[U-Boot] [PATCH 1/2] tools: update checkpatch to latest upstream version
i.e., from the linux kernel's commit be987d9f80354e2e919926349282facd74992f90
Signed-off-by: Kim Phillips kim.phillips@freescale.com --- tools/checkpatch.pl | 752 ++++++++++++++++++++++++++++++++++++++-------------- 1 file changed, 558 insertions(+), 194 deletions(-)
diff --git a/tools/checkpatch.pl b/tools/checkpatch.pl index c7475f9..b28cc38 100755 --- a/tools/checkpatch.pl +++ b/tools/checkpatch.pl @@ -33,6 +33,7 @@ my %ignore_type = (); my @ignore = (); my $help = 0; my $configuration_file = ".checkpatch.conf"; +my $max_line_length = 80;
sub help { my ($exitcode) = @_; @@ -51,6 +52,7 @@ Options: -f, --file treat FILE as regular source file --subjective, --strict enable more subjective tests --ignore TYPE(,TYPE2...) ignore various comma separated message types + --max-line-length=n set the maximum line length, if exceeded, warn --show-types show the message "types" in the output --root=PATH PATH to the kernel tree root --no-summary suppress the per-file summary @@ -107,6 +109,7 @@ GetOptions( 'strict!' => $check, 'ignore=s' => @ignore, 'show-types!' => $show_types, + 'max-line-length=i' => $max_line_length, 'root=s' => $root, 'summary!' => $summary, 'mailback!' => $mailback, @@ -227,8 +230,12 @@ our $Inline = qr{inline|__always_inline|noinline}; our $Member = qr{->$Ident|.$Ident|[[^]]*]}; our $Lval = qr{$Ident(?:$Member)*};
-our $Constant = qr{(?:[0-9]+|0x[0-9a-fA-F]+)[UL]*}; -our $Assignment = qr{(?:*=|/=|%=|+=|-=|<<=|>>=|&=|^=||=|=)}; +our $Float_hex = qr{(?i)0x[0-9a-f]+p-?[0-9]+[fl]?}; +our $Float_dec = qr{(?i)(?:[0-9]+.[0-9]*|[0-9]*.[0-9]+)(?:e-?[0-9]+)?[fl]?}; +our $Float_int = qr{(?i)[0-9]+e-?[0-9]+[fl]?}; +our $Float = qr{$Float_hex|$Float_dec|$Float_int}; +our $Constant = qr{$Float|(?i)(?:0x[0-9a-f]+|[0-9]+)[ul]*}; +our $Assignment = qr{*=|/=|%=|+=|-=|<<=|>>=|&=|^=||=|=}; our $Compare = qr{<=|>=|==|!=|<|>}; our $Operators = qr{ <=|>=|==|!=| @@ -240,9 +247,8 @@ our $NonptrType; our $Type; our $Declare;
-our $UTF8 = qr { - [\x09\x0A\x0D\x20-\x7E] # ASCII - | [\xC2-\xDF][\x80-\xBF] # non-overlong 2-byte +our $NON_ASCII_UTF8 = qr{ + [\xC2-\xDF][\x80-\xBF] # non-overlong 2-byte | \xE0[\xA0-\xBF][\x80-\xBF] # excluding overlongs | [\xE1-\xEC\xEE\xEF][\x80-\xBF]{2} # straight 3-byte | \xED[\x80-\x9F][\x80-\xBF] # excluding surrogates @@ -251,6 +257,11 @@ our $UTF8 = qr { | \xF4[\x80-\x8F][\x80-\xBF]{2} # plane 16 }x;
+our $UTF8 = qr{ + [\x09\x0A\x0D\x20-\x7E] # ASCII + | $NON_ASCII_UTF8 +}x; + our $typeTypedefs = qr{(?x: (?:__)?(?:u|s|be|le)(?:8|16|32|64)| atomic_t @@ -311,7 +322,7 @@ sub build_types { $NonptrType = qr{ (?:$Modifier\s+|const\s+)* (?: - (?:typeof|__typeof__)\s*(\s***\s*$Ident\s*)| + (?:typeof|__typeof__)\s*([^)]*)| (?:$typeTypedefs\b)| (?:${all}\b) ) @@ -319,17 +330,23 @@ sub build_types { }x; $Type = qr{ $NonptrType - (?:[\s*]+\s*const|[\s*]+|(?:\s*[\s*])+)? + (?:(?:\s|*|[])+\s*const|(?:\s|*|[])+|(?:\s*[\s*])+)? (?:\s+$Inline|\s+$Modifier)* }x; $Declare = qr{(?:$Storage\s+)?$Type}; } build_types();
-our $match_balanced_parentheses = qr/(((?:[^()]+|(-1))*))/;
our $Typecast = qr{\s*((\s*$NonptrType\s*)){0,1}\s*}; -our $LvalOrFunc = qr{($Lval)\s*($match_balanced_parentheses{0,1})\s*}; + +# Using $balanced_parens, $LvalOrFunc, or $FuncArg +# requires at least perl version v5.10.0 +# Any use must be runtime checked with $^V + +our $balanced_parens = qr/(((?:[^()]++|(?-1))*))/; +our $LvalOrFunc = qr{($Lval)\s*($balanced_parens{0,1})\s*}; +our $FuncArg = qr{$Typecast{0,1}($LvalOrFunc|$Constant)};
sub deparenthesize { my ($string) = @_; @@ -342,27 +359,6 @@ sub deparenthesize {
$chk_signoff = 0 if ($file);
-my @dep_includes = (); -my @dep_functions = (); -my $removal = "Documentation/feature-removal-schedule.txt"; -if ($tree && -f "$root/$removal") { - open(my $REMOVE, '<', "$root/$removal") || - die "$P: $removal: open failed - $!\n"; - while (<$REMOVE>) { - if (/^Check:\s+(.*\S)/) { - for my $entry (split(/[, ]+/, $1)) { - if ($entry =~ m@include/(.*)@) { - push(@dep_includes, $1); - - } elsif ($entry !~ m@/@) { - push(@dep_functions, $entry); - } - } - } - } - close($REMOVE); -} - my @rawlines = (); my @lines = (); my $vname; @@ -411,7 +407,7 @@ sub top_of_kernel_tree { } } return 1; - } +}
sub parse_email { my ($formatted_email) = @_; @@ -672,6 +668,10 @@ sub ctx_statement_block { if ($off >= $len) { last; } + if ($level == 0 && substr($blk, $off) =~ /^.\s*#\s*define/) { + $level++; + $type = '#'; + } } $p = $c; $c = substr($blk, $off, 1); @@ -734,6 +734,13 @@ sub ctx_statement_block { last; } } + # Preprocessor commands end at the newline unless escaped. + if ($type eq '#' && $c eq "\n" && $p ne "\") { + $level--; + $type = ''; + $off++; + last; + } $off++; } # We are truly at the end, so shuffle to the next line. @@ -1016,7 +1023,7 @@ sub annotate_values { } elsif ($cur =~ /^((\s*$Type\s*))/ && $av_pending eq '_') { print "CAST($1)\n" if ($dbg_values > 1); push(@av_paren_type, $type); - $type = 'C'; + $type = 'c';
