng (3): video: sunxi: extract simplefb match code to a new file video: add an option for video simplefb via DT sunxi: setup simplefb for Allwinner DE2
drivers/video/Kconfig | 10 +++++ drivers/video/sunxi/Makefile | 4 +- drivers/video/sunxi/simplefb_common.c | 29 ++++++++++++++ drivers/video/sunxi/simplefb_common.h | 22 +++++++++++ drivers/video/sunxi/sunxi_de2.c | 72 +++++++++++++++++++++++++++++++++++ drivers/video/sunxi/sunxi_display.c | 13 +------ 6 files changed, 137 insertions(+), 13 deletions(-) create mode 100644 drivers/video/sunxi/simplefb_common.c create mode 100644 drivers/video/sunxi/simplefb_common.h
As the DE2 simplefb setup code can also benefit from the simplefb match code, extract it to a new source file.
Signed-off-by: Icenowy Zheng icenowy@aosc.io Reviewed-by: Andre Przywara andre.przywara@arm.com --- Changes in v3: - Use /** to start kerndoc.
drivers/video/sunxi/Makefile | 2 +- drivers/video/sunxi/simplefb_common.c | 29 +++++++++++++++++++++++++++++ drivers/video/sunxi/simplefb_common.h | 22 ++++++++++++++++++++++ drivers/video/sunxi/sunxi_display.c | 13 ++----------- 4 files changed, 54 insertions(+), 12 deletions(-) create mode 100644 drivers/video/sunxi/simplefb_common.c create mode 100644 drivers/video/sunxi/simplefb_common.h
diff --git a/drivers/video/sunxi/Makefile b/drivers/video/sunxi/Makefile index 0d64c2021f..10862edaca 100644 --- a/drivers/video/sunxi/Makefile +++ b/drivers/video/sunxi/Makefile @@ -5,5 +5,5 @@ # SPDX-License-Identifier: GPL-2.0+ #
-obj-$(CONFIG_VIDEO_SUNXI) += sunxi_display.o lcdc.o tve_common.o ../videomodes.o +obj-$(CONFIG_VIDEO_SUNXI) += sunxi_display.o simplefb_common.o lcdc.o tve_common.o ../videomodes.o obj-$(CONFIG_VIDEO_DE2) += sunxi_de2.o sunxi_dw_hdmi.o lcdc.o ../dw_hdmi.o diff --git a/drivers/video/sunxi/simplefb_common.c b/drivers/video/sunxi/simplefb_common.c new file mode 100644 index 0000000000..4823f13a0c --- /dev/null +++ b/drivers/video/sunxi/simplefb_common.c @@ -0,0 +1,29 @@ +/* + * Common code for Allwinner SimpleFB with pipeline. + * + * (C) Copyright 2014-2015 Hans de Goede hdegoede@redhat.com + * (C) Copyright 2017 Icenowy Zheng icenowy@aosc.io + * + * SPDX-License-Identifier: GPL-2.0+ + */ + +#include <fdtdec.h> + +int sunxi_simplefb_fdt_match(void *blob, const char *pipeline) +{ + int offset, ret; + + /* Find a prefilled simpefb node, matching out pipeline config */ + offset = fdt_node_offset_by_compatible(blob, -1, + "allwinner,simple-framebuffer"); + while (offset >= 0) { + ret = fdt_stringlist_search(blob, offset, "allwinner,pipeline", + pipeline); + if (ret == 0) + break; + offset = fdt_node_offset_by_compatible(blob, offset, + "allwinner,simple-framebuffer"); + } + + return offset; +} diff --git a/drivers/video/sunxi/simplefb_common.h b/drivers/video/sunxi/simplefb_common.h new file mode 100644 index 0000000000..1a2bfabf00 --- /dev/null +++ b/drivers/video/sunxi/simplefb_common.h @@ -0,0 +1,22 @@ +/* + * (C) Copyright 2017 Icenowy Zheng icenowy@aosc.io + * + * SPDX-License-Identifier: GPL-2.0+ + */ + +#ifndef __SIMPLEFB_COMMON_H +#define __SIMPLEFB_COMMON_H + +/** + * sunxi_simplefb_fdt_match() - match a sunxi simplefb node + * + * Match a sunxi simplefb device node with a specified pipeline, and + * return its offset. + * + * @blob: device tree blob + * @pipeline: display pipeline + * @return device node offset in blob, or negative values if failed + */ +int sunxi_simplefb_fdt_match(void *blob, const char *pipeline); + +#endif diff --git a/drivers/video/sunxi/sunxi_display.c b/drivers/video/sunxi/sunxi_display.c index de768ba94a..7f25ed5f26 100644 --- a/drivers/video/sunxi/sunxi_display.c +++ b/drivers/video/sunxi/sunxi_display.c @@ -29,6 +29,7 @@ #include "../anx9804.h" #include "../hitachi_tx18d42vm_lcd.h" #include "../ssd2828.h" +#include "simplefb_common.h"
