Re: [U-Boot] [PATCH 1/2] i.MX28: Fix ref_cpu clock setup
Hi Robert,
On 2/2/12, Robert Deliën robert@delien.nl wrote:
This patch fixes ref_cpu clock setup. This bug leads to a hanging board after rebooting from the Kernel, due to failing memory size detection: U-Boot 2011.12-svn342 (Feb 02 2012 - 17:20:00)
Freescale i.MX28 family
I2C: ready
DRAM: 0 Bytes
The cause of the bug is register hw_clkctrl_frac0 being accessed as a 32-bit long, whereas the manual specifically states it can be accessed as bytes only. Applying this patch fixes this problem.
Signed-off-by: Robert Delien (robert@delien.nl)
Very good, Robert! I tested your patch and it fixes the reboot issue on my mx28evk.
Also checked in the MX28 Reference Manual about the fact that hw_clkctrl_frac0 can only be accessed as bytes.
I have some suggestions though:
1. Your patch comes as attachment. Please use git send-email instead.
2. Please grep the locations where hw_clkctrl_frac0 is assigned as 32-bit and change those as well.
3. Send the two patches in a series via git send-email: 1/2 and 2/2
Good to know that you fixed the stepping issue as well. Good work!
Regards,
Fabio Estevam
On 2/2/12, Fabio Estevam festevam@gmail.com wrote:
- Please grep the locations where hw_clkctrl_frac0 is assigned as
Please do the same for hw_clkctrl_frac1 as well. There is one location in clock.c where it is read as 32-bit.
Thanks,
Fabio Estevam
I will check all hw_clkctrl_frac* register access, but tomorrow because the building closes is a couple of minutes.
Ideally I'd like to set up these registers as uint8_t*. Any ideas? I'll also check if bye-lane shifting is done automatically here.
You can write: writeb(19 , &clkctrl_regs->hw_clkctrl_frac0);
Regards,
Fabio Estevam
Yes, for the first byte I can (and do), but the three higher bytes would get ugly with this method: writeb(bitset >> 8, (unit8_t*)&clkctrl_regs->hw_clkctrl_frac0 + 1);
Hi Fabio,
You're most welcome! I'm glad to hear it fixes your problem too.
It's easy to overlook, I have to admit.
- Your patch comes as attachment. Please use git send-email instead.
I knew I was violating protocol, but I wanted to get it off my chest. I will work on this problem today. I work at two locations, and only at my home office I have an SMTP server I can user. Here at Agilent, unfortunately I only have an MS Exchange server I can use. If I can get that configured at all, there's a good chance it will break my patches.
Will do!
- Send the two patches in a series via git send-email: 1/2 and 2/2
Will do! I'm reading up on that right now, as Wolfgang suggested earlier. I may as well switch our own internal repository from SVN to GIT, but not today.
Thanks. I would really like to urge you guys to test the second patch as well. Marek made a remark on that too, so that will be my next mail to answer.
Cheers,
Robert.
Fabio Estevam
Robert Deliën