} elsif ($cur =~ /^($Type)\s*(?:$Ident|,|)|(|\s*$)/) { print "DECLARE($1)\n" if ($dbg_values > 1); @@ -1208,7 +1215,9 @@ sub possible { case| else| asm|__asm__| - do + do| + #| + ##| )(?:\s|$)| ^(?:typedef|struct|enum)\b )}x; @@ -1312,6 +1321,36 @@ sub check_absolute_file { } }
+sub pos_last_openparen { + my ($line) = @_; + + my $pos = 0; + + my $opens = $line =~ tr/(/(/; + my $closes = $line =~ tr/)/)/; + + my $last_openparen = 0; + + if (($opens == 0) || ($closes >= $opens)) { + return -1; + } + + my $len = length($line); + + for ($pos = 0; $pos < $len; $pos++) { + my $string = substr($line, $pos); + if ($string =~ /^($FuncArg|$balanced_parens)/) { + $pos += length($1) - 1; + } elsif (substr($line, $pos, 1) eq '(') { + $last_openparen = $pos; + } elsif (index($string, '(') == -1) { + last; + } + } + + return $last_openparen + 1; +} + sub process { my $filename = shift;
@@ -1330,6 +1369,11 @@ sub process { my $signoff = 0; my $is_patch = 0;
+ my $in_header_lines = 1; + my $in_commit_log = 0; #Scanning lines before patch + + my $non_utf8_charset = 0; + our @report = (); our $cnt_lines = 0; our $cnt_error = 0; @@ -1352,6 +1396,9 @@ sub process { my %suppress_ifbraces; my %suppress_whiletrailers; my %suppress_export; + my $suppress_statement = 0; + + my %camelcase = ();
# Pre-scan the patch sanitizing the lines. # Pre-scan the patch looking for any __setup documentation. @@ -1461,6 +1508,7 @@ sub process { %suppress_ifbraces = (); %suppress_whiletrailers = (); %suppress_export = (); + $suppress_statement = 0; next;
# track the line number as we move through the hunk, note that @@ -1497,10 +1545,11 @@ sub process { if ($line =~ /^diff --git.*?(\S+)$/) { $realfile = $1; $realfile =~ s@^([^/]*)/@@; - + $in_commit_log = 0; } elsif ($line =~ /^+++\s+(\S+)/) { $realfile = $1; $realfile =~ s@^([^/]*)/@@; + $in_commit_log = 0;
$p1_prefix = $1; if (!$file && $tree && $p1_prefix ne '' && @@ -1536,16 +1585,22 @@ sub process { # Check the patch for a signoff: if ($line =~ /^\s*signed-off-by:/i) { $signoff++; + $in_commit_log = 0; }
# Check signature styles - if ($line =~ /^(\s*)($signature_tags)(\s*)(.*)/) { + if (!$in_header_lines && + $line =~ /^(\s*)([a-z0-9_-]+by:|$signature_tags)(\s*)(.*)/i) { my $space_before = $1; my $sign_off = $2; my $space_after = $3; my $email = $4; my $ucfirst_sign_off = ucfirst(lc($sign_off));
+ if ($sign_off !~ /$signature_tags/) { + WARN("BAD_SIGN_OFF", + "Non-standard signature: $sign_off\n" . $herecurr); + } if (defined $space_before && $space_before ne "") { WARN("BAD_SIGN_OFF", "Do not use whitespace before $ucfirst_sign_off\n" . $herecurr); @@ -1613,6 +1668,28 @@ sub process { "Invalid UTF-8, patch and commit message should be encoded in UTF-8\n" . $hereptr); }
+# Check if it's the start of a commit log +# (not a header line and we haven't seen the patch filename) + if ($in_header_lines && $realfile =~ /^$/ && + $rawline !~ /^(commit\b|from\b|[\w-]+:).+$/i) { + $in_header_lines = 0; + $in_commit_log = 1; + } + +# Check if there is UTF-8 in a commit log when a mail header has explicitly +# declined it, i.e defined some charset where it is missing. + if ($in_header_lines && + $rawline =~ /^Content-Type:.+charset="(.+)".*$/ && + $1 !~ /utf-8/i) { + $non_utf8_charset = 1; + } + + if ($in_commit_log && $non_utf8_charset && $realfile =~ /^$/ && + $rawline =~ /$NON_ASCII_UTF8/) { + WARN("UTF8_BEFORE_PATCH", + "8-bit UTF-8 used in possible commit log\n" . $herecurr); + } + # ignore non-hunk lines and lines being removed next if (!$hunk_line || $line =~ /^-/);
@@ -1633,19 +1710,26 @@ sub process { # Only applies when adding the entry originally, after that we do not have # sufficient context to determine whether it is indeed long enough. if ($realfile =~ /Kconfig/ && - $line =~ /+\s*(?:---)?help(?:---)?$/) { + $line =~ /.\s*config\s+/) { my $length = 0; my $cnt = $realcnt; my $ln = $linenr + 1; my $f; + my $is_start = 0; my $is_end = 0; - while ($cnt > 0 && defined $lines[$ln - 1]) { + for (; $cnt > 0 && defined $lines[$ln - 1]; $ln++) { $f = $lines[$ln - 1]; $cnt-- if ($lines[$ln - 1] !~ /^-/); $is_end = $lines[$ln - 1] =~ /^+/; - $ln++;