#ifdef CONFIG_VIDEO_LCD_BL_PWM_ACTIVE_LOW #define PWM_ON 0 @@ -1377,17 +1378,7 @@ int sunxi_simplefb_setup(void *blob) break; }
- /* Find a prefilled simpefb node, matching out pipeline config */ - offset = fdt_node_offset_by_compatible(blob, -1, - "allwinner,simple-framebuffer"); - while (offset >= 0) { - ret = fdt_stringlist_search(blob, offset, "allwinner,pipeline", - pipeline); - if (ret == 0) - break; - offset = fdt_node_offset_by_compatible(blob, offset, - "allwinner,simple-framebuffer"); - } + offset = sunxi_simplefb_fdt_match(blob, pipeline); if (offset < 0) { eprintf("Cannot setup simplefb: node not found\n"); return 0; /* Keep older kernels working */
Acked-by: Maxime Ripard maxime.ripard@free-electrons.com
Changes in v3:
- Common code for Allwinner SimpleFB with pipeline.
- (C) Copyright 2014-2015 Hans de Goede hdegoede@redhat.com
Your copyright notice seems to be missing
* (C) Copyright 2013-2014 Luc Verhaegen libv@skynet.be
- (C) Copyright 2017 Icenowy Zheng icenowy@aosc.io
- int offset, ret;
pipeline);
if (ret == 0)
break;
- return offset;
- sunxi_simplefb_fdt_match() - match a sunxi simplefb node
- Match a sunxi simplefb device node with a specified pipeline, and
- return its offset.
- @blob: device tree blob
- @pipeline: display pipeline
- @return device node offset in blob, or negative values if failed
pipeline);
if (ret == 0)
break;
- offset = sunxi_simplefb_fdt_match(blob, pipeline); if (offset < 0) { eprintf("Cannot setup simplefb: node not found\n"); return 0; /* Keep older kernels working */
Here is the "git blame" output for this part of code that you are moving around by your patch:
2dae800f drivers/video/sunxi_display.c (Hans de Goede 2014-12-21 16:28:32 +0100 1380) /* Find a prefilled simpefb node, matching out pipeline config */ 2d7a084b drivers/video/sunxi_display.c (Luc Verhaegen 2014-08-13 07:55:07 +0200 1381) offset = fdt_node_offset_by_compatible(blob, -1, 2d7a084b drivers/video/sunxi_display.c (Luc Verhaegen 2014-08-13 07:55:07 +0200 1382) "allwinner,simple-framebuffer"); 2d7a084b drivers/video/sunxi_display.c (Luc Verhaegen 2014-08-13 07:55:07 +0200 1383) while (offset >= 0) { b02e4044 drivers/video/sunxi_display.c (Simon Glass 2016-10-02 17:59:28 -0600 1384) ret = fdt_stringlist_search(blob, offset, "allwinner,pipeline", 6e67f176 drivers/video/sunxi_display.c (Masahiro Yamada 2016-10-17 20:43:01 +0900 1385) pipeline); 2d7a084b drivers/video/sunxi_display.c (Luc Verhaegen 2014-08-13 07:55:07 +0200 1386) if (ret == 0) 2d7a084b drivers/video/sunxi_display.c (Luc Verhaegen 2014-08-13 07:55:07 +0200 1387) break; 2d7a084b drivers/video/sunxi_display.c (Luc Verhaegen 2014-08-13 07:55:07 +0200 1388) offset = fdt_node_offset_by_compatible(blob, offset, 2d7a084b drivers/video/sunxi_display.c (Luc Verhaegen 2014-08-13 07:55:07 +0200 1389) "allwinner,simple-framebuffer"); 2d7a084b drivers/video/sunxi_display.c (Luc Verhaegen 2014-08-13 07:55:07 +0200 1390) } 2d7a084b drivers/video/sunxi_display.c (Luc Verhaegen 2014-08-13 07:55:07 +0200 1391) if (offset < 0) { 2d7a084b drivers/video/sunxi_display.c (Luc Verhaegen 2014-08-13 07:55:07 +0200 1392) eprintf("Cannot setup simplefb: node not found\n"); 2d7a084b drivers/video/sunxi_display.c (Luc Verhaegen 2014-08-13 07:55:07 +0200 1393) return 0; /* Keep older kernels working */ 2d7a084b drivers/video/sunxi_display.c (Luc Verhaegen 2014-08-13 07:55:07 +0200 1394) }
Luc Verhaegen is the real author of the sunxi DE1 simplefb code in U-Boot. If you need to pick only one copyright line from the old code, then you should mention Luc instead of Hans. Hans de Goede surely has done a lot of massaging for this code later (plus added EDID and LCD support). But it was Luc, who made it happen back in 2014 by providing a usable graphics support for the mainline kernel users and laid down the foundation for all the further incremental improvements.
