[PATCH 1/1] test: test sandbox sound driver more rigorously
Consider unexpected values for frequency:
* negative frequency * zero frequency * frequency exceeding sampling frequency
As in these cases the sum of the samples is zero also check the count of the samples.
Signed-off-by: Heinrich Schuchardt heinrich.schuchardt@canonical.com --- arch/sandbox/include/asm/test.h | 10 ++++++++++ drivers/sound/sandbox.c | 9 +++++++++ test/dm/sound.c | 11 +++++++++++ 3 files changed, 30 insertions(+)
diff --git a/arch/sandbox/include/asm/test.h b/arch/sandbox/include/asm/test.h index 0406085917..568738c16d 100644 --- a/arch/sandbox/include/asm/test.h +++ b/arch/sandbox/include/asm/test.h @@ -188,6 +188,16 @@ int sandbox_get_setup_called(struct udevice *dev); */ int sandbox_get_sound_active(struct udevice *dev);
+/** + * sandbox_get_sound_count() - Read back the count of the sound data so far + * + * This data is provided to the sandbox driver by the sound play() method. + * + * @dev: Device to check + * Return: count of audio data + */ +int sandbox_get_sound_count(struct udevice *dev); + /** * sandbox_get_sound_sum() - Read back the sum of the sound data so far * diff --git a/drivers/sound/sandbox.c b/drivers/sound/sandbox.c index 4a2c87a84c..c6cbd81fdb 100644 --- a/drivers/sound/sandbox.c +++ b/drivers/sound/sandbox.c @@ -29,6 +29,7 @@ struct sandbox_i2s_priv { struct sandbox_sound_priv { int setup_called; /* Incremented when setup() method is called */ bool active; /* TX data is being sent */ + int count; /* Use to count the provided audio data */ int sum; /* Use to sum the provided audio data */ bool allow_beep; /* true to allow the start_beep() interface */ int frequency_hz; /* Beep frequency if active, else 0 */ @@ -68,6 +69,13 @@ int sandbox_get_sound_active(struct udevice *dev) return priv->active; }
+int sandbox_get_sound_count(struct udevice *dev) +{ + struct sandbox_sound_priv *priv = dev_get_priv(dev); + + return priv->count; +} + int sandbox_get_sound_sum(struct udevice *dev) { struct sandbox_sound_priv *priv = dev_get_priv(dev); @@ -168,6 +176,7 @@ static int sandbox_sound_play(struct udevice *dev, void *data, uint data_size)
for (i = 0; i < data_size; i++) priv->sum += ((uint8_t *)data)[i]; + priv->count += data_size;
return i2s_tx_data(uc_priv->i2s, data, data_size); } diff --git a/test/dm/sound.c b/test/dm/sound.c index b73f6ab111..15d545ab5a 100644 --- a/test/dm/sound.c +++ b/test/dm/sound.c @@ -26,8 +26,19 @@ static int dm_test_sound(struct unit_test_state *uts) ut_asserteq(0, sandbox_get_setup_called(dev));
ut_assertok(sound_beep(dev, 1, 100)); + ut_asserteq(48, sandbox_get_sound_count(dev)); ut_asserteq(4560, sandbox_get_sound_sum(dev)); ut_assertok(sound_beep(dev, 1, 100)); + ut_asserteq(96, sandbox_get_sound_count(dev)); + ut_asserteq(9120, sandbox_get_sound_sum(dev)); + ut_assertok(sound_beep(dev, 1, -100)); + ut_asserteq(144, sandbox_get_sound_count(dev)); + ut_asserteq(9120, sandbox_get_sound_sum(dev)); + ut_assertok(sound_beep(dev, 1, 0)); + ut_asserteq(192, sandbox_get_sound_count(dev)); + ut_asserteq(9120, sandbox_get_sound_sum(dev)); + ut_assertok(sound_beep(dev, 1, INT_MAX)); + ut_asserteq(240, sandbox_get_sound_count(dev)); ut_asserteq(9120, sandbox_get_sound_sum(dev)); ut_asserteq(false, sandbox_get_sound_active(dev));
On Mon, 5 Dec 2022 at 05:16, Heinrich Schuchardt heinrich.schuchardt@canonical.com wrote:
- negative frequency
- zero frequency
- frequency exceeding sampling frequency