next if ($f =~ /^-/); + + if ($lines[$ln - 1] =~ /.\s*(?:bool|tristate)\s*"/) { + $is_start = 1; + } elsif ($lines[$ln - 1] =~ /.\s*(?:---)?help(?:---)?$/) { + $length = -1; + } + $f =~ s/^.//; $f =~ s/#.*//; $f =~ s/^\s+//; @@ -1657,22 +1741,58 @@ sub process { $length++; } WARN("CONFIG_DESCRIPTION", - "please write a paragraph that describes the config symbol fully\n" . $herecurr) if ($is_end && $length < 4); - #print "is_end<$is_end> length<$length>\n"; + "please write a paragraph that describes the config symbol fully\n" . $herecurr) if ($is_start && $is_end && $length < 4); + #print "is_start<$is_start> is_end<$is_end> length<$length>\n"; + } + +# discourage the addition of CONFIG_EXPERIMENTAL in Kconfig. + if ($realfile =~ /Kconfig/ && + $line =~ /.\s*depends on\s+.*\bEXPERIMENTAL\b/) { + WARN("CONFIG_EXPERIMENTAL", + "Use of CONFIG_EXPERIMENTAL is deprecated. For alternatives, see https://lkml.org/lkml/2012/10/23/580%5Cn"); + } + + if (($realfile =~ /Makefile.*/ || $realfile =~ /Kbuild.*/) && + ($line =~ /+(EXTRA_[A-Z]+FLAGS).*/)) { + my $flag = $1; + my $replacement = { + 'EXTRA_AFLAGS' => 'asflags-y', + 'EXTRA_CFLAGS' => 'ccflags-y', + 'EXTRA_CPPFLAGS' => 'cppflags-y', + 'EXTRA_LDFLAGS' => 'ldflags-y', + }; + + WARN("DEPRECATED_VARIABLE", + "Use of $flag is deprecated, please use `$replacement->{$flag} instead.\n" . $herecurr) if ($replacement->{$flag}); }
# check we are in a valid source file if not then ignore this hunk next if ($realfile !~ /.(h|c|s|S|pl|sh)$/);
-#80 column limit +#line length limit if ($line =~ /^+/ && $prevrawline !~ //**/ && $rawline !~ /^.\s**\s*@$Ident\s/ && !($line =~ /^+\s*$logFunctions\s*(\s*(?:(KERN_\S+\s*|[^"]*))?"[X\t]*"\s*(?:|,|)\s*;)\s*$/ || $line =~ /^+\s*"[^"]*"\s*(?:\s*|,|)\s*;)\s*$/) && - $length > 80) + $length > $max_line_length) { WARN("LONG_LINE", - "line over 80 characters\n" . $herecurr); + "line over $max_line_length characters\n" . $herecurr); + } + +# Check for user-visible strings broken across lines, which breaks the ability +# to grep for the string. Limited to strings used as parameters (those +# following an open parenthesis), which almost completely eliminates false +# positives, as well as warning only once per parameter rather than once per +# line of the string. Make an exception when the previous string ends in a +# newline (multiple lines in one string constant) or \n\t (common in inline +# assembly to indent the instruction on the following line). + if ($line =~ /^+\s*"/ && + $prevline =~ /"\s*$/ && + $prevline =~ /(/ && + $prevrawline !~ /\n(?:\t)*"\s*$/) { + WARN("SPLIT_STRING", + "quoted string split across lines\n" . $hereprev); }
# check for spaces before a quoted newline @@ -1721,6 +1841,58 @@ sub process { "please, no space before tabs\n" . $herevet); }
+# check for && or || at the start of a line + if ($rawline =~ /^+\s*(&&|||)/) { + CHK("LOGICAL_CONTINUATIONS", + "Logical continuations should be on the previous line\n" . $hereprev); + } + +# check multi-line statement indentation matches previous line + if ($^V && $^V ge 5.10.0 && + $prevline =~ /^+(\t*)(if (|$Ident().*(&&||||,)\s*$/) { + $prevline =~ /^+(\t*)(.*)$/; + my $oldindent = $1; + my $rest = $2; + + my $pos = pos_last_openparen($rest); + if ($pos >= 0) { + $line =~ /^(+| )([ \t]*)/; + my $newindent = $2; + + my $goodtabindent = $oldindent . + "\t" x ($pos / 8) . + " " x ($pos % 8); + my $goodspaceindent = $oldindent . " " x $pos; + + if ($newindent ne $goodtabindent && + $newindent ne $goodspaceindent) { + CHK("PARENTHESIS_ALIGNMENT", + "Alignment should match open parenthesis\n" . $hereprev); + } + } + } + + if ($line =~ /^+.**[ \t]*)[ \t]+/) { + CHK("SPACING", + "No space is necessary after a cast\n" . $hereprev); + } + + if ($realfile =~ m@^(drivers/net/|net/)@ && + $rawline =~ /^+[ \t]*/*[ \t]*$/ && + $prevrawline =~ /^+[ \t]*$/) { + WARN("NETWORKING_BLOCK_COMMENT_STYLE", + "networking block comments don't use an empty /* line, use /* Comment...\n" . $hereprev); + } + + if ($realfile =~ m@^(drivers/net/|net/)@ && + $rawline !~ m@^+[ \t]**/[ \t]*$@ && #trailing */ + $rawline !~ m@^+.*/*.**/[ \t]*$@ && #inline /*...*/ + $rawline !~ m@^+.**{2,}/[ \t]*$@ && #trailing **/ + $rawline =~ m@^+[ \t]*.+*/[ \t]*$@) { #non blank */ + WARN("NETWORKING_BLOCK_COMMENT_STYLE", + "networking block comments put the trailing */ on a separate line\n" . $herecurr); + } + # check for spaces at the beginning of a line. # Exceptions: # 1) within comments @@ -1735,6 +1907,12 @@ sub process { # check we are in a valid C source file if not then ignore this hunk next if ($realfile !~ /.(h|c)$/);
+# discourage the addition of CONFIG_EXPERIMENTAL in #if(def). + if ($line =~ /^+\s*#\s*if.*\bCONFIG_EXPERIMENTAL\b/) { + WARN("CONFIG_EXPERIMENTAL", + "Use of CONFIG_EXPERIMENTAL is deprecated. For alternatives, see https://lkml.org/lkml/2012/10/23/580%5Cn"); + } + # check for RCS/CVS revision markers if ($rawline =~ /^+.*$(Revision|Log|Id)(?:$|)/) { WARN("CVS_KEYWORD", @@ -1753,15 +1931,33 @@ sub process { "use the SSYNC() macro in asm/blackfin.h\n" . $herevet); }
