[U-Boot] [PATCHv4 2/3] OMAP3: Remove unused board-types
The board-types defined in struct omap3_sysinfo seem to be unused. The function display_board_info() is passed board type as an argument; which is ignored.
This patch removes all uses of board-type, related definitions and functions.
Signed-off-by: Sanjeev Premi premi@ti.com --- board/omap3/beagle/beagle.h | 2 -- board/omap3/evm/evm.h | 2 -- board/omap3/overo/overo.h | 2 -- board/omap3/pandora/pandora.h | 2 -- board/omap3/zoom1/zoom1.h | 2 -- cpu/arm_cortexa8/omap3/sys_info.c | 17 ----------------- include/asm-arm/arch-omap3/omap3.h | 8 -------- include/asm-arm/arch-omap3/sys_proto.h | 3 --- 8 files changed, 0 insertions(+), 38 deletions(-)
diff --git a/board/omap3/beagle/beagle.h b/board/omap3/beagle/beagle.h index d66f159..5d45f01 100644 --- a/board/omap3/beagle/beagle.h +++ b/board/omap3/beagle/beagle.h @@ -24,8 +24,6 @@ #define _BEAGLE_H_
const omap3_sysinfo sysinfo = { - SDP_3430_V1, - SDP_3430_V2, DDR_STACKED, "OMAP3 Beagle board", #if defined(CONFIG_ENV_IS_IN_ONENAND) diff --git a/board/omap3/evm/evm.h b/board/omap3/evm/evm.h index 199824f..4a82a7f 100644 --- a/board/omap3/evm/evm.h +++ b/board/omap3/evm/evm.h @@ -24,8 +24,6 @@ #define _EVM_H_
const omap3_sysinfo sysinfo = { - OMAP3EVM_V1, - OMAP3EVM_V2, DDR_DISCRETE, "OMAP3 EVM board", #if defined(CONFIG_ENV_IS_IN_ONENAND) diff --git a/board/omap3/overo/overo.h b/board/omap3/overo/overo.h index e8ccc1d..b595f6a 100644 --- a/board/omap3/overo/overo.h +++ b/board/omap3/overo/overo.h @@ -24,8 +24,6 @@ #define _OVERO_H_
const omap3_sysinfo sysinfo = { - SDP_3430_V1, - SDP_3430_V2, DDR_STACKED, "Gumstix Overo board", #if defined(CONFIG_ENV_IS_IN_ONENAND) diff --git a/board/omap3/pandora/pandora.h b/board/omap3/pandora/pandora.h index dd09f12..8f0838c 100644 --- a/board/omap3/pandora/pandora.h +++ b/board/omap3/pandora/pandora.h @@ -24,8 +24,6 @@ #define _PANDORA_H_
const omap3_sysinfo sysinfo = { - SDP_3430_V1, - SDP_3430_V2, DDR_STACKED, "OMAP3 Pandora", "NAND", diff --git a/board/omap3/zoom1/zoom1.h b/board/omap3/zoom1/zoom1.h index bc8fba8..4f49a41 100644 --- a/board/omap3/zoom1/zoom1.h +++ b/board/omap3/zoom1/zoom1.h @@ -28,8 +28,6 @@ #define _BOARD_ZOOM1_H_
const omap3_sysinfo sysinfo = { - SDP_3430_V1, - SDP_3430_V2, DDR_STACKED, "OMAP3 Zoom MDK Rev 1", "NAND", diff --git a/cpu/arm_cortexa8/omap3/sys_info.c b/cpu/arm_cortexa8/omap3/sys_info.c index d605d7c..fb240df 100644 --- a/cpu/arm_cortexa8/omap3/sys_info.c +++ b/cpu/arm_cortexa8/omap3/sys_info.c @@ -130,23 +130,6 @@ u32 get_sdr_cs_offset(u32 cs) return offset; }
-/*********************************************************************** - * get_board_type() - get board type based on current production stats. - * - NOTE-1-: 2 I2C EEPROMs will someday be populated with proper info. - * when they are available we can get info from there. This should - * be correct of all known boards up until today. - * - NOTE-2- EEPROMs are populated but they are updated very slowly. To - * avoid waiting on them we will use ES version of the chip to get info. - * A later version of the FPGA migth solve their speed issue. - ************************************************************************/ -u32 get_board_type(void) -{ - if (get_cpu_rev() == CPU_3430_ES2) - return sysinfo.board_type_v2; - else - return sysinfo.board_type_v1; -} - /*************************************************************************** * get_gpmc0_base() - Return current address hardware will be * fetching from. The below effectively gives what is correct, its a bit diff --git a/include/asm-arm/arch-omap3/omap3.h b/include/asm-arm/arch-omap3/omap3.h index 8c9656f..d0d2737 100644 --- a/include/asm-arm/arch-omap3/omap3.h +++ b/include/asm-arm/arch-omap3/omap3.h @@ -177,14 +177,6 @@ typedef struct gpio { #define WIDTH_8BIT 0x0000 #define WIDTH_16BIT 0x1000 /* bit pos for 16 bit in gpmc */
-/* SDP definitions according to FPGA Rev. Is this OK?? */ -#define SDP_3430_V1 0x1 -#define SDP_3430_V2 0x2 - -/* EVM definitions */ -#define OMAP3EVM_V1 0x1 -#define OMAP3EVM_V2 0x2 - /* I2C power management companion definitions */ #define PWRMGT_ADDR_ID1 0x48 #define PWRMGT_ADDR_ID2 0x49 diff --git a/include/asm-arm/arch-omap3/sys_proto.h b/include/asm-arm/arch-omap3/sys_proto.h index 830447b..7361d08 100644 --- a/include/asm-arm/arch-omap3/sys_proto.h +++ b/include/asm-arm/arch-omap3/sys_proto.h @@ -22,8 +22,6 @@ #define _SYS_PROTO_H_
typedef struct { - u32 board_type_v1; - u32 board_type_v2; u32 mtype; char *board_string; char *nand_string; @@ -46,7 +44,6 @@ u32 get_sysboot_value(void); u32 is_gpmc_muxed(void); u32 get_gpmc0_type(void); u32 get_gpmc0_width(void); -u32 get_board_type(void); u32 get_sdr_cs_size(u32); u32 get_sdr_cs_offset(u32); u32 is_running_in_sdram(void);
Sanjeev Premi
