Re: [U-Boot] fw_setenv writes to bootdelay but not ethaddr
On Sunday 08 April 2012 17:15:26 Bishop, Mark wrote:
On Thursday 05 April 2012 16:32:11 Bishop, Mark wrote:
root:/> fw_setenv ethaddr X1:X2:X3:X4:X5:X6 Can't overwrite "ethaddr"
looks correct to me. you probably didn't set CONFIG_ENV_OVERWRITE.
I wish it was so: #define CONFIG_ENV_OVERWRITE 1 is present in my board file.
I've checked to make sure that it is the correct header file. I've also checked to make sure that CONFIG_OVERWRITE_ETHADDR_ONCE is not set.
I'm using the slightly outdated uclinux uboot from their head repo and I am checking the patches applied to the uboot head if any were to fix something like this.
sorry, should have been a little clearer. the tools installed by uclinux-dist do not have a config, so it uses the default one. the CONFIG_xxx settings in your u-boot don't get used. fw_printenv has to be built with those config settings. -mike
Mike Frysinger