+# check for old HOTPLUG __dev<foo> section markings + if ($line =~ /\b(__dev(init|exit)(data|const|))\b/) { + WARN("HOTPLUG_SECTION", + "Using $1 is unnecessary\n" . $herecurr); + } + # Check for potential 'bare' types my ($stat, $cond, $line_nr_next, $remain_next, $off_next, $realline_next); - if ($realcnt && $line =~ /.\s*\S/) { +#print "LINE<$line>\n"; + if ($linenr >= $suppress_statement && + $realcnt && $line =~ /.\s*\S/) { ($stat, $cond, $line_nr_next, $remain_next, $off_next) = ctx_statement_block($linenr, $realcnt, 0); $stat =~ s/\n./\n /g; $cond =~ s/\n./\n /g;
+#print "linenr<$linenr> <$stat>\n"; + # If this statement has no statement boundaries within + # it there is no point in retrying a statement scan + # until we hit end of it. + my $frag = $stat; $frag =~ s/;+\s*$//; + if ($frag !~ /(?:{|;)/) { +#print "skip<$line_nr_next>\n"; + $suppress_statement = $line_nr_next; + } + # Find the real next line. $realline_next = $line_nr_next; if (defined $realline_next && @@ -1850,6 +2046,12 @@ sub process { my $pre_ctx = "$1$2";
my ($level, @ctx) = ctx_statement_level($linenr, $realcnt, 0); + + if ($line =~ /^+\t{6,}/) { + WARN("DEEP_INDENTATION", + "Too many leading tabs - consider code refactoring\n" . $herecurr); + } + my $ctx_cnt = $realcnt - $#ctx - 1; my $ctx = join("\n", @ctx);
@@ -1887,6 +2089,9 @@ sub process {
# Check relative indent for conditionals and blocks. if ($line =~ /\b(?:(?:if|while|for)\s*(|do\b)/ && $line !~ /^.\s*#/ && $line !~ /}\s*while\s*/) { + ($stat, $cond, $line_nr_next, $remain_next, $off_next) = + ctx_statement_block($linenr, $realcnt, 0) + if (!defined $stat); my ($s, $c) = ($stat, $cond);
substr($s, 0, length($c), ''); @@ -2027,8 +2232,11 @@ sub process { my $path = $1; if ($path =~ m{//}) { ERROR("MALFORMED_INCLUDE", - "malformed #include filename\n" . - $herecurr); + "malformed #include filename\n" . $herecurr); + } + if ($path =~ "^uapi/" && $realfile =~ m@\binclude/uapi/@) { + ERROR("UAPI_INCLUDE", + "No #include in ...include/uapi/... should use a uapi/ path prefix\n" . $herecurr); } }
@@ -2054,7 +2262,7 @@ sub process { # XXX(foo); # EXPORT_SYMBOL(something_foo); my $name = $1; - if ($stat =~ /^.([A-Z_]+)\s*(\s*($Ident)/ && + if ($stat =~ /^(?:.\s*}\s*\n)?.([A-Z_]+)\s*(\s*($Ident)/ && $name =~ /^${Ident}_$2/) { #print "FOO C name<$name>\n"; $suppress_export{$realline_next} = 1; @@ -2132,8 +2340,9 @@ sub process {
# * goes on variable not on type # (char*[ const]) - if ($line =~ m{($NonptrType(\s*(?:$Modifier\b\s*|*\s*)+))}) { - my ($from, $to) = ($1, $1); + while ($line =~ m{(($NonptrType(\s*(?:$Modifier\b\s*|*\s*)+)))}g) { + #print "AA<$1>\n"; + my ($from, $to) = ($2, $2);
# Should start with a space. $to =~ s/^(\S)/ $1/; @@ -2148,8 +2357,10 @@ sub process { ERROR("POINTER_LOCATION", ""(foo$from)" should be "(foo$to)"\n" . $herecurr); } - } elsif ($line =~ m{\b$NonptrType(\s*(?:$Modifier\b\s*|*\s*)+)($Ident)}) { - my ($from, $to, $ident) = ($1, $1, $2); + } + while ($line =~ m{(\b$NonptrType(\s*(?:$Modifier\b\s*|*\s*)+)($Ident))}g) { + #print "BB<$1>\n"; + my ($from, $to, $ident) = ($2, $2, $3);
# Should start with a space. $to =~ s/^(\S)/ $1/; @@ -2210,6 +2421,30 @@ sub process { } }
+ if ($line =~ /\bprintk\s*(\s*KERN_([A-Z]+)/) { + my $orig = $1; + my $level = lc($orig); + $level = "warn" if ($level eq "warning"); + my $level2 = $level; + $level2 = "dbg" if ($level eq "debug"); + WARN("PREFER_PR_LEVEL", + "Prefer netdev_$level2(netdev, ... then dev_$level2(dev, ... then pr_$level(... to printk(KERN_$orig ...\n" . $herecurr); + } + + if ($line =~ /\bpr_warning\s*(/) { + WARN("PREFER_PR_LEVEL", + "Prefer pr_warn(... to pr_warning(...\n" . $herecurr); + } + + if ($line =~ /\bdev_printk\s*(\s*KERN_([A-Z]+)/) { + my $orig = $1; + my $level = lc($orig); + $level = "warn" if ($level eq "warning"); + $level = "dbg" if ($level eq "debug"); + WARN("PREFER_DEV_LEVEL", + "Prefer dev_$level(... to dev_printk(KERN_$orig, ...\n" . $herecurr); + } + # function brace can't be on same line, except for #defines of do while, # or if closed on same line if (($line=~/$Type\s*$Ident(.*).*\s{/) and @@ -2239,7 +2474,7 @@ sub process { my ($where, $prefix) = ($-[1], $1); if ($prefix !~ /$Type\s+$/ && ($where != 0 || $prefix !~ /^.\s+$/) && - $prefix !~ /{\s+$/) { + $prefix !~ /[{,]\s+$/) { ERROR("BRACKET_SPACE", "space prohibited before open square bracket '['\n" . $herecurr); } @@ -2276,6 +2511,13 @@ sub process { "space prohibited between function name and open parenthesis '('\n" . $herecurr); } } + +# check for whitespace before a non-naked semicolon + if ($line =~ /^+.*\S\s+;/) { + CHK("SPACING", + "space prohibited before semicolon\n" . $herecurr); + } + # Check operator spacing. if (!($line=~/#\s*include/)) { my $ops = qr{ @@ -2440,13 +2682,13 @@ sub process { ($op eq '>' && $ca =~ /<\S+@\S+$/)) { - $ok = 1; + $ok = 1; }