If not for Luc Verhaegen, we don't even know what would be the current state of the graphics support on sunxi hardware. And the number of commits does not matter, what matters is having the job done. And Luc did just that. So let's give credit where it is due.
With a proper copyright notice, this patch is Acked-by: Siarhei Siamashka siarhei.siamashka@gmail.com
Add an option to indicate that the video driver should setup a SimpleFB node that passes the video framebuffer initialized by U-Boot to the operating system kernel.
Currently only the Allwinner DE2 driver uses this option.
Signed-off-by: Icenowy Zheng icenowy@aosc.io --- drivers/video/Kconfig | 10 ++++++++++ 1 file changed, 10 insertions(+)
diff --git a/drivers/video/Kconfig b/drivers/video/Kconfig index 082cc4a528..e4e71763f5 100644 --- a/drivers/video/Kconfig +++ b/drivers/video/Kconfig @@ -601,4 +601,14 @@ config VIDEO_DW_HDMI rather requires a SoC-specific glue driver to call it), it can not be enabled from the configuration menu.
+config VIDEO_DT_SIMPLEFB + bool "Enable SimpleFB support for passing framebuffer to OS" + depends on VIDEO_DE2 + default y + help + Enables the code to pass the framebuffer to the kernel as a + simple framebuffer in the device tree. + The video output is initialized by U-Boot, and kept by the + kernel. + endmenu
- bool "Enable SimpleFB support for passing framebuffer to OS"
- depends on VIDEO_DE2
- default y
SIMPLEFB is also used by other platforms, but most platforms also won't use it.
Adding an imply VIDEO_DT_SIMPLEFB to VIDEO_DE2 would make everyone happy I guess.
Maxime
在 2017-09-13 20:04,Maxime Ripard 写道:
- default y
Then should I drop the "depends on VIDEO_DE2"?
Maxime
-- Maxime Ripard, Free Electrons Embedded Linux and Kernel engineering http://free-electrons.com
- default y
Yes.
Maxime
You meant adding a "select VIDEO_DT_SIMPLEFB" to VIDEO_DE2 ?
I think he explicitly meant "imply", which is a rather recent addition to Kconfig [1]:
=============== - weak reverse dependencies: "imply" <symbol> ["if" <expr>] This is similar to "select" as it enforces a lower limit on another symbol except that the "implied" symbol's value may still be set to n from a direct dependency or with a visible prompt. ===============
[1] https://git.kernel.org/pub/scm/linux/kernel/git/torvalds/linux.git/tree/Docu...
Cheers, Andre
As the support of EFI boot on Allwinner H3 is broken, we still need to use simplefb to pass the framebuffer to Linux.
Add code to setup simplefb for Allwinner DE2 driver.
Signed-off-by: Icenowy Zheng icenowy@aosc.io --- Changes in v3: - Extract CONFIG_VIDEO_DT_SIMPLEFB to a Kconfig option.
