[U-Boot] [PATCH] omap3: beagle: re-enable EFI support after the following commit removed it by mistake:
commit d233ccb1d84b901f7e23e6d9b4f2c6a57198b23b ARM: omap3: beagle: Enable DM_SERIAL, update distro usage and NAND layout
Signed-off-by: Guillaume GARDET guillaume.gardet@free.fr Cc: Derald D. Woods woods.technical@gmail.com Cc: Tom Rini trini@konsulko.com
--- configs/omap3_beagle_defconfig | 3 --- 1 file changed, 3 deletions(-)
diff --git a/configs/omap3_beagle_defconfig b/configs/omap3_beagle_defconfig index a37a38f881..1e1a391d7f 100644 --- a/configs/omap3_beagle_defconfig +++ b/configs/omap3_beagle_defconfig @@ -32,8 +32,6 @@ CONFIG_MTDIDS_DEFAULT="nand0=omap2-nand.0" CONFIG_MTDPARTS_DEFAULT="mtdparts=omap2-nand.0:512k(spl),1920k(u-boot),128k(u-boot-env),128k(dtb),6m(kernel),-(rootfs)" CONFIG_CMD_UBI=y # CONFIG_ISO_PARTITION is not set -# CONFIG_EFI_PARTITION is not set -CONFIG_SPL_PARTITION_UUIDS=y CONFIG_OF_CONTROL=y CONFIG_ENV_IS_IN_NAND=y CONFIG_SPL_DM=y @@ -79,4 +77,3 @@ CONFIG_USB_ETHER_SMSC95XX=y CONFIG_FAT_WRITE=y CONFIG_BCH=y CONFIG_SPL_OF_LIBFDT=y -# CONFIG_EFI_LOADER is not set
I have found no compile or runtime issues, on my BeagleBoard Rev. C4 or xM, with the current default configuration. At least, for my non-EFI boot environment.
The following items are brought in from the EFI config additions:
+CONFIG_SMBIOS_PRODUCT_NAME="beagle" +CONFIG_CMD_BOOTEFI=y +CONFIG_CMD_BOOTEFI_HELLO_COMPILE=y +CONFIG_EFI_PARTITION=y +CONFIG_EFI_PARTITION_ENTRIES_NUMBERS=128 +CONFIG_EFI_PARTITION_ENTRIES_OFF=0 +CONFIG_SPL_EFI_PARTITION=y +CONFIG_OF_LIBFDT_OVERLAY=y +CONFIG_GENERATE_SMBIOS_TABLE=y +CONFIG_SMBIOS_MANUFACTURER="ti" +CONFIG_EFI_LOADER=y
I would change the commit message though. It was not a mistake. It was removed to provide a minimal set of configuration options for the base BSP type of setup. Using EFI is a choice. In fact, I tested my changes on 3 different OMAP3 boards. So there has been no period of not working in the basic board configuration. Provably.
So if EFI is required, even though one may not use it, this is a don't care for me. My boards boot just fine without EFI.
Derald
2.18.0
Hi Derald,
It is related to EFI options since I use GPT partitions (and EFI/Grub2 to boot). That is why you did not find anything.
The thing is you introduced a regression with your commit, since EFI was supported previously. And you did not explicitly stated that you disabled it on purpose. So, it sounds like a mistake to me. If you don't care about EFI, it is your choice, but please do not break setup of others. A use case is openSUSE which relies on EFI/Grub2 to boot. Please note that EFI is now a default feature in U-Boot, so, please, let it enabled.
Guillaume
Derald
2.18.0
On Thu, Jul 19, 2018, 2:34 AM Guillaume Gardet guillaume.gardet@free.fr wrote:
Hi Derald,
layout
That is the piece that I do not use.
Guillaume
I am not a novice and my series received the usual mailing list oversight. Maybe even more than one iteration. As I stated, this is a don't care for me. EFI is not mandatory to function/boot. The bare minimum case was the target of the series.
I acknowledge your commit.
Derald
Derald
2.18.0
participants (5)
Derald D. Woods
Derald Woods
Guillaume GARDET
Guillaume Gardet