# Ignore ?: if (($opv eq ':O' && $ca =~ /?$/) || ($op eq '?' && $cc =~ /^:/)) { - $ok = 1; + $ok = 1; }
if ($ok == 0) { @@ -2532,7 +2774,7 @@ sub process { # Flatten any parentheses $value =~ s/(/ (/g; $value =~ s/)/) /g; - while ($value =~ s/[[^{}]*]/1/ || + while ($value =~ s/[[^[]]*]/1/ || $value !~ /(?:$Ident|-?$Constant)\s* $Compare\s* (?:$Ident|-?$Constant)/x && @@ -2557,28 +2799,6 @@ sub process { } }
-# typecasts on min/max could be min_t/max_t - if ($line =~ /^+(?:.*?)\b(min|max)\s*($Typecast{0,1}($LvalOrFunc)\s*,\s*$Typecast{0,1}($LvalOrFunc)\s*)/) { - if (defined $2 || defined $8) { - my $call = $1; - my $cast1 = deparenthesize($2); - my $arg1 = $3; - my $cast2 = deparenthesize($8); - my $arg2 = $9; - my $cast; - - if ($cast1 ne "" && $cast2 ne "") { - $cast = "$cast1 or $cast2"; - } elsif ($cast1 ne "") { - $cast = $cast1; - } else { - $cast = $cast2; - } - WARN("MINMAX", - "$call() should probably be ${call}_t($cast, $arg1, $arg2)\n" . $herecurr); - } - } - # Need a space before open parenthesis after if, while etc if ($line=~/\b(if|while|for|switch)(/) { ERROR("SPACING", "space required before the open parenthesis '('\n" . $herecurr); @@ -2587,6 +2807,9 @@ sub process { # Check for illegal assignment in if conditional -- and check for trailing # statements after the conditional. if ($line =~ /do\s*(?!{)/) { + ($stat, $cond, $line_nr_next, $remain_next, $off_next) = + ctx_statement_block($linenr, $realcnt, 0) + if (!defined $stat); my ($stat_next) = ctx_statement_block($line_nr_next, $remain_next, $off_next); $stat_next =~ s/\n./\n /g; @@ -2702,12 +2925,18 @@ sub process { } }
-#studly caps, commented out until figure out how to distinguish between use of existing and adding new -# if (($line=~/[\w_][a-z\d]+[A-Z]/) and !($line=~/print/)) { -# print "No studly caps, use _\n"; -# print "$herecurr"; -# $clean = 0; -# } +#CamelCase + while ($line =~ m{($Constant|$Lval)}g) { + my $var = $1; + if ($var !~ /$Constant/ && + $var =~ /[A-Z]\w*[a-z]|[a-z]\w*[A-Z]/ && + $var !~ /"^(?:Clear|Set|TestClear|TestSet|)Page[A-Z]/ && + !defined $camelcase{$var}) { + $camelcase{$var} = 1; + WARN("CAMELCASE", + "Avoid CamelCase: <$var>\n" . $herecurr); + } + }
#no spaces allowed after \ in define if ($line=~/#\s*define.*\\s$/) { @@ -2742,47 +2971,13 @@ sub process { my $cnt = $realcnt; my ($off, $dstat, $dcond, $rest); my $ctx = ''; - - my $args = defined($1); - - # Find the end of the macro and limit our statement - # search to that. - while ($cnt > 0 && defined $lines[$ln - 1] && - $lines[$ln - 1] =~ /^(?:-|..*\$)/) - { - $ctx .= $rawlines[$ln - 1] . "\n"; - $cnt-- if ($lines[$ln - 1] !~ /^-/); - $ln++; - } - $ctx .= $rawlines[$ln - 1]; - ($dstat, $dcond, $ln, $cnt, $off) = - ctx_statement_block($linenr, $ln - $linenr + 1, 0); + ctx_statement_block($linenr, $realcnt, 0); + $ctx = $dstat; #print "dstat<$dstat> dcond<$dcond> cnt<$cnt> off<$off>\n"; #print "LINE<$lines[$ln-1]> len<" . length($lines[$ln-1]) . "\n";
- # Extract the remainder of the define (if any) and - # rip off surrounding spaces, and trailing 's. - $rest = ''; - while ($off != 0 || ($cnt > 0 && $rest =~ /\\s*$/)) { - #print "ADDING cnt<$cnt> $off <" . substr($lines[$ln - 1], $off) . "> rest<$rest>\n"; - if ($off != 0 || $lines[$ln - 1] !~ /^-/) { - $rest .= substr($lines[$ln - 1], $off) . "\n"; - $cnt--; - } - $ln++; - $off = 0; - } - $rest =~ s/\\n.//g; - $rest =~ s/^\s*//s; - $rest =~ s/\s*$//s; - - # Clean up the original statement. - if ($args) { - substr($dstat, 0, length($dcond), ''); - } else { - $dstat =~ s/^.\s*#\s*define\s+$Ident\s*//; - } + $dstat =~ s/^.\s*#\s*define\s+$Ident(?:([^)]*))?\s*//; $dstat =~ s/$;//g; $dstat =~ s/\\n.//g; $dstat =~ s/^\s*//s; @@ -2791,14 +2986,20 @@ sub process { # Flatten any parentheses and braces while ($dstat =~ s/([^()]*)/1/ || $dstat =~ s/{[^{}]*}/1/ || - $dstat =~ s/[[^{}]*]/1/) + $dstat =~ s/[[^[]]*]/1/) + { + } + + # Flatten any obvious string concatentation. + while ($dstat =~ s/("X*")\s*$Ident/$1/ || + $dstat =~ s/$Ident\s*("X*")/$1/) { }