Changes in v2: - Extract the simplefb node searching code.
drivers/video/sunxi/Makefile | 2 +- drivers/video/sunxi/sunxi_de2.c | 72 +++++++++++++++++++++++++++++++++++++++++ 2 files changed, 73 insertions(+), 1 deletion(-)
diff --git a/drivers/video/sunxi/Makefile b/drivers/video/sunxi/Makefile index 10862edaca..aec32b79b9 100644 --- a/drivers/video/sunxi/Makefile +++ b/drivers/video/sunxi/Makefile @@ -6,4 +6,4 @@ #
obj-$(CONFIG_VIDEO_SUNXI) += sunxi_display.o simplefb_common.o lcdc.o tve_common.o ../videomodes.o -obj-$(CONFIG_VIDEO_DE2) += sunxi_de2.o sunxi_dw_hdmi.o lcdc.o ../dw_hdmi.o +obj-$(CONFIG_VIDEO_DE2) += sunxi_de2.o sunxi_dw_hdmi.o simplefb_common.o lcdc.o ../dw_hdmi.o diff --git a/drivers/video/sunxi/sunxi_de2.c b/drivers/video/sunxi/sunxi_de2.c index ee67764ac5..67b937098c 100644 --- a/drivers/video/sunxi/sunxi_de2.c +++ b/drivers/video/sunxi/sunxi_de2.c @@ -10,6 +10,8 @@ #include <display.h> #include <dm.h> #include <edid.h> +#include <fdtdec.h> +#include <fdt_support.h> #include <video.h> #include <asm/global_data.h> #include <asm/io.h> @@ -17,6 +19,7 @@ #include <asm/arch/display2.h> #include <dm/device-internal.h> #include <dm/uclass-internal.h> +#include "simplefb_common.h"
DECLARE_GLOBAL_DATA_PTR;
@@ -292,3 +295,72 @@ U_BOOT_DRIVER(sunxi_de2) = { U_BOOT_DEVICE(sunxi_de2) = { .name = "sunxi_de2" }; + +/* + * Simplefb support. + */ +#if defined(CONFIG_OF_BOARD_SETUP) && defined(CONFIG_VIDEO_DT_SIMPLEFB) +int sunxi_simplefb_setup(void *blob) +{ + struct udevice *de2, *hdmi; + struct video_priv *de2_priv; + struct video_uc_platdata *de2_plat; + int mux; + int offset, ret; + u64 start, size; + const char *pipeline = NULL; + + debug("Setting up simplefb\n"); + + if (IS_ENABLED(CONFIG_MACH_SUNXI_H3_H5)) + mux = 0; + else + mux = 1; + + /* Skip simplefb setting if DE2 / HDMI is not present */ + ret = uclass_find_device_by_name(UCLASS_VIDEO, + "sunxi_de2", &de2); + if (ret) { + debug("DE2 not present\n"); + return 0; + } + + ret = uclass_find_device_by_name(UCLASS_DISPLAY, + "sunxi_dw_hdmi", &hdmi); + if (ret) { + debug("HDMI not present\n"); + return 0; + } + + if (mux == 0) + pipeline = "mixer0-lcd0-hdmi"; + else + pipeline = "mixer1-lcd1-hdmi"; + + de2_priv = dev_get_uclass_priv(de2); + de2_plat = dev_get_uclass_platdata(de2); + + offset = sunxi_simplefb_fdt_match(blob, pipeline); + if (offset < 0) { + eprintf("Cannot setup simplefb: node not found\n"); + return 0; /* Keep older kernels working */ + } + + start = gd->bd->bi_dram[0].start; + size = de2_plat->base - start; + ret = fdt_fixup_memory_banks(blob, &start, &size, 1); + if (ret) { + eprintf("Cannot setup simplefb: Error reserving memory\n"); + return ret; + } + + ret = fdt_setup_simplefb_node(blob, offset, de2_plat->base, + de2_priv->xsize, de2_priv->ysize, + VNBYTES(de2_priv->bpix) * de2_priv->xsize, + "x8r8g8b8"); + if (ret) + eprintf("Cannot setup simplefb: Error setting properties\n"); + + return ret; +} +#endif /* CONFIG_OF_BOARD_SETUP && CONFIG_VIDEO_DT_SIMPLEFB */
Maxime
participants (6)
Andre Przywara
Icenowy Zheng
icenowy@aosc.io
Maxime Ripard
Siarhei Siamashka
Vincent Legoll