my $exceptions = qr{ $Declare| module_param_named| - MODULE_PARAM_DESC| + MODULE_PARM_DESC| DECLARE_PER_CPU| DEFINE_PER_CPU| __typeof__(| @@ -2808,23 +3009,84 @@ sub process { ^"|"$ }x; #print "REST<$rest> dstat<$dstat> ctx<$ctx>\n"; - if ($rest ne '' && $rest ne ',') { - if ($rest !~ /while\s*(/ && - $dstat !~ /$exceptions/) - { - ERROR("MULTISTATEMENT_MACRO_USE_DO_WHILE", - "Macros with multiple statements should be enclosed in a do - while loop\n" . "$here\n$ctx\n"); + if ($dstat ne '' && + $dstat !~ /^(?:$Ident|-?$Constant),$/ && # 10, // foo(), + $dstat !~ /^(?:$Ident|-?$Constant);$/ && # foo(); + $dstat !~ /^[!~-]?(?:$Ident|$Constant)$/ && # 10 // foo() // !foo // ~foo // -foo + $dstat !~ /^'X'$/ && # character constants + $dstat !~ /$exceptions/ && + $dstat !~ /^.$Ident\s*=/ && # .foo = + $dstat !~ /^do\s*$Constant\s*while\s*$Constant;?$/ && # do {...} while (...); // do {...} while (...) + $dstat !~ /^for\s*$Constant$/ && # for (...) + $dstat !~ /^for\s*$Constant\s+(?:$Ident|-?$Constant)$/ && # for (...) bar() + $dstat !~ /^do\s*{/ && # do {... + $dstat !~ /^({/) # ({... + { + $ctx =~ s/\n*$//; + my $herectx = $here . "\n"; + my $cnt = statement_rawlines($ctx); + + for (my $n = 0; $n < $cnt; $n++) { + $herectx .= raw_line($linenr, $n) . "\n"; }
- } elsif ($ctx !~ /;/) { - if ($dstat ne '' && - $dstat !~ /^(?:$Ident|-?$Constant)$/ && - $dstat !~ /$exceptions/ && - $dstat !~ /^.$Ident\s*=/ && - $dstat =~ /$Operators/) - { + if ($dstat =~ /;/) { + ERROR("MULTISTATEMENT_MACRO_USE_DO_WHILE", + "Macros with multiple statements should be enclosed in a do - while loop\n" . "$herectx"); + } else { ERROR("COMPLEX_MACRO", - "Macros with complex values should be enclosed in parenthesis\n" . "$here\n$ctx\n"); + "Macros with complex values should be enclosed in parenthesis\n" . "$herectx"); + } + } + +# check for line continuations outside of #defines, preprocessor #, and asm + + } else { + if ($prevline !~ /^..*\$/ && + $line !~ /^+\s*#.*\$/ && # preprocessor + $line !~ /^+.*\b(__asm__|asm)\b.*\$/ && # asm + $line =~ /^+.*\$/) { + WARN("LINE_CONTINUATIONS", + "Avoid unnecessary line continuations\n" . $herecurr); + } + } + +# do {} while (0) macro tests: +# single-statement macros do not need to be enclosed in do while (0) loop, +# macro should not end with a semicolon + if ($^V && $^V ge 5.10.0 && + $realfile !~ m@/vmlinux.lds.h$@ && + $line =~ /^.\s*#\s*define\s+$Ident(()?/) { + my $ln = $linenr; + my $cnt = $realcnt; + my ($off, $dstat, $dcond, $rest); + my $ctx = ''; + ($dstat, $dcond, $ln, $cnt, $off) = + ctx_statement_block($linenr, $realcnt, 0); + $ctx = $dstat; + + $dstat =~ s/\\n.//g; + + if ($dstat =~ /^+\s*#\s*define\s+$Ident\s*${balanced_parens}\s*do\s*{(.*)\s*}\s*while\s*(\s*0\s*)\s*([;\s]*)\s*$/) { + my $stmts = $2; + my $semis = $3; + + $ctx =~ s/\n*$//; + my $cnt = statement_rawlines($ctx); + my $herectx = $here . "\n"; + + for (my $n = 0; $n < $cnt; $n++) { + $herectx .= raw_line($linenr, $n) . "\n"; + } + + if (($stmts =~ tr/;/;/) == 1 && + $stmts !~ /^\s*(if|while|for|switch)\b/) { + WARN("SINGLE_STATEMENT_DO_WHILE_MACRO", + "Single statement macros should not use a do {} while (0) loop\n" . "$herectx"); + } + if (defined $semis && $semis ne "") { + WARN("DO_WHILE_MACRO_WITH_TRAILING_SEMICOLON", + "do {} while (0) macros should not be semicolon terminated\n" . "$herectx"); } } } @@ -2846,7 +3108,8 @@ sub process { #print "chunks<$#chunks> linenr<$linenr> endln<$endln> level<$level>\n"; #print "APW: <<$chunks[1][0]>><<$chunks[1][1]>>\n"; if ($#chunks > 0 && $level == 0) { - my $allowed = 0; + my @allowed = (); + my $allow = 0; my $seen = 0; my $herectx = $here . "\n"; my $ln = $linenr - 1; @@ -2857,6 +3120,7 @@ sub process { my ($whitespace) = ($cond =~ /^((?:\s*\n[+-])*\s*)/s); my $offset = statement_rawlines($whitespace) - 1;
+ $allowed[$allow] = 0; #print "COND<$cond> whitespace<$whitespace> offset<$offset>\n";
# We have looked at and allowed this specific line. @@ -2869,23 +3133,34 @@ sub process {
$seen++ if ($block =~ /^\s*{/);
- #print "cond<$cond> block<$block> allowed<$allowed>\n"; + #print "cond<$cond> block<$block> allowed<$allowed[$allow]>\n"; if (statement_lines($cond) > 1) { #print "APW: ALLOWED: cond<$cond>\n"; - $allowed = 1; + $allowed[$allow] = 1; } if ($block =~/\b(?:if|for|while)\b/) { #print "APW: ALLOWED: block<$block>\n"; - $allowed = 1; + $allowed[$allow] = 1; } if (statement_block_size($block) > 1) { #print "APW: ALLOWED: lines block<$block>\n"; - $allowed = 1; + $allowed[$allow] = 1; } + $allow++; } - if ($seen && !$allowed) { - WARN("BRACES", - "braces {} are not necessary for any arm of this statement\n" . $herectx); + if ($seen) { + my $sum_allowed = 0; + foreach (@allowed) { + $sum_allowed += $_; + } + if ($sum_allowed == 0) { + WARN("BRACES", + "braces {} are not necessary for any arm of this statement\n" . $herectx); + } elsif ($sum_allowed != $allow && + $seen != $allow) { + CHK("BRACES", + "braces {} should be used on all arms of this statement\n" . $herectx); + } } } } @@ -2932,11 +3207,11 @@ sub process { } } if ($level == 0 && $block =~ /^\s*{/ && !$allowed) { - my $herectx = $here . "\n";; + my $herectx = $here . "\n"; my $cnt = statement_rawlines($block);
for (my $n = 0; $n < $cnt; $n++) { - $herectx .= raw_line($linenr, $n) . "\n";; + $herectx .= raw_line($linenr, $n) . "\n"; }
WARN("BRACES", @@ -2944,20 +3219,14 @@ sub process { } }
-# don't include deprecated include files (uses RAW line) - for my $inc (@dep_includes) { - if ($rawline =~ m@^.\s*#\s*include\s*<$inc>@) { - ERROR("DEPRECATED_INCLUDE", - "Don't use <$inc>: see Documentation/feature-removal-schedule.txt\n" . $herecurr); - } +# check for unnecessary blank lines around braces + if (($line =~ /^..*}\s*$/ && $prevline =~ /^.\s*$/)) { + CHK("BRACES", + "Blank lines aren't necessary before a close brace '}'\n" . $hereprev); } - -# don't use deprecated functions - for my $func (@dep_functions) { - if ($line =~ /\b$func\b/) { - ERROR("DEPRECATED_FUNCTION", - "Don't use $func(): see Documentation/feature-removal-schedule.txt\n" . $herecurr); - } + if (($line =~ /^.\s*$/ && $prevline =~ /^..*{\s*$/)) { + CHK("BRACES", + "Blank lines aren't necessary after an open brace '{'\n" . $hereprev); }
# no volatiles please @@ -2974,27 +3243,19 @@ sub process { $herecurr); }
-# check for needless kfree() checks - if ($prevline =~ /\bif\s*(([^)]*))/) { - my $expr = $1; - if ($line =~ /\bkfree(\Q$expr\E);/) { - WARN("NEEDLESS_KFREE", - "kfree(NULL) is safe this check is probably not required\n" . $hereprev); - } - } -# check for needless usb_free_urb() checks - if ($prevline =~ /\bif\s*(([^)]*))/) { - my $expr = $1; - if ($line =~ /\busb_free_urb(\Q$expr\E);/) { - WARN("NEEDLESS_USB_FREE_URB", - "usb_free_urb(NULL) is safe this check is probably not required\n" . $hereprev); +# check for needless "if (<foo>) fn(<foo>)" uses + if ($prevline =~ /\bif\s*(\s*($Lval)\s*)/) { + my $expr = '\s*(\s*' . quotemeta($1) . '\s*)\s*;'; + if ($line =~ /\b(kfree|usb_free_urb|debugfs_remove(?:_recursive)?)$expr/) { + WARN('NEEDLESS_IF', + "$1(NULL) is safe this check is probably not required\n" . $hereprev); } }
# prefer usleep_range over udelay - if ($line =~ /\budelay\s*(\s*(\w+)\s*)/) { + if ($line =~ /\budelay\s*(\s*(\d+)\s*)/) { # ignore udelay's < 10, however - if (! (($1 =~ /(\d+)/) && ($1 < 10)) ) { + if (! ($1 < 10) ) { CHK("USLEEP_RANGE", "usleep_range is preferred over udelay; see Documentation/timers/timers-howto.txt\n" . $line); } @@ -3075,18 +3336,100 @@ sub process { "__aligned(size) is preferred over __attribute__((aligned(size)))\n" . $herecurr); }
+# Check for __attribute__ format(printf, prefer __printf + if ($line =~ /\b__attribute__\s*(\s*(\s*format\s*(\s*printf/) { + WARN("PREFER_PRINTF", + "__printf(string-index, first-to-check) is preferred over __attribute__((format(printf, string-index, first-to-check)))\n" . $herecurr); + } + +# Check for __attribute__ format(scanf, prefer __scanf + if ($line =~ /\b__attribute__\s*(\s*(\s*format\s*(\s*scanf\b/) { + WARN("PREFER_SCANF", + "__scanf(string-index, first-to-check) is preferred over __attribute__((format(scanf, string-index, first-to-check)))\n" . $herecurr); + } + # check for sizeof(&) if ($line =~ /\bsizeof\s*(\s*&/) { WARN("SIZEOF_ADDRESS", "sizeof(& should be avoided\n" . $herecurr); }
+# check for sizeof without parenthesis + if ($line =~ /\bsizeof\s+((?:*\s*|)$Lval|$Type(?:\s+$Lval|))/) { + WARN("SIZEOF_PARENTHESIS", + "sizeof $1 should be sizeof($1)\n" . $herecurr); + } + # check for line continuations in quoted strings with odd counts of " if ($rawline =~ /\$/ && $rawline =~ tr/"/"/ % 2) { WARN("LINE_CONTINUATIONS", "Avoid line continuations in quoted strings\n" . $herecurr); }
+# check for struct spinlock declarations + if ($line =~ /^.\s*\bstruct\s+spinlock\s+\w+\s*;/) { + WARN("USE_SPINLOCK_T", + "struct spinlock should be spinlock_t\n" . $herecurr); + } + +# Check for misused memsets + if ($^V && $^V ge 5.10.0 && + defined $stat && + $stat =~ /^+(?:.*?)\bmemset\s*(\s*$FuncArg\s*,\s*$FuncArg\s*,\s*$FuncArg\s*)/s) { + + my $ms_addr = $2; + my $ms_val = $7; + my $ms_size = $12; + + if ($ms_size =~ /^(0x|)0$/i) { + ERROR("MEMSET", + "memset to 0's uses 0 as the 2nd argument, not the 3rd\n" . "$here\n$stat\n"); + } elsif ($ms_size =~ /^(0x|)1$/i) { + WARN("MEMSET", + "single byte memset is suspicious. Swapped 2nd/3rd argument?\n" . "$here\n$stat\n"); + } + } + +# typecasts on min/max could be min_t/max_t + if ($^V && $^V ge 5.10.0 && + defined $stat && + $stat =~ /^+(?:.*?)\b(min|max)\s*(\s*$FuncArg\s*,\s*$FuncArg\s*)/) { + if (defined $2 || defined $7) { + my $call = $1; + my $cast1 = deparenthesize($2); + my $arg1 = $3; + my $cast2 = deparenthesize($7); + my $arg2 = $8; + my $cast; + + if ($cast1 ne "" && $cast2 ne "" && $cast1 ne $cast2) { + $cast = "$cast1 or $cast2"; + } elsif ($cast1 ne "") { + $cast = $cast1; + } else { + $cast = $cast2; + } + WARN("MINMAX", + "$call() should probably be ${call}_t($cast, $arg1, $arg2)\n" . "$here\n$stat\n"); + } + } + +# check usleep_range arguments + if ($^V && $^V ge 5.10.0 && + defined $stat && + $stat =~ /^+(?:.*?)\busleep_range\s*(\s*($FuncArg)\s*,\s*($FuncArg)\s*)/) { + my $min = $1; + my $max = $7; + if ($min eq $max) { + WARN("USLEEP_RANGE", + "usleep_range should not use min == max args; see Documentation/timers/timers-howto.txt\n" . "$here\n$stat\n"); + } elsif ($min =~ /^\d+$/ && $max =~ /^\d+$/ && + $min > $max) { + WARN("USLEEP_RANGE", + "usleep_range args reversed, use min then max; see Documentation/timers/timers-howto.txt\n" . "$here\n$stat\n"); + } + } + # check for new externs in .c files. if ($realfile =~ /.c$/ && defined $stat && $stat =~ /^.\s*(?:extern\s+)?$Type\s+($Ident)(\s*)(/s) @@ -3133,16 +3476,30 @@ sub process { "unnecessary cast may hide bugs, see http://c-faq.com/malloc/mallocnocast.html%5Cn" . $herecurr); }
+# check for alloc argument mismatch + if ($line =~ /\b(kcalloc|kmalloc_array)\s*(\s*sizeof\b/) { + WARN("ALLOC_ARRAY_ARGS", + "$1 uses number as first arg, sizeof is generally wrong\n" . $herecurr); + } + # check for multiple semicolons if ($line =~ /;\s*;\s*$/) { - WARN("ONE_SEMICOLON", - "Statements terminations use 1 semicolon\n" . $herecurr); + WARN("ONE_SEMICOLON", + "Statements terminations use 1 semicolon\n" . $herecurr); }
-# check for whitespace before semicolon - not allowed at end-of-line - if ($line =~ /\s+;$/) { - WARN("SPACEBEFORE_SEMICOLON", - "Whitespace before semicolon\n" . $herecurr); +# check for switch/default statements without a break; + if ($^V && $^V ge 5.10.0 && + defined $stat && + $stat =~ /^+[$;\s]*(?:case[$;\s]+\w+[$;\s]*:[$;\s]*|)*[$;\s]*\bdefault[$;\s]*:[$;\s]*;/g) { + my $ctx = ''; + my $herectx = $here . "\n"; + my $cnt = statement_rawlines($stat); + for (my $n = 0; $n < $cnt; $n++) { + $herectx .= raw_line($linenr, $n) . "\n"; + } + WARN("DEFAULT_NO_BREAK", + "switch default: should use break\n" . $herectx); }
# check for gcc specific __FUNCTION__ @@ -3151,22 +3508,30 @@ sub process { "__func__ should be used instead of gcc specific __FUNCTION__\n" . $herecurr); }
+# check for use of yield() + if ($line =~ /\byield\s*(\s*)/) { + WARN("YIELD", + "Using yield() is generally wrong. See yield() kernel-doc (sched/core.c)\n" . $herecurr); + } + # check for semaphores initialized locked if ($line =~ /^.\s*sema_init.+,\W?0\W?)/) { WARN("CONSIDER_COMPLETION", "consider using a completion\n" . $herecurr); - } -# recommend kstrto* over simple_strto* - if ($line =~ /\bsimple_(strto.*?)\s*(/) { + +# recommend kstrto* over simple_strto* and strict_strto* + if ($line =~ /\b((simple|strict)_(strto(l|ll|ul|ull)))\s*(/) { WARN("CONSIDER_KSTRTO", - "consider using kstrto* in preference to simple_$1\n" . $herecurr); + "$1 is obsolete, use k$3 instead\n" . $herecurr); } + # check for __initcall(), use device_initcall() explicitly please if ($line =~ /^.\s*__initcall\s*(/) { WARN("USE_DEVICE_INITCALL", "please use device_initcall() instead of __initcall()\n" . $herecurr); } + # check for various ops structs, ensure they are const. my $struct_ops = qr{acpi_dock_ops| address_space_operations| @@ -3264,12 +3629,6 @@ sub process { WARN("EXPORTED_WORLD_WRITABLE", "Exporting world writable files is usually an error. Consider more restrictive permissions.\n" . $herecurr); } - - # Check for memset with swapped arguments - if ($line =~ /memset.*,(\ |)(0x|)0(\ |0|));/) { - ERROR("MEMSET", - "memset size is 3rd argument, not the second.\n" . $herecurr); - } }
# If we have no input at all, then there is nothing to report on @@ -3309,6 +3668,12 @@ sub process { }
if ($quiet == 0) { + + if ($^V lt 5.10.0) { + print("NOTE: perl $^V is not modern enough to detect all possible issues.\n"); + print("An upgrade to at least perl v5.10.0 is suggested.\n\n"); + } + # If there were whitespace errors which cleanpatch can fix # then suggest that. if ($rpt_cleaners) { @@ -3318,13 +3683,12 @@ sub process { } }
- if (keys %ignore_type) { + if ($quiet == 0 && keys %ignore_type) { print "NOTE: Ignored message types:"; foreach my $ignore (sort keys %ignore_type) { print " $ignore"; } - print "\n"; - print "\n" if ($quiet == 0); + print "\n\n"; }
if ($clean == 1 && $quiet == 0) {
without this, patches don't get checked for proper alignment, and e.g., for spaces after a cast and/or before a semicolon.
Signed-off-by: Kim Phillips kim.phillips@freescale.com --- .checkpatch.conf | 3 +++ 1 file changed, 3 insertions(+)
diff --git a/.checkpatch.conf b/.checkpatch.conf index 977db9e..38386b3 100644 --- a/.checkpatch.conf +++ b/.checkpatch.conf @@ -12,3 +12,6 @@
# For min/max --ignore MINMAX + +# enable more tests +--strict
Kim Phillips
